  3. Domoticz
  4. Node with DS18B20 and DHT22
13 Posts 5 Posters 6.9k Views 4 Watching
  • dbemowskD
    dbemowskD
    Just out of curiosity, why are you using DS18B20s with a DHT22? Are these all mounted on the same sensor board?
    • dokhoD
      dokhoD
      dokho
      Hi!
      It's to make a node for the 2nd floor of my house: 6 DS18B20 for bedrooms, office (?), stairs and 2 DHT22 for the 2 bathrooms.
      DHT22 are more expensive than DS18B20 and i need to know humidity only for the bathrooms.
      • dokhoD
        dokhoD
        dokho
        wrote on last edited by dokho
        Hi!
        I've try with developpement librairies and it's the same.
        For information this is the sketch i'm using:
        // Enable debug prints
        //#define MY_RS485
        #include <OneWire.h>
        #define MAX_ATTACHED_DS18B20 6
        #define ONE_WIRE_BUS 4
        #define DHT1_DATA_PIN 2
        #define DHT2_DATA_PIN 3
        #define CHILD_ID_DHT1HUM 6
        #define CHILD_ID_DHT1TEMP 7
        #define CHILD_ID_DHT2HUM 9
        #define CHILD_ID_DHT2TEMP 8
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 3000;
        unsigned long SLEEP_TIME = 30000;
        bool metric = true;
        bool receivedConfig = false;
        int numSensors=0;
        MyMessage msgDallas(0,V_TEMP);
        MyMessage msgDHT1Temp(CHILD_ID_DHT1TEMP,V_TEMP);
        MyMessage msgDHT1Hum(CHILD_ID_DHT1HUM,V_HUM);
        MyMessage msgDHT2Hum(CHILD_ID_DHT2HUM,V_HUM);
        MyMessage msgDHT2Temp(CHILD_ID_DHT2TEMP,V_TEMP);
        DHT dht;
        void before()
          sensors.begin();
          sendSketchInfo("DualDHTandDallas", "1.1");
             present(i, S_TEMP);
          present(CHILD_ID_DHT1TEMP,S_TEMP);
          present(CHILD_ID_DHT1HUM,S_HUM);
          present(CHILD_ID_DHT2HUM,S_HUM);
          present(CHILD_ID_DHT2TEMP,S_TEMP);
          sleep(conversionTime);
            float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
          send(msgDallas.setSensor(i).set(temperature,1));
              #ifdef MY_DEBUG
              Serial.print("Dallas");
              Serial.print(i);
              Serial.print(" :");
        //  sleep(SLEEP_TIME);
          dht.setup(DHT1_DATA_PIN); // set data pin of DHT1 sensor
          dht.readSensor(true);
          float dht1temperature = dht.getTemperature();
          if (isnan(dht1temperature)) {
          } else
            if (!metric) {
              dht1temperature = dht.toFahrenheit(dht1temperature);
            dht1temperature += SENSOR_TEMP_OFFSET;
            send(msgDHT1Temp.set(dht1temperature, 1));
            #ifdef MY_DEBUG
            Serial.print("DHT1TEMP: ");
            Serial.println(dht1temperature);
          sleep(UPDATE_INTERVAL);
          float dht1humidity = dht.getHumidity();
          if (isnan(dht1humidity)) {
          else {
           send(msgDHT1Hum.set(dht1humidity, 1));
            #ifdef MY_DEBUG
            Serial.print("DHT1HUM: ");
            Serial.println(dht1humidity);
          dht.setup(DHT2_DATA_PIN); // set data pin of DHT2 sensor
          float dht2temperature = dht.getTemperature();
          if (isnan(dht2temperature)) {
          } else
            if (!metric) {
              dht2temperature = dht.toFahrenheit(dht2temperature);
            dht2temperature += SENSOR_TEMP_OFFSET;
            send(msgDHT2Temp.set(dht2temperature, 1));
            #ifdef MY_DEBUG
            Serial.print("DHT2TEMP: ");
            Serial.println(dht2temperature);
          float dht2humidity = dht.getHumidity();
          if (isnan(dht2humidity)) {
           send(msgDHT2Hum.set(dht2humidity, 1));
            #ifdef MY_DEBUG
            Serial.print("DHT2HUM: ");
            Serial.println(dht2humidity);
        And in domoticz all childs have the same ID (#1)
        0_1478106899752_Screenshot - 02112016 - 18:14:09.png
        Noboby have an idea of the problem ?
        [EDIT]
        And i just discover an other "problem": the 2nd DHT22 humidity value is updated with the value of the 1st one...
        • dokhoD
          dokhoD
          dokho
          Up ... please :s
            wrote on last edited by hek
            Isn't the left column the sensor id? 0,1,6,7,8,9 ?
            dokhoD 1 Reply Last reply
              dokhoD
              dokhoD
              dokho
              @hek
              No it's the #1 in the "Values" column
              On an other node with 4 DS18B20:
              0_1479066924561_Screenshot - 13112016 - 20:53:28.png
              The DS18B20 have different ID (#1, #2, #3 and #4)
                I don't run Domoticz myself. But the numbers in the left column matches child ids in your sketch exactly.
                • dbemowskD
                  dbemowskD
                  The numbers in the left column ARE the child IDs. The numbers next to V_TEMP in the values column are not the child IDs. Look at your Domoticz indexes and IDs for these under Setup > Devices.
                  • dokhoD
                    dokhoD
                    dokho
                    Ok so the number next to V_TEMP in the values column are groupID ?
                    The problem in my DS18B20+DHT22 node is that they have all the same groupID, so domoticz group TEMP and HUM in the same device and the HUM of the 1st DHT22 is updated with the HUM of the 2nd one ...
                    • Jon EngJ
                      Jon EngJ
                      Jon Eng
                      So I researched this a bit and here is the answer:
                      The grouping of devices origins from this commit:
                      https://github.com/domoticz/domoticz/pull/847
                      and the logic is:
                      https://github.com/domoticz/domoticz/issues/276
                      Unfortunately it doesn´t work very well with other sensor combinations that Temp/hum/pressure - like mine with voltage, impedance and so on..
                      I found a workaround by naming all sensors v_hum - then they are placed in different groups and are possible to work with in domoticz...
                      12.5k
