  3. Pin change interrupt not firing with MySensors
39 Posts 7 Posters 15.2k Views 5 Watching
  • scalzS scalz
    for the moment you can't use pin interrupt change lib with mysensors.
    Also, note, pinchange need you handle the change state. these are not working like D2/D3 INT0/1.
    I'm using pinchange with mysensors, but i use raw registers, my own isr for interrupts, and my sleep function.
    • for this you can have a look at how pinchange works here http://gammon.com.au/interrupts
    • or you can also OR your different pins with diodes
    elysionE
    elysionE
    elysion
    Thanks for the reply scalz!
    I'm not sure what you mean by "pin interrupt change lib", but I would assume it would be possible to use the CHANGE type when calling gw.sleep as in the examples: https://github.com/mysensors/MySensors/blob/59550410a3f55f11b39aacfcaaa2dd8926682673/libraries/MySensors/examples/MotionSensor/MotionSensor.ino#L64
    I have only connected the one motion sensor to my board and the interrupt handler just sends the current state (tripped / not tripped) to the controller. Thus I do not think I need to do anything special here.
    To clarify, I am using the MotionSensor.ino code without any modifications on my board. The execution reaches the gw.sleep call without problems, but does not resume even if the pin state changes. I am able to read the value from the pin by setting SLEEP_TIME to 1000 and this way confirm that the value of the pin does change and that can be read correctly.
      okay!
      you're right, i misread because of the title "pin change" lol . So you're using D3, clear :)
      quickly checked the lib, but i don't see anything fancy for the moment. if i find time, perhaps i'll try to reproduce but i've not heard others having this issue. Do you have this problem without doing any changes in the Motion sketch?
      elysionE 1 Reply Last reply
      • scalzS scalz
        okay!
        elysionE
        elysionE
        elysion
        What I am currently uploading is the unmodified version of MotionSensor.ino linked above. I have previously build a motion sensor using a 3.3V pro mini with the same code. The only difference that I can think of with my current setup is that I am using the internal RC oscillator instead of the external and have changed the fuses accordingly by using the bootloader upload in Arduino IDE. I used the following board configuration:
        atmega328PstandaloneInt8MHz.name=Standalone ATmega328P (ATmega boot, internal 8MHz)
        atmega328PstandaloneInt8MHz.upload.tool=arduino:avrdude
        atmega328PstandaloneInt8MHz.upload.protocol=arduino
        atmega328PstandaloneInt8MHz.upload.maximum_size=30720
        atmega328PstandaloneInt8MHz.upload.maximum_data_size=2048
        atmega328PstandaloneInt8MHz.upload.speed=57600
        atmega328PstandaloneInt8MHz.bootloader.tool=arduino:avrdude
        atmega328PstandaloneInt8MHz.bootloader.low_fuses=0xE2
        atmega328PstandaloneInt8MHz.bootloader.high_fuses=0xDA
        atmega328PstandaloneInt8MHz.bootloader.extended_fuses=0xFD
        atmega328PstandaloneInt8MHz.bootloader.unlock_bits=0x3F
        atmega328PstandaloneInt8MHz.bootloader.lock_bits=0x0F
        atmega328PstandaloneInt8MHz.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
        atmega328PstandaloneInt8MHz.build.mcu=atmega328p
        atmega328PstandaloneInt8MHz.build.f_cpu=8000000L
        atmega328PstandaloneInt8MHz.build.board=AVR_PRO
        atmega328PstandaloneInt8MHz.build.core=arduino
        atmega328PstandaloneInt8MHz.build.variant=standard```
        • I
          I
          idstone
          wrote on last edited by idstone
          Hi.
          Perhaps I ran into a similar issue?
          I created a new node with older 1.5.x version of my sensors-library.
          But I was not able to get a door-contact working via interrupt on pin 3 with a sketch I used more than 5 times before.
          Last change I can remember, was updating Arduino IDE for MacOS Sierra....
          How can I get back a working interrupt controlled door-switch?!
          • I idstone
            Hi.
            elysionE
            elysionE
            elysion
            @idstone: Have you tried passing another mode (e.g. LOW) to gw.sleep method? The issue I am having is that with LOW the interrupt fires, but with CHANGE (which is the default in the sketches) it does not.
            YveauxY I 2 Replies Last reply
            • elysionE elysion
              @elysion Issues were fixed in the 2.1 beta of the MySensors library, so you'd better have a look at this code to see how to wake from interrupt.
              Furthermore, you're using the ATmega out of spec when trying to wake from CHANGE; see http://forum.mysensors.org/topic/250/how-do-i-use-the-interrupt/5
              • elysionE elysion
                I
                I
                idstone
                @elysion
                Hi. It seems, that the problem is related to complete charge of my 3,3V arduino pro's.
