  3. ESP8266 - new WiFi settings
15 Posts 3 Posters 11.5k Views 4 Watching
  • G
    G
    gloob
    I have a problem with flashing a WeMos as a gateway.
    No matter what I insert for the WiFi name, it is always using old values.
    For example I have the following definition in my sketch:
    #define MY_ESP8266_SSID "MySSID"
    #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
    But in the debug output it says:
    no your-ssid found, reconnect after 1s
    It seems that it is using old values from the flash when I did upload an other testversion.
    Is there an option to reset everything in the flash from the ESP8266 so that it is using the new values?
    Regards
    Stefan
    • G gloob
      Regards
      Stefan
      @gloob Well, assuming you are using library 2.1, it should really use your values: https://github.com/mysensors/MySensors/blob/master/core/MyGatewayTransportEthernet.cpp#L113
      Are you sure MY_GATEWAY_ESP8266 is defined ?
      Compare your sketch to an example, e.g.: https://github.com/mysensors/MySensors/blob/master/examples/GatewayESP8266/GatewayESP8266.ino
      • G
        G
        gloob
        wrote on last edited by gloob
        Yes I'm using the new 2.1 version.
        I have tested it with the sample sketch:
         * Version 1.0 - Henrik EKblad
         * Contribution by Ivo Pullens (ESP8266 support)
         * The EthernetGateway sends data received from sensors to the WiFi link.
         * VERA CONFIGURATION:
         * LED purposes:
         * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
         * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
          * Inclusion mode button:
        #define MY_BAUD_RATE 9600
        #define MY_GATEWAY_ESP8266
        // Enable UDP communication
        //#define MY_USE_UDP
        // #define MY_ESP8266_HOSTNAME "sensor-gateway"
        #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
        #define MY_PORT 5003
        // Enable inclusion mode
        // #define MY_INCLUSION_BUTTON_FEATURE
        // Set blinking period
        // #define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Flash leds on rx/tx/err
        #if defined(MY_USE_UDP)
        #include <WiFiUdp.h>
        #include <ESP8266WiFi.h>
        The problem is still the same:
         1384, room 16
        tail 8
        chksum 0x2d
        csum 0x2d
        v3de0c112
        ~ld
        scandone
        reconnect
        f 0, scandone
        reconnect
        f -180, scandone
        reconnect
        f r0, scandone
        reconnect
        f 0, 0;255;3;0;9;TSM:FAIL:RE-INIT
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:FAIL:CNT=2
        0;255;3;0;9;TSM:FAIL:PDT
        scandone
        reconnect
        f -180, scandone
        reconnect
        f r0, scandone
        reconnect
        f 0, scandone
        reconnect
        f -180, scandone
        reconnect
        f r0, 0;255;3;0;9;TSM:FAIL:RE-INIT
        0;255;3;0;9;TSM:FAIL:CNT=3
        scandone
        reconnect
        f 0, scandone
        reconnect
        f -180, scandone
        reconnect
        f r0, scandone
        reconnect
        0;255;3;0;9;TSM:FAIL:CNT=4
        scandone
        reconnect
        f -180, scandone
        reconnect
        f r0, scandone
        reconnect
        f 0, scandone
        reconnect
        f -180, scandone
        reconnect
        0;255;3;0;9;TSM:FAIL:CNT=5
        • G gloob
           * LED purposes:
           * nRF24L01+  ESP8266
           * VCC        VCC
           * CE         GPIO4
           * CSN/CS     GPIO15
           * SCK        GPIO14
           * MISO       GPIO12
           * MOSI       GPIO13
           * GND        GND
           1384, room 16
          tail 8
          chksum 0x2d
          csum 0x2d
          v3de0c112
          ~ld
          scandone
          reconnect
          f 0, scandone
          reconnect
          f -180, scandone
          reconnect
          f r0, scandone
          reconnect
          scandone
          reconnect
          f -180, scandone
          reconnect
          f r0, scandone
          reconnect
          f 0, scandone
          reconnect
          f -180, scandone
          reconnect
          scandone
          reconnect
          f 0, scandone
          reconnect
          f -180, scandone
          reconnect
          f r0, scandone
          reconnect
          scandone
          reconnect
          f -180, scandone
          reconnect
          f r0, scandone
          reconnect
          f 0, scandone
          reconnect
          f -180, scandone
          reconnect
          @gloob Strange. What ESP board package do you have installed in the Arduino 'IDE'?
          • G
            G
            gloob
            For the ESP version I'm using 2.3
            I wil try it with 2.2
            Edit: Version 2.2 will not compile
            In file included from /Users/Stefan/Documents/Arduino/libraries/MySensors/MySensors.h:344:0,
                             from /Users/Stefan/Documents/Arduino/WeMos_MySensors_Gateway/WeMos_MySensors_Gateway.ino:119:
            /Users/Stefan/Documents/Arduino/libraries/MySensors/core/MyMainESP8266.cpp:22:22: fatal error: Schedule.h: No such file or directory
             #include "Schedule.h"
            compilation terminated.
            exit status 1
            Fehler beim Kompilieren für das Board WeMos D1 R2 & mini.
