  2. Announcements
  3. 💬 Power Meter Pulse Sensor
184 Posts 41 Posters 94.6k Views 38 Watching
  • F
    F
    flopp
    wrote on last edited by flopp
    it need to change 0,02 kWh before sending new value
    see more information here
    https://forum.mysensors.org/topic/4727/energy-meter-not-sending-at-expected
    F 1 Reply Last reply
    • F flopp
      F
      F
      flopp
      miljumeM 1 Reply Last reply
      • F flopp
        [[topic:post-is-deleted]]
        miljumeM
        miljumeM
        miljume
        @flopp Thanks for the link but I still cant get anything in sleep mode
        Now I have waited for over an hour with simulated blinks approx twice/second but so far the device havent reported one single time!
        By the way, does anyone know how to reset the value stored in the GW?
        After some testing the value get's quite high :smiley:
        • asgardroA
          asgardroA
          asgardro
          Hi. I built this sensor and loaded the example. It appears the sensor registers with my serial gateway and appears in domoticz. The problem is it hasn't updated the value in 24h? Any ideas?
          • asgardroA asgardro
            F
            F
            flopp
            @asgardro
            What does the serial output in arduino says?
            • asgardroA
              asgardroA
              asgardro
              In the end it displays the watt value and then just hangs. I haven't modified the example at all. I am @ work now but will be able to check again later
              • asgardroA
                asgardroA
                asgardro
                Came back from work and checked. it is sending to the gateway the first value and gets displayed in domoticz. then dead.. it appears it does not get the pulse count from the gateway respectively from domoticz. has anyone got this working with domoticz?
                  F
                  F
                  flopp
                  @asgardro
                  I am using two of these to DZ.
                  One has been working perfect for 1,5 month the second I had some problem with initialize after 3 weeks.
                  • asgardroA
                    asgardroA
                    asgardro
                    would you mind please sharing the sketch? i don't know whats wrong. i even forced it with "bool pcReceived = false" puting it to true. thanks
                    • asgardroA
                      asgardroA
                      asgardro
                      i do not get Serial.print("Received last pulse count from gw:"); in serial output
                      F 2 Replies Last reply
                        F
                        F
                        flopp
                        #25
                        @asgardro
                        this is my sketch
                        i use MS 1.5.1
                         * Version 1.0 - Henrik EKblad
                         * This sketch provides an example how to implement a distance sensor using HC-SR04
                         * Use this sensor to measure KWH and Watt of your house meeter
                         * You need to set the correct pulsefactor of your meeter (blinks per KWH).
                         * The sensor starts by fetching current KWH value from gateway.
                         * Reports both KWH and Watt back to gateway.
                         * Unfortunately millis() won't increment when the Arduino is in
                         * sleepmode. So we cannot make this sensor sleep if we also want
                         * to calculate/report watt-number.
                         * http://www.mysensors.org/build/pulse_power
                        #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                        #define PULSE_FACTOR 1000       // Number of blinks per KWH of your meeter
                        #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
                        #define MAX_WATT 15000          // Max watt value to report. This filters outliers.
                        unsigned long SEND_FREQUENCY = 5*60000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                        double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                        boolean pcReceived = false;
                        unsigned long oldPulseCount = 0;
                        unsigned long oldWatt = 0;
                        //double oldKwh;
                        unsigned long lastSend;
                        MyMessage wattMsg(CHILD_ID,V_WATT);
                        MyMessage kwhMsg(CHILD_ID,V_KWH);
                        MyMessage pcMsg(CHILD_ID,V_VAR1);
                          gw.begin(incomingMessage);
                          gw.sendSketchInfo("Energy Huset", "1.1");
                        //1.1 no check for old value, always send
                          gw.present(CHILD_ID, S_POWER);
                          gw.request(CHILD_ID, V_VAR1);
                          attachInterrupt(INTERRUPT, onPulse, RISING);
                          lastSend=millis();
                          unsigned long now = millis();
                          if (pcReceived && (SLEEP_MODE || sendTime)) {
                            if (!SLEEP_MODE && watt != oldWatt) {
                              if (watt<((unsigned long)MAX_WATT)) {
                                gw.send(wattMsg.set(watt));  // Send watt value to gw
                              Serial.print("Watt:");
                              Serial.println(watt);
                              oldWatt = watt;
                            // Pulse cout has changed
                            if (pulseCount != oldPulseCount) {
                              gw.send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                              double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                              oldPulseCount = pulseCount;
                              //if (kwh != oldKwh) {
                                gw.send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                                //oldKwh = kwh;
                            lastSend = now;
                          } else if (sendTime && !pcReceived) {
                            // No count received. Try requesting it again
                            lastSend=now;
                          if (SLEEP_MODE) {
                            gw.sleep(SEND_FREQUENCY);
                          if (message.type==V_VAR1) {
                            pulseCount = oldPulseCount = message.getLong();
                            Serial.println(pulseCount);
                            pcReceived = true;
                        void onPulse()
                          if (!SLEEP_MODE) {
                            unsigned long interval = newBlink-lastBlink;
                            if (interval<10000L) { // Sometimes we get interrupt on RISING
                              return;
                            watt = (3600000000.0 /interval) / ppwh;
                            lastBlink = newBlink;
                          pulseCount++;
                        • asgardroA
                          asgardroA
                          asgardro
                          0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                          3 TSM:INIT
                          4 TSF:WUR:MS=0
                          11 TSM:INIT:TSP OK
                          13 TSF:SID:OK,ID=254
                          14 TSM:FPAR
                          51 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          2058 !TSM:FPAR:NO REPLY
                          2060 TSM:FPAR
