  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.7k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @Viktor-Zeman
    It only support wired ethernet, and USB. For wifi we have ESP8266 gateways instead.
    There are example sketches available in mysensors (see SensebenderGatewaySerial, or just plain GatewayW5100 would work if it's just ethernet module that you want to use)
    • tbowmoT tbowmo
      We are preparing a new release of the board definitions for our samd. Which fixes the issues with arduino samd 1.6.11.
      It should also contain a driver .inf file for Windows 7/8, for those that needs it (it's not needed on Linux, mac or Windows 10). I had completely forgotten that windows usually needs this inf file to operate correct (I have been using Linux the last 17 years for all my private projects)
      I hope the package will be out tomorrow (sunday) , as I just need to do a couple of tests to verify things.
      Disca
      @tbowmo Great, took a an hour or two to work out what was going on. Not used MySensors before so presumed it was something I was doing wrong. I have an RFM69HW soldered on the sensebender GW now with the serial sketch loaded and it appears to be working!
      • tbowmoT
        tbowmoT
        tbowmo
        for info, a new Mysensors SAMD board definition file have been released (1.0.4)
        Includes the following changes:
        Arduino SAMD 1.6.11 supported (the latest arduino board definitions for SAMD)
        Various bits and pieces regarding pin definitions are fixed (a couple of missing defines)
        Windows driver .inf file added.
        D M 3 Replies Last reply
        • tbowmoT tbowmo
          Disca
          @tbowmo Compiles fine now with 1.0.4, not convinced the drivers are being automatically picked up though. I can force install them by selecting the inf but presumably you want it automatic when someone plugs in the gateway?
          I notice in the arduino SAMD package they have a post-install.bat to seemingly install the inf file - possibly needed?
          It could also be that i've just messed things up with my manual driver install stuff yesterday. I'm on Windows 7 by the way.
          • tbowmoT tbowmo
            Disca
            @tbowmo Also, I notice on Linux (Raspberry Pi 3 running Debian) the device appears as an ACM device rather than the usual TTY device that some might expect. It works fine though so no issues but may confuse alot of people - worth making a note somewhere.
            • tbowmoT tbowmo
              MLs
              @tbowmo
              (for info, a new Mysensors SAMD board definition file have been released (1.0.4))
              Where?
              • F
                F
                Fabien
                @MLs reload board definition from IDE
                I have a little annoying bug : I can't reset de gateway. When resetting, I loose communication with my computer (linux) same after loading a new sketch (last version with IDE 1.8.1 and def 1.0.4))
                [13727.746445] usb 1-1: new full-speed USB device number 9 using xhci_hcd
                [13727.892970] usb 1-1: New USB device found, idVendor=1209, idProduct=6949
                [13727.892974] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                [13727.892977] usb 1-1: Product: Sensebender GW
                [13727.892980] usb 1-1: Manufacturer: MySensors.org
                [13727.895690] cdc_acm 1-1:1.0: ttyACM1: USB ACM device
                [13749.066589] usb 1-1: USB disconnect, device number 9
                So I can't check debug messages from init.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @MLs
                  Check out the setup instructions here
                  and perhaps this
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Fabien
                    Are you using it as an ethernet gw, or standard serial gw? If serial GW, then the gateway waits until something connects to the serial device
                    The ethernet gw doesn't wait for something to connect. But you can hack the core, change hwInit() function in MyHwSAMD.cpp:
                    original
                    void hwInit()
                            MY_SERIALDEVICE.begin(MY_BAUD_RATE);
                    #if defined(MY_GATEWAY_SERIAL)
                            while (!MY_SERIALDEVICE) {}
                            Wire.begin();
                    modify to this
                    void hwInit()
                            Wire.begin();
                    It will make the gateway halt the initialization until something connects to the USB device.
                    Be advised, that if you don't have it connected to a computer, then it will not start up correctly.. That is why you need to hack the core to enable it..
                    F 1 Reply Last reply
                    • tbowmoT tbowmo
                      @MLs
                      and perhaps this
                      MLs
                      @tbowmo
                      When I try to upload sketch
                      Arduino:1.8.0 (Windows 10), Kort:"Arduino/Genuino Zero (Native USB Port)"
                      Sketch uses 46488 bytes (17%) of program storage space. Maximum is 262144 bytes.
