  2. Announcements
  • aandA
    aandA
    aand
    @hausinger -- are you running armbian on your orange pi one?
    H 1 Reply Last reply
    • OliO
      OliO
      Oli
      How can I update MySensors Gateway from 2.1.0 beta to 2.1.0 stable/final release?
      • M musthafa
        @marceloaqno thank you.
        I have already installed OpenHAB 2 on my RPi. Can I install mysgw on to the same RPi ?
        marceloaqno
        Code Contributor
        @musthafa Yes, set the IP Address to 127.0.0.1 in your openhab for the ethernet gateway.
        • aandA aand
          H
          H
          hausinger
          Yes, I'm running on armbian on my orange pi one
          • aandA aand
            @jirm Thanks for the suggestion. I've downloaded the raspian image. To duplicate the path I used with armbian, I downloaded TMRh20's RF24 code so I can test the radio with code I've already had up and running on the hardware.. However, this version of raspbian is really bad. So far nothing compiles. Regular raspbian, and armbian on the orange pi one do not have this kind of problem out of the box; they compile a wide range of packages. I'll spend some more time on it to be diligent, but this distro looks like it needs to be put on the abandon pile.
            I tried compiling mysensors gateway too but no luck with that yet either. This is what I get:
            ./configure
            [OK] init system detected: sysvinit
            [OK] Finished.
            make
            gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RA
            DIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/log
            .c -o build/drivers/Linux/log.o
            cc1: error: bad value (armv8-a) for -march switch
            cc1: error: bad value (cortex-a53) for -mtune switch
            Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
            jirmJ
            jirmJ
            jirm
            @aand
            Hi again!
            I spend some time seeing and reading some of the files from the mysensors github build and I see some things that can help to understand why the error raised to @aand trying to compile on OPI.
            First say that I´m not a coding expert, so please be nice with my if I´m wrong and say something stupid ;-)
            I see in the .configure file that the machine detection have H3 Soc and this are fine detected , but then I see that selecting type and CPU flags seems not properly selected to match OPI specs , because on OPI soc H3 have a cpu armv7 (not armv8) and is a A20 and not A53.
            So maybe that cpu "selection" is not correct for H3 soc , and is so easy try if anyone that have OPI and have time can change only that values in the config file and try to compile.
            All the values on the A20 line seems correct for the OPI H3 soc, so only needed copy them from the A20 line to the H3 line, and give a try.
            File Configure
            function gcc_cpu_flags {
            local soc=$1
            case $soc in
            BCM2835)
            flags="-march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard"
            BCM2836)
            flags="-march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard"
            AM33XX)
            flags="-march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=hard"
            A10)
            A13)
            A20)
            H3)
            flags="-march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard"
            • M marceloaqno
              musthafa
              @marceloaqno Thank you!
              • eyesoftE
                eyesoftE
                eyesoft
                also on banana pi pro when i trie to compile i'm getting this :
                [OK] machine detected: SoC=A20, Type=unknown, CPU=armv7l.
                [OK] Finished.
                type i think must be BananaPro
                on make :
                -o build/examples_linux/mysgw.o
                ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                from ./MySensors.h:294,
                compilation terminated.
                so Banana Pi Pro soc A20 it's also on wait list or never worked ?
                jirmJ 1 Reply Last reply
                • eyesoftE eyesoft
                  [OK] Finished.
                  on make :
                  jirmJ
                  jirmJ
                  jirm
                  wrote on last edited by jirm
                  #211
                  @eyesoft
                  Yes...I see. That error is that said @marceloaqno about own mysensors NRF24 drivers and SPI bus adapt for Raspberry, because for now mysensors is only supported at Raspi and arduinos.
                  On Banana CPU detection seems work better (I agree type seems not good...maybe you can change this on configure file and give a try to compile to see what happends) and I figure can work too on OPI too only changing that I said before, but then is raised NRF24 driver and SPI error.
                  I see that mysensors RF24 driver are derivated from that https://github.com/mz-fuzzy/RF24 build that at same time last this is forked directly from http://tmrh20.github.io/RF24Installer/RPi/install.sh that we know are working fine on OPI and armbian, so I figure that maybe it´s not so much hard to modify mysensors RF24 to adapt to work on OPI.
                  Hope any mysensors "coder" ear our call and cand give us some hand to make the changes on the mysensors build and we can compile the mysgw to OPI soon.
