  3. Home Assistant
  4. Node 0 unknown, error decoding message from gateway
15 Posts 2 Posters 4.8k Views 2 Watching
  • MaKinM
    MaKinM
    MaKin
    Hey guys,
    I have just set up the gateway (also running a DHT22 sensor on the same arduino) in home-assistent and I keep getting the following errors:
    16-12-16 16:49:38 mysensors.mysensors: Node 0 is unknown
    16-12-16 16:49:38 mysensors.mysensors: Error decoding message from gateway, bad data received: T: 23.00
    My config looks like the following:
    mysensors:
      gateways:
        - device: '/dev/ttyACM0'
    #      persistence_file: 'path/mysensors2.json'
          baud_rate: 115200
      debug: true
      optimistic: false
      persistence: true
      retain: true
      version: 2.0
    As you can see above, the values are received which is great. :)
    Any idea how to solve that?
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      There's a bug in mysensors 2.0 where a gateway without radio doesn't present itself. This has been fixed in the mysensors dev branch. See this issue for more info and a workaround:
      https://github.com/theolind/pymysensors/issues/51
      • MaKinM
        MaKinM
        MaKin
        • MaKinM
          MaKinM
          MaKin
          wrote on last edited by MaKin
          Now it's not about the node 0 but the children.
          16-12-17 11:39:31 mysensors.mysensors: Child 1 is unknown
          16-12-17 11:39:31 mysensors.mysensors: Error decoding message from gateway, bad data received: T: 22.50
          16-12-17 11:39:31 mysensors.mysensors: Child 0 is unknown
          16-12-17 11:39:31 mysensors.mysensors: Error decoding message from gateway, bad data received: H: 40.20
          The serial monitor shows me the following:
          0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0)
          0;255;0;0;18;2.0.0
          0;1;1;0;0;23.2
          T: 23.20
          0;0;1;0;1;44.5
          H: 44.50
          0;0;1;0;1;44.4
          Is anything wrong with my sketch? I hacked it together...
          // Enable debug prints
          //#define MY_RADIO_NRF24
          //#define MY_RS485
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Flash leds on rx/tx/err
          // Set blinking period
          // Enable inclusion mode
          #define MY_DEFAULT_RX_LED_PIN  11  // Receive led pin
          #define DHT_DATA_PIN 3
          #define SENSOR_TEMP_OFFSET 0
          static const uint64_t UPDATE_INTERVAL = 2500;
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          float lastTemp;
          float lastHum;
          uint8_t nNoUpdatesTemp;
          uint8_t nNoUpdatesHum;
          bool metric = true;
          DHT dht;
            sendSketchInfo("TemperatureAndHumidity", "1.1");
            present(CHILD_ID_HUM, S_HUM);
            present(255, 18);
            dht.readSensor(true);
            if (isnan(temperature)) {
              lastTemp = temperature;
              if (!metric) {
              // Reset no updates counter
              nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
              Serial.print("T: ");
              nNoUpdatesTemp++;
            if (isnan(humidity)) {
              lastHum = humidity;
              nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
              Serial.print("H: ");
              Serial.println(humidity);
              nNoUpdatesHum++;
            sleep(UPDATE_INTERVAL);
          • martinhjelmareM
            martinhjelmareM
            martinhjelmare
            Looks like presentation function is never called. Try calling it yourself from setup.
            • MaKinM
              MaKinM
              MaKin
              How would you do that? You can see my sketch above.
              • martinhjelmareM
                martinhjelmareM
                martinhjelmare
                Put this after the gateway present call in setup:
                presentation();
                Also replace all sleep with wait. The gateway is not allowed to sleep.
                MaKinM 1 Reply Last reply
                  presentation();
                  MaKinM
                  MaKinM
                  MaKin
                  @martinhjelmare said:
                  presentation();
                  I'll try that. Thanks. :)
                  Now this error remains:
                  16-12-17 21:58:00 mysensors.mysensors: Error decoding message from gateway, bad data received: T: 23.90
                  16-12-17 21:58:00 mysensors.mysensors: Error decoding message from gateway, bad data received: H: 49.30
                  16-12-17 21:58:02 mysensors.mysensors: Error decoding message from gateway, bad data received: T: 24.00
                  16-12-17 21:58:14 mysensors.mysensors: Error decoding message from gateway, bad data received: T: 23.90
                  But the sensors are listed in HASS:
                  sensor.temperatureandhumidity_0_0:
                  friendly_name: TemperatureAndHumidity 0 0
                  V_HUM: 49.2
                  node_id: 0
                  device: /dev/ttyACM0
                  battery_level: 0
                  description:
                  child_id: 0
                  unit_of_measurement: %
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    That's because you are printing debug to serial from the gateway and the controller doesn't expect serial messages from the gateway other than mysensors API messages. Either ignore the errors or remove those debug prints.
                      MaKinM
                      MaKinM
                      MaKin
                      @martinhjelmare thank you so much for your help. :)
                      Is there a way to declare sensor names so that HA receives a presentation with something like
                      mysensors.livingroom.temp
                      Instead of a more cryptic name with node_id?
                      • martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        The entity_id always has the same structure, sketchname_nodeid_childid. You can customize the friendly_name in the config under customize to change what is shown in the gui as name of the sensor.
                        • MaKinM
                          MaKinM
                          MaKin
                          But my Sketch name is SerialGateWayDHT22 and my sensors are called sensor.temperatureandhumidity_0_0 and sensor.temperatureandhumidity_0_1. If it was the Sketchname, it was much simpler to assign the sensors to the rooms later as I could simply name the switch after the room.
                          But it's not much of a problem, as like you said friendly names can be used.
                          • martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            By sketchname I mean what you send to the controller as sketchname using sendSketchInfo method. This is from your sketch:
                            • MaKinM
                              MaKinM
                              MaKin
                              Just saw that myself. Thanks once again. I'm starting to feel embarrassed... :)
                              • martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                Happy to help and great to hear about user stories and also any feedback, both when things are working and when things are not working or missing features.
