  3. Please check my mysensors code.
9 Posts 2 Posters 2.6k Views 2 Watching
  • M Offline
    M Offline
    Matt
    wrote on last edited by Matt
    Hi guys, sorry newbie problem here.
    I am building an automated chickenhouse door using FETs and a electric antenna as the linear actuator.
    Opening and closing the door is not as simple as switching a pin high or low, it will involve reed switches and two separate output pins to control the motor.
    I wish to save the message.getBool() value to a separate bool variable (DOORSTATE).
    I have tried
    DOORSTATE = (message.sensor, message.getBool()?1:0);
    within void receive
    and various permutations of it but keep getting the compile error
    expected unqualified-id before '=' token
    Im sure its something simple but havent figured it out as yet...
    Matt
    • M Matt
      I have tried
      within void receive
      Matt
      @Matt uppercase is most often used for defines. Is DOORSTATE defined somewhere? Could you post your sketch?
        M Offline
        M Offline
        Matt
        @mfalkvidd
        Hiya thanks for your reply. Am in bed now so don't have the sketch to hand. In any case its just getting started, nothing in main void yet. Yep I have DOORSTATE defined as boolean in the setup...
        I just want to set it to true or false based on what the GW sends....
        • M Offline
          M Offline
          Matt
          Sorted it out. Should have read
          bool DOORSTATE = (message.sensor, message.getBool()?1:0);
          or as it turns out, even better would be
          bool DOORSTATE = message.getBool();
          Didn't realise I had to re-declare the variable within void receive as I had already done it in setup.
          Off to work in a minute, but Im hoping void receive passes the value back to void main....
          Thanks anyway,
          Matt
          • M Matt
            Thanks anyway,
            Matt
            @Matt no it won't. Variables declared within a function (such as setup or receive) will only be available within that function. Otherwise functions would mess with eachother's variables which would be a, well, mess.
            If you want the variable to be available in the global scope, it needs to be declared before the first function. See how lastSend is used in the https://www.mysensors.org/build/pulse_power example.
            Also, please do not use an uppercase name for variables. Uppercase names are normally only used for constants. It will work, but there is a risk other programmers will be quite confused.
            M 2 Replies Last reply
              M Offline
              M Offline
              Matt
              @mfalkvidd
              Cheers, thanks for the tips. Learn something every day.
                M Offline
                M Offline
                Matt
                @mfalkvidd have finished my code, it all compiles but I haven't had a chance to test it yet, am still waiting for a step down converter to arrive as it will all be powered by a 12v car battery/solar charge controller/panel which can go up to 14.4V. The actuator is an electric antenna from the wreckers yard.
                There are two reed switches on the door to detect open or closed position. I have added some code to try to unjam the door if it takes longer than 5 seconds to open or close. There is a manual button (debounced) to open or close the door, as well as reset the jam.
                If you have time (HAH! Who does three days out from Christmas) I would well appreciate a critical eye on my code.
                In particular I'm not sure if the lines in void receive are correct Im not too worried about errors elsewhere, can likely work them out myself, but the mysensors bits I am not too sure about.
                DoorState = message.getBool();
                saveState(1, message.getBool());
                as well as the lines that flag to the gateway/controller the door is jammed (last bit of void loop in the else if bit.
                send(msg.set(HIGH));
                Entire sketch below. Apologies if its hard to read, I am newish to C and prior to that only wrote in basic 30+ years ago....
                Many many thanks,
                Matt
                 * Version 1.0 - Henrik Ekblad
                 * Example sketch showing how to control physical relays.
                 * This example will remember relay state after power failure.
                 * http://www.mysensors.org/build/relay
                #define MOTORSW     3  // Motor activation pin
                #define MOTORPWR    4  // Motor power lead pin
                #define REED_OPEN   5  // Reed switch pin, pulled low when door is open
                #define REED_CLOSED 6  // Reed switch pin, pulled low when door is closed
                #define MANUALSW    7  // Momentary switch to control door
                bool DoorState;        // 0 closed, 1 open
                bool PrevState;        // Used to check for stated change
                byte jammed=0;
                unsigned long timer;   // Counter to check door closes in time ie isn't jammed.
                Bounce debouncer = Bounce();
                MyMessage msg(2,V_TRIPPED);
                    pinMode(MOTORSW,     OUTPUT);
                    pinMode(MOTORPWR,    OUTPUT);
                    pinMode(REED_OPEN,   INPUT_PULLUP);   // Using internal pullup. When read switch is closed, will pull this pin to ground.
                    pinMode(REED_CLOSED, INPUT_PULLUP);   // Ditto
                    pinMode(MANUALSW, INPUT_PULLUP);      // Turn on pullup for switch, will be pulled low when pushed
                    DoorState = loadState(1);
                    PrevState = DoorState;
                    debouncer.attach(MANUALSW);
                    debouncer.interval(50);
                  sendSketchInfo("ChickenDoor", "1.0");  // Send the sketch version information to the gateway and Controller
                  present(1, S_BINARY);  // Register door actuator to Gateway
                  present(2, S_DOOR); // This will go on if door is jammed
                  debouncer.update();
                  int value = debouncer.read();
                  if (value == LOW) {
                    DoorState = !DoorState;
                    jammed==0;   // Reset the jam
                    send(msg.set(LOW));
                  if ((DoorState != PrevState) && (jammed < 2)) {       //Something has changed and door isn't jammed
                    switch(DoorState) {
                       case 0: // Close Door
                        timer = millis();
                        while( digitalRead(REED_CLOSED)==HIGH) {  //Drive actuator until door closes then stop
                           digitalWrite(MOTORPWR, HIGH);   //Turn on the actuator
                           wait(50);   // Actuator wakes up
                           digitalWrite(MOTORSW, HIGH);  //Close the door
                           if (millis() - timer > 5000) {   //door is jammed
                            jammed++;
                            jiggle(); //open and close again
                           digitalWrite(MOTORSW, LOW); //Door is closed, turn off actuator switch
                           digitalWrite(MOTORPWR, LOW); //Door is closed, turn off actuator
                           jammed=0;
                       case 1: // Open Door
                        timer = millis();
                        while( digitalRead(REED_OPEN)==HIGH) {  //Drive actuator until door opens then stop
                           digitalWrite(MOTORSW, HIGH); //Wake up the actuator
                           wait(100);
                           digitalWrite(MOTORSW, LOW); //Close the door
                            jammed++;
                            jiggle();
                           jammed=0;
                    else if (jammed >= 2) {
                  if (message.type==V_STATUS) {                     // We only expect one type of message from controller. But we better check anyway.
                     saveState(1, message.getBool());               // Store state in eeprom
                     Serial.print("Incoming change for sensor:");   // Write some debug info
                void jiggle()  //J j j jiggle it a bit (4 times)
                { for(int x = 0; x < 4 ; x++) {
                  wait(500);
                PrevState = !DoorState // Reset PrevState to have another go at opening or closing the door.
                • M Matt
                  Many many thanks,
                  Matt
                  byte jammed=0;
                    debouncer.update();
                    if (value == LOW) {
                      send(msg.set(LOW));
                      switch(DoorState) {
                          timer = millis();
                              jammed++;
                             jammed=0;
                          timer = millis();
                             wait(100);
                              jammed++;
                              jiggle();
                             jammed=0;
                    wait(500);
                  @Matt actually I do have time :-) Waiting for my connecting flight.
                  The code looks good to me. Can't see anything that looks weird.
                    M Offline
                    M Offline
                    Matt
                    @mfalkvidd
                    Thanks heaps, enjoy your trip =)
                    11.9k
                    113.3k
