  3. Using before()
Using before()
9 Posts 3 Posters 3.2k Views 3 Watching
  • JapioJ Offline
    JapioJ Offline
    Japio
    I have created a "MyVersion" of the ESP8266 Mqtt gateway. To show detailed state of the gateway (things like message received, message sent, wifi connection and strength) I connected a Neopixel Stick (8 RGB leds) to the ESP8266.
    To initialize the leds I created a function setup_leds() that initializes the Neopixel library and does some sort of walking light across the RGB colors of each LED.
    So far no problems.
    However, when I call the setup_leds() from the void before() function, the gateway is not able to get an IP address. If I move this call to setup() it does get an ip address.
    This output is with setup_leds() in before():
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGE--,VER=2.0.1-beta
    0;255;3;0;9;MCO:BGN:BFR
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 8
    cnt
    connected with XXXX, channel x
    dhcp client start...
    ip:192.168.X.XX,mask:255.255.255.0,gw:192.168.X.XXX
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    0;255;3;0;9;TSM:READY
    f r0, scandone
    .pm open,type:2 0
    This reproduces 100% of the time. My question is: What is the problem here? Is it possible to use the before? Are there time constraints on placing code in before()?
    Y 2 Replies Last reply
    • JapioJ Japio
      So far no problems.
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 8
      cnt
      f r0, scandone
      .pm open,type:2 0
      Y Offline
      Y Offline
      @Japio what version of the mysensors library are you using?
      • Y Yveaux
        @Yveaux lokks like VER=2.0.1-beta
        Y 1 Reply Last reply
          Y Offline
          Y Offline
          Someone should post a topic requesting the code windows to be enlarged :blush:
          • JapioJ Japio
            So far no problems.
            scandone
            state: 0 -> 2 (b0)
            state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 8
            cnt
            f r0, scandone
            .pm open,type:2 0
            Y Offline
            Y Offline
            @Japio could you try with 2.1? Some things have changed in the startup order.
            • JapioJ Offline
              JapioJ Offline
              Japio
              Indeed it is 2.0.1 beta.
              Yes, I 'll try tonight, and report back on the result.
              • JapioJ Offline
                JapioJ Offline
                Japio
                I installed 2.2.0 beta and indeed something has changed, but nothing that helps me:
                Placed the setup_led() in before():
                0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGE--,VER=2.2.0-beta
                scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 5 (10)
                add 0
                aid 8
                cnt
                connected with XXXX, channel 6
                ip:192.168.X.x,mask:255.255.255.0,gw:192.168.X.X
                Going to MySensors Application mode
                - Broker Ip Address: 192.168.X.X
                - Broker Port: 1883
                - Network name: XXXX
                0;255;3;0;9;TSF:LRT:OK
                0;255;3;0;9;TSF:WUR:MS=0
                f r0, scandone
                .....0;255;3;0;9;TSF:MSG:READ,20-20-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;TSF:MSG:BC
                0;255;3;0;9;TSF:MSG:FPAR REQ,ID=20
                0;255;3;0;9;TSF:PNG:SEND,TO=0
                0;255;3;0;9;TSF:CKU:OK
                0;255;3;0;9;TSF:MSG:GWL OK
                0;255;3;0;9;TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                ...0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                0;255;3;0;9;TSF:MSG:PINGED,ID=20,HP=1
                0;255;3;0;9;TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                ..0;255;3;0;9;TSF:MSG:READ,20-20-0,s=6,c=1,t=17,pt=7,l=5,sg=0:2660
                0;255;3;0;9;TSF:MSG:READ,20-20-0,s=7,c=1,t=17,pt=7,l=5,sg=0: 0
                pm open,type:2 0
                .....................0;255;3;0;9;TSF:MSG:READ,20-20-0,s=6,c=1,t=17,pt=7,l=5,sg=0:2590
                Well, anyway. I moved the setup_led function to the setup() so I am ok for now. But this is still a weird situation.
                • JapioJ Offline
                  JapioJ Offline
                  Japio
                  One more thing I just found out: if I take out the walking-light from the setup_led() it works fine as well.
                  As this takes some time, might there be some kind of race condition during initialization of the MySensors stack?
                  • JapioJ Japio
                    Y Offline
                    Y Offline
                    @Japio I think I've seen the esp start some wifi stuff in parallel to the arduino startup code. Could be that if the gateway setup is delayed the wifi will not start as expected.
                    You could use a timer, initialized from before() to cycle the leds during startup.
                    Just wondering, do you call some form of yield() during the led setup?
                    12.1k
