  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • carlylerC carlyler
    @TimO thanks for the reply. I changed mysensors:bridge-eth:gateway to mysensors:bridge-eth:ethGateway in things and items, restarted OH2, reset ESP8266, several times, but no luck. If I read this right the GW is not trying to do much, ie get node id, present sensor, send data, etc. Any idea?
    GW serial:
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
    0;255;3;0;9;MCO:SLP:WUP=-2
    0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
    Getting temperature
    T: 20.00
    H: 34.70
    Getting temperature
    T: 20.10
    H: 33.90
    I am trying to set node id in sketch:
    #define DHT_DATA_PIN 2
    #define MY_GATEWAY_ESP8266
    // ethernet settings
    #define MY_ESP8266_SSID "xxxxxx"
    #define MY_ESP8266_PASSWORD "xxxxxxxxxx"
    // Enable UDP communication
    //#define MY_USE_UDP
    #define MY_ESP8266_HOSTNAME "HuzzahGateway"
    //#define MY_IP_ADDRESS 192,168,213,113
    //#define MY_IP_GATEWAY_ADDRESS 192,168,213,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192,168,213,116
    // Flash leds on rx/tx/err
    #define MY_NODE_ID 3
    #include <ESP8266WiFi.h>
    TimO
    @carlyler Serial log looks good. The gateway is receiving it's IP per DHCP, right? Is the IP you configured above still correct? I prefer a static IP for my gateway to prevent a changing of the IP.
    Is the gateway reachable by ping? Are you able to connect with "telnet IP 5003" to the gateway?
    • carlylerC
      carlylerC
      carlyler
      @TimO DHCP: yes, but it is actually static by way of reserved addresses via MAC in the router.
      IP: same
      ping: yes, works
      telnet, yes, all I see is:
      Serial is OK? I do not see the send of the Temp and hum; it is printing it because there is code to do that, but I am expecting the MySensors send command; right? My thought was it is not transmitting them for some reason. This is an area I am not confident about and have yet to find a good explanation of it: how a GW handles local sensors. Thoughts?
      • T TimO
        @triceT Just to make sure it is still working with the current snapshot I made a clean install.
        I've used:
        • OH2 Snapshot #631
        • current Binding
        • MySensors 2.0.0
        • Ethernet Gateway (Arduino Uno + Ethernet Shield + NRF24L01+)
        Everything works just fine, so don't give up! :-)
        triceTT
        triceTT
        triceT
        @TimO I have the exact hardware (Mine is Chinese) and SW versions as you, but still can't connect via Ethernet gw. I will not give up till it is working :) I've ordered another Ethernet shield and will try with the new one.
        Regards
        • carlylerC
          carlylerC
          carlyler
          @TimO Good news! I finally got it to work; I have been using the dev, 2.1.0, and decided to try master, 2.0.0 and it came right up! I did notice one thing though that you may be interested in: if I start the ethGateway after OH2 is up, or turn it off and back on, the binding does not reconnect. Not sure if there is anything you can do about that.
          One other change to mention (before changing to v2.0.0): I found a note from hek about the node id of gateway local sensors will always be 0; I changed that in my things file and in my sketch.
          16:34:59.286 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;1;1;0;0;12.5
          16:34:59.291 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2016-12-10T16:34:59.289-0500
          16:34:59.300 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 0 to 2016-12-10T16:34:59.297-0500
          16:34:59.333 [INFO ] [marthome.event.ItemStateChangedEvent] - bTemp changed from 12.8 to 12.5
          16:34:59.354 [INFO ] [marthome.event.ItemStateChangedEvent] - bTempF changed from 55.04 to 54.50
          16:34:59.365 [INFO ] [marthome.event.ItemStateChangedEvent] - bTempC_F changed from 12.8 °C / 55.0 °F to 12.5 °C / 54.5 °F
          16:34:59.490 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
          16:34:59.583 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;0;1;0;1;34.1
          16:34:59.593 [INFO ] [marthome.event.ItemStateChangedEvent] - bHum changed from 34.2 to 34.1
          @hek I could be wrong, or maybe something has changed configuration wise but as you can see from above posts, dev branch v2.1.0, the radioless ethernet (ESP8266) gateway with local temp & hum sensors was not sending local sensor data. When I switched back to master v2.0.0 it started sending.
          jogantJ 1 Reply Last reply
            jogantJ
            jogantJ
            jogant
            @carlyler
            The issue with the oh2 binding is known. You have to restart oh2 or just the binding through oh console and binding:restart
            Maybe an update of the binding may help but I didn't try yet.
            carlylerC 1 Reply Last reply
            • jogantJ jogant
              @carlyler
              carlylerC
              carlylerC
              carlyler
              @jogant Thank you. I did not know about the binding restart so I will look into that.
              • T TimO
                @pentti12 I've pushed a new version of the binding to github, please try it out and let me know if it helps.
                jogantJ
                jogantJ
                jogant
                @TimO
                yesterday I tried the new binding with OH2 b4 and I have exactly the faulty behavior as described before. The gateway goes in online state but none of the mysensor node items goes online. They remain uninitialized. I restored the older binding and everything works well again. As it is the same behavior that @pentti12 describes I think it has to with the binding itself.
                @pentti12 : please try attached binding as that works for me. 0_1482134888619_org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                it is an older snapshot from November, 7th.
                Good luck
                • pentti12P
                  pentti12P
                  pentti12
                  @jogant I moved to different location here in Espoo, so it will take a couple of days before I can continue with proposed MySensors binding, but it is good to know that there is at least one working solution available.
                  • jogantJ jogant
                    @TimO
                    Good luck
                    TimO
                    @jogant you're right, as stated in the wiki the current binding version is only working together with the current snapshot release. I had no luck while trying to create a binding that is backward compatible.
                    • T TimO
                      jogantJ
                      jogantJ
                      jogant
                      @TimO
                      now I tried the new combination of a recent OH2 snapshot as of 2016-12-21 with the recent mysensors binding. I had to restart the gateway and every single node but then everything works well. The nodes were found in the inbox and could be acknowledged as new things. Values are transmitted regularly and my relay node follows the switch items as desired. So no glitch at the moment.
                      Well done @TimO.
