  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.7k Views 53 Watching
  • scalzS scalz
    @alexsh1 why, i don't understand :stuck_out_tongue_winking_eye:
    Here it is : http://www.thingiverse.com/thing:2084269
    alexsh1A
    alexsh1A
    alexsh1
    @scalz Thank you Sir. I am going to probably wait for the PLA version as It has been working a bit better for me.
    • D
      Disca
      Few things about the software side of this. When you plug it into your computer it appears as a "Sensebender GW", with a custom USB VID/PID. You have to override the drivers and use the "Atmel Corp. EDBG CMSIS-DAP" serial port drivers or you will have no serial port at all to communicate with the board.
      Second issue, with the latest Arduino software (1.8.1), and the MySensors SAMD board package installed and MySensor library installed you get an error relating to a missing core "arduino:arduino". Solution to that one is to install the main Arduino SAMD board package which adds the necessary libraries. Secondly, after doing that you will now get another error regarding a missing "Sam.h" file, to fix that you have to manually edit the platform.txt file in "\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.3" with the contents of the one from "\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11" - just being careful to copy over the name and version lines from the top of the Mysensors platform.txt file. After that you are good to go and can finally program the board or get some data out of it :-)
      • tbowmoT
        tbowmoT
        tbowmo
        #126
        We are preparing a new release of the board definitions for our samd. Which fixes the issues with arduino samd 1.6.11.
        It should also contain a driver .inf file for Windows 7/8, for those that needs it (it's not needed on Linux, mac or Windows 10). I had completely forgotten that windows usually needs this inf file to operate correct (I have been using Linux the last 17 years for all my private projects)
        I hope the package will be out tomorrow (sunday) , as I just need to do a couple of tests to verify things.
        D 1 Reply Last reply
        • Viktor ZemanV
          Viktor ZemanV
          Viktor Zeman
          Do you have any example sketch for this gateway? I want to use in my GW radio + wifi module.
          • tbowmoT
            tbowmoT
            tbowmo
            @Viktor-Zeman
            It only support wired ethernet, and USB. For wifi we have ESP8266 gateways instead.
            There are example sketches available in mysensors (see SensebenderGatewaySerial, or just plain GatewayW5100 would work if it's just ethernet module that you want to use)
            • tbowmoT tbowmo
              Disca
              @tbowmo Great, took a an hour or two to work out what was going on. Not used MySensors before so presumed it was something I was doing wrong. I have an RFM69HW soldered on the sensebender GW now with the serial sketch loaded and it appears to be working!
              • tbowmoT
                tbowmoT
                tbowmo
                for info, a new Mysensors SAMD board definition file have been released (1.0.4)
                Includes the following changes:
                Arduino SAMD 1.6.11 supported (the latest arduino board definitions for SAMD)
                Various bits and pieces regarding pin definitions are fixed (a couple of missing defines)
                Windows driver .inf file added.
                D M 3 Replies Last reply
                • tbowmoT tbowmo
                  Disca
                  @tbowmo Compiles fine now with 1.0.4, not convinced the drivers are being automatically picked up though. I can force install them by selecting the inf but presumably you want it automatic when someone plugs in the gateway?
                  I notice in the arduino SAMD package they have a post-install.bat to seemingly install the inf file - possibly needed?
                  It could also be that i've just messed things up with my manual driver install stuff yesterday. I'm on Windows 7 by the way.
                  • tbowmoT tbowmo
                    Disca
                    @tbowmo Also, I notice on Linux (Raspberry Pi 3 running Debian) the device appears as an ACM device rather than the usual TTY device that some might expect. It works fine though so no issues but may confuse alot of people - worth making a note somewhere.
                    • tbowmoT tbowmo
                      MLs
                      @tbowmo
                      (for info, a new Mysensors SAMD board definition file have been released (1.0.4))
                      Where?
                      • F
                        F
                        Fabien
                        @MLs reload board definition from IDE
                        I have a little annoying bug : I can't reset de gateway. When resetting, I loose communication with my computer (linux) same after loading a new sketch (last version with IDE 1.8.1 and def 1.0.4))
                        [13727.746445] usb 1-1: new full-speed USB device number 9 using xhci_hcd
                        [13727.892970] usb 1-1: New USB device found, idVendor=1209, idProduct=6949
                        [13727.892974] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        [13727.892977] usb 1-1: Product: Sensebender GW
                        [13727.892980] usb 1-1: Manufacturer: MySensors.org
                        [13727.895690] cdc_acm 1-1:1.0: ttyACM1: USB ACM device
                        [13749.066589] usb 1-1: USB disconnect, device number 9
                        So I can't check debug messages from init.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @MLs
                          Check out the setup instructions here
                          and perhaps this
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @Fabien
                            Are you using it as an ethernet gw, or standard serial gw? If serial GW, then the gateway waits until something connects to the serial device
                            The ethernet gw doesn't wait for something to connect. But you can hack the core, change hwInit() function in MyHwSAMD.cpp:
                            original
                            void hwInit()
                                    MY_SERIALDEVICE.begin(MY_BAUD_RATE);
                            #if defined(MY_GATEWAY_SERIAL)
                                    while (!MY_SERIALDEVICE) {}
                                    Wire.begin();
                            modify to this
                            void hwInit()
                                    Wire.begin();
                            It will make the gateway halt the initialization until something connects to the USB device.
                            Be advised, that if you don't have it connected to a computer, then it will not start up correctly.. That is why you need to hack the core to enable it..
                            F 1 Reply Last reply
                            • tbowmoT tbowmo
                              @MLs
                              and perhaps this
                              MLs
                              @tbowmo
                              When I try to upload sketch
                              Arduino:1.8.0 (Windows 10), Kort:"Arduino/Genuino Zero (Native USB Port)"
                              Sketch uses 46488 bytes (17%) of program storage space. Maximum is 262144 bytes.
                              No device found on COM4
                              Invalid version found: 1.04
                              When I use the serial monitor
                              0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGS--,VER=2.1.0
                              0;255;3;0;9;TSF:LRT:OK
                              0;255;3;0;9;TSM:INIT
                              0;255;3;0;9;TSF:WUR:MS=0
                              0;255;3;0;9;TSM:INIT:TSP OK
                              0;255;3;0;9;TSM:INIT:GW MODE
                              0;255;0;0;18;2.1.0
                              0;255;3;0;9;MCO:BGN:STP
                              0;255;3;0;9;TSF:MSG:READ,27-27-0,s=0,c=1,t=1,pt=7,l=5,sg=0:45.6
                              27;0;1;0;1;45.6
                              0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.4
                              23;1;1;0;0;8.4
                              0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.3
                              23;1;1;0;0;8.3
                              0;255;3;0;9;TSF:MSG:READ,23-23-0,s=0,c=1,t=1,pt=7,l=5,sg=0:51.8
                              23;0;1;0;1;51.8
                              0;255;3;0;9;TSF:MSG:READ,22-22-0,s=1,c=1,t=0,pt=7,l=5,sg=0:3.4
                              22;1;1;0;0;3.4
                              0;255;3;0;9;TSF:MSG:READ,23-23-0,s=0,c=1,t=1,pt=7,l=5,sg=0:52.0
                              23;0;1;0;1;52.0
                              0;255;3;0;9;TSF:MSG:READ,22-22-0,s=1,c=1,t=0,pt=7,l=5,sg=0:3.5
                              22;1;1;0;0;3.5
                              0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.2
                              23;1;1;0;0;8.2
                              0;255;3;0;9;TSF:MSG:READ,23-23-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                              0;255;3;0;9;TSF:MSG:BC
                              0;255;3;0;9;TSF:MSG:FPAR REQ,ID=23
                              0;255;3;0;9;TSF:PNG:SEND,TO=0
                              0;255;3;0;9;TSF:CKU:OK
                              0;255;3;0;9;TSF:MSG:GWL OK
                              0;255;3;0;9;!TSF:MSG:SEND,0-0-23-23,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                              0;255;3;0;9;TSF:MSG:READ,23-23-0,s=0,c=1,t=1,pt=7,l=5,sg=0:52.4
                              23;0;1;0;1;52.4
                              22;1;1;0;0;3.4
                              0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.1
                              23;1;1;0;0;8.1
                              I USE IDE 1.80
                              Which card should I choose to get upload sketch on GW
                              //Mattias
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @MLs
                                have you installed the mysensors board files? And chosen the Sensebender Gateway as target platform?
                                (Seems that you are using Arduino/Genuino Zero as target?)
                                M 2 Replies Last reply
                                • tbowmoT tbowmo
                                  @Fabien
                                  original
                                  void hwInit()
                                          Wire.begin();
                                  modify to this
                                  void hwInit()
                                          Wire.begin();
                                  F
                                  F
                                  Fabien
                                  @tbowmo I'm using the serial sketch.
                                  I have few issues (I think) :
                                  • when I want to upload a new sketch, first time after powering by computer, every led goes off and SBGW seems to be disconnected. When I unplug/plug, no led are on or blink, but detection is ok and I can upload a firmware.
                                  • When I press RESET after connecting SBGW on my computer, all led goes off and SBGW disconnect.
                                  And it doesn't seems to wait when I plug computer, led start blinking ...
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @Fabien
                                    Is it windows or linux? Linux (ubuntu) have a bad habit of letting modem manager snatch any ACM devices that is connected to the computer.
                                    • tbowmoT tbowmo
                                      @MLs
                                      MLs
                                      wrote on last edited by MLs
                                      #141
                                      @tbowmo
                                      Yes, I have installed MYSensors boards but find only micro
                                      So therefore, I tried another card.
                                      //Mattias
                                      • M MLs
                                        @tbowmo
                                        //Mattias
                                        MLs
                                        @MLs
                                        I found the problem myself. Had just installed Micro
                                        • tbowmoT tbowmo
                                          @Fabien
                                          F
                                          F
                                          Fabien
                                          @tbowmo said in 💬 Sensebender Gateway:
                                          Yes it's ubuntu ... Do you know how to avoid this ? udev ?
