  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • pentti12P
    pentti12P
    pentti12
    I am using Ethernet Gateway in my LAN. Gateway has static IP and it is accessible (ping works). Also port number 5003 is detected correctly.
    I am using standard GatewayW5100.ino sketch.
    How can I force OH2 to use only Ethernet-connection?
    • T
      TimO
      Have you configured the gateway in the *.things file? How does it look?
      • triceTT
        triceTT
        triceT
        Hello to all.
        I have similar problems as pentti12.
        Can not get values updated in OH2, there are always -NAN
        While with serial connection I get some reads in the log file, with eth connection I can't see any reads from gw.
        I've installed everything as per wiki several times without success.
        Radio connection between gw and nodes is running without problems.
        Previous testing gw with w5100MQTTClient sketch, was running perfectly
        My configuration:
        MySensors Binding: 2.0.0.201611221149
        OH2: 2.0.0-SNAPSHOT Build #629 running on debian
        gw: Arduino Uno with W5100 sketch
        Node: arduino nano with temp and humidity sensor.
        Could somebody help me in this.
        Regards!
        *** Debug for serial connection without skipping I-Version check
        2016-12-05 22:06:22.608 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
        2016-12-05 22:06:22.634 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
        2016-12-05 22:06:22.664 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
        2016-12-05 22:06:22.664 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
        2016-12-05 22:06:25.665 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
        2016-12-05 22:06:25.667 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:INIT
        2016-12-05 22:06:25.667 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:RADIO:OK
        2016-12-05 22:06:25.668 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:GW MODE
        2016-12-05 22:06:25.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:READY
        2016-12-05 22:06:25.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - IP: 192.168.1.66
        2016-12-05 22:06:25.865 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        2016-12-05 22:06:26.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        2016-12-05 22:06:27.372 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;No registration required
        2016-12-05 22:06:27.372 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
        2016-12-05 22:06:27.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        2016-12-05 22:06:28.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        2016-12-05 22:06:29.665 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        2016-12-05 22:06:30.665 [ERROR] [col.serial.MySensorsSerialConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
        2016-12-05 22:06:30.665 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:27)
        2016-12-05 22:06:30.666 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
        2016-12-05 22:06:30.666 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
        2016-12-05 22:06:30.666 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialWriter
        2016-12-05 22:06:30.669 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
        2016-12-05 22:06:30.670 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
        *** Debug for serial connection skipping I-Version check
        2016-12-05 22:16:52.785 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
        2016-12-05 22:16:52.786 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: true
        2016-12-05 22:16:52.787 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
        2016-12-05 22:16:52.789 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
        2016-12-05 22:16:52.789 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
        2016-12-05 22:16:52.789 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
        2016-12-05 22:16:52.793 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
        2016-12-05 22:16:52.821 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
        2016-12-05 22:16:52.851 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
        2016-12-05 22:16:52.851 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
        2016-12-05 22:16:55.852 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
        2016-12-05 22:16:55.855 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:INIT
        2016-12-05 22:16:55.856 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:RADIO:OK
        2016-12-05 22:16:55.855 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended...
        2016-12-05 22:16:55.860 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:power:9ba30e1b
        2016-12-05 22:16:55.862 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:gateway:hum01
        2016-12-05 22:16:55.863 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
        2016-12-05 22:16:55.863 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
        2016-12-05 22:16:55.867 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
        2016-12-05 22:16:55.867 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-6 not registered yet, registering...
