  2. Feature Requests
  3. Option non blocking registration at gateway
Scheduled Pinned Locked Moved Feature Requests
26 Posts 10 Posters 11.5k Views 8 Watching
  • D DavidZH
    @Heizelmann
    I've been thinking about his as well. Probably for different reasons though.
    I find myself with time to spare and my laptop at hand quite often, but I'm not home at those moments. I'd love to be able to write code and test sensors at those times, but that's impossible because there's no gateway.
    For that I'd like to propose a "Test Mode".
    • test port to Transport.
    • NO connection to gateway.
    • simulate the Transport calls in the sketch with just a line in the debug with ACK.
    • when possible: send "messages" to node with the Arduino serial monitor.
    I am aware that this might pose some biiiiiiig changes in the lib. So this might be something for the 2.5 or 3.0 release.
    Thoughts?
    H
    H
    Heizelmann
    I am now ready with my node and I need the non-blocking feature urgently. Is there an estimation when this feature will be come or can anyone provide a workaround?
      If you use the development branch and want to prohibit the registration wait. Add
      #define MY_TRANSPORT_WAIT_READY_MS 1
      @tekka, correct me if I'm wrong please ;)
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @hek correct :+1:
        @Heizelmann Would be good to get some feedback on this feature, please let us know how it works in your hands.
        H eric_smidE 2 Replies Last reply
        • tekkaT tekka
          @hek correct :+1:
          H
          H
          Heizelmann
          Here my report after a quick test.
          To say it short: Generally I am happy with it, it works very well. Only one small problem.
          In detail:
          When connection is initially off, the sketch entered after the defined wait the loop.
          before()
          5 TSM:INIT
          7 TSF:WUR:MS=1000
          13 !TSM:INIT:TSP FAIL
          15 TSM:FAIL:CNT=1
          17 TSM:FAIL:PDT
          1008 MCO:BGN:STP
          Setup()
          1510 MCO:BGN:INIT OK,TSP=0
          If the sketch tries to send within the loop a message is logged.
          145312 !MCO:SND:NODE NOT REG
          If connection comes back the sketch connects to the gateway on the fly within the defined wait time.
          244251 TSM:FPAR:OK
          244252 TSM:ID
          244254 TSM:ID:OK
          244255 TSM:UPL
          244259 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          244265 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          244271 TSF:MSG:PONG RECV,HP=1
          244274 TSM:UPL:OK
          244276 TSM:READY:ID=42,PAR=0,DIS=1
          244281 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          244288 TSF:MSG:READ,0-0-42,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          244295 TSF:MSG:SEND,42-42-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.1.0-beta
          244304 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
          244321 TSF:MSG:READ,0-0-42,s=255,c=3,t=6,pt=0,l=1,sg=0:M
          Presentation()
          244329 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:My Node
          244339 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
          244347 TSF:MSG:SEND,42-42-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
          244356 TSF:MSG:SEND,42-42-0-0,s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
          244364 TSF:MSG:SEND,42-42-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          244370 MCO:REG:REQ
          244373 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          244380 TSF:MSG:READ,0-0-42,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          244385 MCO:PIM:NODE REG=1
          Only problem is that you get high logging traffic in the case when you are in loop and network connection gets lost again as long as the connection is lost.
          605458 TSF:MSG:READ,1-1-1,s=1,c=1,t=1,pt=0,l=0,sg=0:
          605463 !TSF:MSG:LEN,0!=7
          605465 TSF:MSG:READ,1-1-1,s=1,c=1,t=1,pt=0,l=0,sg=0:
          605470 !TSF:MSG:LEN,0!=7
          605472 TSF:MSG:READ,1-1-1,s=1,c=1,t=1,pt=0,l=0,sg=0:
          605477 !TSF:MSG:LEN,0!=7
          • H Heizelmann
            In detail:
            before()
            5 TSM:INIT
            7 TSF:WUR:MS=1000
            15 TSM:FAIL:CNT=1
            17 TSM:FAIL:PDT
            1008 MCO:BGN:STP
            Setup()
            244251 TSM:FPAR:OK
            244252 TSM:ID
            244254 TSM:ID:OK
            244255 TSM:UPL
            244274 TSM:UPL:OK
            Presentation()
            244370 MCO:REG:REQ
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            @Heizelmann Thanks for your testing. I couldn't reproduce this behavior, can you post your sketch for further analysis?
            H 1 Reply Last reply
            • tekkaT tekka
              H
              H
              Heizelmann
              wrote on last edited by Heizelmann
              #21
              @tekka May be it is the kind of my testing. For getting quick results I simply plug and un-plug the radio module (NRF24L01+) from the socket in my sensor node. I know, this is not a real use case but it was easy and I didn't thought there is adifference in behaviour. How do you you switch off and on the network connection in your test?
              • H Heizelmann
                tekkaT
                tekkaT
                tekka
                @Heizelmann yes, unplugging the radio results in what you observed. Simply unplug the GW (and repeaters)...
                • tekkaT tekka
                  H
                  H
                  Heizelmann
                  #23
                  @tekka OK unplugging the GW leads to a different behaviour.
                  First the node didn't detect the failure as long it is not trying to send.
