  3. Efergy e2 power meter
33 Posts 9 Posters 17.2k Views 11 Watching
  • G gtortone
    @korttoma
    Hi, I have these modules:
    http://www.banggood.com/433Mhz-RF-Transmitter-With-Receiver-Kit-For-Arduino-ARM-MCU-Wireless-p-74102.html?rmmds=search
    the range is only few centimeters... I will try to do some antenna tuning but I don't expect any significative improvement.
    If you want to try with your RXB6 module the code is always the same, you have only to remove the configuration code lines related to RFM12b configuration;
    korttomaK
    korttomaK
    korttoma
    @gtortone that is the same useless junk I got from e-bay at first, range is terrible.
    This gives me some hope to get this working with the RXB6. I will test this as son as I can (might be a few weeks until I can).
    • Tomas
    • korttomaK
      korttomaK
      korttoma
      Hi @gtortone ,
      I finally found some time to hock up the RFM12B. Seems to be almost working. I just get the value "inf" for current. Do I have some datatype problem or maybe it should be calculated differently my Efergy engage hub?
      I'm using a Arduino Pro Mini 3.3V
      Attached the serial print.0_1484211281663_efergyLog.txt
      I should see values around 100W most of the time and some smaller down to 30W.
      Edit: It seems like it might be payload[6] that is equal to 255 at 100W and 254 at under 40W that is causing problems with the calculation.
      Edit2: Took 3 samples at around 30W, 60W and 100W. 0_1484220204136_efergyLog2.txt I need to find something so that I could test higher values to so I could figure out the formula to use.
      • Tomas
      G 2 Replies Last reply
      • korttomaK korttoma
        Hi @gtortone ,
        G
        G
        gtortone
        wrote on last edited by gtortone
        Hi @korttoma,
        happy to read that you are getting "reasonable" values from RFM12B !!
        but I agree that in your case the decoding protocol needs some refinements...
        just a question: your line voltage is 110 or 240 ?
        take into account that from Efergy current sensor you get the value of "current" and
        not "power" than for 30W expected value from data is (V/30) [Ampere]...
          Hi @gtortone ,
          G
          G
          gtortone
          Hi @korttoma,
          take a look to this decoding based on your collected data for 30W, 60W and 100W;
          everything seems to be ok !!
          Regards,
          Gennaro
          p.s. I checked in your profile that you live in Finland and power voltage is 220/240 V :-)
          • bytes #1: 0x09 fixed value
          • bytes #2: 0X50 fixed value
          • bytes #3: 0x2E fixed value
          • bytes #4: 0x40 fixed value
          • bytes #5: current MSB
          • bytes #6: current LSB
          • bytes #7: exponent
          • bytes #8: CRC
          • current detected = ((MSB << 8) + LSB / 65535) / pow(2, (255-exponent))
          30 W = 0.13 A (@220V)
          9 - 0x09
          80 - 0x50
          46 - 0x2E
          64 - 0x40
          71 - 0x47
          172 - 0xAC
          254 - 0xFE
          184 - 0xB8
          0x47AC = 18348
          current = 18348 / 65535 / pow(2, 1) = 0.139 A
          60 W = 0.26 A (@220V)
          9 - 0x09
          80 - 0x50
          46 - 0x2E
          64 - 0x40
          69 - 0x45
          29 - 0x1D
          255 - 0xFF
          40 - 0x28
          0x451D = 17693
          current = 17693 / 65535 / pow(2, 0) = 0.269 A
          100 W = 0.45 A (@220V)
          9 - 0x09
          80 - 0x50
          46 - 0x2E
          64 - 0x40
          112 - 0x70
          163 - 0xA3
          255 - 0xFF
          217 - 0xD9
          0x70A3 = 28835 (10)
          current = 28835 / 65535 / pow(2, 0) = 0.439 A
          • korttomaK
            korttomaK
            korttoma
            Thanks @gtortone your formula seems to work. I just need to find a way to test higher values.
            I almost had the same formula but I did not have the "65535". Could you explain where you got this value from?
            -- S --
            46
            64
            76
            204
            254
            221
            -- E --
            abc_value = 19660current = 0.15A - power = 34.50 W
            23701 TSF:MSG:SEND,9-9-0-0,s=9,c=1,t=17,pt=2,l=2,sg=0,ft=0,st=OK:34
            OK = 4 - short pk = 0 - long pk = 0 - crc bad = 0
            -- S --
            46
            64
            71
            173
            255
            186
            -- E --
            abc_value = 18349current = 0.28A - power = 64.40 W
            29693 TSF:MSG:SEND,9-9-0-0,s=9,c=1,t=17,pt=2,l=2,sg=0,ft=0,st=OK:64
            OK = 5 - short pk = 0 - long pk = 0 - crc bad = 0
            -- S --
            46
            64
            115
            51
            255
            108
            -- E --
            abc_value = 29491current = 0.45A - power = 103.50 W
            35688 TSF:MSG:SEND,9-9-0-0,s=9,c=1,t=17,pt=2,l=2,sg=0,ft=0,st=OK:103
            OK = 6 - short pk = 0 - long pk = 0 - crc bad = 0
            • Tomas
            G 1 Reply Last reply
              -- S --
              46
              64
              76
              204
              254
              221
              -- E --
              -- S --
              46
              64
              71
              173
              255
              186
              -- E --
              -- S --
              46
              64
              115
              51
              255
              108
              -- E --
              G
              G
              gtortone
              Hi @korttoma,
              the value 65535 or 32768 often is used as multiplier from sensor that send metric;
              usually when you have to send a "small" float value (temperature, current) you can send it as integer
              multiplied by a big constant instead of sending it with a float value converted in binary...
