  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • pentti12P
    pentti12P
    pentti12
    I added into demo.things following line:
    Bridge mysensors:bridge-ser:gateway [ serialPort="dev/ttyUSB0", sendDelay=200 ] {
    In OH2 MySensor Serial Gateway stays OFFLINE state now. And also the Philips HUE things went OFFLINE state even if they have their own Bridge.
    Looks bad!
    JicJ 1 Reply Last reply
    • pentti12P pentti12
      Looks bad!
      JicJ
      JicJ
      Jic
      @pentti12 This configuration is for a Serial Gateway connected to GPIO, I think.
      You should use this one
      Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ] {
      But at this point I am really confused, I don't know how Ethernet Gateway works. I am not sure when I can help you.
      Do you need configure you ESSID and password of your WIFI in your sketch? or the ethernet Gateway geneate their own network?
      • pentti12P
        pentti12P
        pentti12
        Now I am confused, why I should bridge Ethernet Gateway, if I have USB-connection to MySensors Gateway only?
        I tried to use Ethernet Gateway connected into my local IP-network without success, so I think that I will end this work to this point. There seems no good instructions available what is missing or wrong on the MySensors openhab binding..
          JicJ
          JicJ
          Jic
          @pentti12
          Ok, sorry, I think I was wrong.
          Here has a similar example
          http://www.makeuseof.com/tag/diy-smart-home-sensors-arduino-mysensors-openhab/
          Could you try connecting it again separately, and configure in your OH2 and ethernet binding with the ip from your gatweay?
          • pentti12P
            pentti12P
            pentti12
            Can someone explain, why I cannot get real values from MySensors node, which has only temperature and humidity sensors?
            I can get the MySensors Ethernet Gateway into ONLINE STATE. I can get humidity and Temperature Sensors ONLINE STATE, but I cannot get real values from the node.
            What I see from OpenHAB2 log side is:
            09:31:45.356 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
            09:31:45.375 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            09:31:48.356 [WARN ] [otocol.MySensorsNetworkSanityChecker] - I_VERSION message response is not arrived. Remained attempts before disconnection 1
            09:31:55.377 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            09:32:05.380 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
            I think that there must be some error in MySensors Binding at the moment, because for example the Philips HUE bridge is working corretly via Openhab2 in the same Pine64 controller.
            JicJ T 2 Replies Last reply
              JicJ
              JicJ
              Jic
              @pentti12
              This message is, following the information
              https://www.mysensors.org/download/serial_api_20
              node-id ; child-sensor-id ; message-type ; ack ; sub-type ; payload \n
              0; ;0 ;3 ;0 ;2 ;
              A message-type=3 means an internal message of the protocol
              Sub-type=2 means that it is ascking for the gateway version.
              You can find here how to disable it using skipStartupCheck=true
              https://github.com/tobof/openhab2-addons/wiki/Configuration
              Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200, skipStartupCheck=true ] {
              I hope this help you.
                TimO
                Hey @pentti12!
                Which gateway are you using? Serial or Ethernet? You can't use the ethernet gateway via serial connection.
                Which sketch are you using?
                If you are using ethernet gateway sketch but used the serial connection this would explain why the binding could not get any response.
                • pentti12P
                  pentti12P
                  pentti12
                  I am using Ethernet Gateway in my LAN. Gateway has static IP and it is accessible (ping works). Also port number 5003 is detected correctly.
                  I am using standard GatewayW5100.ino sketch.
                  How can I force OH2 to use only Ethernet-connection?
                  • T
                    TimO
                    Have you configured the gateway in the *.things file? How does it look?
                    • triceTT
                      triceTT
                      triceT
                      Hello to all.
                      I have similar problems as pentti12.
                      Can not get values updated in OH2, there are always -NAN
                      While with serial connection I get some reads in the log file, with eth connection I can't see any reads from gw.
                      I've installed everything as per wiki several times without success.
                      Radio connection between gw and nodes is running without problems.
                      Previous testing gw with w5100MQTTClient sketch, was running perfectly
                      My configuration:
                      MySensors Binding: 2.0.0.201611221149
                      OH2: 2.0.0-SNAPSHOT Build #629 running on debian
                      gw: Arduino Uno with W5100 sketch
                      Node: arduino nano with temp and humidity sensor.
                      Could somebody help me in this.
                      Regards!
