  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.3k Views 11 Watching
  • M marceloaqno
    I'm trying to add support for Orange Pi to MySensors, this is the work-in-progress repository:
    https://github.com/marceloaqno/MySensors/tree/spidev
    It would be great if someone could test and submit results from the configure and make commands:
    git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
    cd marceloaqno-spidev
    git checkout spidev
    ./configure
    make
    Tag
    wrote on last edited by Tag
    #44
    @marceloaqno
    Just hooked up a radio to the GPIO header. (used this link for the model 1 RPI https://www.mysensors.org/build/raspberry and attached the interrupt pin also to pin 15)
    This is the result i get
    root@orangepizero:~/marceloaqno-spidev/bin# mysgw
    mysgw: Starting gateway...
    mysgw: Could not open /sys/class/gpio/gpio10/direction
    Illegal instruction
    M 2 Replies Last reply
    • T Tag
      @marceloaqno
      Illegal instruction
      marceloaqno
      Code Contributor
      wrote on last edited by marceloaqno
      #45
      @Tag Great! The mapping of the physical GPIO number in OrangePi is not ready yet, so you need to figure out the correct value for the CE and CSN pins by adding this to the examples_linux/mysgw.cpp or MyConfig.h
      #define MY_RF24_CE_PIN X
      #define MY_RF24_CS_PIN Y
      This is the best pinout image I've found that could help:
      https://oshlab.com/orange-pi-zero-pinout/
      This may also give you some hint:
      cat /sys/kernel/debug/gpio
      • M marceloaqno
        marceloaqno
        Code Contributor
        #46
        @Tag Maybe this one can help too:
        http://orange314.com/WiringOP
        • M marceloaqno
          marceloaqno
          Code Contributor
          @Tag also, please don't set the interrupt pin for now.
          • T Tag
            @marceloaqno
            Illegal instruction
            marceloaqno
            Code Contributor
            @Tag I found more information on the wiki page about the gpio pins:
            http://linux-sunxi.org/GPIO
            It seems that there is a calculation to be made to know which number to use :scream:
            • T
              Tag
              #49
              @marceloaqno
              Hi!!, many thanks for the info!! really helpful!
              Made some progress. first I created this table based on this page: http://linux-sunxi.org/GPIO
              Pin - Num - Name - Calculated value A=1 ((1-1)*32 + Pin)
              CE / 22 / PA02 / 2
              SCK / 23 / PA14 / 14
              MISO / 21 / PA16 / 16
              CSN / 24 / PA13 / 13
              MOSI / 19 / PA15 / 15
              Now it is important that you know which kernel is used on your systems the 4.x architecture is different compared to the 3.x arch...
              If the 4.x kernel is used you need to use the calculated value for the GPIO pin numbering, i could not test that since I am using the 3.x kernel, so this is what i did:
              1. load the GPIO kernel module:
              modprobe gpio-sunxi
              1. Create the GPIO device files since these were not available on my system by default.
              for A in 1 2 3 4 5 6 7 8 9 10 11 12; do echo "$A" > /sys/class/gpio/export ; done
              This created the following entries in /sys/class/gpio
              root@orangepizero:~/marceloaqno-spidev/bin# ls -l /sys/class/gpio
              total 0
              --w------- 1 root root 4096 Jan  8 07:39 export
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio1 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio1
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio11 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio11
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio12 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio12
              lrwxrwxrwx 1 root root    0 Jan  8 07:32 gpio13 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio13
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio2 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio2
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio3 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio3
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio4 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio4
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio5 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio5
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio6 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio6
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio7 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio7
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio8 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio8
              lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio9 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio9
              lrwxrwxrwx 1 root root    0 Jan  1  1970 gpiochip0 -> ../../devices/platform/sunxi-pinctrl/gpio/gpiochip0
              --w------- 1 root root 4096 Jan  1  1970 unexport
              Modified mysgw.cpp to use:
              #define MY_RF24_CE_PIN 2
              #define MY_RF24_CS_PIN 13
              And did a clean build:
              make clean
              ./configure
              make
              Now some thing has changed! :)
              root@orangepizero:~/marceloaqno-spidev/bin# ./mysgw -d
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: !TSM:INIT:TSP FAIL
              mysgw: TSM:FAIL:CNT=1
              mysgw: TSM:FAIL:PDT
              Will do some more testing with an LED today see if the GPIO pin numbering that was created is okay,
              will keep you posted!:
              • T
                Tag
                #50
                @marceloaqno
                Did some testing,
                Setup the GPIO pins:
                modprobe gpio-sunxi
                for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
                done
                (The device files that are created by the commands above do not survive a reboot, so remember to execute the above commands after each reboot!)
