  3. ESP8266 GW+Node (MQTT Transport): Won't Present Sketch or Actuator To Controller
5 Posts 3 Posters 2.7k Views 2 Watching
  • N Offline
    N Offline
    non_avg_joe
    wrote on last edited by non_avg_joe
    Hi There Experts :)
    If You Will, I'd Love Some Assistance w/ Getting My Capstone Project Ready :
    My Software Setup is as Following -
    Node-RED (Flow(s)+Dashboard) <-> Mosquitto MQTT-Broker (v1.4.10) <-> {ESP8266 Arduino-port (IDE : v1.6.12 ; ESP8266 port : latest github 'master'-branch pull) + MySensors Library (v2.1.0-beta - latest github 'master'-branch pull)}
    As Per My Program ('Sketch'), I've Took The 'GatewayESP8266MQTTClient' Example & Elaborated On It a Bit - Merging In Mostly The 'DimmableLEDActuator' Example,
    Along a mDNS+DNS-SD Based Name-Resolver - For The MQTT-Broker Hostname (Via The Library That's Included With The ESP8266 Arduino-port).
    However, While My ESP8266 GW+Node Boots, Successfully Connects to Both WiFi Net. & The MQTT-Broker,
    & Responds - for e.g. : To MySensors Lib. 'set' Commands (Sent Via MQTT) - Just As Expected (Including Sending Back an 'ACK' - If Reqested),
    It Just Won't Present The Sketch Name+Version - OR - The Dimmable-LED-Actuator (Via MQTT),
    Neither It'll Request a Node_Id (Via MQTT).
    Sketch :
    #include <EEPROM.h>
    #include <ESP8266WiFi.h>
    #include <ESP8266mDNS.h>
    // a Dynamic Configuration struct
    //struct __attribute__((packed)) My_Config_t
    struct My_Config_t
    String WLAN_STA_SSID = "";
    String WLAN_STA_PASSWD = "";
    String MQTT_Broker_FQDN = "";
    IPAddress MQTT_Broker_IP;
    uint16_t MQTT_Broker_Port = 0;
    } My_Config;
    //#define MDNS_DEBUG_ERR 1
    //#define MDNS_DEBUG_TX 1
    //#define MDNS_DEBUG_RX 1
     * between your home built sensors/actuators and HA controller of choice. <...>
     * Documentation: http://www.mysensors.org  |  Support Forum: http://forum.mysensors.org
     * Version 1.0 - Henrik Ekblad
     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
    #define MY_DEBUG_VERBOSE
    #define TRANSPORT_DEBUG
    // for testing only - the controller should auto-allocate the nodeId
    //#if defined(MY_NODE_ID)
    //#undef MY_NODE_ID
    //#define MY_NODE_ID 0
    //#endif
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    //#define MY_GATEWAY_FEATURE
    #define MY_GATEWAY_ESP8266
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "root1/mys-gateway1-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "root1/mys-gateway1-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID  (String("mysensors-gw-esp_") + String(ESP.getChipId(), HEX)).c_str()
    //#define MY_MQTT_CLIENT_ID "mysensors-gw1"
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID (My_Config.WLAN_STA_SSID).c_str()
    #define MY_ESP8266_PASSWORD (My_Config.WLAN_STA_PASSWD).c_str()
    //#define MY_ESP8266_HOSTNAME (String("ESP_") + String(ESP.getChipId(), HEX)).c_str()
    //#define MY_IP_ADDRESS (192, 168, 0, 10)
    //#define MY_IP_GATEWAY_ADDRESS (10, 0, 0, 100)
    //#define MY_IP_SUBNET_ADDRESS (255, 255, 255, 0)
    // MQTT-Broker IP Address
    #define MY_CONTROLLER_URL_ADDRESS ((My_Config.MQTT_Broker_FQDN).c_str())
    //#define MY_CONTROLLER_IP_ADDRESS (10, 0, 0, 1) // should be auto-configured using mDNS+DNS-SD !
