  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.3k Views 11 Watching
  • H hausinger
    I'm using a orangepi one and with your help I can compile it.
    I tried it with a serial gateway. I connected a arduino nano with the gateway serial scath on it through USB to my orangepi one. DMESG say to me, that it is attached to ttyUSB0
    So i tried to build the gateway with:
    ./configure --my-gateway=serial --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200
    make has no errors
    after that, i tried to start it with:
    sudo ./bin/mysgw -d
    Is started but i get this problem:
    Do you know whats wrong with it?
    marceloaqno
    Code Contributor
    @hausinger The problem you are having with your serial gateway (./configure --my-gateway=serial --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200) may be related to this bug:
    https://github.com/mysensors/MySensors/issues/720#issuecomment-270712256
      mihai.aldea
      @Tag I made the test setup and retraced my steps from the previous experiment. While the TMRh20 is working, the problem indeed lies with the ** mysgw** compilation. I'm getting the same error.
      After spending quite some time trying to mitigate the errors I hit a wall and I concluded that the problem is not the different pin numbering but the mysgw source code. I believe the problem is the lack of support for this architecture and with MySensors being so complex and my C++ skills so average, I'm afraid I can't help.
      However, if someone can mitigate the source code to successfully compile, the radio should be initialized with:
      RF24 radio(7, 0);
      7 - CE pin
      0 - CS pin
      More details here: https://github.com/TMRh20/RF24/issues/257
      • M mihai.aldea
        RF24 radio(7, 0);
        7 - CE pin
        0 - CS pin
        Tag
        wrote on last edited by Tag
        #39
        Thanks for the confirmation!!, now lets hope that mysgw, will be fixed/ported to the OPI boards soon!
        would be great to expand the number of systems it will run on..
        R 1 Reply Last reply
        • T Tag
          R
          R
          Reza
          @Tag
          Could you setup my sensors gateway on orange pi one? if you can please help me to build this . thank you
          • R Reza
            @Tag
            Tag
            #41
            @Reza
            Unfortunately the mysgw software does not run native on the OPI systems at this moment.The only option today is to add an arduino to the USB port running i.e the serial gateway sketch (if you do not want to use the USB port, an other option would be using an UART trough the GPIO header, you data will show up on i.e. /dev/ttyS1 if UART 1 is used)
            step 2 will be to install controller software.
            (i tested MyController on the OPI and that works like a charm, and looks pretty cool!)
            See this link on how to build a serial gateway on the arduino. Using this setup you can follow the RaspberryPI tutorials.
            Hopefully mysgw will run soon on the OrangePI systems! think this is work in progress......
              marceloaqno
              Code Contributor
              wrote on last edited by marceloaqno
              #42
              I'm trying to add support for Orange Pi to MySensors, this is the work-in-progress repository:
              https://github.com/marceloaqno/MySensors/tree/spidev
              It would be great if someone could test and submit results from the configure and make commands:
              git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
              cd marceloaqno-spidev
              git checkout spidev
              ./configure
              make
              T 2 Replies Last reply
              • M marceloaqno
                git checkout spidev
                ./configure
                make
                Tag
                @marceloaqno
                Hi!, really appreciate your hard work on this!!, below are the results,
                (I was not able to execute the 1st command :( but... tried something else..
                root@orangepizero:~# git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
                Cloning into 'marceloaqno-spidev'...
                remote: Counting objects: 13834, done.
                remote: Compressing objects: 100% (26/26), done.
                remote: Total 13834 (delta 2), reused 0 (delta 0), pack-reused 13808
                Receiving objects: 100% (13834/13834), 9.67 MiB | 3.16 MiB/s, done.
                Resolving deltas: 100% (8289/8289), done.
                Checking connectivity... done.
                root@orangepizero:~# cd marceloaqno-spidev
                root@orangepizero:~/marceloaqno-spidev# git checkout spidev
                Branch spidev set up to track remote branch spidev from origin.
                Switched to a new branch 'spidev'
                root@orangepizero:~/marceloaqno-spidev# ./configure
                [OK] Finished.
                root@orangepizero:~/marceloaqno-spidev# make
                gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                /tmp/ccVhf8xP.s: Assembler messages:
                /tmp/ccVhf8xP.s:14808: Warning: IT blocks containing 32-bit Thumb instructions are deprecated in ARMv8
                g++ -MT build/drivers/SPIDEV/SPI.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_GPIO_CAPABLE -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/SPIDEV/SPI.cpp -o build/drivers/SPIDEV/SPI.o
                g++ -pthread -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/IPAddress.o build/drivers/Linux/compatibility.o build/drivers/Linux/interrupt.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/SPIDEV/SPI.o
                root@orangepizero:~/marceloaqno-spidev# ll bin
                total 640
                -rwxr-xr-x 1 root root 654544 Jan 7 22:48 mysgw
                Seems we have a binary!!
                :D
                • M marceloaqno
                  git checkout spidev
                  ./configure
                  make
                  Tag
                  #44
                  @marceloaqno
                  Just hooked up a radio to the GPIO header. (used this link for the model 1 RPI https://www.mysensors.org/build/raspberry and attached the interrupt pin also to pin 15)
                  This is the result i get
                  root@orangepizero:~/marceloaqno-spidev/bin# mysgw
                  mysgw: Starting gateway...
                  mysgw: Could not open /sys/class/gpio/gpio10/direction
                  Illegal instruction
                  M 2 Replies Last reply
                  • T Tag
                    @marceloaqno
                    Illegal instruction
                    marceloaqno
                    Code Contributor
                    #45
                    @Tag Great! The mapping of the physical GPIO number in OrangePi is not ready yet, so you need to figure out the correct value for the CE and CSN pins by adding this to the examples_linux/mysgw.cpp or MyConfig.h
                    #define MY_RF24_CE_PIN X
                    #define MY_RF24_CS_PIN Y
                    This is the best pinout image I've found that could help:
                    https://oshlab.com/orange-pi-zero-pinout/
                    This may also give you some hint:
                    cat /sys/kernel/debug/gpio
                    • M marceloaqno
                      marceloaqno
                      Code Contributor
                      #46
                      @Tag Maybe this one can help too:
                      http://orange314.com/WiringOP
                      • M marceloaqno
                        marceloaqno
                        Code Contributor
                        @Tag also, please don't set the interrupt pin for now.
                        • T Tag
                          @marceloaqno
                          Illegal instruction
                          marceloaqno
                          Code Contributor
                          @Tag I found more information on the wiki page about the gpio pins:
                          http://linux-sunxi.org/GPIO
                          It seems that there is a calculation to be made to know which number to use :scream:
                          • T
                            Tag
                            #49
                            @marceloaqno
                            Hi!!, many thanks for the info!! really helpful!
                            Made some progress. first I created this table based on this page: http://linux-sunxi.org/GPIO
                            Pin - Num - Name - Calculated value A=1 ((1-1)*32 + Pin)
                            CE / 22 / PA02 / 2
                            SCK / 23 / PA14 / 14
                            MISO / 21 / PA16 / 16
                            CSN / 24 / PA13 / 13
                            MOSI / 19 / PA15 / 15
                            Now it is important that you know which kernel is used on your systems the 4.x architecture is different compared to the 3.x arch...
                            If the 4.x kernel is used you need to use the calculated value for the GPIO pin numbering, i could not test that since I am using the 3.x kernel, so this is what i did:
                            1. load the GPIO kernel module:
                            modprobe gpio-sunxi
                            1. Create the GPIO device files since these were not available on my system by default.
                            for A in 1 2 3 4 5 6 7 8 9 10 11 12; do echo "$A" > /sys/class/gpio/export ; done
                            This created the following entries in /sys/class/gpio
                            root@orangepizero:~/marceloaqno-spidev/bin# ls -l /sys/class/gpio
                            total 0
                            --w------- 1 root root 4096 Jan  8 07:39 export
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio1 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio1
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio11 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio11
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio12 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio12
                            lrwxrwxrwx 1 root root    0 Jan  8 07:32 gpio13 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio13
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio2 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio2
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio3 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio3
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio4 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio4
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio5 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio5
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio6 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio6
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio7 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio7
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio8 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio8
                            lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio9 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio9
                            lrwxrwxrwx 1 root root    0 Jan  1  1970 gpiochip0 -> ../../devices/platform/sunxi-pinctrl/gpio/gpiochip0
                            --w------- 1 root root 4096 Jan  1  1970 unexport
                            Modified mysgw.cpp to use:
                            #define MY_RF24_CE_PIN 2
                            #define MY_RF24_CS_PIN 13
                            And did a clean build:
                            make clean
                            ./configure
                            make
                            Now some thing has changed! :)
                            root@orangepizero:~/marceloaqno-spidev/bin# ./mysgw -d
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: !TSM:INIT:TSP FAIL
                            mysgw: TSM:FAIL:CNT=1
                            mysgw: TSM:FAIL:PDT
                            Will do some more testing with an LED today see if the GPIO pin numbering that was created is okay,
                            will keep you posted!:
                            • T
                              Tag
                              #50
                              @marceloaqno
                              Did some testing,
                              Setup the GPIO pins:
                              modprobe gpio-sunxi
                              for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
                              done
                              (The device files that are created by the commands above do not survive a reboot, so remember to execute the above commands after each reboot!)
