  3. Vera
  4. Lua Startup Failure (*SOLVED*)
arduinoveralite
31 Posts 12 Posters 27.0k Views 3 Watching
  • R Offline
    R Offline
    rafael.brasilia
    wrote on last edited by rafael.brasilia
    I am trying to get my Veralite working with Arduino and nrf24l01+ Rf Transceiver but it doesnt work for some reason.
    I have uploaded all the plugin files on my Veralite and added a new device, but my device shows an error mesage saying "Lua Startup Failure". When I click on start it gives me another error message saying "Device Not Ready".
    I have my arduino connected to the RF receiver and have uploaded the SerialGateway sketch to it.
    On top of my screen it says : "MySensors plugin : Choose the Serial Port", but when I go to choose the serial port my device doesnt appear there. I have reloded several times and reconnected my arduino to my Veralite via usb but no luck.
    Any suggestions?
    Thanks!!
    M 1 Reply Last reply
    • hekH Offline
      hekH Offline
      Are you using an Arduino Nano?
      Try restarting Vera (reload luup-engine might not be enough).
      R 1 Reply Last reply
        R Offline
        R Offline
        rafael.brasilia
        @hek I am using a nano and have restarted my Vera a few times and still no luck. The nano Im using is a clone, maybe that could be the problem?
        • hekH Offline
          hekH Offline
          I've heard about a few people losing serial connection intermittently. @clippermiami is one of them if I remember correctly.
          What happens if you add a powered USB hub between gateway and Vera?
          Even if if you are using a clone it would normally be recognized (I'm also using a clone for my gateway).
          • R Offline
            R Offline
            rafael.brasilia
            I tried the hub but that didnt work either. Actually the Lua Startup Failure Im seeing on my vera has nothing to do with arduino itself right? I downloaded the latest version of the plugin and reinstalled it but it stills fails to start. I dont know what else to try.
            • hekH Offline
              hekH Offline
              The MySensors plugin creates the error if no serial device has been configured.
              As a last resort you could convert your serial gateway into an ethernet gateway.
              You could probably get it recognized by ssh:ing into Vera and add the FTDI signature to some config file. But I can't seem to find information about how that was done. It might be buried in some thread on the micasavesde forum.
                R Offline
                R Offline
                rafael.brasilia
                @hek
                So I downloaded the latest mySensors library from Github, reloaded the SerialGateway sketch and redid all my wiring to make sure I wasn't missing anything.
                But now I keep getting a "Version Mismatch" error in the debugger. I noticed the code was updated 3 days ago and I was wondering if some GIT tag or commit Id got messed up in this latest update. I have also updated the Vera plugin.
                By the way, I'm new to the forum and have learned a ton in the last few days reading all of your posts.
                Thanks for sharing your knowledge and helping so many people!
                We appreciate it!
                hekH 1 Reply Last reply
                • R rafael.brasilia
                  @hek
                  We appreciate it!
                  hekH Offline
                  hekH Offline
                  @rafael.brasilia
                  Strange. If you compile both gateway and sensor using the same library version there shouldn't be any mismatch.
                  • R Offline
                    R Offline
                    RyanAHolland
                    I am seeing the same issue with my Ethernet gateway. I downloaded the new 1.4, pulled the Ethernet gateway code from the site and uploaded it to my Nano. It complies just fine, but debug shows the following:
                    0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
                    0;0;3;0;9;version mismatch
                    D 1 Reply Last reply
                    • R RyanAHolland
                      Damme
                      Code Contributor
                      @RyanAHolland Did you update your sensors too?
                      • J Offline
                        J Offline
                        joe.k
                        wrote on last edited by joe.k
                        I am having a similar problem. U15 GUI has the same "Lua Startup Failure" message and Vera says "Choose the Serial Port". However, everything is working fine ... Vera is communicating to the serial port.