        2016-12-05 22:16:55.868 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:gateway:temp01
        2016-12-05 22:16:55.868 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
        2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:GW MODE
        2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSM:READY
        2016-12-05 22:16:55.869 [DEBUG] [rs.internal.protocol.MySensorsReader] - IP: 192.168.1.66
        2016-12-05 22:16:57.553 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;No registration required
        2016-12-05 22:16:57.558 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
        2016-12-05 22:17:00.811 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
        2016-12-05 22:17:00.811 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:BC
        2016-12-05 22:17:00.812 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:FPAR REQ (sender=4)
        2016-12-05 22:17:00.818 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
        2016-12-05 22:17:00.818 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:GWL OK
        2016-12-05 22:17:01.091 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
        2016-12-05 22:17:02.854 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
        2016-12-05 22:17:02.857 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:PINGED (ID=4, hops=1)
        2016-12-05 22:17:02.868 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
        2016-12-05 22:17:02.881 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        2016-12-05 22:17:02.924 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
        2016-12-05 22:17:02.935 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        2016-12-05 22:17:04.940 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
        2016-12-05 22:17:05.863 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
        2016-12-05 22:17:06.765 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        2016-12-05 22:17:08.599 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=0,t=1,pt=0,l=0,sg=0:
        2016-12-05 22:17:10.422 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=0,t=7,pt=0,l=0,sg=0:
        2016-12-05 22:17:12.248 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
        2016-12-05 22:17:12.258 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
        2016-12-05 22:17:12.261 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
        2016-12-05 22:17:12.304 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=fail:1
        2016-12-05 22:17:12.309 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
        2016-12-05 22:17:12.320 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
        2016-12-05 22:17:12.324 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=11,c=1,t=0,pt=7,l=5,sg=0:19.3
        2016-12-05 22:17:14.157 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:70.8
        2016-12-05 22:17:15.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
        2016-12-05 22:17:15.980 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=6,c=1,t=38,pt=7,l=5,sg=0:4.788
        2016-12-05 22:17:25.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
        2016-12-05 22:17:34.431 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=1,t=16,pt=0,l=1,sg=0:1
        2016-12-05 22:17:35.864 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
        2016-12-05 22:17:36.265 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=11,c=1,t=0,pt=7,l=5,sg=0:19.4
        2016-12-05 22:17:38.088 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:70.6
        2016-12-05 22:17:39.911 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=6,c=1,t=38,pt=7,l=5,sg=0:4.768
        2016-12-05 22:17:41.744 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 4-4-0 s=9,c=1,t=16,pt=0,l=1,sg=0:0
        *** Debug for Ethernet connection without skipping I-Version check
        2016-12-05 22:23:12.927 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
        2016-12-05 22:23:12.930 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Set skip check on startup to: false
        2016-12-05 22:23:12.931 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
        2016-12-05 22:23:12.934 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
        2016-12-05 22:23:12.935 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
        2016-12-05 22:23:12.937 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
        2016-12-05 22:23:12.938 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.66:5003]
        2016-12-05 22:23:13.148 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        2016-12-05 22:23:13.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        2016-12-05 22:23:14.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        2016-12-05 22:23:15.963 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        2016-12-05 22:23:16.964 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
        2016-12-05 22:23:17.964 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
        2016-12-05 22:23:17.967 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
        2016-12-05 22:23:17.968 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
        2016-12-05 22:23:17.968 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
        2016-12-05 22:23:17.971 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
        2016-12-05 22:23:17.975 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 4, chiledId: 10, revertState: false
        2016-12-05 22:23:17.976 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
        2016-12-05 22:23:17.977 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 4, chiledId: 11, revertState: false
        2016-12-05 22:23:17.977 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
        2016-12-05 22:23:17.990 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
        2016-12-05 22:23:17.991 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
        *** Debug for Ethernet connection skipping I-Version check
        2016-12-05 22:27:59.514 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.66:5003]
        2016-12-05 22:27:59.515 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [4]
        2016-12-05 22:27:59.515 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
        2016-12-05 22:27:59.525 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Skipping I_VERSION connection test, not recommended...
        2016-12-05 22:27:59.527 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:gateway:hum01
        2016-12-05 22:27:59.527 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
        2016-12-05 22:27:59.528 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Network Sanity Checker thread disabled from bridge configuration
        2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-10 not registered yet, registering...
        2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:gateway:temp01
        2016-12-05 22:27:59.528 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 4-11 not registered yet, registering...
        2016-12-05 22:28:09.528 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        2016-12-05 22:28:19.528 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        • triceTT triceT
          Hello to all.
          My configuration:
          Regards!
          TimO
          wrote on last edited by TimO
          #68
          @triceT you're trying to connect per serial to your ethernet gateway. Try connecting with the ethernet gateway configuration using the IP 192.168.1.66 and port 5003, like in the last output of your post. You only get the debug output of the serial gateway in OH2, the messages from the nodes are not forwarded to serial.
          The connection seems to be get established, but there is no answer to the I_VERSION message. Are you using RFM69? Did you try a "telnet 192.168.1.66 5003"? Do you see messages incoming?
          triceTT 1 Reply Last reply
          • T TimO
            triceTT
            triceTT
            triceT
            @TimO Thanks for your help....
            I'm using nrf24 radio.
            When I telnet I receive only this:
            Trying 192.168.1.66...
            Connected to 192.168.1.66.
            Escape character is '^]'.
            No mesages are shown
            • triceTT
              triceTT
              triceT
              This is what I'm getting on Arduino gw connecting over ethernet and setting skipstartupcheck to false. If I set skipstartupcheck to true, gw is not receiving anything from ethernet.
              0;255;3;0;9;Eth: connect
              0;255;3;0;9;Eth: 0;0;3;0;2;
              0;255;3;0;9;Eth:
              0;255;3;0;9;Eth:
              0;255;3;0;9;Eth: disconnect
              0;255;3;0;9;Eth:
              0;255;3;0;9;Eth:
              • triceTT triceT
                0;255;3;0;9;Eth:
                0;255;3;0;9;Eth:
                0;255;3;0;9;Eth:
                0;255;3;0;9;Eth:
                TimO
                @triceT Are you sure the gateway isn't in a boot loop? Could you please check serial debug if it gets started over and over again?