            Edit 2: The problem also exists with MySensors 2.0
            Edit 3: If I upload a non MySensors Sketch, the Wifi settings are updated:
             *  This sketch sends a message to a TCP server
            #include <ESP8266WiFiMulti.h>
            ESP8266WiFiMulti WiFiMulti;
                delay(10);
                // We start by connecting to a WiFi network
                WiFiMulti.addAP("SSID", "passpasspass");
                Serial.println();
                Serial.println();
                Serial.print("Wait for WiFi... ");
                while(WiFiMulti.run() != WL_CONNECTED) {
                    Serial.print(".");
                    delay(500);
                Serial.println("");
                Serial.println("WiFi connected");
                Serial.println("IP address: ");
                Serial.println(WiFi.localIP());
                delay(500);
                const uint16_t port = 80;
                const char * host = "192.168.1.1"; // ip or dns
                Serial.print("connecting to ");
                Serial.println(host);
                // Use WiFiClient class to create TCP connections
                WiFiClient client;
                if (!client.connect(host, port)) {
                    Serial.println("connection failed");
                    Serial.println("wait 5 sec...");
                    delay(5000);
                    return;
                // This will send the request to the server
                client.print("Send this data to server");
                //read back one line from server
                String line = client.readStringUntil('\r');
                client.println(line);
                Serial.println("closing connection");
                client.stop();
                delay(5000);
            • G gloob
              exit status 1
                  delay(10);
                  Serial.println();
                  Serial.println();
                      Serial.print(".");
                      delay(500);
                  Serial.println("");
                  delay(500);
                  WiFiClient client;
                      delay(5000);
                      return;
                  client.stop();
                  delay(5000);
              @gloob You should try with WiFi, not WiFiMulti.
              • G
                G
                gloob
                This was just an example that an other sketch is able to set WiFi settings correctly. It is also working with other sample sketches.
                Only the MySensors Gateway sketch does not set the settings correctly.
                For me it sounds that the problem is based on some internal stuff of mysensors
                • G gloob
                  @gloob the MySensors library builds on the arduino port for esp. So, if WiFiMulti works for you, WiFi might still fail as it uses different library functions. I asked, to determine if the problem is in the MySensors library or the arduino port.
                  • G
                    G
                    gloob
                    Okay I have now tried the following sketch:
                     *  This sketch sends data via HTTP GET requests to data.sparkfun.com service.
                     *  You need to get streamId and privateKey at data.sparkfun.com and paste them
                     *  below. Or just customize this script to talk to other HTTP servers.
                    const char* ssid     = "your-ssid";
                    const char* password = "your-password";
                    const char* host = "data.sparkfun.com";
                    const char* streamId   = "....................";
                    const char* privateKey = "....................";
                      delay(10);
                      Serial.println();
                      Serial.println();
                      Serial.print("Connecting to ");
                      Serial.println(ssid);
                      WiFi.begin(ssid, password);
                      while (WiFi.status() != WL_CONNECTED) {
                        delay(500);
                        Serial.print(".");
                      Serial.println("");
                    int value = 0;
                      delay(5000);
                      ++value;
                      WiFiClient client;
                      const int httpPort = 80;
                      if (!client.connect(host, httpPort)) {
                        return;
                      // We now create a URI for the request
                      String url = "/input/";
                      url += streamId;
                      url += "?private_key=";
                      url += privateKey;
                      url += "&value=";
                      url += value;
                      Serial.print("Requesting URL: ");
                      Serial.println(url);
                      client.print(String("GET ") + url + " HTTP/1.1\r\n" +
                                   "Host: " + host + "\r\n" +
                                   "Connection: close\r\n\r\n");
                      unsigned long timeout = millis();
                      while (client.available() == 0) {
                        if (millis() - timeout > 5000) {
                          Serial.println(">>> Client Timeout !");
                          client.stop();
                          return;
                      // Read all the lines of the reply from server and print them to Serial
                      while(client.available()){
                        Serial.print(line);
                      Serial.println();
                    the output looks like expected:
                    Connecting to your-ssid
                    But uploading the following MySensors sample sketch does not update the WiFi settings:
                     * LED purposes:
                     * nRF24L01+  ESP8266
                     * VCC        VCC
                     * CE         GPIO4
                     * CSN/CS     GPIO15
                     * SCK        GPIO14
                     * MISO       GPIO12
                     * MOSI       GPIO13
                     * GND        GND
                    #include <EEPROM.h>
                    // #define MY_LEDS_BLINKING_FEATURE
                      #include <WiFiUDP.h>
                    It is still displaying the WiFi settings from the previous upload:
                    • G
                      G
                      gloob
                      Good morning,
                      I have now tested everything on an other PC and still have the same problem.
                      I use the following versions for my test now:
                      ESP8266: 2.3
                      MySensors: 2.0
                      WiFi: 1.2.7
                      Arduino IDE: 1.6.13
                      Regards
                      Stefan
                      • G gloob
                        Good morning,
                        ESP8266: 2.3
                        MySensors: 2.0
                        WiFi: 1.2.7
                        Arduino IDE: 1.6.13
                        Regards
                        Stefan
                        @gloob I guess I have to replay it then. Busy today.. I'll get back to you
                        • G
                          G
                          gloob
                          I found some kind of "solution"
                          I did now reset the configuration of the ESP8266 with:
                           ESP.eraseConfig();
                           ESP.reset();
                          And now it accepts the new WiFi configuration with each upload of a sketch.
                          I hope this helps other people that have the same problem.
                          YveauxY K 2 Replies Last reply
                          • G gloob
                             ESP.eraseConfig();
                             ESP.reset();
                            @gloob great to hear you got it working!
                            Apparently the mysensors library is using the api correctly (as it is working now)
                            • G gloob
                               ESP.eraseConfig();
                               ESP.reset();
                              K
                              K
                              kalle
                              wrote on last edited by kalle
                              @gloob You can also flash first the Wemos with the "eraseEEprom.ino" from the Arduino sketch examples before you upload the gateway sketch ;-)
                              • K kalle
                                @kalle that probably won't work as it will only erase the mysensors part of the eeprom (simulated in flash) while this issue is about esp caching it's wifi settings internally.
                                But, feel free to try :satisfied:
