  2. Feature Requests
  3. Option non blocking registration at gateway
Scheduled Pinned Locked Moved Feature Requests
26 Posts 10 Posters 11.4k Views 8 Watching
  • eric_smidE
    eric_smidE
    eric_smid
    Great this option is available!
    Is it possible to let the node use the last used parent, instead of configuring the parent?
    tekkaT 1 Reply Last reply
    • eric_smidE eric_smid
      tekkaT
      tekkaT
      tekka
      @eric_smid No, not in the current implementation
        It's only during startup the node does a handshake with the parent node (which can be disabled using MY_TRANSPORT_DONT_CARE_MODE in dev branch). During normal operation the library never block even if communication link is down.
        TheoLT
        TheoLT
        TheoL
        @hek Just curious. How important is the handshake? Because if it's important I think it would be a good option, to let node's do a delayed hand shake when the initial one fails. So that they can continue, but just won't use the my sensors part until a delayed handshake is done.
        A delayed hand shake would only be needed when there's a power cut.
        H 1 Reply Last reply
        • TheoLT TheoL
          H
          H
          Heizelmann
          Coming from this thread, where I learned that an implementation of this feature is in progress.
          In my opinion it is an essential architectural feature. Reasons for this you can see above.
          Here I summarize what I think is necessary:
          General requirements
          • Devices should work independently from the gateway
          • Enter loop() even if gateway is not reachable
          • Buffering of messages not necessary. Its up to the user to implement this.
          Needed functionality
          • retrieve available gateways (gets a list of available gateways)
          • request to register ( gets success or failure with reason)
          • de-register ( gets success or failure with reason)
          D 1 Reply Last reply
          • H Heizelmann
            DavidZH
            @Heizelmann
            I've been thinking about his as well. Probably for different reasons though.
            I find myself with time to spare and my laptop at hand quite often, but I'm not home at those moments. I'd love to be able to write code and test sensors at those times, but that's impossible because there's no gateway.
            For that I'd like to propose a "Test Mode".
            • test port to Transport.
            • NO connection to gateway.
            • simulate the Transport calls in the sketch with just a line in the debug with ACK.
            • when possible: send "messages" to node with the Arduino serial monitor.
            I am aware that this might pose some biiiiiiig changes in the lib. So this might be something for the 2.5 or 3.0 release.
            Thoughts?
            • D DavidZH
              @Heizelmann
              Thoughts?
              H
              H
              Heizelmann
              I am now ready with my node and I need the non-blocking feature urgently. Is there an estimation when this feature will be come or can anyone provide a workaround?
                If you use the development branch and want to prohibit the registration wait. Add
                #define MY_TRANSPORT_WAIT_READY_MS 1
                @tekka, correct me if I'm wrong please ;)
                  tekkaT
                  tekkaT
                  tekka
                  @hek correct :+1:
                  @Heizelmann Would be good to get some feedback on this feature, please let us know how it works in your hands.
                  H eric_smidE 2 Replies Last reply
                  • tekkaT tekka
                    @hek correct :+1:
                    H
                    H
                    Heizelmann
                    Here my report after a quick test.
                    To say it short: Generally I am happy with it, it works very well. Only one small problem.
                    In detail:
                    When connection is initially off, the sketch entered after the defined wait the loop.
                    before()
                    5 TSM:INIT
                    7 TSF:WUR:MS=1000
                    13 !TSM:INIT:TSP FAIL
                    15 TSM:FAIL:CNT=1
                    17 TSM:FAIL:PDT
                    1008 MCO:BGN:STP
                    Setup()
                    1510 MCO:BGN:INIT OK,TSP=0
                    If the sketch tries to send within the loop a message is logged.
                    145312 !MCO:SND:NODE NOT REG
                    If connection comes back the sketch connects to the gateway on the fly within the defined wait time.
                    244251 TSM:FPAR:OK
                    244252 TSM:ID
                    244254 TSM:ID:OK
                    244255 TSM:UPL
                    244259 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    244265 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    244271 TSF:MSG:PONG RECV,HP=1
                    244274 TSM:UPL:OK
                    244276 TSM:READY:ID=42,PAR=0,DIS=1
                    244281 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    244288 TSF:MSG:READ,0-0-42,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    244295 TSF:MSG:SEND,42-42-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.1.0-beta
                    244304 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    244321 TSF:MSG:READ,0-0-42,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    Presentation()
                    244329 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:My Node
                    244339 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                    244347 TSF:MSG:SEND,42-42-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                    244356 TSF:MSG:SEND,42-42-0-0,s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                    244364 TSF:MSG:SEND,42-42-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    244370 MCO:REG:REQ
                    244373 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    244380 TSF:MSG:READ,0-0-42,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    244385 MCO:PIM:NODE REG=1
                    Only problem is that you get high logging traffic in the case when you are in loop and network connection gets lost again as long as the connection is lost.
                    605458 TSF:MSG:READ,1-1-1,s=1,c=1,t=1,pt=0,l=0,sg=0:
                    605463 !TSF:MSG:LEN,0!=7
                    605465 TSF:MSG:READ,1-1-1,s=1,c=1,t=1,pt=0,l=0,sg=0:
                    605470 !TSF:MSG:LEN,0!=7
                    605472 TSF:MSG:READ,1-1-1,s=1,c=1,t=1,pt=0,l=0,sg=0:
                    605477 !TSF:MSG:LEN,0!=7
                    • H Heizelmann
                      In detail:
                      before()
                      5 TSM:INIT
                      7 TSF:WUR:MS=1000
                      15 TSM:FAIL:CNT=1
                      17 TSM:FAIL:PDT
                      1008 MCO:BGN:STP
                      Setup()
                      244251 TSM:FPAR:OK
                      244252 TSM:ID
                      244254 TSM:ID:OK
                      244255 TSM:UPL
                      244274 TSM:UPL:OK
                      Presentation()
                      244370 MCO:REG:REQ
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      @Heizelmann Thanks for your testing. I couldn't reproduce this behavior, can you post your sketch for further analysis?
                      • tekkaT tekka
                        H
                        H
                        Heizelmann
                        wrote on last edited by Heizelmann
                        #21
                        @tekka May be it is the kind of my testing. For getting quick results I simply plug and un-plug the radio module (NRF24L01+) from the socket in my sensor node. I know, this is not a real use case but it was easy and I didn't thought there is adifference in behaviour. How do you you switch off and on the network connection in your test?
                        • H Heizelmann
                          tekkaT
                          tekkaT
                          tekka
                          @Heizelmann yes, unplugging the radio results in what you observed. Simply unplug the GW (and repeaters)...
                          • tekkaT tekka
                            H
                            H
                            Heizelmann
                            #23
                            @tekka OK unplugging the GW leads to a different behaviour.
                            First the node didn't detect the failure as long it is not trying to send.
                            When it tries to send it fails
                            131268 !TSF:MSG:SEND,42-42-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=NACK:1
                            and after some more failure this
                            238494 !TSM:READY:UPL FAIL,SNP
                            238497 TSM:FPAR
                            238534 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=6,st=OK:
                            238995 !TSF:SND:TNR
                            240002 !TSF:SND:TNR
                            240542 !TSM:FPAR:NO REPLY
                            240544 TSM:FPAR
                            240581 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            246683 !TSM:FPAR:FAIL
                            246685 TSM:FAIL:CNT=1
                            246687 TSM:FAIL:PDT
                            and after a while mostly only
                            609748 !TSF:SND:TNR
                            When gateway comes back a proper reinitialization takes place:
                            620572 TSM:FAIL:RE-INIT
                            620574 TSM:INIT
                            620581 TSM:INIT:TSP OK
                            620583 TSM:INIT:STATID=42
                            620587 TSF:SID:OK,ID=42
                            620589 TSM:FPAR
                            620625 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            Current: 0.00
                            0:0:0
                            Current: 0.00
                            0:0:0
                            621443 TSF:MSG:READ,0-0-42,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                            621448 TSF:MSG:FPAR OK,ID=0,D=1
                            Current: 0.00
                            0:0:0
                            Current: 0.00
                            0:0:0
                            622633 TSM:FPAR:OK
                            622635 TSM:ID
                            622637 TSM:ID:OK
                            622638 TSM:UPL
                            622642 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                            622652 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                            622657 TSF:MSG:PONG RECV,HP=1
                            622660 TSM:UPL:OK
                            622662 TSM:READY:ID=42,PAR=0,DIS=1
                            From now the sensor can send again without errors. :smiley:
                            So far my tests.
