  3. How to scan rf remote
12 Posts 7 Posters 5.7k Views 6 Watching
  • A Offline
    A Offline
    aclertant
    I dont know exactly where to post... I'd like to get the Rf code from a remote (in 433Mhz of course) with an arduino to be ebale to simulate this action with a MYS module.
    I found only one tutorial about this but it's on Pi...
    To be clear this what I'd like to control but without the original remote.
    http://img.abrakaba.com/002A5AD0-0/Silvercrest-set-de-4-prises-telecommandees-pour-l-interieur.jpg
    Thanks a lot.
    J 2 Replies Last reply
    • A aclertant
      Thanks a lot.
      J Offline
      J Offline
      Jan Gatzke
      @aclertant
      Just build the ir node and watch the serial monitor
      https://www.mysensors.org/build/ir
      • A Offline
        A Offline
        aclertant
        tks for the very fast reply :o)
        It's exactly what I'd like to do except that the remote use RF 433Mhz and not IR.
        • M Offline
          M Offline
          MLs
          https://www.google.se/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=rf+433+sniffer+arduino
          //Mattias
          • A aclertant
            Thanks a lot.
            J Offline
            J Offline
            Jan Gatzke
            wrote on last edited by Jan Gatzke
            @aclertant
            Ups, I should read more carefully.Sorry.
            Edit: you could use a rflink gateway. Rflink shows code and protocol in the log.
            • E Offline
              E Offline
              emc2
              wrote on last edited by emc2
              Install the library "rc-switch" by sul-77 in Arduino (it can be installed with the library manager)
              Upload one of the ReceiveDemo sketch to your Arduino (and wire a 433MHz receiver accordingly) and it will show you the RF codes, that you can then emulate by plugging a 433MHz Tx (see SendDemo sketch for code example)
              • T Offline
                T Offline
                tbully
                Echoing what @emc2 said. RCSwitch worked great for my 433 project a few months ago.
                https://forum.mysensors.org/topic/4962/laser-christmas-light-control-433mhz/14
                • N Offline
                  N Offline
                  niccodemi
                  as emc2 said; alternatively if rc-switch doesn't work for you (unlikely) you can also try with Remoteswitch library.
                  • A Offline
                    A Offline
                    aclertant
                    yep rc-switch seems to not working for me..
                    I use a nrf24L01 module (the same as on page "connecting the radio")
                    I will test Remoteswitch ;)
                    Tks everybody
                    • A aclertant
                      Tks everybody
                      T Offline
                      T Offline
                      TimO
                      @aclertant Are you trying to receive the 433 MHz signals with the NRF24L01 module which works in the 2,4 GHz band? You need a receiver and sender for the 433 MHz frequency band.
                      • A Offline
                        A Offline
                        aclertant
                        OHH NO I'm a noob :confounded:
                        When it's you who said that... It' pretty clear ...
                        I'm so sorry for that ! I order a 433Mhz receiver right now !
                        Thanks a lot ! Really !
                        • A Offline
                          A Offline
                          aclertant
                          The community is just amazing :o)
                          I found this https://www.mysensors.org/hardware/wall-plug
                          Should be enough for me