                      *** Debug for serial connection without skipping I-Version check
                      2016-12-05 22:06:22.608 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                      2016-12-05 22:06:22.634 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
                      2016-12-05 22:06:22.664 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                      2016-12-05 22:06:22.664 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
                      2016-12-05 22:06:25.665 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
                      2016-12-05 22:06:25.667 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:INIT
                      2016-12-05 22:06:25.667 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:RADIO:OK
                      2016-12-05 22:06:25.668 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:GW MODE
                      2016-12-05 22:06:25.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:READY
                      2016-12-05 22:06:25.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - IP: 192.168.1.66
                      2016-12-05 22:06:25.865 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2016-12-05 22:06:26.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2016-12-05 22:06:27.372 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;No registration required
                      2016-12-05 22:06:27.372 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
                      2016-12-05 22:06:27.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2016-12-05 22:06:28.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2016-12-05 22:06:29.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2016-12-05 22:06:30.665 [ERROR] [col.serial.MySensorsSerialConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
                      2016-12-05 22:06:30.665 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:27)
                      2016-12-05 22:06:30.666 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
                      2016-12-05 22:06:30.666 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                      2016-12-05 22:06:30.666 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialWriter
                      2016-12-05 22:06:30.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                      2016-12-05 22:06:30.670 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
                      *** Debug for serial connection skipping I-Version check
                      2016-12-05 22:16:52.785 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                      2016-12-05 22:16:52.786 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: true
                      2016-12-05 22:16:52.787 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                      2016-12-05 22:16:52.789 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                      2016-12-05 22:16:52.789 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
                      2016-12-05 22:16:52.789 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                      2016-12-05 22:16:52.793 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                      2016-12-05 22:16:52.821 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
                      2016-12-05 22:16:52.851 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                      2016-12-05 22:16:52.851 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
                      2016-12-05 22:16:55.852 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
                      2016-12-05 22:16:55.855 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:INIT
                      2016-12-05 22:16:55.856 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:RADIO:OK
                      2016-12-05 22:16:55.855 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended...
                      2016-12-05 22:16:55.860 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:power:9ba30e1b
                      2016-12-05 22:16:55.862 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:gateway:hum01
                      2016-12-05 22:16:55.863 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
                      2016-12-05 22:16:55.863 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
                      2016-12-05 22:16:55.867 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
                      2016-12-05 22:16:55.867 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-6 not registered yet, registering...
                      2016-12-05 22:16:55.868 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:gateway:temp01
                      2016-12-05 22:16:55.868 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
                      2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:GW MODE
                      2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:READY
                      2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - IP: 192.168.1.66
                      2016-12-05 22:16:57.553 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;No registration required
                      2016-12-05 22:16:57.558 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
                      2016-12-05 22:17:00.811 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                      2016-12-05 22:17:00.811 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:BC
                      2016-12-05 22:17:00.812 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:FPAR REQ (sender=4)
                      2016-12-05 22:17:00.818 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                      2016-12-05 22:17:00.818 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:GWL OK
                      2016-12-05 22:17:01.091 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                      2016-12-05 22:17:02.854 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      2016-12-05 22:17:02.857 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:PINGED (ID=4, hops=1)
                      2016-12-05 22:17:02.868 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                      2016-12-05 22:17:02.881 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      2016-12-05 22:17:02.924 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                      2016-12-05 22:17:02.935 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      2016-12-05 22:17:04.940 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
                      2016-12-05 22:17:05.863 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                      2016-12-05 22:17:06.765 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                      2016-12-05 22:17:08.599 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=0,t=1,pt=0,l=0,sg=0:
                      2016-12-05 22:17:10.422 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=0,t=7,pt=0,l=0,sg=0:
                      2016-12-05 22:17:12.248 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      2016-12-05 22:17:12.258 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                      2016-12-05 22:17:12.261 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      2016-12-05 22:17:12.304 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=fail:1
                      2016-12-05 22:17:12.309 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      2016-12-05 22:17:12.320 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                      2016-12-05 22:17:12.324 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=11,c=1,t=0,pt=7,l=5,sg=0:19.3
                      2016-12-05 22:17:14.157 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:70.8
                      2016-12-05 22:17:15.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                      2016-12-05 22:17:15.980 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=6,c=1,t=38,pt=7,l=5,sg=0:4.788