                            Except the case where the radio of the sensor went off and causes a lot of logging all test cases where satisfactorily.
                            I think this is really an edge case and not so serious.
                            From this point of view I would welcome that this beta development version will be published.
                            • tekkaT tekka
                              @hek correct :+1:
                              eric_smidE
                              eric_smidE
                              eric_smid
                              I tested my node with the "#define MY_TRANSPORT_WAIT_READY_MS 1" feature.
                              It seems to work fine!
                              Tnx for the work.
                              • H
                                H
                                Heizelmann
                                I detected another problem. From debug log it looks like the loop() function starts before initialization is finished. This can cause problems when trying to send data in loop() very early.
                                Here a log example:
                                0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
                                4 MCO:BGN:BFR
                                5 before() begin
                                5 before() end
                                5 TSM:INIT
                                9 TSF:WUR:MS=1000
                                16 TSM:INIT:TSP OK
                                17 TSM:INIT:STATID=42
                                20 TSF:SID:OK,ID=42
                                21 TSM:FPAR
                                58 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                651 TSF:MSG:READ,0-0-42,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                656 TSF:MSG:FPAR OK,ID=0,D=1
                                1010 MCO:BGN:STP
                                1011 Setup() begin
                                1512 Setup() end
                                1512 MCO:BGN:INIT OK,TSP=0
                                1516 loop() begin
                                2017 loop() end
                                2017 loop() begin
                                2065 TSM:FPAR:OK
                                2066 TSM:ID
                                2067 TSM:ID:OK
                                2069 TSM:UPL
                                2072 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                2078 TSF:MSG:READ,0-0-42,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                2083 TSF:MSG:PONG RECV,HP=1
                                2086 TSM:UPL:OK
                                2087 TSM:READY:ID=42,PAR=0,DIS=1
                                2093 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                2100 TSF:MSG:READ,0-0-42,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                2107 TSF:MSG:SEND,42-42-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.1.0-beta
                                2116 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                2126 TSF:MSG:READ,0-0-42,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                2131 Presentation() begin
                                2135 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:Sink Pump Control Node
                                2145 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                                2153 TSF:MSG:SEND,42-42-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                2161 TSF:MSG:SEND,42-42-0-0,s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                                2168 TSF:MSG:SEND,42-42-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                2174 Presentation() end
                                2176 MCO:REG:REQ
                                2181 TSF:MSG:SEND,42-42-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                2187 TSF:MSG:READ,0-0-42,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                2192 MCO:PIM:NODE REG=1
                                2518 loop() end
                                2518 loop() begin
                                • H Heizelmann
                                  Here a log example:
                                  4 MCO:BGN:BFR
                                  5 before() begin
                                  5 before() end
                                  5 TSM:INIT
                                  9 TSF:WUR:MS=1000
                                  16 TSM:INIT:TSP OK
                                  20 TSF:SID:OK,ID=42
                                  21 TSM:FPAR
                                  1010 MCO:BGN:STP
                                  1011 Setup() begin
                                  1512 Setup() end
                                  1516 loop() begin
                                  2017 loop() end
                                  2017 loop() begin
                                  2065 TSM:FPAR:OK
                                  2066 TSM:ID
                                  2067 TSM:ID:OK
                                  2069 TSM:UPL
                                  2086 TSM:UPL:OK
                                  2176 MCO:REG:REQ
                                  2518 loop() end
                                  2518 loop() begin
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Heizelmann I'm not sure I understood your concern.
                                  Initialization is finished here, right before the main loop is entered:
                                  Since your timeout is set to 1sec (which obviously is too short to fully establish the transport link) the node will enter the main loop() after the timeout. However, since the link is not established, only init messages are sent at that point (i.e. library init, signing preferences, presentation). Sensor data will not be sent until the node is registered.