                • T TimO
                  triceTT
                  triceTT
                  triceT
                  @TimO I guess it is not in a loop. Here is the serial debug...
                  IP: 192.168.1.66
                  0;255;3;0;9;Eth:
                  0;255;3;0;9;Eth:
                  0;255;3;0;9;Eth:
                  0;255;3;0;9;Eth:
                  0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                  0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                  0;255;3;0;9;TSP:MSG:READ 4-4-0 s=10,c=1,t=1,pt=7,l=5,sg=0:61.7
                  0;255;3;0;9;Eth:
                  0;255;3;0;9;Eth:
                  0;255;3;0;9;TSP:SANCHK:OK
                  • carlylerC
                    carlylerC
                    carlyler
                    @TimO brief setup: controller and serial gateway on raspberryPi running OH2, serial working OK. Trying to add ESP8266 Huzzah gateway with only local sensor, DHT22 - no radio. It seems I have a similar situation as others, but before I post all my setup and logs a question for you: when using both a serial gateway and ethernet gateway can they be named the same, "gateway", in things file? What bothers me is the "channel" in the items file ends up looking like it is from the same source or am I missing something?
                    Things file:
                    Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyMySensorsGateway", sendDelay=200 ]
                       humidity         hum01   [ nodeId="1", childId="0" ]
                       temperature      temp01  [ nodeId="1", childId="1" ]
                       humidity         hum02   [ nodeId="1", childId="2" ]
                       temperature      temp02  [ nodeId="1", childId="3" ]
                       humidity         hum03   [ nodeId="1", childId="4" ]
                       temperature      temp03  [ nodeId="1", childId="5" ]
                       power            power01 [ nodeId="2", childId="0" ]
                    Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.1.113", tcpPort=5003, sendDelay=200 ]
                       humidity         hum04   [ nodeId="3", childId="0" ]
                       temperature      temp04  [ nodeId="3", childId="1" ]
                    Items file snippet (hum02/temp02 on serial GW and hum04/temp04 on eth GW)
                    Number mHum                 "Master Humidity [%.0f %%]"             <humidity>      (grpChart,grpTemperatures)  { channel="mysensors:humidity:gateway:hum02:hum" }
                    Number mTemp                "Master Temperature"                    <temperature>                               { channel="mysensors:temperature:gateway:temp02:temp" }
                    Number bHum                 "Bean's Humidity [%.0f %%]"             <humidity>      (grpChart,grpTemperatures)  { channel="mysensors:humidity:gateway:hum04:hum" }
                    Number bTemp                "Bean's Temperature"                    <temperature>                               { channel="mysensors:temperature:gateway:temp04:temp" }
                    • carlylerC carlyler
                      Things file:
                      TimO
                      @carlyler The name must be unique for each gateway. So please change that first and report back, if that solves the problem.
                      • triceTT triceT
                        IP: 192.168.1.66
                        0;255;3;0;9;Eth:
                        0;255;3;0;9;Eth:
                        0;255;3;0;9;Eth:
                        0;255;3;0;9;Eth:
                        0;255;3;0;9;Eth:
                        0;255;3;0;9;Eth:
                        TimO
                        @triceT Just to make sure it is still working with the current snapshot I made a clean install.
                        I've used:
                        • OH2 Snapshot #631
                        • current Binding
                        • MySensors 2.0.0
                        • Ethernet Gateway (Arduino Uno + Ethernet Shield + NRF24L01+)
                        Everything works just fine, so don't give up! :-)
                        • carlylerC
                          carlylerC
                          carlyler
                          @TimO thanks for the reply. I changed mysensors:bridge-eth:gateway to mysensors:bridge-eth:ethGateway in things and items, restarted OH2, reset ESP8266, several times, but no luck. If I read this right the GW is not trying to do much, ie get node id, present sensor, send data, etc. Any idea?
                          GW serial:
                          0;255;3;0;9;MCO:BGN:STP
                          0;255;3;0;9;MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          0;255;3;0;9;MCO:SLP:WUP=-2
                          0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
                          Getting temperature
                          T: 20.00
                          H: 34.70
                          Getting temperature
                          T: 20.10
                          H: 33.90
                          I am trying to set node id in sketch:
                          #define DHT_DATA_PIN 2
                          #define MY_GATEWAY_ESP8266
                          // ethernet settings
                          #define MY_ESP8266_SSID "xxxxxx"
                          #define MY_ESP8266_PASSWORD "xxxxxxxxxx"
                          // Enable UDP communication
                          //#define MY_USE_UDP
                          #define MY_ESP8266_HOSTNAME "HuzzahGateway"
                          //#define MY_IP_ADDRESS 192,168,213,113
                          //#define MY_IP_GATEWAY_ADDRESS 192,168,213,1
                          #define MY_PORT 5003
                          //#define MY_CONTROLLER_IP_ADDRESS 192,168,213,116
                          // Flash leds on rx/tx/err
                          #define MY_NODE_ID 3
                          #include <ESP8266WiFi.h>
                            GW serial:
                            Getting temperature
                            T: 20.00
                            H: 34.70
                            Getting temperature
                            T: 20.10
                            H: 33.90
                            TimO
                            @carlyler Serial log looks good. The gateway is receiving it's IP per DHCP, right? Is the IP you configured above still correct? I prefer a static IP for my gateway to prevent a changing of the IP.
