  3. Uno R3 + W5100 Shield + NRF24L01+
5 Posts 2 Posters 1.7k Views 2 Watching
  • TheGreatDocT Offline
    TheGreatDoc
    wrote on last edited by TheGreatDoc
    Hi All,
    Im really new to Arduino and this is my first complex project.
    Im doing this: https://www.openhardware.io/view/55/Home-Automation with this starting hardware:
    GW:
    • Arduino Uno R3 https://www.amazon.es/gp/product/B018SC114U
    • Ethernet W5100 Shield https://www.amazon.es/gp/product/B00HG82V1A
    • NRF24L01+ https://www.amazon.es/gp/product/B01C2NOKDU
    • DHT11 + 1 Relay
    Node:
    • Arduino Nano https://www.amazon.es/gp/product/B019SXNBQY
    • DS18B20
    Controller:
    Ubuntu 16 with Home-Assistant
    Im following the wiring/code of the openhardware proyect, checking it with the mysensors wiring guides and updated coded. I cant put the 10uF. If I put it the radio fails to init and show a check wiring message.
    Comms through ethernet works well, the problem is the NRF24L01+, I cant make it work with the shield.
    This is the gw log:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;RF24:write register, reg=0, value=14
    0;255;3;0;9;RF24:write register, reg=3, value=3
    0;255;3;0;9;RF24:write register, reg=4, value=95
    0;255;3;0;9;RF24:write register, reg=5, value=76
    0;255;3;0;9;RF24:write register, reg=6, value=39
    0;255;3;0;9;RF24:read register, reg=6, value=39
    0;255;3;0;9;RF24:read register, reg=5, value=76
    0;255;3;0;9;RF24:write register, reg=16, value=115
    0;255;3;0;9;RF24:write register, reg=29, value=6
    0;255;3;0;9;RF24:write register, reg=2, value=2
    0;255;3;0;9;RF24:write register, reg=1, value=0
    0;255;3;0;9;RF24:write register, reg=28, value=3
    0;255;3;0;9;RF24:flushRX
    0;255;3;0;9;RF24:flushTX
    0;255;3;0;9;RF24:write register, reg=7, value=112
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;RF24:write register, reg=2, value=3
    0;255;3;0;9;RF24:write register, reg=1, value=1
    0;255;3;0;9;RF24:start listening
    0;255;3;0;9;RF24:write register, reg=0, value=15
    0;255;3;0;9;RF24:write register, reg=10, value=0
    0;255;3;0;9;TSM:READY
    IP: 192.168.100.8
    IP: 192.168.100.8
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;TSP:SANCHK:OK
    0;255;3;0;9;Sending message on topic: P/0/132/1/0/0
    0;255;3;0;9;Sending message on topic: P/0/131/1/0/1
    0;255;3;0;9;Sending message on topic: P/0/131/1/0/1```
    Node log:
    ```Starting sensor (RNNNA-, 2.0.0)
    TSM:INIT
    RF24:flushRX
    RF24:flushTX
    TSM:RADIO:OK
    RF24:write register, reg=10, value=12
    TSP:ASSIGNID:OK (ID=12)
    TSM:FPAR
    RF24:stop listening
    RF24:open writing pipe, recipient=255
    RF24:write register, reg=10, value=255
    RF24:write register, reg=16, value=255
    RF24:send message to 255, len=7
    RF24:flushTX
    RF24:write register, reg=7, value=48
    RF24:MAX_RT
    RF24:flushTX
    TSP:MSG:SEND 12-12-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    RF24:stop listening
    RF24:flushTX
    RF24:MAX_RT
    RF24:flushTX
    TSM:FPAR
    RF24:stop listening
    RF24:flushTX
    RF24:MAX_RT
    RF24:flushTX
    TSM:FPAR
    RF24:stop listening
    RF24:flushTX
    RF24:MAX_RT
    RF24:flushTX
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    RF24:write register, reg=0, value=12
    RF24:power down
    What can be the problem?
    FYI. I tried the almost all the possible solutions I found on google (enable spi_en, set to output and high ping 10, 10 and 4, etc...)
    Thanks in advance!
    EDIT: sketchs are now attached, forgot it, sorry.0_1482253986954_MyS-Cocina200.ino 0_1482253999734_MyS-Gateway-Test1.ino
      TheGreatDoc
      By the way, more info:
      SO: Win 7
      IDE: 1.6.13
      Power: USB Cable to PC. I've tested the output and is 3.31v constant in the 3.3v of Uno R3 and in the radio input.
      Curiously, if instead of connecting the radio power directly to Uno I use a breadboard, with or without 10uF, the radio never power up (but I tested the radio power input also here and there is 3.31v)
        it looks like you are having the same problem on the sensor node as I do. Does yours gets to the setup or loop funtions? Because mine can't even get to setup and loops on
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TheGreatDocT 1 Reply Last reply
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TheGreatDoc
          I dont really know if the problem is the sensor node (Nano) or in the GW (UNO).
          The node seems to try to connect to the GW, but the GW recieves nothing.
          I will try this week with external power supplies instead the internal ones for the radios and will tell you something.
            I bought 2 of these -> http://www.gearbest.com/transmitters-receivers-module/pp_453011.html
            But so far I haven't been able to establish a communication between the 2. Also I have some a mixed situation with a UNO and a Mega that for what I have read requires different pins to be connected (hopefully I should have understood that :D )
            11.9k
            113.3k
