  3. Video How To - Phoney TV
22 Posts 10 Posters 16.2k Views 9 Watching
  • Dave DanD
    Dave DanD
    Dave Dan
    LMs is Logitech Media Server. It's the same as Sonos (more like 'hand made') based on a Server (LMS) and clients (as Sonos Speakers).
    I was looking for a solution to stream music across the house having also the ability to sync specific speakers to sound same time / same music.
    Tried some solutions, started to think on Sonos (too expensive for me) so I started to investigate LMS.
    The current version is distributed for free here: http://www.mysqueezebox.com/download. You can install this in a Raspberry Pi (I have my server in a RPI 1 and goes pretty fast).
    Then the Clients (Speakers) I use PiCorePlayer (https://sites.google.com/site/picoreplayer/home/news) with a HiFi HAT attached to each client (https://www.hifiberry.com/).
    There's a plugin for Vera and works super cool with OpenHab.
    Let me know if you have questions. I'll be happy to share specifics.
    petewillP 1 Reply Last reply
    • Dave DanD Dave Dan
      petewillP
      petewillP
      petewill
      @Dave-Dan That looks cool! I wish I had seen this before I purchased my Sonos speakers... I was searching around but didn't find this. Oh well, hopefully it can help some others who haven't yet taken the plunge.
      • SparkmanS
        SparkmanS
        Sparkman
        wrote on last edited by Sparkman
        @Dave-Dan @petewill I use LMS as well, but mainly with the "official" hardware players. Still a large used market for those (search ebay for squeezebox). I have first gen Slim Devices players all the way to the latest ones released by Logitech. There's a great plugin for HomeSeer as well. We use them for automated alarm clocks (Squeezebox Radio's mainly), voice announcements, status displays and music of course :D.
        Al
        • chiefC
          chiefC
          chief
          @petewill Have you, or anyone else for that matter, looked at upgrading this code to compile under MySensors ver 2.0? I've setup multiple versions of the library so I can get it compiled under 1.4, but would like to move all my sensors to 2.0, if possible. If not, I'll look at changing the code after I finish with the hardware build.
          Thanks for your work on this, and thanks to @BulldogLowell for the great project, been wanting to do a faketv type setup for some time now.
          P.S.) your fritzing layout is missing the ground connection on the Pro Mini.
          Chief P
          • chiefC chief
            Chief P
            petewillP
            petewillP
            petewill
            @chief I haven't upgraded to 2.0 yet. It's on the list but it will take me quite a while (I have a lot of sensors) so I need a good chunk of time to do it. I'll update the code then but if you get to it first please do share it :)
            And, thanks for pointing out the missing ground! Good catch. I'll fix that now.
            • jimbolayaJ
              jimbolayaJ
              jimbolaya
              Could you suggest a replacement transistor. The listed one is now obsolete. Thx.
              Jim
              SparkmanS 1 Reply Last reply
              • jimbolayaJ jimbolaya
                SparkmanS
                SparkmanS
                Sparkman
                @jimbolaya Something like this should work: http://www.digikey.com/products/en?keywords=IPP055N03LGXKSA1-ND.
                • jimbolayaJ
                  jimbolayaJ
                  jimbolaya
                  Thx for the reply @Sparkman. The link you included brings me to a page that lists all their products. Could you please check and repost?
                  Jim
                    SparkmanS
                    SparkmanS
                    Sparkman
                    @jimbolaya Sorry, link is now fixed.
                    • jimbolayaJ
                      jimbolayaJ
                      jimbolaya
                      Much appreciated.
                      Jim
                      • BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        I had to update my firmware for MySensors version 2.0.0, I thought I would post it in case anyone comes across this post...
                         * PhoneyTV v3.2.0
                         * This Sketch illuminates 6 sets of LED's in a random fashion as to mimic the
                         * light eminating from a television.  It is intended to make an empty home,
                         * or an empty section of a home, appear to be occupied by someone watching
                         * TV.  As an alternative to a real television left on, this uses less than 1%
                         * of the electrical energy.
                         * With the use of the MySensors plugin and gateway, PhoneyTV is intended to
                         * be used with a controller (e.g. Vera or Raspberry PI).
                         * Sketch does not use any delays to create the random blinking as a way to
                         * assure that communication back to the gateway is as unaffected as possible.
                         * You can adjust the length of the blink interval and its "twitchyness" by
                         * modifying the random number generators, if you prefer more/less 'motion' in
                         * in your unit.  The lines are highlighted in the code, play around to create the
                         * random effect you like.
                         * Sketch takes advantage of available PWM on pins 3, 5 & 6 using the white/blue LEDs
                         * to allow fluctuations in the intensity of the light, enhancing the PhoneyTV's
                         * realistic light effects.
                         * Created 12-APR-2014
                         * Free for distrubution
                         * Credit should be given to MySensors.org for their base code for relay control
                         * and for the radio configuration.  Thanks Guys.