                          2096 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          2121 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          2126 TSF:MSG:FPAR OK,ID=0,D=1
                          4104 TSM:FPAR:OK
                          4105 TSM:ID
                          4106 TSM:ID:OK
                          4108 TSM:UPL
                          4113 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          4123 TSF:MSG:READ,0-0-254,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          4128 TSF:MSG:PONG RECV,HP=1
                          4131 TSM:UPL:OK
                          4132 TSM:READY:ID=254,PAR=0,DIS=1
                          4140 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          4164 TSF:MSG:READ,0-0-254,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          4172 TSF:MSG:SEND,254-254-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                          4183 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                          4203 TSF:MSG:READ,0-0-254,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                          4210 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Energy Meter
                          4224 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                          4235 TSF:MSG:SEND,254-254-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
                          4241 MCO:REG:REQ
                          4246 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                          4253 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          4258 MCO:PIM:NODE REG=1
                          4260 MCO:BGN:STP
                          4267 TSF:MSG:SEND,254-254-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                          4273 MCO:BGN:INIT OK,TSP=1
                          4283 TSF:MSG:READ,0-0-254,s=1,c=2,t=24,pt=0,l=1,sg=0:1
                          Received last pulse count from gw:1
                          • asgardroA
                            asgardroA
                            asgardro
                            here is my serial output. and remains like this.
                            i have found your sketch but can not seem to get it to work to gw 2.0
                            • asgardroA
                              asgardroA
                              asgardro
                              And this is my log from DZ
                              2017-01-10 22:00:28.664 MySensors: Node: 254, Sketch Name: Energy Meter
                              2017-01-10 22:00:28.675 MySensors: Node: 254, Sketch Version: 1.0
                              2017-01-10 22:00:33.737 (Gate) General/kWh (Meter)
                              2017-01-10 22:00:33.761 (Gate) General/kWh (Meter)
                              2017-01-10 22:01:34.631 (Gate) Temp + Humidity (GatewayBed1)
                              2017-01-10 22:01:37.207 (Gate) Temp (Radio Room)
                              2017-01-10 22:01:46.109 (Gate) General/Barometer (Pressure)
                              2017-01-10 22:02:34.570 (Gate) Temp + Humidity (GatewayBed1)
                              2017-01-10 22:02:34.573 (Gate) Temp + Humidity (GatewayBed1)
                              2017-01-10 22:03:34.510 (Gate) Temp + Humidity (GatewayBed1)
                              2017-01-10 22:03:34.513 (Gate) Temp + Humidity (GatewayBed1)
                              2017-01-10 22:03:50.973 (Gate) Temp (Radio Room)
                              2017-01-10 22:04:03.239 (Gate) Temp (Outside)
                              2017-01-10 22:04:03.249 (Gate) General/Barometer (Pressure)
                              • F
                                F
                                flopp
                                can you please print your code?
                                I am not so good to read the Message structure but it look like it present temperature and other stuff
                                • asgardroA
                                  asgardroA
                                  asgardro
                                  Ah the gateway works fine with other sensors
                                  The code for the pulse power meter is the one in the example
                                    F
                                    F
                                    flopp
                                    Yes you do, look at the last line and you will see it.
                                      F
                                      F
                                      flopp
                                      #32
                                      @asgardro
                                      change SEND_FREQUENCY to 5000, upload to Arduino, when you see Received from GW, trig Digital Input 3 and after 5 seconds it should send data to DZ again
                                      • asgardroA
                                        asgardroA
                                        asgardro
                                        Done that... reset everything..still the same
                                        here is my code
                                        #define PULSE_FACTOR 1000 // Nummber of blinks per KWH of your meeter
                                        #define MAX_WATT 10000 // Max watt value to report. This filetrs outliers.
                                        unsigned long SEND_FREQUENCY = 5000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                                        bool pcReceived = true;
                                        double oldKwh;
                                        pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                                        attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                                        lastSend=millis();
                                        oldWatt = watt;
                                            oldKwh = kwh;
                                        lastSend = now;
                                        lastSend=now;
                                        if (SLEEP_MODE) {
                                        pcReceived = true;
                                        void onPulse()
                                        if (!SLEEP_MODE) {
                                        return;
                                        pulseCount++;
                                        F V 3 Replies Last reply
                                          here is my code
                                          double oldKwh;
                                          lastSend=millis();
                                          oldWatt = watt;
                                              oldKwh = kwh;
                                          lastSend = now;
                                          lastSend=now;
                                          if (SLEEP_MODE) {
                                          pcReceived = true;
                                          void onPulse()
                                          if (!SLEEP_MODE) {
                                          return;
                                          pulseCount++;
                                          F
                                          F
                                          flopp
                                          @asgardro
                                          don't forget to use CODE function when posting code.
                                          If you don't see any reaction when you trig Digital 3 i don't know what can be the problem,
                                          Have you tried another Arduino?
                                          12.5k
