  3. Domoticz
  4. Node with DS18B20 and DHT22
13 Posts 5 Posters 6.5k Views 4 Watching
  • dokhoD Offline
    dokhoD Offline
    dokho
    Hi!
    First sorry for my bad english :)
    I'm trying to make a node with 2 DS18B20 and 2 DHT22 but in domoticz the DS18B20 is show like "Temp + Humidity" sensors (with the humidity value of the 1st DHT22).
    I've read on github that it's possible to set "groupID" to resolve this problem, but i don't understand how to set this.
    I've try this, but not working:
      present(0, S_TEMP, "SENSOR1");
      present(1, S_TEMP, "SENSOR2");
      present(CHILD_ID_TEMP1, S_TEMP, "SENSOR3");
      present(CHILD_ID_HUM1, S_HUM, "SENSOR3");
      present(CHILD_ID_TEMP2, S_TEMP, "SENSOR4");
      present(CHILD_ID_HUM2, S_HUM, "SENSOR4");
    Does someone can explain me please ?
    Thank you.
    • dokhoD dokho
      Hi!
      Thank you.
      Welcome to the MySensors community @dokho !
      I think the discussion in https://forum.mysensors.org/topic/5132/ds18b20-ans-sht31-d-show-up-as-combined-sensors-on-domoticz/8 will give you what you need. See if that helps and report back the result. We'll try to help if you get stuck.
      • dokhoD Offline
        dokhoD Offline
        dokho
        Hi !
        Thank you for the greeting @mfalkvidd :)
        I've already read the discussion you've quote but i'm not sure to understand: some say "modify domoticz code" other say "present sensor after each other" ...
        Witch version of mysensors is needed to do what i try ? 2.0 or beta ?
        I'm using, perhaps it's not the good version ...
        • D Offline
          Just out of curiosity, why are you using DS18B20s with a DHT22? Are these all mounted on the same sensor board?
          • dokhoD Offline
            dokhoD Offline
            dokho
            Hi!
            It's to make a node for the 2nd floor of my house: 6 DS18B20 for bedrooms, office (?), stairs and 2 DHT22 for the 2 bathrooms.
            DHT22 are more expensive than DS18B20 and i need to know humidity only for the bathrooms.
            • dokhoD Offline
              dokhoD Offline
              dokho
              wrote on last edited by dokho
              Hi!
              I've try with developpement librairies and it's the same.
              For information this is the sketch i'm using:
              // Enable debug prints
              //#define MY_RS485
              #include <OneWire.h>
              #define MAX_ATTACHED_DS18B20 6
              #define ONE_WIRE_BUS 4
              #define DHT1_DATA_PIN 2
              #define DHT2_DATA_PIN 3
              #define CHILD_ID_DHT1HUM 6
              #define CHILD_ID_DHT1TEMP 7
              #define CHILD_ID_DHT2HUM 9
              #define CHILD_ID_DHT2TEMP 8
              #define SENSOR_TEMP_OFFSET 0
              static const uint64_t UPDATE_INTERVAL = 3000;
              unsigned long SLEEP_TIME = 30000;
              bool metric = true;
              bool receivedConfig = false;
              int numSensors=0;
              MyMessage msgDallas(0,V_TEMP);
              MyMessage msgDHT1Temp(CHILD_ID_DHT1TEMP,V_TEMP);
              MyMessage msgDHT1Hum(CHILD_ID_DHT1HUM,V_HUM);
              MyMessage msgDHT2Hum(CHILD_ID_DHT2HUM,V_HUM);
              MyMessage msgDHT2Temp(CHILD_ID_DHT2TEMP,V_TEMP);
              DHT dht;
              void before()
                sensors.begin();
                sendSketchInfo("DualDHTandDallas", "1.1");
                   present(i, S_TEMP);
                present(CHILD_ID_DHT1TEMP,S_TEMP);
                present(CHILD_ID_DHT1HUM,S_HUM);
                present(CHILD_ID_DHT2HUM,S_HUM);
                present(CHILD_ID_DHT2TEMP,S_TEMP);
                sleep(conversionTime);
                  float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                send(msgDallas.setSensor(i).set(temperature,1));
                    #ifdef MY_DEBUG
                    Serial.print("Dallas");
                    Serial.print(i);
                    Serial.print(" :");
              //  sleep(SLEEP_TIME);
                dht.setup(DHT1_DATA_PIN); // set data pin of DHT1 sensor
                dht.readSensor(true);
                float dht1temperature = dht.getTemperature();
                if (isnan(dht1temperature)) {
                } else