                Hooked up an led between ground and i.e. pin 22, this pin is linked to GPIO2
                Then:
                echo out > /sys/class/gpio/gpio2/direction
                echo 1 > /sys/class/gpio/gpio2/value
                echo 0 > /sys/class/gpio/gpio2/value
                And eureka!! Led went on and off :D
                Did this for all GPIO ports used by mysgw, below is the verified pin / GPIO table
                Pin#  -  GPIO / NRF24
                22 - GPIO2   / CE
                23 - GPIO14  / SCK
                21 - GPIO16  / MISO
                24 - GPIO13  / CSN
                19 - GPIO15  / MOSI
                Tested all pins and led went on and off on all
                How i connected the radio: https://www.mysensors.org/build/raspberry (see the Pi1 part)
                How to setup GPIO: http://linux-sunxi.org/GPIO (3.x kernel part, and added pin 13/14/15/16)
                Pinout for the OPI Zero: https://i1.wp.com/oshlab.com/wp-content/uploads/2016/11/Orange-Pi-Zero-Pinout-banner2.jpg?fit=1200%2C628&ssl=1 (carefully look at the pin numbering!)
                Maybe it is usefull, I rebuild mysgw with NRF24 radio debugging enabled, this is the output I get:
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: RF24:write register, reg=0, value=14
                mysgw: RF24:write register, reg=3, value=3
                mysgw: RF24:write register, reg=4, value=95
                mysgw: RF24:write register, reg=5, value=76
                mysgw: RF24:write register, reg=6, value=39
                mysgw: RF24:write register, reg=16, value=115
                mysgw: RF24:write register, reg=29, value=6
                mysgw: RF24:read register, reg=6, value=0
                mysgw: RF24:read register, reg=5, value=0
                mysgw: !RF24:INIT:SANCHK FAIL
                mysgw: TSM:FAIL:PDT
                mysgw: RF24:write register, reg=0, value=12
                mysgw: RF24:PD
                ^Cmysgw: Received SIGINT
                keeps looping, until ctrl-c is given.
                • T Tag
                  @marceloaqno
                  CE / 22 / PA02 / 2
                  modprobe gpio-sunxi
                  total 0
                  make clean
                  ./configure
                  make
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: TSM:FAIL:PDT
                  mihai.aldea
                  CE / 22 / PA02 / 482
                  SCK / 23 / PA14 / 494
                  MISO / 21 / PA16 / 496
                  CSN / 24 / PA13 / 493
                  MOSI / 19 / PA15 / 495
                  Are you sure this is correct?
                  The formula is: (position of letter in alphabet - 1) * 32 + pin number
                  For PA02 for instance the correct value is:
                  PA02 = (1 - 1) * 32 + 02 = 2
                  Actually you don't need to use the formula at all with the PA ports, all you have to do is use the trailing number.
                  • M mihai.aldea
                    Tag
                    @mihai.aldea
                    You are right, took the letter P, which is 16.... but is should have been A.... (for the 4.x kernel)
                    Updated the table!,
                    Thx!!
                    • R
                      R
                      Reza
                      wrote on last edited by Reza
                      #53
                      i have problem in build gateway on orangepi one
                      root@OrangePI:~/marceloaqno-spidev# make
                      Makefile:16: Makefile.inc: No such file or directory
                      [Running configure]
                      [OK] Finished.
                      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                      g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                      g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                      g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                      g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                      g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                      g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                      g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                      g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                      g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                      drivers/Linux/interrupt.cpp: In function ‘void* interruptHandler(void*)’:
                      drivers/Linux/interrupt.cpp:107:26: warning: ignoring return value of ‘ssize_t read(int, void*, size_t)’, declared with attribute warn_unused_result [-Wunused-result]
                         (void)read (fd, &c, 1) ;
                      g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                      g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                      g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                      In file included from ./MySensors.h:294:0,
                                       from examples_linux/mysgw.cpp:74:
                      ./drivers/RF24/RF24.cpp:39:11: error: Not supported on this platform.
                        hwDigitalWrite(MY_RF24_CS_PIN, level);
                      ./drivers/RF24/RF24.cpp:44:11: error: Not supported on this platform.
                        hwDigitalWrite(MY_RF24_CE_PIN, level);
                      ./drivers/RF24/RF24.cpp:388:11: error: Not supported on this platform.
                        hwPinMode(MY_RF24_CE_PIN,OUTPUT);
                      ./drivers/RF24/RF24.cpp:389:11: error: Not supported on this platform.
