  3. Paying peanuts
Paying peanuts
9 Posts 3 Posters 3.2k Views 2 Watching
  • I
    I
    idi0tech
    I have a breadboard with an arduino nano (funduino V.30) and an NRF240L1+ attached to it.
    It also has a a DHT22 attached to it and there is a MySensors Temperature and Humidity sensor.ino running fine and reporting to node-red/openhab
    However when i replace the funduino with a cheaper Nano (Gravitech v3.0) with the exact same sketch, there is a radio fail. Any Ideas please guys?
    • pansenP
      pansenP
      pansen
      Are they both 3.3V? nrf24 needs 3.3V power supply..
      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
      • I
        I
        idi0tech
        As far as i can tell they both have a 3.3v and 5v pins
        The one on the rightworks fine.
        • I
          I
          idi0tech
          wrote on last edited by idi0tech
          Although on closer inspection, it looks as though the one on the left 3.3v pin has no route to the chip.
          Do sellers make these with unconnected 3.3v pins?
          • F
            F
            flopp
            3.3 pin should be connected to a regulator on the back side.
            If you have a multimeter you can measure on 3.3 pin, if you don't have a multimeter use a led diode with a resistor
            I 1 Reply Last reply
            • F flopp
              I
              I
              idi0tech
              @flopp Ok Thanks, Ill try i with an LED later.
              • pansenP
                pansenP
                pansen
                Ohh right, the nano, my head spins only around the mini pro at the moment. Sorry ^^
                Could you solve your problem?
                • I
                  I
                  idi0tech
                  I solved the problem by clearing the EEPROM. Then adding the 47uF CAP solved the next issue that sprung up.
                  Never had to clear EEPROM on other boards
                  Lesson learned. thanks for the responses guys :-)
                  • pansenP
                    pansenP
                    pansen
                    Good to know and good to hear. Have fun with your projects!