              I just refined my formula with this that is more close to formula I found for my Efergy using a small
              constant:
              current = 18348 / 32768 / pow(2, 255-254 + 1) = 0.139 A
              current = 17693 / 32768 / pow(2, 255-255 + 1) = 0.269 A
              current = 28835 / 32768 / pow(2, 255-255 + 1) = 0.439 A
              • korttomaK
                korttomaK
                korttoma
                Hi @gtortone I'm working on finalizing this node and I'm having some trouble with stability. The node stays alive from a few minutes to 30min and then stops communicating.
                What kind of decoupling capacitors are you using in your setup?
                I now have 2 pc 0.1uF, 2 pc 47uF and one 0.33uF.
                I use a HLK-PM03, a Pro Mini 3.3, and the NRF24L01+
                Debugging output don't give me much to go in since it just stops responding.
                • Tomas
                  G
                  G
                  gtortone
                  @korttoma
                  at the moment I'm defining some things in order to use RFM69 modules...
                  in the past, on my NRF24L01+ I was using 10 uF capacitor but I had same problems of "stop responding"...
                  korttomaK 2 Replies Last reply
                  • G gtortone
                    @korttoma
                    korttomaK
                    korttomaK
                    korttoma
                    @gtortone My node has now been running for more then 40min since I added the 0.1uF and 0.33uF tantalum caps. I'm hoping this will be the solution for me since I have no tools to debug any disturbance like this.
                    EDIT: It failed again :(
                    • Tomas
                    • korttomaK
                      korttomaK
                      korttoma
                      Tried exchanging the NRF24L01+ with an RFM69 but it does not seem to work at all with this setup. Might be because the RFM69 is using the same frequency as the RFM12B or maybe I can not have the 2 in the same node because they are related.
                      • Tomas
                      • G gtortone
                        @korttoma
                        korttomaK
                        korttomaK
                        korttoma
                        @gtortone did you have any chance to look at the "stop responding" issue of this device?
                        I tried to add some more debug prints to your code today but if I add them to the wrong places the efergy receive function stops working and receives only 0 value. I guess it messes with the timing.
                        • Tomas
                          G
                          G
                          gtortone
                          @korttoma Hi, I just returned to play with Efergy and Arduino. I realized that debug messages on UART reset the micro. Now I'm skipping (with a #define DEBUG and #ifdef) all debug messages and it seems to work fine. But take into account that now I'm not using any radio module... just to test the firmware.
                          • korttomaK
                            korttomaK
                            korttoma
                            #24
                            :D What a coincidence. I returned to this project today also. Now trying to set this up as an Ethernet GW with local sensor without NRF radio. I still have to share the SPI bus with the Ethernet module though. I'll let you know how it goes.
                            I think I did try removing the serial prints earlier but I'm not sure..
                            • Tomas
                            • korttomaK
                              korttomaK
                              korttoma
                              The ethernet GW approach performs even worse than your original solution. I get one or 2 measurements and then nothing. Still responds to ping but no communication with the controller.
                              I don't know how to debug this since it just stops working. Is there by any chance anything in the code that consumes memory?
                              • Tomas
                              • A
                                ailiev
                                Hi All,
                                First of all, great work man!
                                I was wondering do you know if we need to have established link between the wireless sensor and the receiver?
                                I only have the wireless sensor so I was wondering if I can use this without the receiver?
                                Any thoughts?
                                korttomaK 1 Reply Last reply
                                • A ailiev
                                  Hi All,
                                  Any thoughts?
                                  korttomaK
                                  korttomaK
                                  korttoma
                                  @ailiev it "works" without the receiver but for me the node fails after about 1h so I gave up. I could try again now with the new MySensors 2.2.0 lib to see if it makes any difference (when I find some time).
                                  • Tomas
                                    shifaz
                                    I have been trying to receive the efergy signal using RFM69 and so far it's a dead end. I'm unable to receive any data on the RFM69 module.
                                    Since you guys talked about RFM69 module here, I thought you might have some insight to share.
                                    gohanG 1 Reply Last reply
                                    • S shifaz
                                      @shifaz I think you need the RFM12B to receive the data you want
                                      • J
                                        J
                                        Jens Lauridsen
                                        wrote on last edited by Jens Lauridsen
                                        #30
                                        @gtortone
                                        Any chance that I can see how you wired up the NRF24L01+? I bought the parts back in January 2017 and just found it in a drawer this evening. I assembled everything but the NRF24L01+ and I am a bit stuck right now.
                                        BTW: Great build - I really hope that I will get mine up and running :)
                                        /Jens
                                        • B
                                          B
                                          banda banda
                                          Banned
                                          #31
                                          Since you guys talked about RFM69 module here, I thought you might have some insight to share. (spam links removed by moderator)