                        hwPinMode(MY_RF24_CS_PIN,OUTPUT);
                      ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
                       LOCAL void RF24_csn(const bool level)
                      ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
                       LOCAL void RF24_ce(const bool level)
                      ./drivers/RF24/RF24.cpp: In function ‘uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)’:
                      ./drivers/RF24/RF24.cpp:56:11: error: ‘LOW’ was not declared in this scope
                        RF24_csn(LOW);
                      ./drivers/RF24/RF24.cpp:99:11: error: ‘HIGH’ was not declared in this scope
                        RF24_csn(HIGH);
                      ./drivers/RF24/RF24.cpp: In function ‘void RF24_startListening()’:
                      ./drivers/RF24/RF24.cpp:235:10: error: ‘HIGH’ was not declared in this scope
                        RF24_ce(HIGH);
                      ./drivers/RF24/RF24.cpp: In function ‘void RF24_stopListening()’:
                      ./drivers/RF24/RF24.cpp:241:10: error: ‘LOW’ was not declared in this scope
                        RF24_ce(LOW);
                      ./drivers/RF24/RF24.cpp: In function ‘void RF24_powerDown()’:
                      ./drivers/RF24/RF24.cpp:251:10: error: ‘LOW’ was not declared in this scope
                        RF24_ce(LOW);
                      ./drivers/RF24/RF24.cpp: In function ‘bool RF24_sendMessage(uint8_t, const void*, uint8_t)’:
                      ./drivers/RF24/RF24.cpp:269:10: error: ‘HIGH’ was not declared in this scope
                        RF24_ce(HIGH);
                      ./drivers/RF24/RF24.cpp:276:10: error: ‘LOW’ was not declared in this scope
                        RF24_ce(LOW);
                      ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
                      ./drivers/RF24/RF24.cpp:395:10: error: ‘LOW’ was not declared in this scope
                        RF24_ce(LOW);
                      ./drivers/RF24/RF24.cpp:396:11: error: ‘HIGH’ was not declared in this scope
                        RF24_csn(HIGH);
                      Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
                      i want build a gateway with orangepi one with channel 0 . what am i do ? thank you
                      • R Reza
                        [Running configure]
                        [OK] Finished.
                          RF24_csn(LOW);
                          RF24_csn(HIGH);
                          RF24_ce(HIGH);
                          RF24_ce(LOW);
                          RF24_ce(LOW);
                          RF24_ce(HIGH);
                          RF24_ce(LOW);
                          RF24_ce(LOW);
                          RF24_csn(HIGH);
                        marceloaqno
                        Code Contributor
                        @Reza You need to run:
                        modprobe gpio-sunxi
                        so that /sys/class/gpio/export is created.
                        • T Tag
                          @mihai.aldea
                          Updated the table!,
                          Thx!!
                          marceloaqno
                          Code Contributor
                          #55
                          @Tag Does the TMRh20 works in the way your radio is currently connected?
                          • M marceloaqno
                            Tag
                            #56
                            @marceloaqno
                            The library compiled, but unfortunately i cannot get the examples for linux working.
                            need to edit i.e. gettingstarted.cpp with the correct pin setting, have tried a lot, but either it says that the radio is not connected, and if used with incorrect settings it will not compile at all....
                            Maybe someone following this thread who has experince with this lib?
                            if there is any progress from my side will keep you posted...
                              mihai.aldea
                              wrote on last edited by mihai.aldea
                              #57
                              If you used this wiring scheme:
                              nRF24L01 | Orange Pi
                              _________|________________
                              VCC      | VCC3V3-EXT
                              GND      | GND
                              CSN      | SPI0_CS0 (SPI-CE0)
                              CE       | PA7 (IO-7)
                              MOSI     | SPI0_MOSI (SPI-MOSI)
                              SCK      | SPI0_CLK (SPI-CLK)
                              MISO     | SPI0_MISO (SPI-MISO)
                              Then you should initialize the radio with:
                              RF24 radio(7,0);
                              Worked for me:
                              root@opi-pc-1:~/RF24-master/examples_linux# ./gettingstarted
                              RF24/examples/GettingStarted/
                              STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                              RX_ADDR_P0-1	 = 0x65646f4e32 0x65646f4e31
                              RX_ADDR_P2-5	 = 0xc3 0xc4 0xc5 0xc6
                              TX_ADDR		 = 0x65646f4e32
                              RX_PW_P0-6	 = 0x20 0x20 0x00 0x00 0x00 0x00
                              EN_AA		 = 0x3f
                              EN_RXADDR	 = 0x02
                              RF_CH		 = 0x4c
                              RF_SETUP	 = 0x07
                              CONFIG		 = 0x0e
                              DYNPD/FEATURE	 = 0x00 0x00
                              Data Rate	 = 1MBPS
                              Model		 = nRF24L01+
                              CRC Length	 = 16 bits
                              PA Power	 = PA_MAX
                               ************ Role Setup ***********
                              Choose a role: Enter 0 for pong_back, 1 for ping_out (CTRL+C to exit)
                              M T 2 Replies Last reply
                              • M mihai.aldea
                                VCC      | VCC3V3-EXT
                                GND      | GND
                                CE       | PA7 (IO-7)
                                RF24 radio(7,0);
                                Worked for me:
                                EN_AA		 = 0x3f
                                EN_RXADDR	 = 0x02
                                RF_CH		 = 0x4c
                                RF_SETUP	 = 0x07
                                CONFIG		 = 0x0e
                                Data Rate	 = 1MBPS
                                Model		 = nRF24L01+
                                PA Power	 = PA_MAX
                                marceloaqno
                                Code Contributor
                                @mihai.aldea Could you try the repo I'm working on (https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev) adding your settings to the examples_linux/mysgw.cpp?