                      2016-12-05 22:17:25.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                      2016-12-05 22:17:34.431 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=1,t=16,pt=0,l=1,sg=0:1
                      2016-12-05 22:17:35.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                      2016-12-05 22:17:36.265 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=11,c=1,t=0,pt=7,l=5,sg=0:19.4
                      2016-12-05 22:17:38.088 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:70.6
                      2016-12-05 22:17:39.911 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=6,c=1,t=38,pt=7,l=5,sg=0:4.768
                      2016-12-05 22:17:41.744 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=1,t=16,pt=0,l=1,sg=0:0
                      *** Debug for Ethernet connection without skipping I-Version check
                      2016-12-05 22:23:12.927 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                      2016-12-05 22:23:12.930 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Set skip check on startup to: false
                      2016-12-05 22:23:12.931 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
                      2016-12-05 22:23:12.934 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                      2016-12-05 22:23:12.935 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
                      2016-12-05 22:23:12.937 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                      2016-12-05 22:23:12.938 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.66:5003]
                      2016-12-05 22:23:13.148 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2016-12-05 22:23:13.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2016-12-05 22:23:14.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2016-12-05 22:23:15.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2016-12-05 22:23:16.964 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                      2016-12-05 22:23:17.964 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
                      2016-12-05 22:23:17.967 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
                      2016-12-05 22:23:17.968 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                      2016-12-05 22:23:17.968 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                      2016-12-05 22:23:17.971 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
                      2016-12-05 22:23:17.975 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 4, chiledId: 10, revertState: false
                      2016-12-05 22:23:17.976 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
                      2016-12-05 22:23:17.977 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 4, chiledId: 11, revertState: false
                      2016-12-05 22:23:17.977 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
                      2016-12-05 22:23:17.990 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                      2016-12-05 22:23:17.991 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
                      *** Debug for Ethernet connection skipping I-Version check
                      2016-12-05 22:27:59.514 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.66:5003]
                      2016-12-05 22:27:59.515 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
                      2016-12-05 22:27:59.515 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                      2016-12-05 22:27:59.525 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Skipping I_VERSION connection test, not recommended...
                      2016-12-05 22:27:59.527 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:gateway:hum01
                      2016-12-05 22:27:59.527 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                      2016-12-05 22:27:59.528 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Network Sanity Checker thread disabled from bridge configuration
                      2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
                      2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:gateway:temp01
                      2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
                      2016-12-05 22:28:09.528 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                      2016-12-05 22:28:19.528 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                      • triceTT triceT
                        Hello to all.
                        My configuration:
                        Regards!
                        TimO
                        wrote on last edited by TimO
                        #68
                        @triceT you're trying to connect per serial to your ethernet gateway. Try connecting with the ethernet gateway configuration using the IP 192.168.1.66 and port 5003, like in the last output of your post. You only get the debug output of the serial gateway in OH2, the messages from the nodes are not forwarded to serial.
                        The connection seems to be get established, but there is no answer to the I_VERSION message. Are you using RFM69? Did you try a "telnet 192.168.1.66 5003"? Do you see messages incoming?
                        triceTT 1 Reply Last reply
                        • T TimO
                          triceTT
                          triceTT
                          triceT
                          @TimO Thanks for your help....
                          I'm using nrf24 radio.
                          When I telnet I receive only this:
                          Trying 192.168.1.66...
                          Connected to 192.168.1.66.
                          Escape character is '^]'.
                          No mesages are shown
                          • triceTT
                            triceTT
                            triceT
                            This is what I'm getting on Arduino gw connecting over ethernet and setting skipstartupcheck to false. If I set skipstartupcheck to true, gw is not receiving anything from ethernet.
                            0;255;3;0;9;Eth: connect
                            0;255;3;0;9;Eth: 0;0;3;0;2;
                            0;255;3;0;9;Eth:
                            0;255;3;0;9;Eth:
                            0;255;3;0;9;Eth: disconnect
                            0;255;3;0;9;Eth:
                            0;255;3;0;9;Eth:
                            • triceTT triceT
                              0;255;3;0;9;Eth:
                              0;255;3;0;9;Eth:
                              0;255;3;0;9;Eth:
                              0;255;3;0;9;Eth:
                              TimO
                              @triceT Are you sure the gateway isn't in a boot loop? Could you please check serial debug if it gets started over and over again?
                              • T TimO
                                triceTT
                                triceTT
                                triceT
                                @TimO I guess it is not in a loop. Here is the serial debug...
                                IP: 192.168.1.66
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                                0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:61.7
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;TSP:SANCHK:OK
                                • carlylerC
                                  carlylerC
                                  carlyler
                                  @TimO brief setup: controller and serial gateway on raspberryPi running OH2, serial working OK. Trying to add ESP8266 Huzzah gateway with only local sensor, DHT22 - no radio. It seems I have a similar situation as others, but before I post all my setup and logs a question for you: when using both a serial gateway and ethernet gateway can they be named the same, "gateway", in things file? What bothers me is the "channel" in the items file ends up looking like it is from the same source or am I missing something?