    // MQTT-Broker Port
    #define MY_PORT (My_Config.MQTT_Broker_Port)
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    //#define MY_USE_UDP
    #if defined(MY_USE_UDP)
      #include <WiFiUdp.h>
    uint8_t MYS_childSensorId1 = 0;
    #define MY_LED_PIN D1
    #define MY_LED_FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    static uint8_t MY_LED_Light_Level = 0;  // Current dim. level
    MyMessage MYS_dimmerMsg(MYS_childSensorId1, V_PERCENTAGE);
    MyMessage MYS_statusMsg(MYS_childSensorId1, V_STATUS);
    void setup_net()
    //  sprintf(wifi_ap_ssid, "ESP-AP-%06X", ESP.getChipId());
      Serial.print("setup_net(): Hostname = ");
      Serial.println((String("ESP_") + String(ESP.getChipId(), HEX)).c_str());
      WiFi.hostname((String("ESP_") + String(ESP.getChipId(), HEX)).c_str());
      WiFi.begin((My_Config.WLAN_STA_SSID).c_str(), (My_Config.WLAN_STA_PASSWD).c_str());
      while (WiFi.status() != WL_CONNECTED) {
        delay(500);
        Serial.print(".");
      Serial.println();
      Serial.print("setup_net(): Connected to ");
      Serial.print((My_Config.WLAN_STA_SSID).c_str());
      Serial.print(", IP address: ");
      Serial.println(WiFi.localIP());
    void setup_mdns()
      if (!MDNS.begin((String("ESP_") + String(ESP.getChipId(), HEX)).c_str())) { Serial.println("setup_mdns(): Error Setting-Up mDNS Responder !"); }
      else { Serial.println("setup_mdns(): mDNS responder started"); }
    void mdns_get_first_record_for_fqdn(String _FQDN, IPAddress &_IP, uint16_t &_Port)
      // trim the ".local" ending - for handing over to the mDNS Resolver
      _FQDN.replace(".local","");
      Serial.print("mdns_get_first_record_for_fqdn(): Non-FQDN Hostname = ");
      Serial.println(_FQDN.c_str());
      Serial.println("mdns_get_first_record_for_fqdn(): Sending mDNS query");
      // Send out query for mqtt tcp services
      uint8_t n = MDNS.queryService("mqtt", "tcp");
      Serial.println("mdns_get_first_record_for_fqdn(): mDNS query done");
      if (n == 0) {
        Serial.println("mdns_get_first_record_for_fqdn(): No Services Were Found");
      else {
        Serial.print("mdns_get_first_record_for_fqdn(): ");
        Serial.print(n);
        Serial.println(" Service(s) Were Found :");
        for (uint8_t i = 0; i < n; ++i) {
          // Print details for each service found
          Serial.print(i); Serial.print(": ");
          Serial.print(MDNS.hostname(i)); Serial.print(" (");
          Serial.print(MDNS.IP(i)); Serial.print(":"); Serial.print(MDNS.port(i));
          Serial.println(")");
        if (_FQDN == MDNS.hostname(i)) {
            _IP = MDNS.IP(i);
            _Port = MDNS.port(i);
            Serial.print("mdns_get_first_record_for_fqdn(): mDNS 1st Matching Record# = ");
            Serial.println(i);
            // return the 1st matching record only
    // before() : Anything To Be Done Before mySensors Lib. Starts
    void before() {
    MY_SERIALDEVICE.println("before() : Hello !");
    // Here to be the reading of a json/cbor object from a file on a local storage (e.g. : SPIFFS over Serial NVRAM) & the parsing of it into the My_Config struct
    My_Config.WLAN_STA_SSID = "My-WLAN";
    My_Config.WLAN_STA_PASSWD = "My-Passwd";
    My_Config.MQTT_Broker_FQDN = "hercules.local";
    // a '.local' TLD -> to be resolved via mDNS
    if ((My_Config.MQTT_Broker_FQDN).endsWith(".local"))
    setup_net();
    setup_mdns();
    mdns_get_first_record_for_fqdn(My_Config.MQTT_Broker_FQDN, My_Config.MQTT_Broker_IP, My_Config.MQTT_Broker_Port);
    Serial.print("before(): MQTT Broker IP:Port = ");
    Serial.print(My_Config.MQTT_Broker_IP); Serial.print(":");
    Serial.println(My_Config.MQTT_Broker_Port);
    if (My_Config.MQTT_Broker_Port != 0) { My_Config.MQTT_Broker_FQDN = (My_Config.MQTT_Broker_IP).toString(); }
    Serial.print("before(): My_Config.MQTT_Broker_FQDN = ");
    Serial.println(My_Config.MQTT_Broker_FQDN);
    // < mDNS Resolution
    MY_SERIALDEVICE.println("setup() : Hello !");
    request( MYS_childSensorId1, V_PERCENTAGE ); // request the formerly-set light-level from the controller
        MY_SERIALDEVICE.println("presentation() : Hello !");
        present( MYS_childSensorId1, S_DIMMER );
        sendSketchInfo("Capstone_2016", "1.0");
        Serial.print("ESP.getFreeHeap() = ");
        Serial.println(ESP.getFreeHeap());
        sendHeartbeat();
    //  delay(50); // a >100ms delay() will interfere with the WiFi Connectivity ! (& might also cause a system hang/reset)
        wait(15000); // Wait for a specified amount of time to pass. Keeps process()ing. This does not power-down the radio nor the Arduino. Because this calls process() in a loop, it is a good way to wait in your loop() on a node that listens to messages.
