  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.7k Views 53 Watching
    Thank you @scalz!
    alexsh1A
    alexsh1A
    alexsh1
    @scalz Please share the STL files!
      @alexsh1 why, i don't understand :stuck_out_tongue_winking_eye:
      Here it is : http://www.thingiverse.com/thing:2084269
      alexsh1A 2 Replies Last reply
        #120
        I'm proud to say enclosure files have been integrated in the MySensors Sensebender GW project and git.
        So you can find the files here at Mysensors.
        Enjoy :)
          MLs
          wrote on last edited by MLs
          #121
          Hey it should look like this?
          But you see the gap between the W5100 and Sensebende Gateway.
          Sorry for a very poor camera
          //Mattias
          • tbowmoT
            tbowmoT
            tbowmo
            @MLs
            Yes, according to the build instructions here, you can also raise the socket a bit over the pcb.
            The problem is that the ethernet connector is higher than a normal IDC socket, which means you can't insert the board fully in the socket. I have searched for a higher variant of the socket, but haven't found a suitable candidate..
            alexsh1A 1 Reply Last reply
            • tbowmoT tbowmo
              @MLs
              alexsh1A
              alexsh1A
              alexsh1
              @tbowmo What I did was soldering the socket a bit higher. Not a problem with some soldering skills...
              • scalzS scalz
                alexsh1A
                alexsh1A
                alexsh1
                @scalz Thank you Sir. I am going to probably wait for the PLA version as It has been working a bit better for me.
                • D
                  Disca
                  Few things about the software side of this. When you plug it into your computer it appears as a "Sensebender GW", with a custom USB VID/PID. You have to override the drivers and use the "Atmel Corp. EDBG CMSIS-DAP" serial port drivers or you will have no serial port at all to communicate with the board.
                  Second issue, with the latest Arduino software (1.8.1), and the MySensors SAMD board package installed and MySensor library installed you get an error relating to a missing core "arduino:arduino". Solution to that one is to install the main Arduino SAMD board package which adds the necessary libraries. Secondly, after doing that you will now get another error regarding a missing "Sam.h" file, to fix that you have to manually edit the platform.txt file in "\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.3" with the contents of the one from "\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11" - just being careful to copy over the name and version lines from the top of the Mysensors platform.txt file. After that you are good to go and can finally program the board or get some data out of it :-)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    #126
                    We are preparing a new release of the board definitions for our samd. Which fixes the issues with arduino samd 1.6.11.
                    It should also contain a driver .inf file for Windows 7/8, for those that needs it (it's not needed on Linux, mac or Windows 10). I had completely forgotten that windows usually needs this inf file to operate correct (I have been using Linux the last 17 years for all my private projects)
                    I hope the package will be out tomorrow (sunday) , as I just need to do a couple of tests to verify things.
                    D 1 Reply Last reply
                    • Viktor ZemanV
                      Viktor ZemanV
                      Viktor Zeman
                      Do you have any example sketch for this gateway? I want to use in my GW radio + wifi module.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Viktor-Zeman
                        It only support wired ethernet, and USB. For wifi we have ESP8266 gateways instead.
                        There are example sketches available in mysensors (see SensebenderGatewaySerial, or just plain GatewayW5100 would work if it's just ethernet module that you want to use)
                        • tbowmoT tbowmo
                          Disca
                          @tbowmo Great, took a an hour or two to work out what was going on. Not used MySensors before so presumed it was something I was doing wrong. I have an RFM69HW soldered on the sensebender GW now with the serial sketch loaded and it appears to be working!
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            for info, a new Mysensors SAMD board definition file have been released (1.0.4)
                            Includes the following changes:
                            Arduino SAMD 1.6.11 supported (the latest arduino board definitions for SAMD)
                            Various bits and pieces regarding pin definitions are fixed (a couple of missing defines)
                            Windows driver .inf file added.
                            D M 3 Replies Last reply
                            • tbowmoT tbowmo
                              Disca
                              @tbowmo Compiles fine now with 1.0.4, not convinced the drivers are being automatically picked up though. I can force install them by selecting the inf but presumably you want it automatic when someone plugs in the gateway?
                              I notice in the arduino SAMD package they have a post-install.bat to seemingly install the inf file - possibly needed?
                              It could also be that i've just messed things up with my manual driver install stuff yesterday. I'm on Windows 7 by the way.
                              • tbowmoT tbowmo
                                Disca
                                @tbowmo Also, I notice on Linux (Raspberry Pi 3 running Debian) the device appears as an ACM device rather than the usual TTY device that some might expect. It works fine though so no issues but may confuse alot of people - worth making a note somewhere.
                                • tbowmoT tbowmo
                                  MLs
                                  @tbowmo
                                  (for info, a new Mysensors SAMD board definition file have been released (1.0.4))
                                  Where?