                              Hooked up an led between ground and i.e. pin 22, this pin is linked to GPIO2
                              Then:
                              echo out > /sys/class/gpio/gpio2/direction
                              echo 1 > /sys/class/gpio/gpio2/value
                              echo 0 > /sys/class/gpio/gpio2/value
                              And eureka!! Led went on and off :D
                              Did this for all GPIO ports used by mysgw, below is the verified pin / GPIO table
                              Pin#  -  GPIO / NRF24
                              22 - GPIO2   / CE
                              23 - GPIO14  / SCK
                              21 - GPIO16  / MISO
                              24 - GPIO13  / CSN
                              19 - GPIO15  / MOSI
                              Tested all pins and led went on and off on all
                              How i connected the radio: https://www.mysensors.org/build/raspberry (see the Pi1 part)
                              How to setup GPIO: http://linux-sunxi.org/GPIO (3.x kernel part, and added pin 13/14/15/16)
                              Pinout for the OPI Zero: https://i1.wp.com/oshlab.com/wp-content/uploads/2016/11/Orange-Pi-Zero-Pinout-banner2.jpg?fit=1200%2C628&ssl=1 (carefully look at the pin numbering!)
                              Maybe it is usefull, I rebuild mysgw with NRF24 radio debugging enabled, this is the output I get:
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: RF24:write register, reg=0, value=14
                              mysgw: RF24:write register, reg=3, value=3
                              mysgw: RF24:write register, reg=4, value=95
                              mysgw: RF24:write register, reg=5, value=76
                              mysgw: RF24:write register, reg=6, value=39
                              mysgw: RF24:write register, reg=16, value=115
                              mysgw: RF24:write register, reg=29, value=6
                              mysgw: RF24:read register, reg=6, value=0
                              mysgw: RF24:read register, reg=5, value=0
                              mysgw: !RF24:INIT:SANCHK FAIL
                              mysgw: TSM:FAIL:PDT
                              mysgw: RF24:write register, reg=0, value=12
                              mysgw: RF24:PD
                              ^Cmysgw: Received SIGINT
                              keeps looping, until ctrl-c is given.
                              • T Tag
                                @marceloaqno
                                CE / 22 / PA02 / 2
                                modprobe gpio-sunxi
                                total 0
                                make clean
                                ./configure
                                make
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: TSM:FAIL:PDT
                                mihai.aldea
                                CE / 22 / PA02 / 482
                                SCK / 23 / PA14 / 494
                                MISO / 21 / PA16 / 496
                                CSN / 24 / PA13 / 493
                                MOSI / 19 / PA15 / 495
                                Are you sure this is correct?
                                The formula is: (position of letter in alphabet - 1) * 32 + pin number
                                For PA02 for instance the correct value is:
                                PA02 = (1 - 1) * 32 + 02 = 2
                                Actually you don't need to use the formula at all with the PA ports, all you have to do is use the trailing number.
                                • M mihai.aldea
                                  Tag
                                  @mihai.aldea
                                  You are right, took the letter P, which is 16.... but is should have been A.... (for the 4.x kernel)
                                  Updated the table!,
                                  Thx!!
                                  • R
                                    R
                                    Reza
                                    wrote on last edited by Reza
                                    #53
                                    i have problem in build gateway on orangepi one
                                    root@OrangePI:~/marceloaqno-spidev# make
                                    Makefile:16: Makefile.inc: No such file or directory
                                    [Running configure]
                                    [OK] Finished.
                                    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                    g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                    g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                    g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                                    g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                    g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                    g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                    g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                    g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                    g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                                    drivers/Linux/interrupt.cpp: In function ‘void* interruptHandler(void*)’:
                                    drivers/Linux/interrupt.cpp:107:26: warning: ignoring return value of ‘ssize_t read(int, void*, size_t)’, declared with attribute warn_unused_result [-Wunused-result]
                                       (void)read (fd, &c, 1) ;
                                    g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                    g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                    g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                    In file included from ./MySensors.h:294:0,
                                                     from examples_linux/mysgw.cpp:74:
                                    ./drivers/RF24/RF24.cpp:39:11: error: Not supported on this platform.
                                      hwDigitalWrite(MY_RF24_CS_PIN, level);
                                    ./drivers/RF24/RF24.cpp:44:11: error: Not supported on this platform.
                                      hwDigitalWrite(MY_RF24_CE_PIN, level);
                                    ./drivers/RF24/RF24.cpp:388:11: error: Not supported on this platform.
                                      hwPinMode(MY_RF24_CE_PIN,OUTPUT);
                                    ./drivers/RF24/RF24.cpp:389:11: error: Not supported on this platform.
                                      hwPinMode(MY_RF24_CS_PIN,OUTPUT);
                                    ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
                                     LOCAL void RF24_csn(const bool level)
                                    ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
                                     LOCAL void RF24_ce(const bool level)
                                    ./drivers/RF24/RF24.cpp: In function ‘uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)’:
                                    ./drivers/RF24/RF24.cpp:56:11: error: ‘LOW’ was not declared in this scope
                                      RF24_csn(LOW);
                                    ./drivers/RF24/RF24.cpp:99:11: error: ‘HIGH’ was not declared in this scope
                                      RF24_csn(HIGH);
                                    ./drivers/RF24/RF24.cpp: In function ‘void RF24_startListening()’:
                                    ./drivers/RF24/RF24.cpp:235:10: error: ‘HIGH’ was not declared in this scope
                                      RF24_ce(HIGH);
                                    ./drivers/RF24/RF24.cpp: In function ‘void RF24_stopListening()’:
                                    ./drivers/RF24/RF24.cpp:241:10: error: ‘LOW’ was not declared in this scope
                                      RF24_ce(LOW);
                                    ./drivers/RF24/RF24.cpp: In function ‘void RF24_powerDown()’:
                                    ./drivers/RF24/RF24.cpp:251:10: error: ‘LOW’ was not declared in this scope
                                      RF24_ce(LOW);
                                    ./drivers/RF24/RF24.cpp: In function ‘bool RF24_sendMessage(uint8_t, const void*, uint8_t)’:
                                    ./drivers/RF24/RF24.cpp:269:10: error: ‘HIGH’ was not declared in this scope
                                      RF24_ce(HIGH);
                                    ./drivers/RF24/RF24.cpp:276:10: error: ‘LOW’ was not declared in this scope
                                      RF24_ce(LOW);
                                    ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
                                    ./drivers/RF24/RF24.cpp:395:10: error: ‘LOW’ was not declared in this scope
                                      RF24_ce(LOW);
                                    ./drivers/RF24/RF24.cpp:396:11: error: ‘HIGH’ was not declared in this scope
                                      RF24_csn(HIGH);
                                    Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
                                    i want build a gateway with orangepi one with channel 0 . what am i do ? thank you
                                    • R Reza
                                      [Running configure]
                                      [OK] Finished.
                                        RF24_csn(LOW);
                                        RF24_csn(HIGH);
                                        RF24_ce(HIGH);
                                        RF24_ce(LOW);
                                        RF24_ce(LOW);
                                        RF24_ce(HIGH);
                                        RF24_ce(LOW);
                                        RF24_ce(LOW);
                                        RF24_csn(HIGH);
                                      marceloaqno
                                      Code Contributor
                                      @Reza You need to run:
                                      modprobe gpio-sunxi
                                      so that /sys/class/gpio/export is created.
                                      • T Tag
                                        @mihai.aldea
                                        Updated the table!,
                                        Thx!!
                                        marceloaqno
                                        Code Contributor
                                        #55
                                        @Tag Does the TMRh20 works in the way your radio is currently connected?
                                        • M marceloaqno
                                          Tag
                                          #56
                                          @marceloaqno
                                          The library compiled, but unfortunately i cannot get the examples for linux working.
                                          need to edit i.e. gettingstarted.cpp with the correct pin setting, have tried a lot, but either it says that the radio is not connected, and if used with incorrect settings it will not compile at all....
                                          Maybe someone following this thread who has experince with this lib?
                                          if there is any progress from my side will keep you posted...
