  2. Announcements
  • skywatchS
    skywatchS
    skywatch
    Can I just check that this is OK? .....
    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-transport=nrf24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    Can you see any problems here, it seemed to work but I hope to test fully this week, maybe tomorrow.....
    G 1 Reply Last reply
    • skywatchS skywatch
      G
      G
      gtortone
      @skywatch
      Hi, options for "configure" are ok, I suggest you to double check your cabling !
      • skywatchS
        skywatchS
        skywatch
        What makes you think that the cabling is wrong? - I checked and can't see any problem....can you be less cryptic please? :)
          G
          G
          gtortone
          @skywatch
          I meaning that often is also useful to check cable two (or three) times !
          but if you already did it... ok !
          • skywatchS
            skywatchS
            skywatch
            Ah, OK then :) - I thought there was something in the console data I posted that meant there was a problem! - Tomorrow to build a sensor and get that going.... Thanks again!
            • michlb1982M
              michlb1982M
              michlb1982
              hi
              yesterday i tried to build a rpi-gateway but i had trouble to access, after changeing the rights on the port to 777 and group to dialout i could access via
              fhem. and i didn't use the symlink, i used the port directly /dev/pts/0@115200 andthen it works perfectly!
              thanks...
              p.s.: i uses always sudo while make and the other installation commands.
              greets mike
              • martinsM
                martinsM
                martins
                Get this error from the gateway installed on Raspberry Pi2 with RFM69 Radio.
                From the IDE it works fine:
                0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSM:RADIO:OK
                0;255;3;0;9;TSM:GW MODE
                0;255;3;0;9;TSM:READY
                0;255;0;0;18;2.0.0
                0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;TSP:MSG:BC
                0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
                0;255;3;0;9;TSP:CHKUPL:OK
                0;255;3;0;9;TSP:MSG:GWL OK
                0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
                0;255;3;0;9;TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                255;255;3;0;3;
                255;255;3;0;3;
                255;255;3;0;3;
                255;255;3;0;3;
                mysgw: Starting gateway...
                mysgw: Protocol version - 2.1.0-beta
                mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0-beta
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: !TSM:INIT:TSP FAIL
                mysgw: TSM:FAIL:CNT=1
                From the gateway on the Pi this is the error:
                ./bin/mysgw -d
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:FAIL:PDT
                mysgw: TSM:FAIL:RE-INIT
                mysgw: TSM:INIT
                mysgw: TSM:FAIL:CNT=2
                mysgw: TSM:FAIL:PDT
                mysgw: TSM:INIT
                mysgw: TSM:FAIL:CNT=3
                mysgw: TSM:FAIL:PDT
                mysgw: TSM:INIT
                mysgw: TSM:FAIL:CNT=4
                mysgw: TSM:FAIL:PDT
                Any ideas where I might start looking at?
                Martin
                • martinsM martins
                  0;255;0;0;18;2.0.0
                  255;255;3;0;3;
                  255;255;3;0;3;
                  255;255;3;0;3;
                  255;255;3;0;3;
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  ./bin/mysgw -d
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: TSM:FAIL:PDT
                  mysgw: TSM:INIT
                  mysgw: TSM:FAIL:PDT
                  mysgw: TSM:INIT
                  mysgw: TSM:FAIL:PDT
                  mysgw: TSM:INIT
                  mysgw: TSM:FAIL:PDT
                  Martin
                  marceloaqno
                  Code Contributor
                  @martins RFM69 is not yet supported in RPi.
                  martinsM 1 Reply Last reply
                  • M marceloaqno
                    martinsM
                    martinsM
                    martins
                    @marceloaqno
                    OK let me explain better. I've build an arduino serial gateway and connecting it on the uart of the pi. If I do tail -f /dev/ttyAMA0 I can see the messages comming in on the serial interface. However if I run ./bin/mysgw -d I get this error:
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: TSM:FAIL:PDT
                    This is the configure I used to build it:
                    ./configure --my-gateway=serial --my-serial-port=/dev/ttyAMA0 --my-serial-baudrate=38400
                    So the RFM69 Radio in not directly on the PI but on the arduino and is used as the serial gateway.
                    Hope this clarify it more.
                    Regards,
                    Martin
                    • martinsM martins
                      @marceloaqno
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:FAIL:PDT
                      Regards,
                      Martin
                      martinsM
                      martinsM
                      martins
                      @marceloaqno
                      Issue solved. Domoticz read directly the serial inputs from the arduino that's connected on the PI. I was under the impression that you need a gateway (software) running on the PI to interface with Domoticz.
                      Martin
                      • E
                        E
                        ewgor
                        Hi there,
                        I'm trying to make a gateway on my pi and since the begining i'm stuck!
                        Using this: git clone https://github.com/mysensors/MySensors.git
                        i get: fatal: unable to access 'https://github.com/mysensors/MySensors.git/': Could not resolve host: github.com
                        I tried with sudo too! am i the only one getting this?
                        • E ewgor
                          Hi there,
                          #165
                          @ewgor "Could not resolve host" means dns is not working on your raspberry pi. Is the network working properly (can you access other web sites from the pi?) http://www.suntimebox.com/raspberry-pi-tutorial-course/week-3/day-5/ seems to have a guide if you need help configuring network settings.
