  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.0k Views 37 Watching
  • asgardroA asgardro
    Done that... reset everything..still the same
    here is my code
    #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your light sensor. (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR 1000 // Nummber of blinks per KWH of your meeter
    #define SLEEP_MODE false // Watt-value can only be reported when sleep mode is false.
    #define MAX_WATT 10000 // Max watt value to report. This filetrs outliers.
    #define CHILD_ID 1 // Id of the sensor child
    unsigned long SEND_FREQUENCY = 5000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    bool pcReceived = true;
    unsigned long oldPulseCount = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
    MyMessage pcMsg(CHILD_ID,V_VAR1);
    request(CHILD_ID, V_VAR1);
    pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
    attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
    lastSend=millis();
    present(CHILD_ID, S_POWER);
    unsigned long now = millis();
    if (pcReceived && (SLEEP_MODE || sendTime)) {
    if (!SLEEP_MODE && watt != oldWatt) {
    if (watt<((unsigned long)MAX_WATT)) {
    send(wattMsg.set(watt)); // Send watt value to gw
    Serial.print("Watt:");
    Serial.println(watt);
    oldWatt = watt;
    // Pulse cout has changed
    if (pulseCount != oldPulseCount) {
      send(pcMsg.set(pulseCount));  // Send pulse count value to gw
      double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
      oldPulseCount = pulseCount;
      if (kwh != oldKwh) {
        send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
        oldKwh = kwh;
    lastSend = now;
    } else if (sendTime && !pcReceived) {
    // No count received. Try requesting it again
    lastSend=now;
    if (SLEEP_MODE) {
    sleep(SEND_FREQUENCY);
    if (message.type==V_VAR1) {
    pulseCount = oldPulseCount = message.getLong();
    Serial.print("Received last pulse count from gw:");
    Serial.println(pulseCount);
    pcReceived = true;
    void onPulse()
    if (!SLEEP_MODE) {
    unsigned long interval = newBlink-lastBlink;
    if (interval<10000L) { // Sometimes we get interrupt on RISING
    return;
    watt = (3600000000.0 /interval) / ppwh;
    lastBlink = newBlink;
    pulseCount++;
    F
    F
    flopp
    @asgardro
    don't forget to use CODE function when posting code.
    If you don't see any reaction when you trig Digital 3 i don't know what can be the problem,
    Have you tried another Arduino?
      here is my code
      double oldKwh;
      lastSend=millis();
      oldWatt = watt;
          oldKwh = kwh;
      lastSend = now;
      lastSend=now;
      if (SLEEP_MODE) {
      pcReceived = true;
      void onPulse()
      if (!SLEEP_MODE) {
      return;
      pulseCount++;
      F
      F
      flopp
      @asgardro
      change bool pcReceived to false
      • asgardroA
        asgardroA
        asgardro
        ooops sorry about that... just found the function lol
        the sensor inits itself once and then doesn't do anything/ i don't know through what miracle i got the pulse count.
        will try another arduino... i do not think it is a radio problem..
        thanks for your help
        • asgardroA
          asgardroA
          asgardro
          wrote on last edited by asgardro
          #37
          changed it to false.
          put it true before to try to force the sensor sending independent of the count.. if i am correct
          still the same outcome... will try tomorrow diffrent hardware
          anyway, thanks a lot for the help
          F 1 Reply Last reply
            F
            F
            flopp
            Yes it will but it will only send 0 to VAR in DZ so it will be a loop of same value.
            Maybe that's why it never sends again.
            Try now to trig digital 3
            • asgardroA
              asgardroA
              asgardro
              sorry for the next noob question but what do you mean by trigginh the pin 3? simulating the sensor? if yes i done that.. i have a led blinking
                F
                F
                flopp
                @asgardro
                what have you connected to digital 3?
                asgardroA 1 Reply Last reply
                • asgardroA
                  asgardroA
                  asgardro
                  this is the code now
                   * Version 1.0 - Henrik EKblad
                   * This sketch provides an example how to implement a distance sensor using HC-SR04
                   * Use this sensor to measure KWH and Watt of your house meeter
                   * You need to set the correct pulsefactor of your meeter (blinks per KWH).
                   * The sensor starts by fetching current KWH value from gateway.
                   * Reports both KWH and Watt back to gateway.
                   * Unfortunately millis() won't increment when the Arduino is in
                   * sleepmode. So we cannot make this sensor sleep if we also want
                   * to calculate/report watt-number.