                  if (!metric) {
                    dht1temperature = dht.toFahrenheit(dht1temperature);
                  dht1temperature += SENSOR_TEMP_OFFSET;
                  send(msgDHT1Temp.set(dht1temperature, 1));
                  #ifdef MY_DEBUG
                  Serial.print("DHT1TEMP: ");
                  Serial.println(dht1temperature);
                sleep(UPDATE_INTERVAL);
                float dht1humidity = dht.getHumidity();
                if (isnan(dht1humidity)) {
                else {
                 send(msgDHT1Hum.set(dht1humidity, 1));
                  #ifdef MY_DEBUG
                  Serial.print("DHT1HUM: ");
                  Serial.println(dht1humidity);
                dht.setup(DHT2_DATA_PIN); // set data pin of DHT2 sensor
                float dht2temperature = dht.getTemperature();
                if (isnan(dht2temperature)) {
                } else
                  if (!metric) {
                    dht2temperature = dht.toFahrenheit(dht2temperature);
                  dht2temperature += SENSOR_TEMP_OFFSET;
                  send(msgDHT2Temp.set(dht2temperature, 1));
                  #ifdef MY_DEBUG
                  Serial.print("DHT2TEMP: ");
                  Serial.println(dht2temperature);
                float dht2humidity = dht.getHumidity();
                if (isnan(dht2humidity)) {
                 send(msgDHT2Hum.set(dht2humidity, 1));
                  #ifdef MY_DEBUG
                  Serial.print("DHT2HUM: ");
                  Serial.println(dht2humidity);
              And in domoticz all childs have the same ID (#1)
              0_1478106899752_Screenshot - 02112016 - 18:14:09.png
              Noboby have an idea of the problem ?
              [EDIT]
              And i just discover an other "problem": the 2nd DHT22 humidity value is updated with the value of the 1st one...
              • dokhoD Offline
                dokhoD Offline
                dokho
                Up ... please :s
                • H Offline
                  H Offline
                  wrote on last edited by hek
                  Isn't the left column the sensor id? 0,1,6,7,8,9 ?
                  dokhoD 1 Reply Last reply
                  • H hek
                    dokhoD Offline
                    dokhoD Offline
                    dokho
                    @hek
                    No it's the #1 in the "Values" column
                    On an other node with 4 DS18B20:
                    0_1479066924561_Screenshot - 13112016 - 20:53:28.png
                    The DS18B20 have different ID (#1, #2, #3 and #4)
                    • H Offline
                      H Offline
                      I don't run Domoticz myself. But the numbers in the left column matches child ids in your sketch exactly.
                      • D Offline
                        The numbers in the left column ARE the child IDs. The numbers next to V_TEMP in the values column are not the child IDs. Look at your Domoticz indexes and IDs for these under Setup > Devices.
                        • dokhoD Offline
                          dokhoD Offline
                          dokho
                          Ok so the number next to V_TEMP in the values column are groupID ?
                          The problem in my DS18B20+DHT22 node is that they have all the same groupID, so domoticz group TEMP and HUM in the same device and the HUM of the 1st DHT22 is updated with the HUM of the 2nd one ...
                          • Jon EngJ Offline
                            Jon EngJ Offline
                            Jon Eng
                            So I researched this a bit and here is the answer:
                            The grouping of devices origins from this commit:
                            https://github.com/domoticz/domoticz/pull/847
                            and the logic is:
                            https://github.com/domoticz/domoticz/issues/276
                            Unfortunately it doesn´t work very well with other sensor combinations that Temp/hum/pressure - like mine with voltage, impedance and so on..
                            I found a workaround by naming all sensors v_hum - then they are placed in different groups and are possible to work with in domoticz...
                            12.1k
