  2. Announcements
  • M marceloaqno
    @LaMB95 No, I meant the options you used when you ran ./configure
    LaMB95L
    LaMB95L
    LaMB95
    wrote on last edited by LaMB95
    #295
    I m sorry I m new to using a raspberry pi and its for a project.
    But if this is not what you asked for could you be a little more specific :$1_1484506047866_Screen Shot 2017-01-15 at 10.46.49 PM.png 0_1484506047866_Screen Shot 2017-01-15 at 10.46.35 PM.png
    • E
      E
      ericvdb
      use sudo ;)
      LaMB95L 1 Reply Last reply
        @marceloaqno from the docs I assume it is the gateway that has to open up port 5003 but I guess it does not because it can't connect to the ethernet (for some reason) or am I wrong?
        marceltrapmanM
        marceltrapmanM
        marceltrapman
        Oh and one other thing, when I set the gateway up for MQTT it works.
        Fulltime Servoy Developer
          marceloaqno
          Code Contributor
          @marceltrapman
          If you use the --my-controller-ip-address= option, the gateway will act as a client and attempt to conect to the supplied ip and port. If you want the gateway to open port 5003, omit this option.
          • R Reza
            @marceloaqno
            i means that without arduino and usb port, similar to raspberry gateway ( raspberry +nrf24)
            i means connect rs485 module to GPIO raspberry pi :) with domoticz
            marceloaqno
            Code Contributor
            @Reza You could connect the rs485 to the RPi UART and use the option --my-rs485-serial-port=/dev/ttyAMA0, but you need to turning off the UART functioning as a serial console.
            Or, to make things easier:
            rs485 <==> TTL/USB <==> RPi
            R 1 Reply Last reply
            • M marceloaqno
              R
              R
              Reza
              @marceloaqno
              i am beginner and i can not turning off the UART functioning. . . also on some board usb port after power off/on lost and i should disconnect/connect cable... i test your steps serial gateway with raspberry and GPIO with virtual usb serial . and i see this problem solve and after power off/on gateway is connect .
              i suggest that you add this commands to page of rs485 gateway step by step and update this .
              (https://www.mysensors.org/build/rs485)
              I thank you for hard working and trying
              b0rmannB 1 Reply Last reply
              • R Reza
                @marceloaqno
                b0rmannB
                b0rmannB
                b0rmann
                wrote on last edited by b0rmann
                #301
                @Reza
                if you want use rpi /dev/ttyAMA0 for rs485 gateway -
                1. remove string "console=serial0,115200" from /boot/cmdline.txt
                2. add strings "enable_uart=1" and "dtoverlay=pi3-disable-bt" to /boot/config.txt (only on rpi3)
                3. reboot raspi
                • M marceloaqno
                  @marceltrapman
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  wrote on last edited by marceltrapman
                  #302
                  @marceloaqno nice, working now :+1:
                  Thank you...
                  • b0rmannB b0rmann
                    @Reza
                    3. reboot raspi
                    R
                    R
                    Reza
                    @b0rmann
                    thank you friend , but i am sorry i am very beginner in raspberry pi . because i use vera before and with raspberry and orange pi i use recently. so i need a full steps for a rs485 gateway(wiring and commands . . .) i dont know what is ttyAMA0 ! i use a serial gateway with usb port with raspberrypi 3 but i have some problem , but with a raspberrypi gateway and use a virtual serial port (ttyUSB020) all of my problem resolve. but i have problem with wireless. so i want have a wiring network. i want a full steps for setup a rs485 module with raspberrypi 3(wiring and steps for install...) thank you for help
                    • AndurilA
                      AndurilA
                      Anduril
                      Do I read that correctly, does this gateway also gives a ethernet link to a serial-only controller? How do I have to configure ip and port? In the build section I see no option to set them.
                      • E ericvdb
                        use sudo ;)
                        LaMB95L
                        LaMB95L
                        LaMB95
                        @LaMB95 said:
                        @ericvdb
                        Okay what could be the problem? :3
                        • R Reza
                          @b0rmann
                          marceloaqno
                          Code Contributor
                          @Reza There are many guides on the web teaching how to connect and use rs485 with the RPi. I recommend you start with them and when you are sure it is working, you add MySensors to the equation.
                          • M marceloaqno
                            R
                            R
                            Reza
                            ok thank you :(
                            • AndurilA Anduril
                              Tag
                              @Anduril
                              you will get all the build options for the mysgw with the command
                              ./configure -help
                              Here you can configure all options like serial and ethernet
                              • AndurilA
                                AndurilA
                                Anduril
                                just cloned and read the --help, but still I don't know how to use.
                                To make it a litte less abstract: I have a ethernet gateway (ESP8266) running at 192.168.38.19 with port 5003 to connect to. I want to have this accessible by a serial-only controller on the raspberry.
                                I tried to do this config and make afterwards, but starting gave only FAILs...
                                ./configure --my-gateway=ethernet --my-controller-ip-address=192.168.38.19 --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                                ~/MySensors$ sudo ./bin/mysgw -d
                                mysgw: Starting gateway...
                                mysgw: Protocol version - 2.1.0
                                mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: !TSM:INIT:TSP FAIL
                                mysgw: TSM:FAIL:CNT=1
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:FAIL:RE-INIT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:CNT=2
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:CNT=3
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:CNT=4
                                mysgw: TSM:FAIL:PDT
                                I think my config is wrong and it tries to connect to a nrf24 at the rpi. So what's the correct config for my case?
                                Thanks in advance.
                                gohanG 1 Reply Last reply
                                • AndurilA Anduril
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:PDT
                                  Thanks in advance.
                                  @Anduril
                                  Why are you using an esp8266 as a serial gateway? Wouldn't it be easier to use a normal UNO?
                                  • AndurilA
                                    AndurilA
                                    Anduril
                                    I'm using a ESP8266 as ethernet gateway and want to have this connected as virtuall serial port to my raspberry pi so my controller can connect to that.
                                    • lakshmcL
                                      lakshmcL
                                      lakshmc
                                      I using RPi2 and NRF24 for this. I followed the instructions, to clone the repo, and then added config
                                      ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=nrf24
                                      make
                                      when i run with sudo ./bin/mysgw -d, it is failing to connect to MQTT. Can you please help?
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: TSM:INIT:TSP OK
                                      mysgw: TSM:INIT:GW MODE
                                      mysgw: MCO:REG:NOT NEEDED
                                      mysgw: MCO:BGN:STP
                                      mysgw: MCO:BGN:INIT OK,TSP=1
                                      mysgw: failed to connect
                                      P 1 Reply Last reply
                                      • AndurilA Anduril
                                        @Anduril
                                        Have you aver considered Using the GatewayESP8266MQTTClient? What controller are you trying to connect?
                                        • AndurilA
                                          AndurilA
                                          Anduril
                                          I use pimatic which does not have a native compatibility to ethernet or mqtt. Thats why my question came up on how to configure it to do this...
                                          Building a Raspberry Pi Gateway:
                                          If you are running a controller on the Raspberry Pi that doesn't support communication with the gateway through ethernet, you can use a virtual serial port:
                                          ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
