  3. Vera - Can't create GW device with UI7 files
21 Posts 9 Posters 10.9k Views 7 Watching
  • stevebusS
    stevebusS
    stevebus
    Yeah, I never did get it working, nor find anyone who would tell me they had the same scenario working (vera edge, UI7, serial gateway). I had to work with Vera support to get my USB port enabled at all. Once it was enabled, I tried to get the serial GW working and never did. After over a month corresponding with Vera support (they would go days without responding), they punted and said as far as they were concerned, the serial port was working and I'd need to "talk to the mysensors folks" to get it all working. So I was stuck in a loop.
    However, around that same time I found an old thread that gave me a tip to get my Ethernet gateway stabilized with an alternate implementation off UIPEthernet library. I can still crash the Ethernet gateway, at will, by telneting into port 5003 and manually sending commands to it for debugging, but since I know that crashes it, I don't do it anymore :-). But if I don't fool with it, it's been working for weeks with zero issues.
    Also, after a combination of deleting and re-uploading files and most importantly CLEAR YOUR BROWSER CACHE AFTER YOU DO (my one and only tip for you), I've got the UI7 Vera files working too.
    So, unfortunately I don't have the answer for you (other than make sure you clear your browser cache after uploading the UI7 files) because I got my Ethernet GW stable and abandoned the serial GW.
    Vera Edge/UI7; mysensors; Arduino's and RPIs; data posted to Azure for an IoT 'dashboard' of my house
    Opinions expressed here are my own and do not necessarily reflect Microsoft's feelings on a given topic :-)
    • NbaarsN
      NbaarsN
      Nbaars
      Thanks for your reply, so i will try what you say and look if it works. Are you using a Arduino copy or original? I see people using a original Nano, and that seems to work with the VeraEdge.
      • AnticimexA
        AnticimexA
        Anticimex
        I don't have a Vera edge, but a Vera lite and I found that I could not really trust a serial gw. I don't think the Vera can provide enough current on its USB port so my nano acted strange. I have decoupled everything with node-red now so all my controllers communicate using ethernet/tcp ports and I once more use a serial gw connected to a raspberrypi (but with the option in node-red to switch to an ethernet gw if I wanted to without changing anything in the controllers). It also makes debugging things a lot easier since all io between gw and controllers can be monitored.
        • stevebusS
          stevebusS
          stevebus
          @Nbaars - I'm not sure how you tell? it was advertised as an Arduino Nano, not a copy or clone or "compatible", but I don't know if you can rely on that. Is there an easy way to tell?
          @Anticimex - interesting idea. I might explore it, but I'm pretty satisfied with my straight Ethernet GW now (except for it being a pain to debug)
          • NbaarsN
            NbaarsN
            Nbaars
            @stevebus Pete B is using for his Serial gateway a Arduino nano clone from the shop on my sensors. But for now im stuck that my SG is not working. Im just new to all this.
            • J
              J
              jlieffort
              Did you ever get your nano clone to work as a serial gateway?
              I'm struggling with the same issue right now. I have 4 nanos none have the FTDI chip and I can't get the vera to set the serial port.
              Is the only option to get a "genuine" nano?
              • stevebusS
                stevebusS
                stevebus
                Never got it working, but quit trying because of Ethernet GW has been fairly reliable lately. I've tried two different Nano's (bought from the links on mysensors site. But I assume they are clones. I'm not sure how to verify one is genuine, do you?
                I'd love to get it working as an option.
                • kylehullK
                  kylehullK
                  kylehull
                  Hello not sure if you are still active or what but the below link may help i recently tried to make a gateway with a nano a failed like you guys have however after reading the below forum it turn out that you need to have a nano with a FTDI chipset for the gateway i went and bought one, they are a bit more expensive then the cheaper ones but I've plugged it in and tested it and it now it works fine i hope that it help
                  Link
                  • stevebusS
                    stevebusS
                    stevebus
                    Hey @kylehull .. thanks for the response. I've heard that before, about the need to have a genuine FTDI chipset. I had previously dug out the magnifying class and i'm pretty sure my Nano (that didn't work) says "FTDI" on the serial chipset. (not sure if there is another way to tell)... but based on the symptoms, I guess maybe it didn't..
                    either way, since the 2.0 libraries game out, I rebuilt my Ethernet GW and it has been rock solid. So I'm not going to rock the boat there :-).
                    thanks for following up on this old thread, though. I'm sure it'll help others.
                    • miroM
                      miroM
                      miro
                      So, to get rid of my error messages "Can´t Detect Device" I have to build a Ethernet gateway instead of having the serial gateway?
                      korttomaK 1 Reply Last reply
                      • miroM miro
                        korttomaK
                        korttomaK
                        korttoma
                        @miro are you getting the "Can´t Detect Device" for MySensor devices? That is a new one. If your device is working normally try going in to the advanced variables tab for your device and see if there is a variable called "CommFailure" and change the value to 0. Restart the luup engine.
                        • Tomas
                        • miroM
                          miroM
                          miro
                          This was fixed for me when I changed all three CommFailure.
                          CommFailure = 0
                          CommFailureTime = 0
                          CommFailureAlarm= 0
                          Thanks a lot!