                   * http://www.mysensors.org/build/pulse_power
                  // Enable debug prints
                  bool pcReceived = false;
                  double oldKwh;
                    lastSend=millis();
                        oldWatt = watt;
                          oldKwh = kwh;
                      lastSend = now;
                      lastSend=now;
                    if (SLEEP_MODE) {
                      pcReceived = true;
                  void onPulse()
                    if (!SLEEP_MODE) {
                        return;
                    pulseCount++;
                  • F flopp
                    @asgardro
                    asgardroA
                    asgardroA
                    asgardro
                    @flopp
                    i have connected the digital out from the sensor
                      @flopp
                      F
                      F
                      flopp
                      wrote on last edited by flopp
                      #43
                      @asgardro said:
                      @flopp
                      Do you mean LM393?
                      Can you put a flash light in front of the sensor so trigger it. You shall now see some text in serial monitor
                      asgardroA 2 Replies Last reply
                      • F flopp
                        @asgardro said:
                        @flopp
                        Do you mean LM393?
                        asgardroA
                        asgardroA
                        asgardro
                        @flopp
                        lm393
                          @flopp
                          lm393
                          F
                          F
                          flopp
                          @asgardro said:
                          @flopp
                          lm393
                          Have you trimmed the pot so the LED turns on when your power meter flash?
                          • F flopp
                            @asgardro said:
                            @flopp
                            Do you mean LM393?
                            asgardroA
                            asgardroA
                            asgardro
                            @flopp
                            i have done that and calibrated the lm393 , i have a blinking light that triggers the sensor. thats how i am testing...but after initializing sends the value first time and thats it
                            sorry to reply so late but have to wait 120seconds between posts lol
                            • asgardroA
                              asgardroA
                              asgardro
                              //#define MY_RF24_CHANNEL 74
                              double oldKwh;
                                lastSend=millis();
                                Serial.println("7");
                              //Serial.println("6");
                                    oldWatt = watt;
                              Serial.println("5");
                                      oldKwh = kwh;
                                    Serial.println("4");
                                  lastSend = now;
                                  lastSend=now;
                              Serial.println("3");
                                if (SLEEP_MODE) {
                                Serial.println("2");
                              Serial.println("rece");
                              pcReceived = true;
                              Serial.println("not_rece");
                              void onPulse()
                                if (!SLEEP_MODE) {
                                    return;
                                pulseCount++;
                                Serial.println("1");
                              this
                              • maghacM
                                maghacM
                                maghac
                                As the sketch starts by requesting the latest pulse count (e.g starting kWh value) and does not send anything without having received it, how do I "seed" this value to my GW? I am using a MQTT GW, can I construct a MQTT special message containing the value, or how is it supposed to work?
                                • maghacM maghac
                                  F
                                  F
                                  flopp
                                  @maghac
                                  I am using Domoticz ans MyS 1.5.1
                                  You don't have to create VAR1, it will be created when you ask for it or it always exists for each Child.
                                  If you want VAR1 to be exactly the same as your meter you need to open domoticz.db and set the value or in your sketch.
                                  maghacM 1 Reply Last reply
                                  • sundberg84S
                                    sundberg84S
                                    #50
                                    Anyone knows why I dont get the sleep() function (time) to work properly.
                                    My hardware is EasyPCB, Pro Mini 3.3v 8mhz, Booster 2xAA and NRF24 radio.
                                    My software is: standard sketch 2.0.1, with sleep function.
                                    The problem is the sleep time is 5 times less than declared so maybe timing?
                                    When i enter sleep(10000) for example the nodes sleeps for 2 sec and wakes up.
                                    The interupt works fine.
                                    My sollution was adding *5 to get the correct sleep time - but why doesnt it work?
                                    • F flopp
                                      @maghac
                                      maghacM
                                      maghacM
                                      maghac
                                      @flopp I had to set pcReceived to true, upload the sketch, run it and then change back to false again and recompile/reupload. I can understand why it does it, since you don't want the pulse counter to reset to 0 if the sensor happens to restart (because you killed the power or whatever).
                                      What I don't understand is how I can seed the value with the correct initial value.
                                      Is it the controller (in my case HomeAssistant) or the gateway that is supplying the value?
                                      • maghacM maghac
                                        maghacM
                                        maghacM
                                        maghac
                                        It appears to be the controller that stores the value. I deleted the sensor from HomeAssistant and restarted, when it came back in again it started from zero.
                                        • maghacM maghac
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          @maghac
                                          This is a hack, but if using json persistence, you can set the count in the JSON file and restart home assistant, with the node turned off. Then turn on the node.