                          Velo17V 1 Reply Last reply
                            Velo17V
                            Velo17V
                            Velo17
                            wrote on last edited by Velo17
                            #166
                            (sorry, I hit reply on mfalkvidd's post)
                            I have a strange problem:
                            I tried to be smart (haha) and updated my Raspberry2 with
                            sudo apt-get update
                            sudo apt-get dist-upgrade
                            This took quite a while and looked successful to me.
                            Unfortunately the MySensors Gateway and/or controller setup is not working correctly anymore. For troubleshooting I disabled my controller (MyController running on the Pi and for sniffing also MYSController available on my Windows machine). I stopped the gateway service and manually ran the gateway with -d debug information and get this:
                            mysGateway: Starting gateway...
                            mysGateway: Protocol version - 2.0.1-beta
                            mysGateway: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
                            mysGateway: TSF:LRT:OK
                            mysGateway: TSM:INIT
                            mysGateway: TSM:INIT:TSP OK
                            mysGateway: TSM:INIT:GW MODE
                            mysGateway: TSM:READY
                            mysGateway: Listening for connections on 0.0.0.0:5003
                            mysGateway: MCO:REG:NOT NEEDED
                            mysGateway: MCO:BGN:STP
                            mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                            mysGateway: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                            mysGateway: TSF:MSG:BC
                            mysGateway: TSF:MSG:FPAR REQ,ID=7
                            mysGateway: TSF:PNG:SEND,TO=0
                            mysGateway: TSF:CKU:OK
                            mysGateway: TSF:MSG:GWL OK
                            mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                            mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                            mysGateway: TSF:MSG:PINGED,ID=7,HP=1
                            mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                            mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                            mysGateway: TSF:MSG:READ,7-7-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                            mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                            mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=11,pt=0,l=17,sg=0:Ernie Giess-O-Mat
                            mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=12,pt=0,l=4,sg=0:0.17
                            mysGateway: TSF:MSG:READ,7-7-0,s=2,c=0,t=6,pt=0,l=0,sg=0:
                            mysGateway: TSF:MSG:READ,7-7-0,s=0,c=0,t=7,pt=0,l=0,sg=0:
                            mysGateway: TSF:MSG:READ,7-7-0,s=3,c=0,t=30,pt=0,l=0,sg=0:
                            mysGateway: TSF:MSG:READ,7-7-0,s=4,c=0,t=21,pt=0,l=0,sg=0:
                            mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                            mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                            mysGateway: TSF:MSG:READ,7-7-0,s=0,c=1,t=1,pt=7,l=5,sg=0:8219.0
                            mysGateway: TSF:MSG:READ,7-7-0,s=2,c=1,t=0,pt=7,l=5,sg=0:29.66
                            mysGateway: TSF:MSG:READ,7-7-0,s=3,c=1,t=38,pt=7,l=5,sg=0:9.0
                            mysGateway: TSF:MSG:READ,7-7-0,s=4,c=1,t=34,pt=1,l=1,sg=0:0
                            mysGateway: TSF:MSG:READ,17-17-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                            mysGateway: TSF:MSG:FPAR REQ,ID=17
                            mysGateway: TSF:MSG:SEND,0-0-17-17,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                            mysGateway: TSF:MSG:READ,17-17-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                            mysGateway: TSF:MSG:PINGED,ID=17,HP=1
                            mysGateway: TSF:MSG:SEND,0-0-17-17,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                            mysGateway: TSF:MSG:READ,7-7-0,s=0,c=1,t=1,pt=7,l=5,sg=0:10834.0
                            mysGateway: TSF:MSG:READ,7-7-0,s=2,c=1,t=0,pt=7,l=5,sg=0:3.96
                            mysGateway: TSF:MSG:READ,17-17-0,s=255,c=3,t=0,pt=1,l=1,sg=0:67
                            mysGateway: TSF:MSG:READ,17-17-0,s=1,c=1,t=0,pt=7,l=5,sg=0:18.8
                            mysGateway: TSM:READY:NWD REQ
                            mysGateway: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                            mysGateway: TSF:SRT:OK
                            Which looks okay to me (2 sensor nodes are sending data here). But after this NWD REQ...STR:OK block nothing more happens, only more of these 3 lines blocks repeat over and over with about 15 minutes or so inbetween.
                            "of course" I also re-compiled the gateway source with re-setting the configuration, which is
                            sudo ./configure --my-rf24-channel=124 --my-rf24-irq-pin=11  --my-debug=enable
                            sudo make install
                            any ideas what I can try to make it work again? :-(
                            In any case, happy weekend to everyone,
                            greetings from Germany!
                            • Velo17V Velo17
                              sudo apt-get update
                              sudo make install
                              marceloaqno
                              Code Contributor
                              wrote on last edited by marceloaqno
                              #167
                              @Velo17 It might be related to the nrf24 irq pin. Could you try to build the gateway without the my-rf24-irq-pin option and check if the gateway still behaves this way?