                                  • F
                                    F
                                    Fabien
                                    @MLs reload board definition from IDE
                                    I have a little annoying bug : I can't reset de gateway. When resetting, I loose communication with my computer (linux) same after loading a new sketch (last version with IDE 1.8.1 and def 1.0.4))
                                    [13727.746445] usb 1-1: new full-speed USB device number 9 using xhci_hcd
                                    [13727.892970] usb 1-1: New USB device found, idVendor=1209, idProduct=6949
                                    [13727.892974] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                    [13727.892977] usb 1-1: Product: Sensebender GW
                                    [13727.892980] usb 1-1: Manufacturer: MySensors.org
                                    [13727.895690] cdc_acm 1-1:1.0: ttyACM1: USB ACM device
                                    [13749.066589] usb 1-1: USB disconnect, device number 9
                                    So I can't check debug messages from init.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @MLs
                                      Check out the setup instructions here
                                      and perhaps this
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @Fabien
                                        Are you using it as an ethernet gw, or standard serial gw? If serial GW, then the gateway waits until something connects to the serial device
                                        The ethernet gw doesn't wait for something to connect. But you can hack the core, change hwInit() function in MyHwSAMD.cpp:
                                        original
                                        void hwInit()
                                                MY_SERIALDEVICE.begin(MY_BAUD_RATE);
                                        #if defined(MY_GATEWAY_SERIAL)
                                                while (!MY_SERIALDEVICE) {}
                                                Wire.begin();
                                        modify to this
                                        void hwInit()
                                                Wire.begin();
                                        It will make the gateway halt the initialization until something connects to the USB device.
                                        Be advised, that if you don't have it connected to a computer, then it will not start up correctly.. That is why you need to hack the core to enable it..
                                        F 1 Reply Last reply
                                        • tbowmoT tbowmo
                                          @MLs
                                          and perhaps this
                                          MLs
                                          @tbowmo
                                          When I try to upload sketch
                                          Arduino:1.8.0 (Windows 10), Kort:"Arduino/Genuino Zero (Native USB Port)"
                                          Sketch uses 46488 bytes (17%) of program storage space. Maximum is 262144 bytes.
                                          No device found on COM4
                                          Invalid version found: 1.04
                                          When I use the serial monitor
                                          0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGS--,VER=2.1.0
                                          0;255;3;0;9;TSF:LRT:OK
                                          0;255;3;0;9;TSM:INIT
                                          0;255;3;0;9;TSF:WUR:MS=0
                                          0;255;3;0;9;TSM:INIT:TSP OK
                                          0;255;3;0;9;TSM:INIT:GW MODE
                                          0;255;0;0;18;2.1.0
                                          0;255;3;0;9;MCO:BGN:STP
                                          0;255;3;0;9;TSF:MSG:READ,27-27-0,s=0,c=1,t=1,pt=7,l=5,sg=0:45.6
                                          27;0;1;0;1;45.6
                                          0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.4
                                          23;1;1;0;0;8.4
                                          0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.3
                                          23;1;1;0;0;8.3
                                          0;255;3;0;9;TSF:MSG:READ,23-23-0,s=0,c=1,t=1,pt=7,l=5,sg=0:51.8
                                          23;0;1;0;1;51.8
                                          0;255;3;0;9;TSF:MSG:READ,22-22-0,s=1,c=1,t=0,pt=7,l=5,sg=0:3.4
                                          22;1;1;0;0;3.4
                                          0;255;3;0;9;TSF:MSG:READ,23-23-0,s=0,c=1,t=1,pt=7,l=5,sg=0:52.0
                                          23;0;1;0;1;52.0
                                          0;255;3;0;9;TSF:MSG:READ,22-22-0,s=1,c=1,t=0,pt=7,l=5,sg=0:3.5
                                          22;1;1;0;0;3.5
                                          0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.2
                                          23;1;1;0;0;8.2
                                          0;255;3;0;9;TSF:MSG:READ,23-23-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          0;255;3;0;9;TSF:MSG:BC
                                          0;255;3;0;9;TSF:MSG:FPAR REQ,ID=23
                                          0;255;3;0;9;TSF:PNG:SEND,TO=0
                                          0;255;3;0;9;TSF:CKU:OK
                                          0;255;3;0;9;TSF:MSG:GWL OK
                                          0;255;3;0;9;!TSF:MSG:SEND,0-0-23-23,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                          0;255;3;0;9;TSF:MSG:READ,23-23-0,s=0,c=1,t=1,pt=7,l=5,sg=0:52.4
                                          23;0;1;0;1;52.4
                                          22;1;1;0;0;3.4
                                          0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.1
                                          23;1;1;0;0;8.1
                                          I USE IDE 1.80
                                          Which card should I choose to get upload sketch on GW
                                          //Mattias
