  2. Announcements
    I am trying to get the raspi ethernet gateway running but on both my pi 3 (also running openHAB) and the pi B (pretty basic install).
    Unfortunately I get the same error on both.
    Any ideas what could be going on here?
    I am running the latest gateway and the latest raspbian.
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.1.0
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: failed to connect
    mysgw: Eth: connect
    mysgw: Eth: connect
    LaMB95L
    LaMB95L
    LaMB95
    @marceltrapman
    I am using a Rasp Pi 3 as well.
    I can't even proceed further in the tutorial cause of this error cause nothing works after it.
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: Eth: connect
      mysgw: Eth: connect
      marceloaqno
      Code Contributor
      @marceltrapman @LaMB95
      Could you post the complete ./configure command used to configure the gateway?
      marceltrapmanM LaMB95L 2 Replies Last reply
      • M marceloaqno
        marceltrapmanM
        marceltrapmanM
        marceltrapman
        @marceloaqno Sure, forgot it :)
        sudo ./configure \
            --my-gateway=ethernet \
            --my-controller-ip-address=192.168.1.xx \
            --my-port=5003 \
            --my-transport=nrf24
        Fulltime Servoy Developer
          sudo ./configure \
              --my-port=5003 \
          marceloaqno
          Code Contributor
          @marceltrapman Are you sure it's not a problem with your controller?
          Have you tried connecting to your controller using telnet?
          telnet 192.168.1.x 5003
          marceltrapmanM 2 Replies Last reply
          • M marceloaqno
            LaMB95L
            LaMB95L
            LaMB95
            wrote on last edited by LaMB95
            #287
            Is this what you meant?
            • M marceloaqno
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              @marceloaqno not sure no.
              So, I downloaded telnet on the same raspi that I want to use as the gateway and the issue seems to be that port 5003 is not available.
              Funny but how do I solve this.
              It can't be an issue with the firewall because it allows all traffic on the internal network.
              • M marceloaqno
                marceltrapmanM
                marceltrapmanM
                marceltrapman
                @marceloaqno and the same from the controller to the gateway gives the same error on that port :(
                  marceloaqno
                  Code Contributor
                  @Reza Yes, you can use rs485 in the RPi.
                  ./configure --my-transport=rs485 --my-rs485-serial-port=<YOUR_SERIAL_PORT>
                  For more options, run:
                  ./configure -h
                  R 1 Reply Last reply
                  • LaMB95L LaMB95
                    marceloaqno
                    Code Contributor
                    @LaMB95 No, I meant the options you used when you ran ./configure
                    LaMB95L 1 Reply Last reply
                    • tianaT tiana
                      Is it possible to use the second ISP on my raspberypi 3 to connect NRF24L01+ and what will be the wiring diagram, also what have to change in mygsw library
                      marceloaqno
                      Code Contributor
                      @tiana
                      "The Broadcom SoC has three independant SPI interfaces, however only one of these is brought out to the GPIO connector, and that one SPI interface has 2 Chip enable lines."
                      More info here: https://www.raspberrypi.org/forums/viewtopic.php?f=44&t=22608
                        marceltrapmanM
                        marceltrapmanM
                        marceltrapman
                        wrote on last edited by marceltrapman
                        #293
                        @marceloaqno from the docs I assume it is the gateway that has to open up port 5003 but I guess it does not because it can't connect to the ethernet (for some reason) or am I wrong?
                        marceltrapmanM M 2 Replies Last reply
                        • M marceloaqno
                          ./configure -h
                          R
                          R
                          Reza
                          @marceloaqno
                          i means that without arduino and usb port, similar to raspberry gateway ( raspberry +nrf24)
                          i means connect rs485 module to GPIO raspberry pi :) with domoticz
                          • M marceloaqno
                            LaMB95L
                            LaMB95L
                            LaMB95
                            #295
                            I m sorry I m new to using a raspberry pi and its for a project.
                            But if this is not what you asked for could you be a little more specific :$1_1484506047866_Screen Shot 2017-01-15 at 10.46.49 PM.png 0_1484506047866_Screen Shot 2017-01-15 at 10.46.35 PM.png
                            • E
                              E
                              ericvdb
                              use sudo ;)
                                marceltrapmanM
                                marceltrapmanM
                                marceltrapman
                                Oh and one other thing, when I set the gateway up for MQTT it works.
                                  marceloaqno
                                  Code Contributor
                                  @marceltrapman
                                  If you use the --my-controller-ip-address= option, the gateway will act as a client and attempt to conect to the supplied ip and port. If you want the gateway to open port 5003, omit this option.
                                  • R Reza
                                    @marceloaqno
                                    marceloaqno
                                    Code Contributor
                                    @Reza You could connect the rs485 to the RPi UART and use the option --my-rs485-serial-port=/dev/ttyAMA0, but you need to turning off the UART functioning as a serial console.
                                    Or, to make things easier:
                                    rs485 <==> TTL/USB <==> RPi
                                    • M marceloaqno
                                      R
                                      R
                                      Reza
                                      @marceloaqno
                                      i am beginner and i can not turning off the UART functioning. . . also on some board usb port after power off/on lost and i should disconnect/connect cable... i test your steps serial gateway with raspberry and GPIO with virtual usb serial . and i see this problem solve and after power off/on gateway is connect .
                                      i suggest that you add this commands to page of rs485 gateway step by step and update this .
                                      (https://www.mysensors.org/build/rs485)
                                      I thank you for hard working and trying
                                      b0rmannB 1 Reply Last reply
                                      • R Reza
                                        @marceloaqno
                                        b0rmannB
                                        b0rmannB
                                        b0rmann
                                        wrote on last edited by b0rmann
                                        #301
                                        @Reza
                                        if you want use rpi /dev/ttyAMA0 for rs485 gateway -
                                        1. remove string "console=serial0,115200" from /boot/cmdline.txt
                                        2. add strings "enable_uart=1" and "dtoverlay=pi3-disable-bt" to /boot/config.txt (only on rpi3)
                                        3. reboot raspi
                                        • M marceloaqno
                                          @marceltrapman
                                          marceltrapmanM
                                          marceltrapmanM
                                          marceltrapman
                                          #302
                                          @marceloaqno nice, working now :+1:
                                          Thank you...