                  When it tries to send it fails
                  131268 !TSF:MSG:SEND,42-42-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=NACK:1
                  and after some more failure this
                  238494 !TSM:READY:UPL FAIL,SNP
                  238497 TSM:FPAR
                  238534 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=6,st=OK:
                  238995 !TSF:SND:TNR
                  240002 !TSF:SND:TNR
                  240542 !TSM:FPAR:NO REPLY
                  240544 TSM:FPAR
                  240581 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  246683 !TSM:FPAR:FAIL
                  246685 TSM:FAIL:CNT=1
                  246687 TSM:FAIL:PDT
                  and after a while mostly only
                  609748 !TSF:SND:TNR
                  When gateway comes back a proper reinitialization takes place:
                  620572 TSM:FAIL:RE-INIT
                  620574 TSM:INIT
                  620581 TSM:INIT:TSP OK
                  620583 TSM:INIT:STATID=42
                  620587 TSF:SID:OK,ID=42
                  620589 TSM:FPAR
                  620625 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  Current: 0.00
                  0:0:0
                  Current: 0.00
                  0:0:0
                  621443 TSF:MSG:READ,0-0-42,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  621448 TSF:MSG:FPAR OK,ID=0,D=1
                  Current: 0.00
                  0:0:0
                  Current: 0.00
                  0:0:0
                  622633 TSM:FPAR:OK
                  622635 TSM:ID
                  622637 TSM:ID:OK
                  622638 TSM:UPL
                  622642 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  622652 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  622657 TSF:MSG:PONG RECV,HP=1
                  622660 TSM:UPL:OK
                  622662 TSM:READY:ID=42,PAR=0,DIS=1
                  From now the sensor can send again without errors. :smiley:
                  So far my tests.
                  Except the case where the radio of the sensor went off and causes a lot of logging all test cases where satisfactorily.
                  I think this is really an edge case and not so serious.
                  From this point of view I would welcome that this beta development version will be published.
                  • tekkaT tekka
                    @hek correct :+1:
                    eric_smidE
                    eric_smidE
                    eric_smid
                    I tested my node with the "#define MY_TRANSPORT_WAIT_READY_MS 1" feature.
                    It seems to work fine!
                    Tnx for the work.
                    • H
                      H
                      Heizelmann
                      I detected another problem. From debug log it looks like the loop() function starts before initialization is finished. This can cause problems when trying to send data in loop() very early.
                      Here a log example:
                      0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
                      4 MCO:BGN:BFR
                      5 before() begin
                      5 before() end
                      5 TSM:INIT
                      9 TSF:WUR:MS=1000
                      16 TSM:INIT:TSP OK
                      17 TSM:INIT:STATID=42
                      20 TSF:SID:OK,ID=42
                      21 TSM:FPAR
                      58 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      651 TSF:MSG:READ,0-0-42,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      656 TSF:MSG:FPAR OK,ID=0,D=1
                      1010 MCO:BGN:STP
                      1011 Setup() begin
                      1512 Setup() end
                      1512 MCO:BGN:INIT OK,TSP=0
                      1516 loop() begin
                      2017 loop() end
                      2017 loop() begin
                      2065 TSM:FPAR:OK
                      2066 TSM:ID
                      2067 TSM:ID:OK
                      2069 TSM:UPL
                      2072 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      2078 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      2083 TSF:MSG:PONG RECV,HP=1
                      2086 TSM:UPL:OK
                      2087 TSM:READY:ID=42,PAR=0,DIS=1
                      2093 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      2100 TSF:MSG:READ,0-0-42,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      2107 TSF:MSG:SEND,42-42-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.1.0-beta
                      2116 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      2126 TSF:MSG:READ,0-0-42,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      2131 Presentation() begin
                      2135 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:Sink Pump Control Node
                      2145 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                      2153 TSF:MSG:SEND,42-42-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                      2161 TSF:MSG:SEND,42-42-0-0,s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                      2168 TSF:MSG:SEND,42-42-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      2174 Presentation() end
                      2176 MCO:REG:REQ
                      2181 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      2187 TSF:MSG:READ,0-0-42,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      2192 MCO:PIM:NODE REG=1
                      2518 loop() end
                      2518 loop() begin
                      • H Heizelmann
                        Here a log example:
                        4 MCO:BGN:BFR
                        5 before() begin
                        5 before() end
                        5 TSM:INIT
                        9 TSF:WUR:MS=1000
                        16 TSM:INIT:TSP OK
                        20 TSF:SID:OK,ID=42
                        21 TSM:FPAR
                        1010 MCO:BGN:STP
                        1011 Setup() begin
                        1512 Setup() end
                        1516 loop() begin
                        2017 loop() end
                        2017 loop() begin
                        2065 TSM:FPAR:OK
                        2066 TSM:ID
                        2067 TSM:ID:OK
                        2069 TSM:UPL
                        2086 TSM:UPL:OK
                        2176 MCO:REG:REQ
                        2518 loop() end
                        2518 loop() begin
                        tekkaT
                        tekkaT
                        tekka
                        @Heizelmann I'm not sure I understood your concern.
                        Initialization is finished here, right before the main loop is entered:
                        Since your timeout is set to 1sec (which obviously is too short to fully establish the transport link) the node will enter the main loop() after the timeout. However, since the link is not established, only init messages are sent at that point (i.e. library init, signing preferences, presentation). Sensor data will not be sent until the node is registered.
                        12.5k