                         * 29-May-2014
                         * Version 2:  Simplified the code, removing all redundant relay setup from original
                         * code.  Added an on/off momentary pushputton option to be set up on pin 2.  Inproved
                         * the dark dips for longer duration (can be configured) at intervals.
                         * 6-Jun-2015
                         * Version 3.1
                         * Updated for MySensors V1.4.1
                         * Contributed by Jim (BulldogLowell@gmail.com) Inspired by Josh >> Deltanu1142@gmail.com
                         * Version 3.2.0 updated for MySensors 2.0.0 by Jim (BulldogLowell@gmail.com)
                         * How to video: https://youtu.be/p37qnl8Kjfc
                        //#define MY_REPEATER_FEATURE
                        #define RADIO_RESET_DELAY_TIME 20
                        #define DEBUG_ON
                        #ifdef DEBUG_ON
                        const byte buttonPin = 2;
                        const byte ledPin3 =  3;      // White using PWM
                        const byte ledPin4 =  4;      // Red
                        const byte ledPin5 =  5;      // Blue using PWM
                        const byte ledPin6 =  6;      // Blue using PWM
                        const byte ledPin7 =  7;      // Green
                        const byte ledPin8 =  8;      // White (No PWM)
                        Bounce debouncer = Bounce();
                        byte oldValue = 0;
                        boolean state = false;
                        boolean oldState = false;
                        int dipInterval = 10;
                        unsigned int darkTime = 250;
                        unsigned long currentDipTime;
                        unsigned long dipStartTime;
                        unsigned long currentMillis;
                        byte ledState = LOW;
                        unsigned long previousMillis = 0UL;
                        byte led = 5;
                        unsigned long interval = 2000UL;
                        unsigned int twitch = 50;
                        int dipCount = 0;
                        int analogLevel = 100;
                        boolean timeToDip = false;
                        boolean gotAck=false;
                        MyMessage msg(1,V_LIGHT);
                        void before()
                          state = loadState(1)? 1 : 0;
                          SERIAL_START(115200);
                          pinMode(ledPin3, OUTPUT);
                          pinMode(ledPin4, OUTPUT);
                          pinMode(ledPin5, OUTPUT);
                          pinMode(ledPin6, OUTPUT);
                          pinMode(ledPin7, OUTPUT);
                          pinMode(ledPin8, OUTPUT);
                          pinMode(buttonPin, INPUT_PULLUP);
                          debouncer.attach(buttonPin);
                          debouncer.interval(50);
                          sendSketchInfo("PhoneyTV", "1.5");
                          present(1, S_LIGHT);
                          debouncer.update();
                          byte value = debouncer.read();
                          if (value != oldValue && value == 0)
                          state = !state;
                          send(msg.set(state ? 1 : 0));
                        //  while(!gotAck)
                        //    gw.send(msg.set(state), true);
                        //    gw.wait(RADIO_RESET_DELAY_TIME);
                        //  gotAck = false;
                          DEBUG_PRINT(F("State Changed to:"));
                          DEBUG_PRINTLN(state? F("PhoneyTV ON") : F("PhoneyTV OFF"));
                          oldValue = value;
                          if (state)
                          if (timeToDip == false)
                            currentMillis = millis();
                            if (currentMillis - previousMillis > interval)
                            interval = random(750, 4001); //Adjusts the interval for more/less frequent random light changes
                            twitch = random(40, 100); // Twitch provides motion effect but can be a bit much if too high
                            dipCount++;
                            if (currentMillis - previousMillis < twitch)
                            led = random(3, 9);
                            analogLevel = random(50, 255); // set the range of the 3 pwm leds
                            ledState = !ledState;
                            switch (led) //for the three PWM pins
                              case 3:
                              pwmWrite();
                              case 5:
                              pwmWrite();
                              case 6:
                              pwmWrite();
                              default:
                              digitalWrite(led, ledState);
                            if (dipCount > dipInterval)
                              timeToDip = true;
                              dipCount = 0;
                              dipStartTime = millis();
                              darkTime = random(50, 150);
                              dipInterval = random(5, 250); // cycles of flicker
                            DEBUG_PRINTLN(F("Dip Time"));
                            currentDipTime = millis();
                            if (currentDipTime - dipStartTime < darkTime)
                            for (int i = 3; i < 9; i++)
                              digitalWrite(i, LOW);
                            timeToDip = false;
                          if (state != oldState)
                          oldState = state;
                          if (message.type==V_LIGHT) {
                             // Change relay state
                             state = message.getBool()? 1 : 0;
                             // Store state in eeprom
                        void pwmWrite()
                          if (ledState == HIGH)
                          analogWrite(led, analogLevel);
                          digitalWrite(led, LOW);
                        • tombstoneT
                          tombstoneT
                          tombstone
                          another nice video :+1:
