  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.6k Views 37 Watching
  • asgardroA
    asgardroA
    asgardro
    And this is my log from DZ
    2017-01-10 22:00:28.664 MySensors: Node: 254, Sketch Name: Energy Meter
    2017-01-10 22:00:28.675 MySensors: Node: 254, Sketch Version: 1.0
    2017-01-10 22:00:33.737 (Gate) General/kWh (Meter)
    2017-01-10 22:00:33.761 (Gate) General/kWh (Meter)
    2017-01-10 22:01:34.631 (Gate) Temp + Humidity (GatewayBed1)
    2017-01-10 22:01:37.207 (Gate) Temp (Radio Room)
    2017-01-10 22:01:46.109 (Gate) General/Barometer (Pressure)
    2017-01-10 22:02:34.570 (Gate) Temp + Humidity (GatewayBed1)
    2017-01-10 22:02:34.573 (Gate) Temp + Humidity (GatewayBed1)
    2017-01-10 22:03:34.510 (Gate) Temp + Humidity (GatewayBed1)
    2017-01-10 22:03:34.513 (Gate) Temp + Humidity (GatewayBed1)
    2017-01-10 22:03:50.973 (Gate) Temp (Radio Room)
    2017-01-10 22:04:03.239 (Gate) Temp (Outside)
    2017-01-10 22:04:03.249 (Gate) General/Barometer (Pressure)
    • F
      F
      flopp
      can you please print your code?
      I am not so good to read the Message structure but it look like it present temperature and other stuff
      • asgardroA
        asgardroA
        asgardro
        Ah the gateway works fine with other sensors
        The code for the pulse power meter is the one in the example
        F 1 Reply Last reply
        • asgardroA asgardro
          i do not get Serial.print("Received last pulse count from gw:"); in serial output
          F
          F
          flopp
          Yes you do, look at the last line and you will see it.
            F
            F
            flopp
            wrote on last edited by flopp
            #32
            @asgardro
            change SEND_FREQUENCY to 5000, upload to Arduino, when you see Received from GW, trig Digital Input 3 and after 5 seconds it should send data to DZ again
            • asgardroA
              asgardroA
              asgardro
              Done that... reset everything..still the same
              here is my code
              #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your light sensor. (Only 2 and 3 generates interrupt!)
              #define PULSE_FACTOR 1000 // Nummber of blinks per KWH of your meeter
              #define SLEEP_MODE false // Watt-value can only be reported when sleep mode is false.
              #define MAX_WATT 10000 // Max watt value to report. This filetrs outliers.
              #define CHILD_ID 1 // Id of the sensor child
              unsigned long SEND_FREQUENCY = 5000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
              double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
              bool pcReceived = true;
              unsigned long oldPulseCount = 0;
              unsigned long oldWatt = 0;
              double oldKwh;
              unsigned long lastSend;
              MyMessage wattMsg(CHILD_ID,V_WATT);
              MyMessage kwhMsg(CHILD_ID,V_KWH);
              MyMessage pcMsg(CHILD_ID,V_VAR1);
              request(CHILD_ID, V_VAR1);
              pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
              attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
              lastSend=millis();
              present(CHILD_ID, S_POWER);
              unsigned long now = millis();
              if (pcReceived && (SLEEP_MODE || sendTime)) {
              if (!SLEEP_MODE && watt != oldWatt) {
              if (watt<((unsigned long)MAX_WATT)) {
              send(wattMsg.set(watt)); // Send watt value to gw
              Serial.print("Watt:");
              Serial.println(watt);
              oldWatt = watt;
              // Pulse cout has changed
              if (pulseCount != oldPulseCount) {
                send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                oldPulseCount = pulseCount;
                if (kwh != oldKwh) {
                  send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                  oldKwh = kwh;
              lastSend = now;
              } else if (sendTime && !pcReceived) {
              // No count received. Try requesting it again
              lastSend=now;
              if (SLEEP_MODE) {
              sleep(SEND_FREQUENCY);
              if (message.type==V_VAR1) {
              pulseCount = oldPulseCount = message.getLong();
              Serial.println(pulseCount);
              pcReceived = true;
              void onPulse()
              if (!SLEEP_MODE) {
              unsigned long interval = newBlink-lastBlink;
              if (interval<10000L) { // Sometimes we get interrupt on RISING
              return;
              watt = (3600000000.0 /interval) / ppwh;
              lastBlink = newBlink;
              pulseCount++;
              F V 3 Replies Last reply
                here is my code
                double oldKwh;
                lastSend=millis();
                oldWatt = watt;
                    oldKwh = kwh;
                lastSend = now;
                lastSend=now;
                if (SLEEP_MODE) {
                pcReceived = true;
                void onPulse()
                if (!SLEEP_MODE) {
                return;
                pulseCount++;
                F
                F
                flopp
                @asgardro
                don't forget to use CODE function when posting code.
