  3. livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz
135 Posts 31 Posters 135.4k Views 44 Watching
  • TigroenotT
    TigroenotT
    Tigroenot
    Those guys have an additional 12 v power wire in the switch mounting, the wire fore 12v power has been put there during the construction.
    The power supply in livolo switches is capable to make up to 250mA current. So I suppose it is not possible to feed the esp8266, but more than enough to power the 328p and Nrf24 radio. Currently I have one double button livolo switch running for a week or so with no issues whatsoever. But you have to change the BOD fuses to 1,8 v. Running at 2,7 bod causes reboot at sending data.
    Drawing more power from livolo power supply is not hard, but your load has to be at least 40w light bulbs.
    jirmJ 1 Reply Last reply
    • TigroenotT Tigroenot
      jirmJ
      jirmJ
      jirm
      @Tigroenot Thank you for your quick reply.
      I think additional power supply is not the right path for that, because needed modify all house wiring is a real pain and most costly solution.
      If 250ma drawn current is avaiable from livolo switch I think is really so close for the "calculate" needs for a esp8266, so maybe is time to real test it and see what happends but If esp cannot not work properly it does not matter because you say have stable working arduino+nrf24 that is equal good solution or in some cases maybe better than an alone esp.
      Maybe we always easily can add one parallel capacitor at loads (any 0,47nf X2 400V rated or livolo can provide someone too) to increase load current drawn if we find that some switch cannot drawn enough power from his load?
      Regards
      • V
        V
        Viciousman
        Hello Tigroenot, you have the EU version of livolo correct?
        Can you please post a schematic on how you performed the Boost to the power supply? I'm using mysensors+nrf24 so I just need arround 20ma power.
        Thank you.
        • jirmJ jirm
          Regards
          jirmJ
          jirmJ
          jirm
          wrote on last edited by jirm
          #54
          @jirm
          @Tigroenot .The BOD fuses you mean that we need forced to work the 328p at 1.8V and not at 2.7V as default is usually done?
          How do you power the arduino + nrf24 circuit?
          From what voltage of the switch livolo and since what "pins" ?.
          I am not able to see exactly where to extract the feed (in the real circuit board) of the plate on the livolo (I use the version 2016 EU of switches).
          You could put some schematic and / or pics regarding how to connect the feed on the livolo board because in the posts I have seen above I am not able to verify it in what correspond at least to my EU version switches?
          regards
          • TigroenotT
            TigroenotT
            Tigroenot
            wrote on last edited by Tigroenot
            #55
            I have the pictures, but I have to resize them so the forum engine accepts. I will do it at work tomorrow.
            In two words you need to bypass the big resistor that feeds the transformator and decrease the resistance of the voltage divider that controls the mosfet in the primary coil of the trans. I'll provide the pictures.
            Can you please show the lower board of the 2016 model switch?
            P. S. And by the way I didn't find a proper way to control the esp switch in domoticz. I need to have two dummy switches - one for state and one for changing state. I used espEasy and Lua scripts both but no luck... With MySensors it is IMHO the proper way :)
            jirmJ 2 Replies Last reply
              jirmJ
              jirmJ
              jirm
              @Tigroenot Ok I wait your pics. I half understand that you say we need to do but better "see" how do it that not suposse because is easy to kill the switch if that is not do it propperly.
              I have same problems than you to post here pics from my switch boards and so on (I have all my house with livolo´s... near 40 switch) and need too some time to take good pics and feet to post it here, but tomorrow can upload some of them.
              See you
                jirmJ
                jirmJ
                jirm
                @Tigroenot Sorry I dont know Domoticz, and only few little steps in Home Assistant and in past some on Openhab...but I belive that any people there in Domoticz forums can help you for sure to make that work.
                I only "ear" that easyesp is so "easy" to make it work with domoticz and for sure you know is trivial for setup easyesp to work a simple relay with any easpeasy sketch for that.
                I dont know your exactly issue and how to help you better and also I'm a real newby in any home system, just starting now only with some few steps starting to try to make work livolo's like I want with a realiable (and hope easy way) to provide a good feedback status from them hope universal for any home automation system.
                We need some look, but seems close to have some good results.
                See you
                • Nca78N
                  Are you saying that you can draw up to 250mA but when you transmit with NRF, which should consume less than 25mA, the power supply is already on it's knees and the voltage drops ?
                  It doesn't sound like a good idea to make any changes to the main voltage board to achieve this. Have you tried using a ceramic capacitor (100uF or more) to help the power supply when power consumption increases too quickly ?
                  • TigroenotT
                    TigroenotT
                    Tigroenot
                    It's not just that. In the off state the switch is powered through a standby power circuit. When radio activates it draws power and the same moment the pic of the switch draws power, and the rele changes state to on also drawing a lot of power. All together it is a significant amount of power. So the voltage drops from 3v to 2,7-2,6 causing the brown out.
                    And the 250mA is in theory. With the trans used.
                    • TigroenotT
                      TigroenotT
                      Tigroenot
                      And yes, I have a 47uF cap for radio and 100uF aluminum electrolytic cap for power input on the mcu.
                      Nca78N 1 Reply Last reply
                        I see...
                        Maybe it can be a good idea to sleep arduino and radio for a short time after button touch to let the relay change state and transmit state to controller only after sleep ?
                        TigroenotT 1 Reply Last reply
                        • TigroenotT
                          TigroenotT
                          Tigroenot
                          #62
                          0_1482390326320_IMG_20161222_30763.jpg 0_1482390399345_IMG_20161222_2453.jpg
                          • Nca78N Nca78
                            I see...