                Reaction on interrupt while closing a door-switch on pin 3 works on an older 5V arduino.
                I've read about problems at a customer-evalutation (amazon), especially with arduino pro clones and their interrupt-function.
                Bought some more over store from mysensors on ebay... hope these will work correctly :(
                • I idstone
                  @elysion
                  Can you quote your source please?
                  I 1 Reply Last reply
                  • YveauxY Yveaux
                    I
                    I
                    idstone
                    @Yveaux
                    https://www.amazon.de/Aukru-Redesign-atmega328-ATmega128-Compatible/dp/B00PLD3E1S
                    5.0 von 5 SternenWunderbar!
                    Von Ludwig Enfield am 19. Juli 2015
                    Bei den Arduino Remakes gibt es immer wieder kleine Abweichungen im Pinout. Also aufpassen - das betrifft hier insbeondere die Interrupt-Pins 0 und 1 bzw. die Pins A6/A7 (u.a. Analog-Ports).
                    • I idstone
                      @Yveaux
                      @idstone thanks!
                      If I understand it correctly, the feedback states the pinout of arduino pro mini clones is often slightly different, especially on interrupt pins and analog.
                      For analog pins this is certainly true, for interrupt pins I have not experienced this myself (yet).
                      • D
                        DavidZH
                        In one sketch I am using pin change interrupt. But that is a node I built from scratch. I have the feeling the issues arise with the MyS function "sleep()" in combination with a set time. As long as I call sleep(0xff,0x00, 0xff, 0x00, 0);
                        pin change interrupts work. As soon as I change any of the parameters, the node will not wake up anymore.
                        That was on 2.0 I have yet to convert and try it on 2.1.
                        As soon as I have done that, I will post the code .
                        • D DavidZH
                          @DavidZH Just a shot in the dark, but could you try @tekka workaround from https://github.com/mysensors/MySensors/issues/725 and see if it still crashes ?
                          D 1 Reply Last reply
                          • YveauxY Yveaux
                            DavidZH
                            @Yveaux I will try that as soon as I'm back from my winter sports vacation (as far as you can call lush green Alpine meadows that. At least the slopes are well maintained!). I have no access to a node and gateway now.
                            For me it worked for that sketch as it's main function is reading momentary switches, either on mains power or on battery. As soon as I want to add a sensor that needs to send it's info on a set interval I needed it to be on mains power.
                            But like I said, I will convert the sketch to 2.1 this week, and next week I'll give the workaround a shot.
                            Keep you posted!
                            • YveauxY Yveaux
                              @idstone thanks!
                              I
                              I
                              idstone
                              @Yveaux
                              Hey!
                              Got some news... the new charge of Arduino Pros arrived, but the problem persists. So I started more trail ' n error and got something:
                              I installed the Arduino-IDE and mysensors-1.5.4-library on an manjaro-based notebook. I had to do some symlinking to get a newer version of avrdude working and now the same sketch I used before works now!
                              Back to my Mac, flashing the same sketch, the node doesn't work correctly?!
                              So problem seems to be the version of avrdude, which is offered by the arduino-ide?!
                              I finally downgraded to IDE 1.6.8 and especially AVR Boards 1.6.8.
                              Now everything works as expected .... :D
                                So it was just a bug in the latest updates of the ide and boards? I'm having probably the same problem on a mega2560
                                  I
                                  I
                                  idstone
                                  @gohan
                                  I'm not familiar with your problem, but mine was, that the interrupt on pin3 didn't work as expected. So I was not able to use my new sensor as watchdog for my windows/doors. With downgrade of the Arduino-IDE AND especially AVR Boards 1.6.8 my problem is solved now and every change on that interrupt-pin is correctly recognised and send to gateway.
                                  gohanG 1 Reply Last reply
                                  • I idstone
                                    @gohan
                                    @idstone if you don't mind, please take a look at last line of my code https://forum.mysensors.org/topic/5807/interrupt-and-sleep
                                      I
                                      I
                                      idstone
                                      @gohan
                                      Hi again. I can confirm, that I got similar problems... the state of the interrupt pin wasn't correctly recognized, too.
                                      May be You could try downgrading Arduino-IDE and (very important) avr boards (1.6.8) ?!
                                      elysionE gohanG 2 Replies Last reply
                                      • I idstone
                                        @gohan
                                        elysionE
                                        elysionE
                                        elysion
                                        I'll see if I can find time today or tomorrow to try this. Also might be interesting to see whether it would be possible to get around the issue using Platform.io.
                                        • I idstone
                                          @gohan
                                          @idstone
                                          I'll give it a try maybe on another computer just to be safe