                            Is the gateway reachable by ping? Are you able to connect with "telnet IP 5003" to the gateway?
                            • carlylerC
                              carlylerC
                              carlyler
                              @TimO DHCP: yes, but it is actually static by way of reserved addresses via MAC in the router.
                              IP: same
                              ping: yes, works
                              telnet, yes, all I see is:
                              Serial is OK? I do not see the send of the Temp and hum; it is printing it because there is code to do that, but I am expecting the MySensors send command; right? My thought was it is not transmitting them for some reason. This is an area I am not confident about and have yet to find a good explanation of it: how a GW handles local sensors. Thoughts?
                              • T TimO
                                I've used:
                                • OH2 Snapshot #631
                                • current Binding
                                • MySensors 2.0.0
                                triceTT
                                triceTT
                                triceT
                                @TimO I have the exact hardware (Mine is Chinese) and SW versions as you, but still can't connect via Ethernet gw. I will not give up till it is working :) I've ordered another Ethernet shield and will try with the new one.
                                Regards
                                • carlylerC
                                  carlylerC
                                  carlyler
                                  @TimO Good news! I finally got it to work; I have been using the dev, 2.1.0, and decided to try master, 2.0.0 and it came right up! I did notice one thing though that you may be interested in: if I start the ethGateway after OH2 is up, or turn it off and back on, the binding does not reconnect. Not sure if there is anything you can do about that.
                                  One other change to mention (before changing to v2.0.0): I found a note from hek about the node id of gateway local sensors will always be 0; I changed that in my things file and in my sketch.
                                  16:34:59.286 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;12.5
                                  16:34:59.291 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2016-12-10T16:34:59.289-0500
                                  16:34:59.300 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2016-12-10T16:34:59.297-0500
                                  16:34:59.333 [INFO ] [marthome.event.ItemStateChangedEvent] - bTemp changed from 12.8 to 12.5
                                  16:34:59.354 [INFO ] [marthome.event.ItemStateChangedEvent] - bTempF changed from 55.04 to 54.50
                                  16:34:59.365 [INFO ] [marthome.event.ItemStateChangedEvent] - bTempC_F changed from 12.8 °C / 55.0 °F to 12.5 °C / 54.5 °F
                                  16:34:59.490 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  16:34:59.583 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;0;1;0;1;34.1
                                  16:34:59.593 [INFO ] [marthome.event.ItemStateChangedEvent] - bHum changed from 34.2 to 34.1
                                  @hek I could be wrong, or maybe something has changed configuration wise but as you can see from above posts, dev branch v2.1.0, the radioless ethernet (ESP8266) gateway with local temp & hum sensors was not sending local sensor data. When I switched back to master v2.0.0 it started sending.
                                  jogantJ 1 Reply Last reply
                                    jogantJ
                                    jogantJ
                                    jogant
                                    @carlyler
                                    The issue with the oh2 binding is known. You have to restart oh2 or just the binding through oh console and binding:restart
                                    Maybe an update of the binding may help but I didn't try yet.
                                    carlylerC 1 Reply Last reply
                                    • jogantJ jogant
                                      @carlyler
                                      carlylerC
                                      carlylerC
                                      carlyler
                                      @jogant Thank you. I did not know about the binding restart so I will look into that.
                                      • T TimO
                                        @pentti12 I've pushed a new version of the binding to github, please try it out and let me know if it helps.
                                        jogantJ
                                        jogantJ
                                        jogant
                                        @TimO
                                        yesterday I tried the new binding with OH2 b4 and I have exactly the faulty behavior as described before. The gateway goes in online state but none of the mysensor node items goes online. They remain uninitialized. I restored the older binding and everything works well again. As it is the same behavior that @pentti12 describes I think it has to with the binding itself.
                                        @pentti12 : please try attached binding as that works for me. 0_1482134888619_org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                                        it is an older snapshot from November, 7th.
                                        Good luck
                                        • pentti12P
                                          pentti12P
                                          pentti12
                                          @jogant I moved to different location here in Espoo, so it will take a couple of days before I can continue with proposed MySensors binding, but it is good to know that there is at least one working solution available.