                                #define MY_RF24_CE_PIN 7
                                #define MY_RF24_CS_PIN 0
                                • M mihai.aldea
                                  VCC      | VCC3V3-EXT
                                  GND      | GND
                                  CE       | PA7 (IO-7)
                                  RF24 radio(7,0);
                                  Worked for me:
                                  EN_AA		 = 0x3f
                                  EN_RXADDR	 = 0x02
                                  RF_CH		 = 0x4c
                                  RF_SETUP	 = 0x07
                                  CONFIG		 = 0x0e
                                  Data Rate	 = 1MBPS
                                  Model		 = nRF24L01+
                                  PA Power	 = PA_MAX
                                  Tag
                                  #59
                                  @mihai.aldea
                                  Hmmm.... checked the docs again and guess what. the 26 pin header on the OPI Zero has SPI1.... instead of SPI0
                                  Expansion Port
                                  The Orange Pi Zero has a 26-pin, 0.1" unpopulated connector with several low-speed interfaces.
                                  2x13 Header
                                  1	3.3V	           2	5V
                                  3	TWI0_SDA / PA12	   4	5V
                                  5	TWI0_SCK / PA11	   6	GND
                                  7	PWM1 / PA06	       8	UART1_TX / PG06
                                  9	GND	               10	UART1_RX / PG07
                                  11	UART2_RX / PA01	   12	SIM_CLK/PA_EINT7 / PA07
                                  13	UART2_TX / PA00	   14	GND
                                  15	UART2_CTS / PA03   16	TWI1-SDA / PA19
                                  17	3.3V	           18	TWI1-SCK / PA18
                                  19	SPI1_MOSI / PA15   20	GND
                                  21	SPI1_MISO / PA16   22	UART2_RTS / PA02
                                  23	SPI1_CLK / PA14    24	SPI1_CS / PA13
                                  25	GND	               26	SIM_DET/PA_EINT10 / PA10
                                  From http://linux-sunxi.org/Xunlong_Orange_Pi_Zero
                                  If i look at /dev I only see spi0, which is most probably used for the onboard flash...
                                  root@orangepizero:/# ll /dev | grep -i spi
                                  crw------- 1 root root    153,   0 Jan  8 11:12 spidev0.0
                                  So now i need to figure out a way to get SPI1 up and running
                                  • M marceloaqno
                                    mihai.aldea
                                    @marceloaqno Here's the output:
                                    ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                                                     from ./MySensors.h:294,
                                                     from examples_linux/mysgw.cpp:77:
                                    compilation terminated.
                                      mihai.aldea
                                      @Tag Use this info:
                                      http://linux-sunxi.org/Sunxi-tools
                                      To export /boot/script.bin, edit the output file and enable SPI1, then compile it back and reboot your OPi with the SPI1 active.
                                      If you haven't done this before, it's quite simple.
                                      apt-get install sunxi-tools
                                      cd ~
                                      bin2fex /boot/script.bin > script.fex
                                      Edit the script.fex file, find the [spi1] section and change spi_used = 0 to spi_used = 1. Save the file and exit.
                                      Then
                                      fex2bin script.fex > /boot/script.bin
                                      Reboot, then you should have the SPI1 active.
                                      • R
                                        R
                                        Reza
                                        @marceloaqno
                                        i have error yet
                                        orangepi is a good board. please work at this board and run mysensors gateway on this, i follow this topic when you can fix this on orange pi . thank you
                                        • M mihai.aldea
                                          @Tag Use this info:
                                          cd ~
                                          Then
                                          Tag
                                          #63
                                          @mihai.aldea
                                          Yep already found it :) problem was the old version of the tools, it was not able to decompile the script.bin file...
                                          [update]
                                          • modified the script file,
                                          • changed spi_used = 1
                                          • compiled back and rebooted
                                          just 1 device file in called spidev0.0 no new device files are created..... :(
                                          dmesg output:
                                          [    0.814287] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
                                          [    0.814316] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
                                          [    0.815569] spi spi0: master is unqueued, this is deprecated
                                          [    0.816776] spi spi1: master is unqueued, this is deprecated
                                          Thx, will keep you posted!
