  2. Announcements
  • aandA aand
    @hausinger -- are you running armbian on your orange pi one?
    H
    H
    hausinger
    Yes, I'm running on armbian on my orange pi one
    • aandA aand
      @jirm Thanks for the suggestion. I've downloaded the raspian image. To duplicate the path I used with armbian, I downloaded TMRh20's RF24 code so I can test the radio with code I've already had up and running on the hardware.. However, this version of raspbian is really bad. So far nothing compiles. Regular raspbian, and armbian on the orange pi one do not have this kind of problem out of the box; they compile a wide range of packages. I'll spend some more time on it to be diligent, but this distro looks like it needs to be put on the abandon pile.
      I tried compiling mysensors gateway too but no luck with that yet either. This is what I get:
      ./configure
      [OK] init system detected: sysvinit
      [OK] Finished.
      make
      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RA
      DIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/log
      .c -o build/drivers/Linux/log.o
      cc1: error: bad value (armv8-a) for -march switch
      cc1: error: bad value (cortex-a53) for -mtune switch
      Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
      jirmJ
      jirmJ
      jirm
      @aand
      Hi again!
      I spend some time seeing and reading some of the files from the mysensors github build and I see some things that can help to understand why the error raised to @aand trying to compile on OPI.
      First say that I´m not a coding expert, so please be nice with my if I´m wrong and say something stupid ;-)
      I see in the .configure file that the machine detection have H3 Soc and this are fine detected , but then I see that selecting type and CPU flags seems not properly selected to match OPI specs , because on OPI soc H3 have a cpu armv7 (not armv8) and is a A20 and not A53.
      So maybe that cpu "selection" is not correct for H3 soc , and is so easy try if anyone that have OPI and have time can change only that values in the config file and try to compile.
      All the values on the A20 line seems correct for the OPI H3 soc, so only needed copy them from the A20 line to the H3 line, and give a try.
      File Configure
      function gcc_cpu_flags {
      local soc=$1
      case $soc in
      BCM2835)
      flags="-march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard"
      BCM2836)
      flags="-march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard"
      AM33XX)
      flags="-march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=hard"
      A10)
      A13)
      A20)
      H3)
      flags="-march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard"
      • M marceloaqno
        @musthafa Yes, set the IP Address to 127.0.0.1 in your openhab for the ethernet gateway.
        musthafa
        @marceloaqno Thank you!
        • eyesoftE
          eyesoftE
          eyesoft
          also on banana pi pro when i trie to compile i'm getting this :
          [OK] machine detected: SoC=A20, Type=unknown, CPU=armv7l.
          [OK] Finished.
          type i think must be BananaPro
          on make :
          -o build/examples_linux/mysgw.o
          ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
          from ./MySensors.h:294,
          compilation terminated.
          so Banana Pi Pro soc A20 it's also on wait list or never worked ?
          jirmJ 1 Reply Last reply
          • eyesoftE eyesoft
            [OK] Finished.
            on make :
            jirmJ
            jirmJ
            jirm
            wrote on last edited by jirm
            #211
            @eyesoft
            Yes...I see. That error is that said @marceloaqno about own mysensors NRF24 drivers and SPI bus adapt for Raspberry, because for now mysensors is only supported at Raspi and arduinos.
            On Banana CPU detection seems work better (I agree type seems not good...maybe you can change this on configure file and give a try to compile to see what happends) and I figure can work too on OPI too only changing that I said before, but then is raised NRF24 driver and SPI error.
            I see that mysensors RF24 driver are derivated from that https://github.com/mz-fuzzy/RF24 build that at same time last this is forked directly from http://tmrh20.github.io/RF24Installer/RPi/install.sh that we know are working fine on OPI and armbian, so I figure that maybe it´s not so much hard to modify mysensors RF24 to adapt to work on OPI.
            Hope any mysensors "coder" ear our call and cand give us some hand to make the changes on the mysensors build and we can compile the mysgw to OPI soon.
            • jirmJ jirm
              @eyesoft
              jirmJ
              jirmJ
              jirm
              #212
              @jirm
              As a side coment, the configure file is on the root Mysensors directory that is buid when you complete the first step "git clone https://github.com/mysensors/MySensors.git" on the mysgw install process.
              Anyone can edit the file with a plain text editor and change the values for see what happens when try compile.
              Regards
              • jirmJ jirm
                @jirm
                Regards
                marceloaqno
                Code Contributor
                @jirm The configure script from MySensor repo is based on the https://github.com/TMRh20/RF24/blob/master/configure. Could you try with theTMRh20 master branch and post the result?
                git clone https://github.com/TMRh20/RF24.git
                cd RF24
                ./configure
                make
                • eyesoftE
                  eyesoftE
                  eyesoft
                  @marceloaqno
                  cd RF24
                  ./configure
                  [SECTION] Detecting arm compilation environment.
