  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • pansenP
    pansenP
    pansen
    out of curiousity: this all relates to 3.x kernel in armbian right? which has proprietary stuff in there?
    i read somewhere that mainline 4.10 SPI is "work in progress"
    Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
    • pansenP pansen
      Tag
      @pansen
      Yes correct, for OPI Zero only ARMbian 3.x is available as a download image.
      I used the debian jessie one
        marceloaqno
        Code Contributor
        Instructions page updated, let me know if there is any mistake.
        • M marceloaqno
          Tag
          @marceloaqno
          looks great!! thx!!:thumbsup:
            mihai.aldea
            Excellent work !!! It finally works, I believe the slight mistake was with the damn SPI device ID. Now that I've enabled /dev/spidev1.0 everything works perfect. Really nice job and awesome commitment to showing people that it's time for them to pull their heads out of their a.... and spend less for way more awesome boards because let's face it, RPi has the greatest community support but it's a nothing more than an expensive closed source crappy board.
            • M mihai.aldea
              Tag
              wrote on last edited by Tag
              #110
              @mihai.aldea
              Great!!, found out the SPI0 is used for the NAND flash, once you add SPI1 to the script.bin, also the need board paragraph with bus 1 needs to be added otherwise it will not work.... anyway great you got mysensors up and running!!
              About the RPI, i like both boards, and in my opinion the enormous success of the RPI is responsible, for the large collection of OPI boards that is available these days ;)
                mihai.aldea
                There are few who know that lots of asian compaines were producing SBC's long before RPi ever existed. RPi has to take credit for the SBC boom, but the connaisseurs will always prefer a top notch SBC that costs less than half of an RPi and is piled with features. Take the OPi Zero for instance, it's way smaller than RPi 3, has half the RAM and doesn't have Bluetooth. But you can buy 4 OPi Zeros with the money you'd spend on an RPi 3.
                Anyway it's an endless debate here, I'm just glad I could help a bit bringing this to life, even though you and @marceloaqno did the heavy lifting.
                • Nca78N
                  Thank you for the hard work guys, I have a fresh orange pi zero and I will install armbian and try this hack as soon as possible. Looks like a great way to have an ultra compact&cheap controller + gateway system !
                    marceloaqno
                    Code Contributor
                    wrote on last edited by marceloaqno
                    #113
                    Support for OrangePi is now part of the official MySensors development repository.
                    In the official version, it is necessary to define the CE and CS pins, as the default ones will not work. This will change in the future, but more work needs to be done to better detect the different types of Orange Pi and other H3 soc boards.
                    For now, if you have set your system in the same way as the wiring instructions, use:
                    ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
                    • M marceloaqno
                      Tag
                      @marceloaqno
                      Thank you for your hard work and continued support on this!!
                      • M mihai.aldea
                        I confirm it's not working on the OPi PC where TMRh20 works.
                        sergey-sychev
                        @mihai.aldea
                        It's working on my OPi One with Armbian. MySensors and TMRh20 works!
                        Only in ./MySensors: bin
                        Only in ./MySensors: build
                        diff -ruBdX ex ./_MySensors/drivers/RF24/RF24.cpp ./MySensors/drivers/RF24/RF24.cpp
                        --- ./_MySensors/drivers/RF24/RF24.cpp<>2017-01-28 10:24:03.557215399 +0200
                        +++ ./MySensors/drivers/RF24/RF24.cpp<->2017-01-28 10:58:51.757543157 +0200
                        @@ -29,7 +29,7 @@
                         LOCAL RF24_receiveCallbackType RF24_receiveCallback = NULL;
                        -#ifdef LINUX_SPI_BCM
                        +#if defined (LINUX_SPI_BCM) || (LINUX_SPI_SPIDEV)
                         uint8_t spi_rxbuff[32+1] ; //SPI receive buffer (payload max 32 bytes)
                         uint8_t spi_txbuff[32+1] ; //SPI transmit buffer (payload max 32 bytes + 1 byte for the command)
                        @@ -56,7 +56,7 @@
                         <----->RF24_csn(LOW);
                         <----->// timing
                         <----->delayMicroseconds(10);
                         <----->uint8_t * prx = spi_rxbuff;
                         <----->uint8_t * ptx = spi_txbuff;
                         <----->uint8_t size = len + 1; // Add register value to transmit buffer
                        diff -ruBdX ex ./_MySensors/Makefile.inc ./MySensors/Makefile.inc
                        --- ./_MySensors/Makefile.inc<->2017-01-28 10:49:53.990638008 +0200
                        +++ ./MySensors/Makefile.inc<-->2017-01-28 11:12:57.601198157 +0200
                        @@ -1,5 +1,5 @@
                         SOC=H3
                        -CPPFLAGS=-march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV.
                        +CPPFLAGS=-march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DLINUX_SPI_SPIDEV -DMY_RF24_CE_PIN=7 -DSPI_S
                         LDFLAGS=-pthread.
                         PREFIX=/usr/local
                         CC=gcc
                        • H
                          H
                          hausinger
                          Hi all
                          I want to give feedback here.
                          Today i tried to build a orange pi gateway with a connected usb - rs485 converter on it. And what should I say - It worked without problems. Many thanks to you all :)
                          Great
                          • D
                            dantefff
                            Hi to all, I don't know if this is the right thread, but I'm trying to use an odroid c1 as a gateway. I'm posting here because I think you all could help me.
                            The original thread I have done is this one
                            https://forum.mysensors.org/topic/6083/odroid-c1-as-getaway
                            Feel free to go over there and give me advises.