                  • jirmJ jirm
                    @eyesoft
                    jirmJ
                    jirmJ
                    jirm
                    #212
                    @jirm
                    As a side coment, the configure file is on the root Mysensors directory that is buid when you complete the first step "git clone https://github.com/mysensors/MySensors.git" on the mysgw install process.
                    Anyone can edit the file with a plain text editor and change the values for see what happens when try compile.
                    Regards
                    • jirmJ jirm
                      @jirm
                      Regards
                      marceloaqno
                      Code Contributor
                      @jirm The configure script from MySensor repo is based on the https://github.com/TMRh20/RF24/blob/master/configure. Could you try with theTMRh20 master branch and post the result?
                      git clone https://github.com/TMRh20/RF24.git
                      cd RF24
                      ./configure
                      make
                      • eyesoftE
                        eyesoftE
                        eyesoft
                        @marceloaqno
                        cd RF24
                        ./configure
                        [SECTION] Detecting arm compilation environment.
                        [OK] arm-linux-gnueabihf-gcc detected.
                        [OK] arm-linux-gnueabihf-g++ detected.
                        [SECTION] Detecting DRIVER
                        [OK] DRIVER detected:SPIDEV.
                        [SECTION] Detecting OS.
                        [INFO] OS detected:LINUX.
                        [SECTION] Preparing configuration.
                        [OK] Finished.
                        make
                        arm-linux-gnueabihf-g++ -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c RF24.cpp
                        arm-linux-gnueabihf-g++ -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/spi.cpp
                        arm-linux-gnueabihf-g++ -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/gpio.cpp
                        arm-linux-gnueabihf-gcc -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/compatibility.c
                        arm-linux-gnueabihf-g++ -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/interrupt.c
                        [Linking]
                        arm-linux-gnueabihf-gcc -pthread -shared -Wl,-soname,librf24.so.1 -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -o librf24.so.1.2.0 RF24.o spi.o gpio.o compatibility.o interrupt.o
                        • OliO Oli
                          marceloaqno
                          Code Contributor
                          @Oli After these steps:
                          cd MySensors
                          to switch to the master branch, run:
                          git checkout master
                          and reinstall the gateway following the same steps from the instructions.
                          • eyesoftE
                            eyesoftE
                            eyesoft
                            @marceloaqno
                            i've tried on banana pi pro :
                            cat /etc/debian_version
                            8.6
                            cat /etc/bananian_platform
                            BananaPro
                            • eyesoftE eyesoft
                              @marceloaqno
                              8.6
                              BananaPro
                              marceloaqno
                              Code Contributor
                              @eyesoft thanks for the feedback, we need to add support for SPIDEV driver in order to use the BananaPi.
                              • M marceloaqno
                                cd RF24
                                ./configure
                                make
                                jirmJ
                                jirmJ
                                jirm
                                #218
                                @marceloaqno Sadly I´m so much bussy and traveling for few days and cannot acces to my OPI´s :-( , but I´m sure someone here (@aand , @hausinger, etc.. ) can give a try on her OPI the things we said before. At least I hope this ...
                                • M marceloaqno
                                  jirmJ
                                  jirmJ
                                  jirm
                                  #219
                                  @marceloaqno I see some huge steps up on BananaPi...seems only need add SPIDEV support for make it working... :-)
                                  • OliO
                                    OliO
                                    Oli
                                    @marceloaqno I am rather copy/paste not a programming kind a guy, so sorry for my lame questions.
                                    pi@raspberrypi ~ $ git clone https://github.com/mysensors/MySensors.git
                                    fatal: destination path 'MySensors' already exists and is not an empty directory
                                    pi@raspberrypi ~/MySensors $ git checkout master
                                    Branch master set up to track remote branch master from origin.
                                    Switched to a new branch 'master'
                                    but after that:
                                    make: *** No targets specified and no makefile found. Stop.
                                    pi@raspberrypi ~/MySensors $ sudo make install
                                    make: *** No rule to make target 'install'. Stop.
                                    • eyesoftE
                                      eyesoftE
                                      eyesoft
                                      @Oli ... try :
                                      ./configure
                                      make
                                      sudo make install
                                      • OliO
                                        OliO
                                        Oli
                                        @eyesoft same errors
                                        • eyesoftE
                                          eyesoftE
                                          eyesoft
                                          @Oli see commands above how to Install and Build, with git checkout master you are on master if you :
                                          cat README.md
                                          MySensors Library v2.1.0
                                          default on git clone you are on development :
                                          cat README.md
                                          MySensors Library v2.2.0-beta
