  2. Announcements
    marceloaqno
    Code Contributor
    @Reza Yes, you can use rs485 in the RPi.
    ./configure --my-transport=rs485 --my-rs485-serial-port=<YOUR_SERIAL_PORT>
    For more options, run:
    ./configure -h
    R 1 Reply Last reply
    • LaMB95L LaMB95
      Is this what you meant?
      marceloaqno
      Code Contributor
      @LaMB95 No, I meant the options you used when you ran ./configure
      LaMB95L 1 Reply Last reply
      • tianaT tiana
        Is it possible to use the second ISP on my raspberypi 3 to connect NRF24L01+ and what will be the wiring diagram, also what have to change in mygsw library
        marceloaqno
        Code Contributor
        @tiana
        "The Broadcom SoC has three independant SPI interfaces, however only one of these is brought out to the GPIO connector, and that one SPI interface has 2 Chip enable lines."
        More info here: https://www.raspberrypi.org/forums/viewtopic.php?f=44&t=22608
          @marceloaqno and the same from the controller to the gateway gives the same error on that port :(
          marceltrapmanM
          marceltrapmanM
          marceltrapman
          wrote on last edited by marceltrapman
          #293
          @marceloaqno from the docs I assume it is the gateway that has to open up port 5003 but I guess it does not because it can't connect to the ethernet (for some reason) or am I wrong?
          Fulltime Servoy Developer
          marceltrapmanM M 2 Replies Last reply
          • M marceloaqno
            ./configure -h
            R
            R
            Reza
            @marceloaqno
            i means that without arduino and usb port, similar to raspberry gateway ( raspberry +nrf24)
            i means connect rs485 module to GPIO raspberry pi :) with domoticz
            • M marceloaqno
              LaMB95L
              LaMB95L
              LaMB95
              wrote on last edited by LaMB95
              #295
              I m sorry I m new to using a raspberry pi and its for a project.
              But if this is not what you asked for could you be a little more specific :$1_1484506047866_Screen Shot 2017-01-15 at 10.46.49 PM.png 0_1484506047866_Screen Shot 2017-01-15 at 10.46.35 PM.png
              • E
                E
                ericvdb
                use sudo ;)
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  Oh and one other thing, when I set the gateway up for MQTT it works.
                    marceloaqno
                    Code Contributor
                    @marceltrapman
                    If you use the --my-controller-ip-address= option, the gateway will act as a client and attempt to conect to the supplied ip and port. If you want the gateway to open port 5003, omit this option.
                    • R Reza
                      @marceloaqno
                      marceloaqno
                      Code Contributor
                      @Reza You could connect the rs485 to the RPi UART and use the option --my-rs485-serial-port=/dev/ttyAMA0, but you need to turning off the UART functioning as a serial console.
                      Or, to make things easier:
                      rs485 <==> TTL/USB <==> RPi
                      • M marceloaqno
                        R
                        R
                        Reza
                        @marceloaqno
                        i am beginner and i can not turning off the UART functioning. . . also on some board usb port after power off/on lost and i should disconnect/connect cable... i test your steps serial gateway with raspberry and GPIO with virtual usb serial . and i see this problem solve and after power off/on gateway is connect .
                        i suggest that you add this commands to page of rs485 gateway step by step and update this .
                        (https://www.mysensors.org/build/rs485)
                        I thank you for hard working and trying
                        b0rmannB 1 Reply Last reply
                        • R Reza
                          @marceloaqno
                          b0rmannB
                          b0rmannB
                          b0rmann
                          wrote on last edited by b0rmann
                          #301
                          @Reza
                          if you want use rpi /dev/ttyAMA0 for rs485 gateway -
                          1. remove string "console=serial0,115200" from /boot/cmdline.txt
                          2. add strings "enable_uart=1" and "dtoverlay=pi3-disable-bt" to /boot/config.txt (only on rpi3)
                          3. reboot raspi
                          • M marceloaqno
                            @marceltrapman
                            marceltrapmanM
                            marceltrapmanM
                            marceltrapman
                            #302
                            @marceloaqno nice, working now :+1:
                            Thank you...
                            • b0rmannB b0rmann
                              @Reza
                              3. reboot raspi
                              R
                              R
                              Reza
                              @b0rmann
                              thank you friend , but i am sorry i am very beginner in raspberry pi . because i use vera before and with raspberry and orange pi i use recently. so i need a full steps for a rs485 gateway(wiring and commands . . .) i dont know what is ttyAMA0 ! i use a serial gateway with usb port with raspberrypi 3 but i have some problem , but with a raspberrypi gateway and use a virtual serial port (ttyUSB020) all of my problem resolve. but i have problem with wireless. so i want have a wiring network. i want a full steps for setup a rs485 module with raspberrypi 3(wiring and steps for install...) thank you for help
                              • AndurilA
                                AndurilA
                                Anduril
                                Do I read that correctly, does this gateway also gives a ethernet link to a serial-only controller? How do I have to configure ip and port? In the build section I see no option to set them.
                                • E ericvdb
                                  use sudo ;)
                                  LaMB95L
                                  LaMB95L
                                  LaMB95
                                  @LaMB95 said:
                                  @ericvdb
                                  Okay what could be the problem? :3
                                  • R Reza
                                    @b0rmann
                                    marceloaqno
                                    Code Contributor
                                    @Reza There are many guides on the web teaching how to connect and use rs485 with the RPi. I recommend you start with them and when you are sure it is working, you add MySensors to the equation.
                                    • M marceloaqno
                                      R
                                      R
                                      Reza
                                      ok thank you :(
                                      • AndurilA Anduril
                                        Tag
                                        @Anduril
                                        you will get all the build options for the mysgw with the command
                                        ./configure -help
                                        Here you can configure all options like serial and ethernet
                                        • AndurilA
                                          AndurilA
                                          Anduril
                                          just cloned and read the --help, but still I don't know how to use.
                                          To make it a litte less abstract: I have a ethernet gateway (ESP8266) running at 192.168.38.19 with port 5003 to connect to. I want to have this accessible by a serial-only controller on the raspberry.
                                          I tried to do this config and make afterwards, but starting gave only FAILs...
                                          ./configure --my-gateway=ethernet --my-controller-ip-address=192.168.38.19 --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                                          ~/MySensors$ sudo ./bin/mysgw -d
                                          mysgw: Starting gateway...
                                          mysgw: Protocol version - 2.1.0
                                          mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: !TSM:INIT:TSP FAIL
                                          mysgw: TSM:FAIL:CNT=1
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:FAIL:RE-INIT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:CNT=2
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:CNT=3
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:CNT=4
                                          mysgw: TSM:FAIL:PDT
                                          I think my config is wrong and it tries to connect to a nrf24 at the rpi. So what's the correct config for my case?
                                          Thanks in advance.
                                          gohanG 1 Reply Last reply