                  [OK] arm-linux-gnueabihf-gcc detected.
                  [OK] arm-linux-gnueabihf-g++ detected.
                  [SECTION] Detecting DRIVER
                  [OK] DRIVER detected:SPIDEV.
                  [SECTION] Detecting OS.
                  [INFO] OS detected:LINUX.
                  [SECTION] Preparing configuration.
                  [OK] Finished.
                  make
                  arm-linux-gnueabihf-g++ -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c RF24.cpp
                  arm-linux-gnueabihf-g++ -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/spi.cpp
                  arm-linux-gnueabihf-g++ -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/gpio.cpp
                  arm-linux-gnueabihf-gcc -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/compatibility.c
                  arm-linux-gnueabihf-g++ -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/interrupt.c
                  [Linking]
                  arm-linux-gnueabihf-gcc -pthread -shared -Wl,-soname,librf24.so.1 -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -o librf24.so.1.2.0 RF24.o spi.o gpio.o compatibility.o interrupt.o
                  • OliO Oli
                    How can I update MySensors Gateway from 2.1.0 beta to 2.1.0 stable/final release?
                    marceloaqno
                    Code Contributor
                    @Oli After these steps:
                    cd MySensors
                    to switch to the master branch, run:
                    git checkout master
                    and reinstall the gateway following the same steps from the instructions.
                    • eyesoftE
                      eyesoftE
                      eyesoft
                      @marceloaqno
                      i've tried on banana pi pro :
                      cat /etc/debian_version
                      8.6
                      cat /etc/bananian_platform
                      BananaPro
                      • eyesoftE eyesoft
                        @marceloaqno
                        8.6
                        BananaPro
                        marceloaqno
                        Code Contributor
                        @eyesoft thanks for the feedback, we need to add support for SPIDEV driver in order to use the BananaPi.
                        • M marceloaqno
                          cd RF24
                          ./configure
                          make
                          jirmJ
                          jirmJ
                          jirm
                          #218
                          @marceloaqno Sadly I´m so much bussy and traveling for few days and cannot acces to my OPI´s :-( , but I´m sure someone here (@aand , @hausinger, etc.. ) can give a try on her OPI the things we said before. At least I hope this ...
                          • M marceloaqno
                            jirmJ
                            jirmJ
                            jirm
                            #219
                            @marceloaqno I see some huge steps up on BananaPi...seems only need add SPIDEV support for make it working... :-)
                            • OliO
                              OliO
                              Oli
                              @marceloaqno I am rather copy/paste not a programming kind a guy, so sorry for my lame questions.
                              pi@raspberrypi ~ $ git clone https://github.com/mysensors/MySensors.git
                              fatal: destination path 'MySensors' already exists and is not an empty directory
                              pi@raspberrypi ~/MySensors $ git checkout master
                              Branch master set up to track remote branch master from origin.
                              Switched to a new branch 'master'
                              but after that:
                              make: *** No targets specified and no makefile found. Stop.
                              pi@raspberrypi ~/MySensors $ sudo make install
                              make: *** No rule to make target 'install'. Stop.
                              • eyesoftE
                                eyesoftE
                                eyesoft
                                @Oli ... try :
                                ./configure
                                make
                                sudo make install
                                • OliO
                                  OliO
                                  Oli
                                  @eyesoft same errors
                                  • eyesoftE
                                    eyesoftE
                                    eyesoft
                                    @Oli see commands above how to Install and Build, with git checkout master you are on master if you :
                                    cat README.md
                                    MySensors Library v2.1.0
                                    default on git clone you are on development :
                                    cat README.md
                                    MySensors Library v2.2.0-beta
                                    • OliO Oli
                                      jirmJ
                                      jirmJ
                                      jirm
                                      #224
                                      @Oli First you need delete all Mysensors directory on your machine.
                                      Then use step by step the guide on Mysensors Gateway installation process:
                                      https://www.mysensors.org/build/raspberry
                                      Dont forget put command sudo on sentences if needed.
                                      Regards
                                      • OliO
                                        OliO
                                        Oli
                                        I wanna update not to re install of MySensors. I thought about something like ./updaterelease or ./updatebeta... I spend hours of make it work before, so I leave it as it is. No time or nerves for fighting next couple of days.
                                        mfalkviddM jirmJ 2 Replies Last reply
                                        • OliO Oli
                                          #226
                                          @Oli what did you have to do to make it work? It should just be a matter of following the instructions that @jirm linked to.
                                          EDIT: Since you already have the MySensors repo cloned from git, you can update by running
                                          pi@raspberrypi ~/MySensors $ git pull
                                          Than run configure, make, etc as per the original instructions.