                                  Things file:
                                  Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyMySensorsGateway", sendDelay=200 ]
                                     humidity         hum01   [ nodeId="1", childId="0" ]
                                     temperature      temp01  [ nodeId="1", childId="1" ]
                                     humidity         hum02   [ nodeId="1", childId="2" ]
                                     temperature      temp02  [ nodeId="1", childId="3" ]
                                     humidity         hum03   [ nodeId="1", childId="4" ]
                                     temperature      temp03  [ nodeId="1", childId="5" ]
                                     power            power01 [ nodeId="2", childId="0" ]
                                  Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.1.113", tcpPort=5003, sendDelay=200 ]
                                     humidity         hum04   [ nodeId="3", childId="0" ]
                                     temperature      temp04  [ nodeId="3", childId="1" ]
                                  Items file snippet (hum02/temp02 on serial GW and hum04/temp04 on eth GW)
                                  Number mHum                 "Master Humidity [%.0f %%]"             <humidity>      (grpChart,grpTemperatures)  { channel="mysensors:humidity:gateway:hum02:hum" }
                                  Number mTemp                "Master Temperature"                    <temperature>                               { channel="mysensors:temperature:gateway:temp02:temp" }
                                  Number bHum                 "Bean's Humidity [%.0f %%]"             <humidity>      (grpChart,grpTemperatures)  { channel="mysensors:humidity:gateway:hum04:hum" }
                                  Number bTemp                "Bean's Temperature"                    <temperature>                               { channel="mysensors:temperature:gateway:temp04:temp" }
                                  • carlylerC carlyler
                                    Things file:
                                    TimO
                                    @carlyler The name must be unique for each gateway. So please change that first and report back, if that solves the problem.
                                    • triceTT triceT
                                      IP: 192.168.1.66
                                      0;255;3;0;9;Eth:
                                      0;255;3;0;9;Eth:
                                      0;255;3;0;9;Eth:
                                      0;255;3;0;9;Eth:
                                      0;255;3;0;9;Eth:
                                      0;255;3;0;9;Eth:
                                      TimO
                                      @triceT Just to make sure it is still working with the current snapshot I made a clean install.
                                      I've used:
                                      • OH2 Snapshot #631
                                      • current Binding
                                      • MySensors 2.0.0
                                      • Ethernet Gateway (Arduino Uno + Ethernet Shield + NRF24L01+)
                                      Everything works just fine, so don't give up! :-)
                                      • carlylerC
                                        carlylerC
                                        carlyler
                                        @TimO thanks for the reply. I changed mysensors:bridge-eth:gateway to mysensors:bridge-eth:ethGateway in things and items, restarted OH2, reset ESP8266, several times, but no luck. If I read this right the GW is not trying to do much, ie get node id, present sensor, send data, etc. Any idea?
                                        GW serial:
                                        0;255;3;0;9;MCO:BGN:STP
                                        0;255;3;0;9;MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                        0;255;3;0;9;MCO:SLP:WUP=-2
                                        0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
                                        Getting temperature
                                        T: 20.00
                                        H: 34.70
                                        Getting temperature
                                        T: 20.10
                                        H: 33.90
                                        I am trying to set node id in sketch:
                                        #define DHT_DATA_PIN 2
                                        #define MY_GATEWAY_ESP8266
                                        // ethernet settings
                                        #define MY_ESP8266_SSID "xxxxxx"
                                        #define MY_ESP8266_PASSWORD "xxxxxxxxxx"
                                        // Enable UDP communication
                                        //#define MY_USE_UDP
                                        #define MY_ESP8266_HOSTNAME "HuzzahGateway"
                                        //#define MY_IP_ADDRESS 192,168,213,113
                                        //#define MY_IP_GATEWAY_ADDRESS 192,168,213,1
                                        #define MY_PORT 5003
                                        //#define MY_CONTROLLER_IP_ADDRESS 192,168,213,116
                                        // Flash leds on rx/tx/err
                                        #define MY_NODE_ID 3
                                        #include <ESP8266WiFi.h>
                                          GW serial:
                                          Getting temperature
                                          T: 20.00
                                          H: 34.70
                                          Getting temperature
                                          T: 20.10
                                          H: 33.90
                                          TimO
                                          @carlyler Serial log looks good. The gateway is receiving it's IP per DHCP, right? Is the IP you configured above still correct? I prefer a static IP for my gateway to prevent a changing of the IP.
                                          Is the gateway reachable by ping? Are you able to connect with "telnet IP 5003" to the gateway?