                            TigroenotT
                            TigroenotT
                            Tigroenot
                            #63
                            @Nca78
                            Well, now it's working fine for almost two weeks, no issues. I'm always trying to modify the sketch to work even better but it ends up that "the best is an enemy of the good" :)
                            As for connections: as you can see on the photo of upper board I have connected 5 wires (actually later I added sixth). They are ground, two wires to leds for reading status (through 4k7 to pin 5 and 6), and wires to touch sensor pads (through optocoupler to pins 3 and 4, the other side of coupler to ground through 5nF cap) . I showed schematics earlier. With the sixth wire I took 3v from the drilled holes at the bottom of the board, as I remember the central hole. You can make sure with the multimeter.
                              @Nca78
                              jirmJ
                              jirmJ
                              jirm
                              @Tigroenot
                              Thanks for the pics. I see now little much better how you wired and what is needed modify on switch board (wired bridges on red) to make it working. But form me still need added the schematic for understand all conections from/to arduino+nrf24 and Livolo to really see how all are working together.
                              So sorry yestarday but I stay so so busy to take pics from my switch´s, but I try today do my best to take some pics of them.
                              I think is so so similar connection like guys from smartsystems controllers are doing for her comercial project s you can see in schematic at min 2:30 on this youtube video https://www.youtube.com/watch?v=LNEE9tjnHR8
                              If it are so and are the same wired on both (your connections and smartsystems are doing to) I think the connection sources from livolo switch are well tested (over enough time and from diferent people) and is at this moment the better aproach to do that connections to livolo swith.
                              That is a great step.
                              I Still figuring how much current can drawn from livolo switch and how doing that in a secure maner and with a generical way to supply "any" radio system (better if can including esp) for provide livolo´s with feedback and additional remote way of control because for me still some dubts about that question. But like I say yesterday seems is time to test and test and not more throw more assumptions.
                              Regards
                              • jirmJ
                                jirmJ
                                jirm
                                #65
                                Sorry about the delay. So much bussy these days.
                                Pictures from my switch version:
                                3 first are from a dimmer, last are from swtich remote 1 gang - 1 way.
                                And a quick view I can see maybe only some little diferences comparing @Tigroenot version on main board mainly I see the antenna on mine and not on @Tigroenot and the central connection pad that seems he have on the rigth, but totally diferent on touch board I suposse because his pics are from a dual swtich version.
                                All my switch has ben purchased only 2 monts ago.
                                • Hugo PereiraH
                                  Hugo PereiraH
                                  Hugo Pereira
                                  Hello everyone,
                                  I am really sorry if I am here making an entirely noob question, but did someone managed to get the light state from this light wall switch? If so is there any video or circuit showing how? I have doubts if i should or should not buy this for my entire house, but if this wall switch cannot send the state through rf i guess it is a no go.
                                  Hope you can help me
                                  • Hugo PereiraH Hugo Pereira
                                    Hello everyone,
                                    @Hugo-Pereira said:
                                    Hello everyone,
                                    Hello, by default it is not sending the status by radio (which is used for receiving only).
                                    But I think with the modifications you can see earlier in the thread it can send and receive using nrf24/mysensors. These are based on the basic switch without radio, no use to buy the much more expensive radio versions when the radio will not be used.
                                    I'm using a different approach which is to replace completely the PCB, so there are no modifications to do to the "main power" part, just plug the new touch PCB (that includes logic and NRF radio). I'm doing it for another switch format (US/AU) but the logic is very similar in EU format switch so if there is a demand I will adapt my PCB for this format later.
                                    Hugo PereiraH 1 Reply Last reply
                                    • Nca78N Nca78
                                      @Hugo-Pereira said:
                                      Hello everyone,
                                      Hugo PereiraH
                                      Hugo PereiraH
                                      Hugo Pereira
                                      @Nca78 Very interisting if the prices are the same and the design! You have a buyer :P Hope you ship to Portugal eheh I will be waiting for your solution for EU. Cause honestly i did not wanted to make too complicated adaptations on the circuit.
                                        I think you misunderstood :P
                                        I'm making only the PCB (electronic board on which to solder the components). So you still need to buy Livolo switches (with no radio) and then get my PCB done and solder components on it. Then replace the touch PCB from Livolo switch with it.
                                        It won't be very expensive (about 5-6$ of parts per switch I think) but there's some work to do :P
                                        mtiutiuM 1 Reply Last reply
                                        • Nca78N Nca78
                                          mtiutiuM
                                          mtiutiuM
                                          mtiutiu
                                          @Nca78
                                          Hi, I'm working on this one too. This Livolo stuff captured my attention a long time ago as I needed an in wall solution for controlling the lights(without using batteries and such). I wanted this to be integrated with the existing infrastructure also(the existing house electrical wiring for lights). I studied the power supply part before the Livolo switches era as I wanted to make one of my own but in the end it seemed not so an easy task because of the series circuit( to take power from the live wire only). Anyways if the power board from the existing Livolo switches will be capable of delivering the required power it will be really awesome(as the non radio switch is really cheap
                                          In my case I'm using the rfm69 module(the CW variant as it's more compact) which requires a little bit more current(45 mA or so). I don't want to use the existing 3V line which the Livolo power board has because as I've seen from this thread pictures and schematics it uses a low current voltage regulator(30mA max or so from my investigations). This is fine for the nrf24l01 low power variant but for RFM69 it isn't. So currently I'm working on identifying the 12V line as my design uses a buck converter to get it as low as 3.0-3.3V.
                                          The project and progress is posted here: https://www.openhardware.io/view/306/Livolo-EU-switch-Mysensors-integration. Depending on my free time I will continue to work on it but I don't know when it will be finished.
                                          Keep up the good work and congrats to the Mysensors creators for this wonderful project.