                      No device found on COM4
                      Invalid version found: 1.04
                      When I use the serial monitor
                      0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGS--,VER=2.1.0
                      0;255;3;0;9;TSF:LRT:OK
                      0;255;3;0;9;TSM:INIT
                      0;255;3;0;9;TSF:WUR:MS=0
                      0;255;3;0;9;TSM:INIT:TSP OK
                      0;255;3;0;9;TSM:INIT:GW MODE
                      0;255;0;0;18;2.1.0
                      0;255;3;0;9;MCO:BGN:STP
                      0;255;3;0;9;TSF:MSG:READ,27-27-0,s=0,c=1,t=1,pt=7,l=5,sg=0:45.6
                      27;0;1;0;1;45.6
                      0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.4
                      23;1;1;0;0;8.4
                      0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.3
                      23;1;1;0;0;8.3
                      0;255;3;0;9;TSF:MSG:READ,23-23-0,s=0,c=1,t=1,pt=7,l=5,sg=0:51.8
                      23;0;1;0;1;51.8
                      0;255;3;0;9;TSF:MSG:READ,22-22-0,s=1,c=1,t=0,pt=7,l=5,sg=0:3.4
                      22;1;1;0;0;3.4
                      0;255;3;0;9;TSF:MSG:READ,23-23-0,s=0,c=1,t=1,pt=7,l=5,sg=0:52.0
                      23;0;1;0;1;52.0
                      0;255;3;0;9;TSF:MSG:READ,22-22-0,s=1,c=1,t=0,pt=7,l=5,sg=0:3.5
                      22;1;1;0;0;3.5
                      0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.2
                      23;1;1;0;0;8.2
                      0;255;3;0;9;TSF:MSG:READ,23-23-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;TSF:MSG:BC
                      0;255;3;0;9;TSF:MSG:FPAR REQ,ID=23
                      0;255;3;0;9;TSF:PNG:SEND,TO=0
                      0;255;3;0;9;TSF:CKU:OK
                      0;255;3;0;9;TSF:MSG:GWL OK
                      0;255;3;0;9;!TSF:MSG:SEND,0-0-23-23,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      0;255;3;0;9;TSF:MSG:READ,23-23-0,s=0,c=1,t=1,pt=7,l=5,sg=0:52.4
                      23;0;1;0;1;52.4
                      22;1;1;0;0;3.4
                      0;255;3;0;9;TSF:MSG:READ,23-23-0,s=1,c=1,t=0,pt=7,l=5,sg=0:8.1
                      23;1;1;0;0;8.1
                      I USE IDE 1.80
                      Which card should I choose to get upload sketch on GW
                      //Mattias
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @MLs
                        have you installed the mysensors board files? And chosen the Sensebender Gateway as target platform?
                        (Seems that you are using Arduino/Genuino Zero as target?)
                        M 2 Replies Last reply
                        • tbowmoT tbowmo
                          @Fabien
                          original
                          void hwInit()
                                  Wire.begin();
                          modify to this
                          void hwInit()
                                  Wire.begin();
                          F
                          F
                          Fabien
                          @tbowmo I'm using the serial sketch.
                          I have few issues (I think) :
                          • when I want to upload a new sketch, first time after powering by computer, every led goes off and SBGW seems to be disconnected. When I unplug/plug, no led are on or blink, but detection is ok and I can upload a firmware.
                          • When I press RESET after connecting SBGW on my computer, all led goes off and SBGW disconnect.
                          And it doesn't seems to wait when I plug computer, led start blinking ...
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @Fabien
                            Is it windows or linux? Linux (ubuntu) have a bad habit of letting modem manager snatch any ACM devices that is connected to the computer.
                            • tbowmoT tbowmo
                              @MLs
                              MLs
                              wrote on last edited by MLs
                              #141
                              @tbowmo
                              Yes, I have installed MYSensors boards but find only micro
                              So therefore, I tried another card.
                              //Mattias
                              • M MLs
                                @tbowmo
                                //Mattias
                                MLs
                                @MLs
                                I found the problem myself. Had just installed Micro
                                • tbowmoT tbowmo
                                  @Fabien
                                  F
                                  F
                                  Fabien
                                  @tbowmo said in 💬 Sensebender Gateway:
                                  Yes it's ubuntu ... Do you know how to avoid this ? udev ?
                                  • F
                                    F
                                    Fabien
                                    Ok :
                                    sudo apt-get --purge remove modemmanager
                                    • tbowmoT tbowmo
                                      @MLs
                                      MLs
                                      #145
                                      @tbowmo
                                      Hi i get same error whit Sensebender Ga
                                      Arduino:1.8.0 (Windows 10), Kort:"Sensebender Gateway"
                                      Sketch uses 46720 bytes (17%) of program storage space. Maximum is 262144 bytes.
                                      option enabled in File -> Preferences.```
                                      But serial monitor works fine with COM4
                                      //Mattias
                                      D 1 Reply Last reply
                                      • M MLs
                                        @tbowmo
                                        //Mattias
                                        Disca
                                        @MLs In Device Manager what com port is assigned to the sensebender GW? Have you manually installed the inf file?
                                        com4 is likely the last com port you used in the arduino interface not the one assigned to the GW.
                                        • D Disca
                                          MLs
                                          #147
                                          @Disca
                                          No, I have not installed or selected com port.
                                          Device Manager COM4
                                          As I understood it so Windows 10 would fix everything, right?
                                          //Mattias
