  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • pentti12P pentti12
    I am not using the MQTT gateway, I am using standard GatewayW5100.ino, which has correct IP-settings:
    #define MY_IP_ADDRESS 192,168,1,201 // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 185
    // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
    And MySensors Ethernet Gateway is detected by Advanced IP Scanner and I can ping it and so on..
    JicJ
    JicJ
    Jic
    @pentti12
    Can you start manually your gateway with -d option to see the log?
    You should see there if your gateway its receiving messages. If you are receiving message then, the problem should be in the OH2
    jogantJ 1 Reply Last reply
    • JicJ Jic
      @pentti12
      jogantJ
      jogantJ
      jogant
      @Jic
      what do you mean with "start gateway manually -d option"? My gateway is a standalone device, ethernet connector on one side, nrf24 on the other, arduino in the middle connecting the other two parts.
      • pentti12P
        pentti12P
        pentti12
        Wait a minute! I think that from the original GatewayW5100 sketch there were missing the IP Gateway and subnet addresses!
        So I will recompile sketch and test again.
          jogantJ
          jogantJ
          jogant
          wrote on last edited by jogant
          #49
          @pentti12
          slowly my image gets complete. Online/Offline status is resolved by OH2 binding via polling during initialization. Value updates are sent spontaneous by the gateway via callback, afair. So the gateway needs to know the address and mask of the controller to send values.
          • pentti12P
            pentti12P
            pentti12
            No help after new sketch loaded into GatewayW5100. OH2 log informs the same result:
            14:49:09.484 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            I will take a break - to be continued on next day...
              jogantJ
              jogantJ
              jogant
              @pentti12
              "connection skipped" message occurs frequently, usually every 10 seconds. That is normal and ok. But you should see messages from the gateway everytime the sensor nodes send updates, except the value is the same as before.
              • pentti12P
                pentti12P
                pentti12
                I connected my laptop into Ethernet Gateway. Here is a sample of monitoring listing:
                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.4
                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:21.9
                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.5
                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.0
                0;255;3;0;9;TSP:SANCHK:OK
                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.6
                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.7
                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:21.8
                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=0,c=1,t=0,pt=7,l=5,sg=0:30.8
                So I think that this is OK, when I have only one sensor node alive.
                But still, how I shall modify my Arduino Gateway sketch in order to get OH2 server show temperature and humidity values?
                JicJ 1 Reply Last reply
                  JicJ
                  JicJ
                  Jic
                  @pentti12
                  Could be permission problem?
                  Can you connect your gateway on rpi and execute
                  ls -l /dev/tty*
                  I think you are using a ethernet gateway skecth, normaly it's should be mounted in /dev/ttyACM0
                  Have you already execute
                  sudo usermod -a -G dialout openhab
                  Be sure that you have the las binding
                  https://github.com/tobof/openhab2-addons/blob/MySensors/addons/binding/org.openhab.binding.mysensors/target/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                  and your openhab2 is updated.
                  • pentti12P
                    pentti12P
                    pentti12
                    I am running the Ethernet GatewayW5100 software on Arduino UNO. I don't have rpi, I have installed OH2 on Pine64. It is running debian Jessie and it is uptodate. Also the latest mysensors binding is in use. So what to next?
                      JicJ
                      JicJ
                      Jic
                      wrote on last edited by Jic
                      #55
                      @pentti12 I am confused.
                      Don't you need to connect your Ethernet GatewayW5100 by USB into your pine64?
                      • pentti12P
                        pentti12P
                        pentti12
                        OK, now Gateway is connected via USB into Pine64 and it is shown as /dev/ttyUSB0.
                          JicJ
                          JicJ
                          Jic
                          @pentti12 said:
                          /dev/ttyUSB0
                          Now, you need to configure your binding in your OH2?
                          https://github.com/tobof/openhab2-addons/wiki/Configuration
                          • pentti12P
                            pentti12P
                            pentti12
                            I added into demo.things following line:
                            Bridge mysensors:bridge-ser:gateway [ serialPort="dev/ttyUSB0", sendDelay=200 ] {
                            In OH2 MySensor Serial Gateway stays OFFLINE state now. And also the Philips HUE things went OFFLINE state even if they have their own Bridge.
                            Looks bad!
                              Looks bad!
                              JicJ
                              JicJ
                              Jic
                              @pentti12 This configuration is for a Serial Gateway connected to GPIO, I think.
                              You should use this one
                              Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ] {
                              But at this point I am really confused, I don't know how Ethernet Gateway works. I am not sure when I can help you.
                              Do you need configure you ESSID and password of your WIFI in your sketch? or the ethernet Gateway geneate their own network?
                              • pentti12P
                                pentti12P
                                pentti12
                                Now I am confused, why I should bridge Ethernet Gateway, if I have USB-connection to MySensors Gateway only?
                                I tried to use Ethernet Gateway connected into my local IP-network without success, so I think that I will end this work to this point. There seems no good instructions available what is missing or wrong on the MySensors openhab binding..
                                  JicJ
                                  JicJ
                                  Jic
                                  @pentti12
                                  Ok, sorry, I think I was wrong.
                                  Here has a similar example
                                  http://www.makeuseof.com/tag/diy-smart-home-sensors-arduino-mysensors-openhab/
                                  Could you try connecting it again separately, and configure in your OH2 and ethernet binding with the ip from your gatweay?
                                  • pentti12P
                                    pentti12P
                                    pentti12
                                    Can someone explain, why I cannot get real values from MySensors node, which has only temperature and humidity sensors?
                                    I can get the MySensors Ethernet Gateway into ONLINE STATE. I can get humidity and Temperature Sensors ONLINE STATE, but I cannot get real values from the node.
                                    What I see from OpenHAB2 log side is:
                                    09:31:45.356 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                    09:31:45.375 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                    09:31:48.356 [WARN ] [otocol.MySensorsNetworkSanityChecker] - I_VERSION message response is not arrived. Remained attempts before disconnection 1
                                    09:31:55.377 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                    09:32:05.380 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                    I think that there must be some error in MySensors Binding at the moment, because for example the Philips HUE bridge is working corretly via Openhab2 in the same Pine64 controller.
                                    JicJ T 2 Replies Last reply
                                      JicJ
                                      JicJ
                                      Jic
                                      @pentti12
                                      This message is, following the information
                                      https://www.mysensors.org/download/serial_api_20
                                      node-id ; child-sensor-id ; message-type ; ack ; sub-type ; payload \n
                                      0; ;0 ;3 ;0 ;2 ;
                                      A message-type=3 means an internal message of the protocol
                                      Sub-type=2 means that it is ascking for the gateway version.
                                      You can find here how to disable it using skipStartupCheck=true
                                      Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200, skipStartupCheck=true ] {
                                      I hope this help you.
                                        TimO
                                        Hey @pentti12!
                                        Which gateway are you using? Serial or Ethernet? You can't use the ethernet gateway via serial connection.
                                        Which sketch are you using?
                                        If you are using ethernet gateway sketch but used the serial connection this would explain why the binding could not get any response.
                                        • pentti12P
                                          pentti12P
                                          pentti12
                                          I am using Ethernet Gateway in my LAN. Gateway has static IP and it is accessible (ping works). Also port number 5003 is detected correctly.
                                          I am using standard GatewayW5100.ino sketch.
                                          How can I force OH2 to use only Ethernet-connection?