                If you don't see any reaction when you trig Digital 3 i don't know what can be the problem,
                Have you tried another Arduino?
                  here is my code
                  double oldKwh;
                  lastSend=millis();
                  oldWatt = watt;
                      oldKwh = kwh;
                  lastSend = now;
                  lastSend=now;
                  if (SLEEP_MODE) {
                  pcReceived = true;
                  void onPulse()
                  if (!SLEEP_MODE) {
                  return;
                  pulseCount++;
                  F
                  F
                  flopp
                  @asgardro
                  change bool pcReceived to false
                  • asgardroA
                    asgardroA
                    asgardro
                    ooops sorry about that... just found the function lol
                    the sensor inits itself once and then doesn't do anything/ i don't know through what miracle i got the pulse count.
                    will try another arduino... i do not think it is a radio problem..
                    thanks for your help
                    • asgardroA
                      asgardroA
                      asgardro
                      wrote on last edited by asgardro
                      #37
                      changed it to false.
                      put it true before to try to force the sensor sending independent of the count.. if i am correct
                      still the same outcome... will try tomorrow diffrent hardware
                      anyway, thanks a lot for the help
                        F
                        F
                        flopp
                        Yes it will but it will only send 0 to VAR in DZ so it will be a loop of same value.
                        Maybe that's why it never sends again.
                        Try now to trig digital 3
                        • asgardroA
                          asgardroA
                          asgardro
                          sorry for the next noob question but what do you mean by trigginh the pin 3? simulating the sensor? if yes i done that.. i have a led blinking
                            F
                            F
                            flopp
                            @asgardro
                            what have you connected to digital 3?
                            asgardroA 1 Reply Last reply
                            • asgardroA
                              asgardroA
                              asgardro
                              this is the code now
                               * Version 1.0 - Henrik EKblad
                               * This sketch provides an example how to implement a distance sensor using HC-SR04
                               * Use this sensor to measure KWH and Watt of your house meeter
                               * You need to set the correct pulsefactor of your meeter (blinks per KWH).
                               * The sensor starts by fetching current KWH value from gateway.
                               * Reports both KWH and Watt back to gateway.
                               * Unfortunately millis() won't increment when the Arduino is in
                               * sleepmode. So we cannot make this sensor sleep if we also want
                               * to calculate/report watt-number.
                               * http://www.mysensors.org/build/pulse_power
                              // Enable debug prints
                              bool pcReceived = false;
                              double oldKwh;
                                lastSend=millis();
                                    oldWatt = watt;
                                      oldKwh = kwh;
                                  lastSend = now;
                                  lastSend=now;
                                if (SLEEP_MODE) {
                                  pcReceived = true;
                              void onPulse()
                                if (!SLEEP_MODE) {
                                    return;
                                pulseCount++;
                              • F flopp
                                @asgardro
                                asgardroA
                                asgardroA
                                asgardro
                                @flopp
                                i have connected the digital out from the sensor
                                  @flopp
                                  F
                                  F
                                  flopp
                                  #43
                                  @asgardro said:
                                  @flopp
                                  Do you mean LM393?
                                  Can you put a flash light in front of the sensor so trigger it. You shall now see some text in serial monitor
                                  asgardroA 2 Replies Last reply
                                  • F flopp
                                    @asgardro said:
                                    @flopp
                                    Do you mean LM393?
                                    asgardroA
                                    asgardroA
                                    asgardro
                                    @flopp
                                    lm393
                                      @flopp
                                      lm393
                                      F
                                      F
                                      flopp
                                      @asgardro said:
                                      @flopp
                                      lm393
                                      Have you trimmed the pot so the LED turns on when your power meter flash?
                                      • F flopp
                                        @asgardro said:
                                        @flopp
                                        Do you mean LM393?
                                        asgardroA
                                        asgardroA
                                        asgardro
                                        @flopp
                                        i have done that and calibrated the lm393 , i have a blinking light that triggers the sensor. thats how i am testing...but after initializing sends the value first time and thats it
                                        sorry to reply so late but have to wait 120seconds between posts lol
                                        • asgardroA
                                          asgardroA
                                          asgardro
                                          //#define MY_RF24_CHANNEL 74
                                          double oldKwh;
                                            lastSend=millis();
                                            Serial.println("7");
                                          //Serial.println("6");
                                                oldWatt = watt;
                                          Serial.println("5");
                                                  oldKwh = kwh;
                                                Serial.println("4");
                                              lastSend = now;
                                              lastSend=now;
                                          Serial.println("3");
                                            if (SLEEP_MODE) {
                                            Serial.println("2");
                                          Serial.println("rece");
                                          pcReceived = true;
                                          Serial.println("not_rece");
                                          void onPulse()
                                            if (!SLEEP_MODE) {
                                                return;
                                            pulseCount++;
                                            Serial.println("1");
                                          this