                              • M marceloaqno
                                Velo17V
                                Velo17V
                                Velo17
                                @marceloaqno Thanks for the hint! This actually solves the lock up. But shouldnt the interrupt offer a superior connectivity and thus be desireable? Until yesterday (before I did the RPi upgrading) this worked - or at least it appeared to work (I dont know if the interrupt was actually used)
                                • Velo17V Velo17
                                  marceloaqno
                                  Code Contributor
                                  @Velo17 I had the same problem in the past but I thought it was because of my nrf24 module wasn't properly shielded or my cables was too long, causing some kind of interference to the irq pin.
                                  I end up disabling the interrupt options until I replace my nrf24 module or rearrange the cables, which I haven't done yet.
                                  Could you give more details on what kind of nrf module you are using and how it is connected to rpi?
                                  • P
                                    P
                                    pettib
                                    Hi everyone.
                                    I´m trying to build a new homeController with the following parts / software.
                                    Raspberry Pi 3
                                    Home Assistant
                                    MySensors
                                    Tellstick
                                    Mosquitto MQTT Broker
                                    I got everything working beside the MySensors. I´m trying to connect the NRF 24L01+ chip directly to the RPI with help from https://www.mysensors.org/build/raspberry.
                                    I want to use MQTT between MySensors and HomeAssistant
                                    The MQTT broker is working when i´m testing it.
                                    The Mosquitto is configurated with username and Password in the config of Mosquitto.
                                    The config i´m using when Make Mysensors is the following:
                                    ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=nrf24 --my-rf24-irq-pin=15
                                    I also changed in the file /examples_linux/mysgw.cpp
                                    #define MY_MQTT_USER "My User"
                                    #define MY_MQTT_PASSWORD "My Password"
                                    When i´m running the command: sudo systemctl status mysgw I got following result.
                                    ● mysgw.service - MySensors Gateway daemon
                                    Loaded: loaded (/etc/systemd/system/mysgw.service; enabled)
                                    Active: active (running) since tis 2016-12-27 18:52:34 CET; 25min ago
                                    Main PID: 1405 (mysgw)
                                    CGroup: /system.slice/mysgw.service
                                    └─1405 /usr/local/bin/mysgw
                                    dec 27 19:18:10 HomeAssistant mysgw[1405]: failed to connect
                                    dec 27 19:18:10 HomeAssistant mysgw[1405]: socket: Too many open files
                                    When trying to run command sudo mysgw -d it shows following info in a endless loop:
                                    mysgw: connected to 127.0.0.1
                                    Please help figure this out.
                                    //PeTi
                                    • Flor SandersF
                                      Flor SandersF
                                      Flor Sanders
                                      wrote on last edited by Flor Sanders
                                      #171
                                      Hello
                                      The past two days I've been trying to setup the gateway on my RPi 2 with domoticz.
                                      Here's what I did.
                                      I installed domoticz onto my raspi, then I tried the install the gateway.
                                      cd MySensors
                                      Afterwards I did the following
                                      make
                                      sudo ./bin/mysgw -d
                                      Then it seems to start normally onto the point where it refuses to connect to anything.
                                      Does anyone have a clue what's going wrong?
                                      I can't seem to figure it out. I've tried it several times over, and always go similar results.
                                      I was using GertSanders's connector for the RPi Hub and I've tried it with normal wiring too.
                                      As far as I can see it shouldn't be a wiring problem...
                                      0_1482936624899_upload-edfa86af-fd0c-4e63-be7b-5393e20f27eb
                                      EDIT:
                                      !UPDATE!
                                      I think I just fixed it. I reconfigured it to include the IRQ Pin and now it's just listening for throughput
                                      pi@raspberrypi:~/MySensors $  sudo ./bin/mysgw -d
                                      mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.1.0-beta
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: TSM:INIT:TSP OK
                                      mysgw: TSM:INIT:GW MODE
                                      mysgw: MCO:REG:NOT NEEDED
                                      mysgw: MCO:BGN:STP
                                      mysgw: MCO:BGN:INIT OK,TSP=1
                                      • Flor SandersF
                                        Flor SandersF
                                        Flor Sanders
                                        I got the previous problem out of the way for now...
                                        Now onto the next one.
                                        I started a node and now I can clearly see data being sent and received on my serial log and ssh. (See picture)
                                        0_1482941358792_upload-08fe5f75-3536-4fb5-a0f4-2ee7d0edbc6a
                                        So I tried adding the gateway to domoticz using following settings:
                                        0_1482941417649_upload-ce92a80a-a5aa-4713-bfe8-227c71b8ce72
                                        Yet if I check hardware setup I can see no nodes being presented.
                                        0_1482941455435_upload-e36e2fbf-ac80-4381-895d-293e6e638ead
                                        Are there settings or steps I missed?
                                        Greetings
                                        Flor
                                        TigroenotT 1 Reply Last reply
                                        • Flor SandersF Flor Sanders
                                          Greetings
                                          Flor
                                          TigroenotT
                                          TigroenotT
                                          Tigroenot
                                          @Flor-Sanders I think you maybe should choose not USB but Ethernet gateway in domoticz.
