  3. Battery status in scetch?
7 Posts 3 Posters 3.1k Views 2 Watching
  • miroM Offline
    miroM Offline
    miro
    I want to have the oportunity to see battery status in my controller for my BinarySwitchSleepSensor.
    Therefore I wounder if someone could help me to take does needed parts from this one:
    unsigned long SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
       sendSketchInfo("Battery Meter", "1.0");
       // get the battery Voltage
       #ifdef MY_DEBUG
       Serial.println(sensorValue);
       #ifdef MY_DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
       sleep(SLEEP_TIME);
    To this one...
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
      // Setup the buttons
      // Activate internal pull-ups
      present(SECONDARY_CHILD_ID, S_DOOR);
      uint8_t value;
      static uint8_t sentValue=2;
      static uint8_t sentValue2=2;
      sleep(5);
      if (value != sentValue) {
         send(msg.set(value==HIGH ? 1 : 0));
         sentValue = value;
      if (value != sentValue2) {
         send(msg2.set(value==HIGH ? 1 : 0));
         sentValue2 = value;
      sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
    Regards
    Mikael
    • miroM Offline
      miroM Offline
      miro
      I think I have fixed this by my own without any coding knowledge. LOL
      But one thing I don`t understand.
      Why is the battery status symbol showed on the node and not the sensor?
      B 1 Reply Last reply
      • S Offline
        Hello.
        Great to hear you've figured it by yourself, try&retries is good for learning ;) So i assume you've copy/pasted the batt code to your node.
        That said, regarding your 2nd question, I'm not sure to understand..
        But using sendBatteryVoltage is an internal Mysensors function which send the battery voltage with a special internal message I_BATTERY_LEVEL . Its purpose is especially that controllers can easily recognize which message is for battery level. Imho, in a controller i prefer to have the battery level at node level.
        It's still possible to create a dedicated CHILD _ID_BATTERY_LEVEL or CHILD _ID_BATTERY_VOLTAGE if you want the battery voltage for instance. and populate the corresponding code in your sketch. Then you can do what you want with the value in your controller etc..but the controller itself won't be able to know this is a battery level value. Up to you then to tell him.
        • miroM miro
          B Offline
          B Offline
          blacey
          Because there is a single power source for a given node even though a node can host multiple sensors. Many home automation controllers expect and present the battery status for a given node because it is a property of the node and not the sensors. Does this make sense?
          • miroM Offline
            miroM Offline
            miro
            Hmm, not really.
            On my fibaro sensors I have battery status on the sensors. Why is it like that?
            Don`t they have nodes?
            • miroM miro
              Hmm, not really.
              B Offline
              B Offline
              blacey
              @miro Hmmm, don't know - it is a Fibraro choice or controller ui choice, and I suspect the later. For example, on the Vera home controller, the Fibraro LED dimmers report power consumption on the parent node, not the RGBW children.
              • S Offline
                @miro
                i think you're confusing a node id VS a child node id, a device VS a sensor data. typo mistake.
                for a device you can have only one id. but you can have multiple sensors so multiple child ids in a device.
                Battery could be one of these sensors.
                You can't have the battery voltage for a temperature sensor or humidity sensor. that does not mean anything. you're not sensing battery level with the temperature ic/sensor... whereas a battery level for a device makes sense.
                For more infos i would advise to read the great docs https://www.mysensors.org/download/sensor_api_20 etc.
