  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.0k Views 37 Watching
  • asgardroA asgardro
    Came back from work and checked. it is sending to the gateway the first value and gets displayed in domoticz. then dead.. it appears it does not get the pulse count from the gateway respectively from domoticz. has anyone got this working with domoticz?
    F
    F
    flopp
    @asgardro
    I am using two of these to DZ.
    One has been working perfect for 1,5 month the second I had some problem with initialize after 3 weeks.
    • asgardroA
      asgardroA
      asgardro
      would you mind please sharing the sketch? i don't know whats wrong. i even forced it with "bool pcReceived = false" puting it to true. thanks
      • asgardroA
        asgardroA
        asgardro
        i do not get Serial.print("Received last pulse count from gw:"); in serial output
        F 2 Replies Last reply
          F
          F
          flopp
          wrote on last edited by flopp
          #25
          @asgardro
          this is my sketch
          i use MS 1.5.1
           * Version 1.0 - Henrik EKblad
           * This sketch provides an example how to implement a distance sensor using HC-SR04
           * Use this sensor to measure KWH and Watt of your house meeter
           * You need to set the correct pulsefactor of your meeter (blinks per KWH).
           * The sensor starts by fetching current KWH value from gateway.
           * Reports both KWH and Watt back to gateway.
           * Unfortunately millis() won't increment when the Arduino is in
           * sleepmode. So we cannot make this sensor sleep if we also want
           * to calculate/report watt-number.
           * http://www.mysensors.org/build/pulse_power
          #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
          #define PULSE_FACTOR 1000       // Number of blinks per KWH of your meeter
          #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
          #define MAX_WATT 15000          // Max watt value to report. This filters outliers.
          unsigned long SEND_FREQUENCY = 5*60000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
          double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
          boolean pcReceived = false;
          unsigned long oldPulseCount = 0;
          unsigned long oldWatt = 0;
          //double oldKwh;
          unsigned long lastSend;
          MyMessage wattMsg(CHILD_ID,V_WATT);
          MyMessage kwhMsg(CHILD_ID,V_KWH);
          MyMessage pcMsg(CHILD_ID,V_VAR1);
            gw.begin(incomingMessage);
            gw.sendSketchInfo("Energy Huset", "1.1");
          //1.1 no check for old value, always send
            gw.present(CHILD_ID, S_POWER);
            gw.request(CHILD_ID, V_VAR1);
            attachInterrupt(INTERRUPT, onPulse, RISING);
            lastSend=millis();
            unsigned long now = millis();
            if (pcReceived && (SLEEP_MODE || sendTime)) {
              if (!SLEEP_MODE && watt != oldWatt) {
                if (watt<((unsigned long)MAX_WATT)) {
                  gw.send(wattMsg.set(watt));  // Send watt value to gw
                Serial.print("Watt:");
                Serial.println(watt);
                oldWatt = watt;
              // Pulse cout has changed
              if (pulseCount != oldPulseCount) {
                gw.send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                oldPulseCount = pulseCount;
                //if (kwh != oldKwh) {
                  gw.send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                  //oldKwh = kwh;
              lastSend = now;
            } else if (sendTime && !pcReceived) {
              // No count received. Try requesting it again
              lastSend=now;
            if (SLEEP_MODE) {
              gw.sleep(SEND_FREQUENCY);
            if (message.type==V_VAR1) {
              pulseCount = oldPulseCount = message.getLong();
              Serial.println(pulseCount);
              pcReceived = true;
          void onPulse()
            if (!SLEEP_MODE) {
              unsigned long interval = newBlink-lastBlink;
              if (interval<10000L) { // Sometimes we get interrupt on RISING
                return;
              watt = (3600000000.0 /interval) / ppwh;
              lastBlink = newBlink;
            pulseCount++;
          • asgardroA
            asgardroA
            asgardro
            0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
            3 TSM:INIT
            4 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            13 TSF:SID:OK,ID=254
            14 TSM:FPAR
            51 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2058 !TSM:FPAR:NO REPLY
            2060 TSM:FPAR
            2096 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2121 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            2126 TSF:MSG:FPAR OK,ID=0,D=1
            4104 TSM:FPAR:OK
            4105 TSM:ID
            4106 TSM:ID:OK
            4108 TSM:UPL
            4113 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            4123 TSF:MSG:READ,0-0-254,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            4128 TSF:MSG:PONG RECV,HP=1
            4131 TSM:UPL:OK
            4132 TSM:READY:ID=254,PAR=0,DIS=1
            4140 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            4164 TSF:MSG:READ,0-0-254,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            4172 TSF:MSG:SEND,254-254-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
            4183 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            4203 TSF:MSG:READ,0-0-254,s=255,c=3,t=6,pt=0,l=1,sg=0:M
            4210 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Energy Meter
            4224 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
            4235 TSF:MSG:SEND,254-254-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
            4241 MCO:REG:REQ
            4246 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            4253 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            4258 MCO:PIM:NODE REG=1
            4260 MCO:BGN:STP
            4267 TSF:MSG:SEND,254-254-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
            4273 MCO:BGN:INIT OK,TSP=1
            4283 TSF:MSG:READ,0-0-254,s=1,c=2,t=24,pt=0,l=1,sg=0:1
            Received last pulse count from gw:1
            • asgardroA
              asgardroA
              asgardro
              here is my serial output. and remains like this.