                        I've been using this code from the very start (v1.2 days). I first saw this problem after upgrading to v1.4 from 1.4beta. I was able to fix it though by recreating the gateway device and reconfiguring the serial port in U15.
                        This morning I loaded "EventWatcher" mios plugin and now seeing the problem again. However, this time I cannot clear the error - even after recreating the gateway device and serial port. But everything is working fine - meaning the serial gw is working.
                        Not sure what else to try to clear or fix the error messages?
                        Thanks,
                        Joe
                        • R rafael.brasilia
                          Any suggestions?
                          Thanks!!
                          M Offline
                          M Offline
                          Micke
                          I have the same (almost) issue as @rafael.brasilia.
                          Installed the MySensors device with files downloaded today (18/9-14) according to the instructions. When pushing "Reload" after creating the device i had not connected the Gateway to the USB yet. Got the error in the picture below. I then connected the gateway with exactly the same result. Then rebooted and got the same result again.
                          Please note! I am using a not supported gateway - the Arduino Pro Mini (the Uno is still on a boat somewhere between here and China :-)), but the issue doesn't seem to be related to the gateway, rather the creation of the device.
                          What is my newbee mistake? Except for using the wrong hardware ;-)
                          Untitled.tiff
                          • hekH Offline
                            hekH Offline
                            Pro Mini and Uno won't be recognized by Vera. You must use Arduino Nano as instructed on the documentation site.
                            M 2 Replies Last reply
                              M Offline
                              M Offline
                              Micke
                              @hek ... Sorry, typo - of course it is a Nano I am waiting for.
                              • I Offline
                                I Offline
                                integlikewhoa
                                I'm having same problem with my clone NANO.
                                I can't get serial adaptor to show up in VERA. I have a powered hub with my VERAlite. I have a usb to serial already for my caddx alarm and usb flash drive for my logs. I have even removed the hub and tried only the nano to the vera. Powered down for a bit and restart. Never can get serial to show up. I can program the NANO and rear the data get a code and startup command.
                                Think its my clone? I have an extra UNO but haven't tried it as people said it needed to be a NANO hooked to VERA.
                                  M Offline
                                  M Offline
                                  Micke
                                  @hek
                                  I bought a Nano today at Electro:Kit Malmö cuz I just couldn't wait for the boat from China :-)... but the the error remains the same! Reboot, re-download, rewiring, ... I cannot get the MySensors plugin to work.
                                  BTW, I use codebender and know the software loads OK.
                                  Any suggestions?
                                  • M Micke
                                    @hek
                                    Any suggestions?
                                    M Offline
                                    M Offline
                                    Micke
                                    @Micke @hek
                                    Status update: Just stubbled across the
                                    • "Serial Port Configuration" in the Apps->Develop Apps->Serial Port Configuration tab,
                                    • selected the "MySensors" device in the drop down,
                                    • got an error when reloading ("select 115200 baud rate") so I changed the the baud rate
                                    • reloaded - and no errors!
                                    Don't know if it works (got not clients/sensors to talk to) but the HUD is all green :-)
                                    hekH R 2 Replies Last reply
                                    • M Micke
                                      @Micke @hek
                                      hekH Offline
                                      hekH Offline
                                      @Micke
                                      It's all documented here:
                                      http://mysensors.org/build/vera
                                      • M Micke
                                        @Micke @hek
                                        R Offline
                                        R Offline
                                        rafael.brasilia
                                        @Micke What did you do to make you Serial gateway show up in Vera? I have tried everything you can imagine but my Vera wont recognize it.
                                        • R rafael.brasilia
                                          M Offline
                                          M Offline
                                          Micke
                                          @rafael.brasilia I followed the instructions in this link.
                                          Can you give some more information on how far you got, eg:
                                          • Did you test to upload the blink example to the Nano? Did it work?
                                          • Was the upload of the Gateway to the Nano successful?
                                          • Any problems downloading files from Git.hub, uploading these files to Vera?
                                          • Is the creation successful in the Vera?
                                            /Micke
