  3. Arduino Nano + NRF24L01+ + MQTT + VMWare PC - missing link
4 Posts 2 Posters 1.7k Views 3 Watching
  • ? Offline
    ? Offline
    A Former User
    Hi everyone
    I would really love to figure this out on my own but since I'm pushing this project away since a long time and I'm just missing the basic understanding I thought I ask before I push it further...
    I really love the easy getting started section but when it comes to the gateway I think there are missing some explanations.
    My goal:
    Having multiple of these sensors (see below) communicate with my Home Assistant installation without a USB cable and they should be battery powered.
    I started with the serial gateway setup:
    setup
    Everything works so far and I get the readings from the humidity sensor. Combining the different sensors would already be problem I assume.
    • As a starter: Why do I need a NRF24L01+ 2.4GHz Wireless Transceiver for a non wireless connection? I was always looking for a way to connect it to my network but obviously couldn't find any.
    • Is MQTT what I can use with my sensor setup (particular with the NRF24L01+)? I would follow this setup guide to install Mosquitto on my linux server: https://www.youtube.com/watch?v=AsDHEDbyLfg
    • I read that I need to follow the ethernet setup (https://www.mysensors.org/build/ethernet_gateway) but don't get how this is related? Do I need a Ethernet module in order to use MQTT?
    • The MQTT page (https://www.mysensors.org/build/mqtt_gateway) talks about ethernet and the ESP8266. What does that tell me about my NRF24L01+?
    Would be great if someone could connect the dots for me.
    Best regards!
    • ? A Former User
      Hi everyone
      My goal:
      setup
      Best regards!
      MQTT runs over tcp/ip. Running tcp/ip over Nrf24l01+ can be done but would be very inefficient and would result in bad battery time. Running tcp/ip over nrf24l01+ is not supported by MySensors. Therefore, something that supports tcp/ip is needed. Ethernet supports tcp/ip, and wireless lan supports tcp/ip.
      For MySensors, mqtt is supported by a mqtt gateway. This can be wired (ethernet, https://www.mysensors.org/build/mqtt_gateway) or wireless (esp8266)
      An overview of how gateways and sensors work in MySensors: https://www.mysensors.org/about/network
      You need something that supports tcp/ip. See explanation above.
      See the overview linked above. Yes, really read it. Doing that will save you many hours of confusion. But in short: nrf is used between sensors and the gateway. The nrf communication is very energy-efficient which means the sensors can be powered by battery. Mqtt is used from the gateway to anything you want.
      ? 1 Reply Last reply
        ? Offline
        ? Offline
        A Former User
        @mfalkvidd
        Thank you for this guidance: https://www.mysensors.org/about/network
        I read this page a long time ago and skipped it on my retry (fatal mistake ;) )
        I will not use the MQTT in this case. I assume now I can attach one Arduino Nano with a NRF24L01+ via USB to my Home Assistant server and all other sensors with a NRF24L01+ should be detected by the Home Assistant Controller. Thats correct, right?
        I will give this a shot! Thank you
        • ? A Former User
          @mfalkvidd
          @AEkschen yes that's correct. Good luck!
          If you get stuck along the way, take a look at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help - and you are of course welcome to post more questions in the forum if anything is unclear.
          12.1k
