  2. Feature Requests
  3. Option non blocking registration at gateway
Scheduled Pinned Locked Moved Feature Requests
26 Posts 10 Posters 11.4k Views 8 Watching
    It's only during startup the node does a handshake with the parent node (which can be disabled using MY_TRANSPORT_DONT_CARE_MODE in dev branch). During normal operation the library never block even if communication link is down.
    tekkaT
    tekkaT
    tekka
    Important: enabling MY_TRANSPORT_DONT_CARE_MODE requires setting MY_PARENT_NODE_ID
    • eric_smidE
      eric_smidE
      eric_smid
      Great this option is available!
      Is it possible to let the node use the last used parent, instead of configuring the parent?
      tekkaT 1 Reply Last reply
      • eric_smidE eric_smid
        tekkaT
        tekkaT
        tekka
        @eric_smid No, not in the current implementation
          TheoLT
          TheoLT
          TheoL
          @hek Just curious. How important is the handshake? Because if it's important I think it would be a good option, to let node's do a delayed hand shake when the initial one fails. So that they can continue, but just won't use the my sensors part until a delayed handshake is done.
          A delayed hand shake would only be needed when there's a power cut.
          H 1 Reply Last reply
          • TheoLT TheoL
            H
            H
            Heizelmann
            Coming from this thread, where I learned that an implementation of this feature is in progress.
            In my opinion it is an essential architectural feature. Reasons for this you can see above.
            Here I summarize what I think is necessary:
            General requirements
            • Devices should work independently from the gateway
            • Enter loop() even if gateway is not reachable
            • Buffering of messages not necessary. Its up to the user to implement this.
            Needed functionality
            • retrieve available gateways (gets a list of available gateways)
            • request to register ( gets success or failure with reason)
            • de-register ( gets success or failure with reason)
            D 1 Reply Last reply
            • H Heizelmann
              DavidZH
              @Heizelmann
              I've been thinking about his as well. Probably for different reasons though.
              I find myself with time to spare and my laptop at hand quite often, but I'm not home at those moments. I'd love to be able to write code and test sensors at those times, but that's impossible because there's no gateway.
              For that I'd like to propose a "Test Mode".
              • test port to Transport.
              • NO connection to gateway.
              • simulate the Transport calls in the sketch with just a line in the debug with ACK.
              • when possible: send "messages" to node with the Arduino serial monitor.
              I am aware that this might pose some biiiiiiig changes in the lib. So this might be something for the 2.5 or 3.0 release.
              Thoughts?
              • D DavidZH
                @Heizelmann
                Thoughts?
                H
                H
                Heizelmann
                I am now ready with my node and I need the non-blocking feature urgently. Is there an estimation when this feature will be come or can anyone provide a workaround?
                  If you use the development branch and want to prohibit the registration wait. Add
                  #define MY_TRANSPORT_WAIT_READY_MS 1
                  @tekka, correct me if I'm wrong please ;)
                    tekkaT
                    tekkaT
                    tekka
                    @hek correct :+1:
                    @Heizelmann Would be good to get some feedback on this feature, please let us know how it works in your hands.
                    H eric_smidE 2 Replies Last reply
                    • tekkaT tekka
                      @hek correct :+1:
                      H
                      H
                      Heizelmann
                      Here my report after a quick test.
                      To say it short: Generally I am happy with it, it works very well. Only one small problem.
                      In detail:
                      When connection is initially off, the sketch entered after the defined wait the loop.
                      before()
                      5 TSM:INIT
                      7 TSF:WUR:MS=1000
                      13 !TSM:INIT:TSP FAIL
                      15 TSM:FAIL:CNT=1
                      17 TSM:FAIL:PDT
                      1008 MCO:BGN:STP
                      Setup()
                      1510 MCO:BGN:INIT OK,TSP=0
                      If the sketch tries to send within the loop a message is logged.
                      145312 !MCO:SND:NODE NOT REG
                      If connection comes back the sketch connects to the gateway on the fly within the defined wait time.
                      244251 TSM:FPAR:OK
                      244252 TSM:ID
                      244254 TSM:ID:OK
                      244255 TSM:UPL
                      244259 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      244265 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      244271 TSF:MSG:PONG RECV,HP=1
                      244274 TSM:UPL:OK
                      244276 TSM:READY:ID=42,PAR=0,DIS=1
                      244281 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      244288 TSF:MSG:READ,0-0-42,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      244295 TSF:MSG:SEND,42-42-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.1.0-beta
                      244304 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      244321 TSF:MSG:READ,0-0-42,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      Presentation()
                      244329 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:My Node
                      244339 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                      244347 TSF:MSG:SEND,42-42-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                      244356 TSF:MSG:SEND,42-42-0-0,s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                      244364 TSF:MSG:SEND,42-42-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      244370 MCO:REG:REQ
                      244373 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      244380 TSF:MSG:READ,0-0-42,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      244385 MCO:PIM:NODE REG=1
                      Only problem is that you get high logging traffic in the case when you are in loop and network connection gets lost again as long as the connection is lost.
                      605458 TSF:MSG:READ,1-1-1,s=1,c=1,t=1,pt=0,l=0,sg=0:
                      605463 !TSF:MSG:LEN,0!=7
                      605465 TSF:MSG:READ,1-1-1,s=1,c=1,t=1,pt=0,l=0,sg=0:
                      605470 !TSF:MSG:LEN,0!=7
                      605472 TSF:MSG:READ,1-1-1,s=1,c=1,t=1,pt=0,l=0,sg=0:
                      605477 !TSF:MSG:LEN,0!=7
                      • H Heizelmann
                        In detail:
                        before()
                        5 TSM:INIT
                        7 TSF:WUR:MS=1000
                        15 TSM:FAIL:CNT=1
                        17 TSM:FAIL:PDT
                        1008 MCO:BGN:STP
                        Setup()
                        244251 TSM:FPAR:OK
                        244252 TSM:ID
                        244254 TSM:ID:OK
                        244255 TSM:UPL
                        244274 TSM:UPL:OK
                        Presentation()
                        244370 MCO:REG:REQ
                        tekkaT
                        tekkaT
                        tekka
                        wrote on last edited by tekka
                        @Heizelmann Thanks for your testing. I couldn't reproduce this behavior, can you post your sketch for further analysis?
                        • tekkaT tekka
                          H
                          H
                          Heizelmann
                          wrote on last edited by Heizelmann
                          #21
                          @tekka May be it is the kind of my testing. For getting quick results I simply plug and un-plug the radio module (NRF24L01+) from the socket in my sensor node. I know, this is not a real use case but it was easy and I didn't thought there is adifference in behaviour. How do you you switch off and on the network connection in your test?
                          • H Heizelmann
                            tekkaT
                            tekkaT
                            tekka
                            @Heizelmann yes, unplugging the radio results in what you observed. Simply unplug the GW (and repeaters)...
                            • tekkaT tekka
                              H
                              H
                              Heizelmann
                              #23
                              @tekka OK unplugging the GW leads to a different behaviour.
                              First the node didn't detect the failure as long it is not trying to send.
                              When it tries to send it fails
                              131268 !TSF:MSG:SEND,42-42-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=NACK:1
                              and after some more failure this
                              238494 !TSM:READY:UPL FAIL,SNP
                              238497 TSM:FPAR
                              238534 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=6,st=OK:
                              238995 !TSF:SND:TNR
                              240002 !TSF:SND:TNR
                              240542 !TSM:FPAR:NO REPLY
                              240544 TSM:FPAR
                              240581 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              246683 !TSM:FPAR:FAIL
                              246685 TSM:FAIL:CNT=1
                              246687 TSM:FAIL:PDT
                              and after a while mostly only
                              609748 !TSF:SND:TNR
                              When gateway comes back a proper reinitialization takes place:
                              620572 TSM:FAIL:RE-INIT
                              620574 TSM:INIT
                              620581 TSM:INIT:TSP OK
                              620583 TSM:INIT:STATID=42
                              620587 TSF:SID:OK,ID=42
                              620589 TSM:FPAR
                              620625 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              Current: 0.00
                              0:0:0
                              Current: 0.00
                              0:0:0
                              621443 TSF:MSG:READ,0-0-42,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                              621448 TSF:MSG:FPAR OK,ID=0,D=1
                              Current: 0.00
                              0:0:0
                              Current: 0.00
                              0:0:0
                              622633 TSM:FPAR:OK
                              622635 TSM:ID
                              622637 TSM:ID:OK
                              622638 TSM:UPL
                              622642 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                              622652 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                              622657 TSF:MSG:PONG RECV,HP=1
                              622660 TSM:UPL:OK
                              622662 TSM:READY:ID=42,PAR=0,DIS=1
                              From now the sensor can send again without errors. :smiley:
                              So far my tests.
                              Except the case where the radio of the sensor went off and causes a lot of logging all test cases where satisfactorily.
                              I think this is really an edge case and not so serious.
                              From this point of view I would welcome that this beta development version will be published.
                              • tekkaT tekka
                                @hek correct :+1:
                                eric_smidE
                                eric_smidE
                                eric_smid
                                I tested my node with the "#define MY_TRANSPORT_WAIT_READY_MS 1" feature.
                                It seems to work fine!
                                Tnx for the work.
                                • H
                                  H
                                  Heizelmann
                                  I detected another problem. From debug log it looks like the loop() function starts before initialization is finished. This can cause problems when trying to send data in loop() very early.
                                  Here a log example:
                                  0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
                                  4 MCO:BGN:BFR
                                  5 before() begin
                                  5 before() end
                                  5 TSM:INIT
                                  9 TSF:WUR:MS=1000
                                  16 TSM:INIT:TSP OK
                                  17 TSM:INIT:STATID=42
                                  20 TSF:SID:OK,ID=42
                                  21 TSM:FPAR
                                  58 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  651 TSF:MSG:READ,0-0-42,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  656 TSF:MSG:FPAR OK,ID=0,D=1
                                  1010 MCO:BGN:STP
                                  1011 Setup() begin
                                  1512 Setup() end
                                  1512 MCO:BGN:INIT OK,TSP=0
                                  1516 loop() begin
                                  2017 loop() end
                                  2017 loop() begin
                                  2065 TSM:FPAR:OK
                                  2066 TSM:ID
                                  2067 TSM:ID:OK
                                  2069 TSM:UPL
                                  2072 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  2078 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  2083 TSF:MSG:PONG RECV,HP=1
                                  2086 TSM:UPL:OK
                                  2087 TSM:READY:ID=42,PAR=0,DIS=1
                                  2093 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  2100 TSF:MSG:READ,0-0-42,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  2107 TSF:MSG:SEND,42-42-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.1.0-beta
                                  2116 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  2126 TSF:MSG:READ,0-0-42,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                  2131 Presentation() begin
                                  2135 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:Sink Pump Control Node
                                  2145 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                                  2153 TSF:MSG:SEND,42-42-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2161 TSF:MSG:SEND,42-42-0-0,s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2168 TSF:MSG:SEND,42-42-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2174 Presentation() end
                                  2176 MCO:REG:REQ
                                  2181 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                  2187 TSF:MSG:READ,0-0-42,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  2192 MCO:PIM:NODE REG=1
                                  2518 loop() end
                                  2518 loop() begin
                                  • H Heizelmann
                                    Here a log example:
                                    4 MCO:BGN:BFR
                                    5 before() begin
                                    5 before() end
                                    5 TSM:INIT
                                    9 TSF:WUR:MS=1000
                                    16 TSM:INIT:TSP OK
                                    20 TSF:SID:OK,ID=42
                                    21 TSM:FPAR
                                    1010 MCO:BGN:STP
                                    1011 Setup() begin
                                    1512 Setup() end
                                    1516 loop() begin
                                    2017 loop() end
                                    2017 loop() begin
                                    2065 TSM:FPAR:OK
                                    2066 TSM:ID
                                    2067 TSM:ID:OK
                                    2069 TSM:UPL
                                    2086 TSM:UPL:OK
                                    2176 MCO:REG:REQ
                                    2518 loop() end
                                    2518 loop() begin
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Heizelmann I'm not sure I understood your concern.
                                    Initialization is finished here, right before the main loop is entered:
                                    Since your timeout is set to 1sec (which obviously is too short to fully establish the transport link) the node will enter the main loop() after the timeout. However, since the link is not established, only init messages are sent at that point (i.e. library init, signing preferences, presentation). Sensor data will not be sent until the node is registered.