              i have found your sketch but can not seem to get it to work to gw 2.0
              • asgardroA
                asgardroA
                asgardro
                And this is my log from DZ
                2017-01-10 22:00:28.664 MySensors: Node: 254, Sketch Name: Energy Meter
                2017-01-10 22:00:28.675 MySensors: Node: 254, Sketch Version: 1.0
                2017-01-10 22:00:33.737 (Gate) General/kWh (Meter)
                2017-01-10 22:00:33.761 (Gate) General/kWh (Meter)
                2017-01-10 22:01:34.631 (Gate) Temp + Humidity (GatewayBed1)
                2017-01-10 22:01:37.207 (Gate) Temp (Radio Room)
                2017-01-10 22:01:46.109 (Gate) General/Barometer (Pressure)
                2017-01-10 22:02:34.570 (Gate) Temp + Humidity (GatewayBed1)
                2017-01-10 22:02:34.573 (Gate) Temp + Humidity (GatewayBed1)
                2017-01-10 22:03:34.510 (Gate) Temp + Humidity (GatewayBed1)
                2017-01-10 22:03:34.513 (Gate) Temp + Humidity (GatewayBed1)
                2017-01-10 22:03:50.973 (Gate) Temp (Radio Room)
                2017-01-10 22:04:03.239 (Gate) Temp (Outside)
                2017-01-10 22:04:03.249 (Gate) General/Barometer (Pressure)
                • F
                  F
                  flopp
                  can you please print your code?
                  I am not so good to read the Message structure but it look like it present temperature and other stuff
                  • asgardroA
                    asgardroA
                    asgardro
                    Ah the gateway works fine with other sensors
                    The code for the pulse power meter is the one in the example
                    F 1 Reply Last reply
                      F
                      F
                      flopp
                      Yes you do, look at the last line and you will see it.
                        F
                        F
                        flopp
                        #32
                        @asgardro
                        change SEND_FREQUENCY to 5000, upload to Arduino, when you see Received from GW, trig Digital Input 3 and after 5 seconds it should send data to DZ again
                        • asgardroA
                          asgardroA
                          asgardro
                          Done that... reset everything..still the same
                          here is my code
                          #define PULSE_FACTOR 1000 // Nummber of blinks per KWH of your meeter
                          #define MAX_WATT 10000 // Max watt value to report. This filetrs outliers.
                          unsigned long SEND_FREQUENCY = 5000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                          bool pcReceived = true;
                          double oldKwh;
                          pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                          attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                          lastSend=millis();
                          oldWatt = watt;
                              oldKwh = kwh;
                          lastSend = now;
                          lastSend=now;
                          if (SLEEP_MODE) {
                          pcReceived = true;
                          void onPulse()
                          if (!SLEEP_MODE) {
                          return;
                          pulseCount++;
                          F V 3 Replies Last reply
                            here is my code
                            double oldKwh;
                            lastSend=millis();
                            oldWatt = watt;
                                oldKwh = kwh;
                            lastSend = now;
                            lastSend=now;
                            if (SLEEP_MODE) {
                            pcReceived = true;
                            void onPulse()
                            if (!SLEEP_MODE) {
                            return;
                            pulseCount++;
                            F
                            F
                            flopp
                            @asgardro
                            don't forget to use CODE function when posting code.
                            If you don't see any reaction when you trig Digital 3 i don't know what can be the problem,
                            Have you tried another Arduino?
                              here is my code
                              double oldKwh;
                              lastSend=millis();
                              oldWatt = watt;
                                  oldKwh = kwh;
                              lastSend = now;
                              lastSend=now;
                              if (SLEEP_MODE) {
                              pcReceived = true;
                              void onPulse()
                              if (!SLEEP_MODE) {
                              return;
                              pulseCount++;
                              F
                              F
                              flopp
                              @asgardro
                              change bool pcReceived to false
                              • asgardroA
                                asgardroA
                                asgardro
                                ooops sorry about that... just found the function lol
                                the sensor inits itself once and then doesn't do anything/ i don't know through what miracle i got the pulse count.
                                will try another arduino... i do not think it is a radio problem..
                                thanks for your help
                                • asgardroA
                                  asgardroA
                                  asgardro
                                  wrote on last edited by asgardro
                                  #37
                                  changed it to false.
                                  put it true before to try to force the sensor sending independent of the count.. if i am correct
                                  still the same outcome... will try tomorrow diffrent hardware
                                  anyway, thanks a lot for the help
                                    F
                                    F
                                    flopp
                                    Yes it will but it will only send 0 to VAR in DZ so it will be a loop of same value.
                                    Maybe that's why it never sends again.
                                    Try now to trig digital 3
                                    • asgardroA
                                      asgardroA
                                      asgardro
                                      sorry for the next noob question but what do you mean by trigginh the pin 3? simulating the sensor? if yes i done that.. i have a led blinking
                                        F
                                        F
                                        flopp
                                        @asgardro
                                        what have you connected to digital 3?
                                        asgardroA 1 Reply Last reply
                                        • asgardroA
                                          asgardroA
                                          asgardro
                                          this is the code now
                                          // Enable debug prints
                                          bool pcReceived = false;
                                          double oldKwh;
                                            lastSend=millis();
                                                oldWatt = watt;
                                                  oldKwh = kwh;
                                              lastSend = now;
                                              lastSend=now;
                                            if (SLEEP_MODE) {
                                              pcReceived = true;
                                          void onPulse()
                                            if (!SLEEP_MODE) {
                                                return;
                                            pulseCount++;