        Serial.print( "V_STATUS command received. Value is " ); Serial.println( message.data  );
        uint8_t lstate = atoi( message.data );
        Serial.print( "V_STATUS new state: " ); Serial.println( lstate );
        if ((lstate != 0) && (lstate != 1)) {
          Serial.println( "V_STATUS data invalid (should be 0/1)" );
    if (message.type == V_PERCENTAGE) {
        Serial.print( "V_PERCENTAGE command received. Value is " ); Serial.println( message.data  );
        uint8_t dimvalue = atoi( message.data );
        Serial.print( "V_PERCENTAGE new state: " ); Serial.println( dimvalue );
        if ((dimvalue<0)||(dimvalue>100)) {
          Serial.println( "V_PERCENTAGE data Invalid (should be 0..100)" );
        if (message.type == V_STATUS || message.type == V_PERCENTAGE) {
            // Adjust incoming level if this is a V_STATUS variable update [0 == off, 1 == on]
            requestedLevel *= ( message.type == V_STATUS ? 35 : 1 );
            Serial.print( "Changing level to " ); Serial.print( requestedLevel );
            Serial.print( ", from " ); Serial.println( MY_LED_Light_Level );
            fadeToLevel( requestedLevel );
            send(MYS_statusMsg.set(MY_LED_Light_Level > 0));
            // hek comment: Is this really nessesary?
            send( MYS_dimmerMsg.set(MY_LED_Light_Level) );
     *  This method provides a graceful fade up/down effect
    void fadeToLevel( int toLevel )
        int delta = (( toLevel - MY_LED_Light_Level ) < 0) ? -1 : 1;
        while ( MY_LED_Light_Level != toLevel ) {
            MY_LED_Light_Level += delta;
            analogWrite( MY_LED_PIN, (int)(MY_LED_Light_Level / 100. * 255) );
            delay( MY_LED_FADE_DELAY );
    Debugging Output - via Serial Port :
    (~45 First Seconds)
    0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGE--,VER=2.1.0-beta
    0;255;3;0;9;MCO:BGN:BFR
    before() : Hello !
    setup_net(): Hostname = ESP_c04b5b
    scandone
    f 0, scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 1
    cnt
    connected with My-WLAN, channel 1
    dhcp client start...
    ...ip:10.0.0.102,mask:255.255.255.0,gw:10.0.0.250
    setup_net(): Connected to My-WLAN, IP address: 10.0.0.102
    mdns_get_first_record_for_fqdn(): Non-FQDN Hostname = hercules
    mdns_get_first_record_for_fqdn(): 1 Service(s) Were Found :
    0: hercules (10.0.0.1:1883)
    mdns_get_first_record_for_fqdn(): mDNS 1st Matching Record# = 0
    before(): MQTT Broker IP:Port = 10.0.0.1:1883
    before(): My_Config.MQTT_Broker_FQDN = 10.0.0.1
    f r0, scandone
    .IP: 10.0.0.102
    0;255;3;0;9;MCO:BGN:STP
    setup() : Hello !
    0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
    IP: 10.0.0.102
    0;255;3;0;9;MQTT connected
    ESP.getFreeHeap() = 39568
    pm open,type:2 0
    ESP.getFreeHeap() = 41168
    • N Offline
      N Offline
      non_avg_joe
      Update:
      While Commit# [ https://github.com/mysensors/MySensors/commit/38013ce5acf7b5af23ce5e9dbc2920d38836a910 ] Seem To Have Fixed The Presentation Issue ( Thanks a Bunch ! :) ),
      No Node_ID Is Ever Requested ( Is There a Way, Preferrably Reliable..., To Manually "Push" a Node_ID From The Controller ? ).
      • N non_avg_joe
        Update:
        T Offline
        T Offline
        tekka
        wrote on last edited by tekka
        @non_avg_joe A gateway will always have ID=0, hence no ID request.
        But there is something I need to adjust...hold on :)
        PR submitted: https://github.com/mysensors/MySensors/pull/699
        Thanks for reporting.
        • M Offline
          M Offline
          Mickey
          @non_avg_joe
          In the section where needed to populate the params from SPIFFS
          Did you ever got to implement this section?
          N 1 Reply Last reply
          • M Mickey
            @non_avg_joe
            N Offline
            N Offline
            non_avg_joe
            @tekka: Thanks For All Your Efforts, Buddy ! :)
            @Mickey:
            Not Yet, Although I Plan On Utilizing [ https://github.com/tzapu/WiFiManager ] & a Similar Example Is Included There -
            https://github.com/tzapu/WiFiManager/blob/master/examples/AutoConnectWithFSParameters/AutoConnectWithFSParameters.ino
            https://github.com/tzapu/WiFiManager/blob/master/examples/OnDemandConfigPortal/OnDemandConfigPortal.ino
            12.2k
