  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @MLs
    have you installed the mysensors board files? And chosen the Sensebender Gateway as target platform?
    (Seems that you are using Arduino/Genuino Zero as target?)
    M 2 Replies Last reply
    • tbowmoT tbowmo
      @Fabien
      Are you using it as an ethernet gw, or standard serial gw? If serial GW, then the gateway waits until something connects to the serial device
      The ethernet gw doesn't wait for something to connect. But you can hack the core, change hwInit() function in MyHwSAMD.cpp:
      original
      void hwInit()
              MY_SERIALDEVICE.begin(MY_BAUD_RATE);
      #if defined(MY_GATEWAY_SERIAL)
              while (!MY_SERIALDEVICE) {}
              Wire.begin();
      modify to this
      void hwInit()
              Wire.begin();
      It will make the gateway halt the initialization until something connects to the USB device.
      Be advised, that if you don't have it connected to a computer, then it will not start up correctly.. That is why you need to hack the core to enable it..
      F
      F
      Fabien
      @tbowmo I'm using the serial sketch.
      I have few issues (I think) :
      • when I want to upload a new sketch, first time after powering by computer, every led goes off and SBGW seems to be disconnected. When I unplug/plug, no led are on or blink, but detection is ok and I can upload a firmware.
      • When I press RESET after connecting SBGW on my computer, all led goes off and SBGW disconnect.
      And it doesn't seems to wait when I plug computer, led start blinking ...
      • tbowmoT
        tbowmoT
        tbowmo
        @Fabien
        Is it windows or linux? Linux (ubuntu) have a bad habit of letting modem manager snatch any ACM devices that is connected to the computer.
        F 1 Reply Last reply
        • tbowmoT tbowmo
          @MLs
          MLs
          wrote on last edited by MLs
          #141
          @tbowmo
          Yes, I have installed MYSensors boards but find only micro
          So therefore, I tried another card.
          //Mattias
          • M MLs
            @tbowmo
            //Mattias
            MLs
            @MLs
            I found the problem myself. Had just installed Micro
            • tbowmoT tbowmo
              @Fabien
              F
              F
              Fabien
              @tbowmo said in 💬 Sensebender Gateway:
              Yes it's ubuntu ... Do you know how to avoid this ? udev ?
              • F
                F
                Fabien
                Ok :
                sudo apt-get --purge remove modemmanager
                • tbowmoT tbowmo
                  @MLs
                  MLs
                  #145
                  @tbowmo
                  Hi i get same error whit Sensebender Ga
                  Arduino:1.8.0 (Windows 10), Kort:"Sensebender Gateway"
                  Sketch uses 46720 bytes (17%) of program storage space. Maximum is 262144 bytes.
                  No device found on COM4
                  Invalid version found: 1.04
                  option enabled in File -> Preferences.```
                  But serial monitor works fine with COM4
                  //Mattias
                  D 1 Reply Last reply
                  • M MLs
                    @tbowmo
                    //Mattias
                    Disca
                    @MLs In Device Manager what com port is assigned to the sensebender GW? Have you manually installed the inf file?
                    com4 is likely the last com port you used in the arduino interface not the one assigned to the GW.
                    • D Disca
                      MLs
                      #147
                      @Disca
                      No, I have not installed or selected com port.
                      Device Manager COM4
                      As I understood it so Windows 10 would fix everything, right?
                      //Mattias
                      • F
                        F
                        Fabien
                        @tbowmo : It's better for seeing debug from start.
                        But there is 2 bugs :
                        • When you want to upload sketch. /dev/ttyACM0 disapear (and D4 goes off) afterunplu/plug it works for uploading sketch (D4 off) but at the end of uplaod ArduinoIDE makes a soft reset and /dev/ttyACM0 disapear. Works fine after plus/unplug (D4 ON)
                        • When pressing reset /dev/ttyACM0 disapear (and D4 goes off). Works fine after plug/unplug
                        • M MLs
                          @Disca
                          Device Manager COM4
                          //Mattias
                          Disca
                          @MLs mmm not sure then, it works for me on Windows 7 with 1.8.1 (slightly newer version?)
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @MLs
                            I don't have windows installed, so I'm sorry that I can't help with windows specifics.
                            • tbowmoT tbowmo
                              @MLs
                              MLs
                              @tbowmo
                              Now, I think it feels like hardware failure more than software errors. Will try tomorrow on my second computer with Windows 7 and see if there is any difference.
                              //Mattias
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @Fabien
                                I added a couple of udev rules, to stop modemmanager take control over the device
                                ACTION!="add|change|move", GOTO="local_usb_device_blacklist_end"
                                SUBSYSTEM!="usb", GOTO="local_usb_device_blacklist_end"
                                ENV{DEVTYPE}!="usb_device",  GOTO="local_usb_device_blacklist_end"
                                ATTRS{idVendor}=="1209", ENV{ID_MM_DEVICE_IGNORE}="1"
                                LABEL="local_usb_device_blacklist_end"
                                Add the above to this file /etc/udev/rules.d/mysensors.rules
                                As the USB is native in the arm processor, then it will re-enumerate on the USB port whenever a reset condition occurs. When you press the reset button it will act as a unplug / plug operation (you can see this in dmesg)
                                When uploading to the gateway, it will reset itself to enter bootloader.. The bootloader will have another VID/PID combo (VID:1209, PID:6448) than during normal operation (VID:1209, PID:6449).
                                I have never seen the problems that you are having, where you need to fysically unplug / plug the device, after you have pressed the reset button (or uploaded a new firmware). And I have uploaded firmware (and pressed the reset button) quite some times :)
                                Also please note, that if you double tap the reset button, the gateway will enter bootloader mode, and wait for a new sketch to be sent.
                                • F
                                  F
                                  Fabien
                                  @tbowmo : Same with udev rules (but this file is not necessary because modemmanger is not installed).
                                  I try to power SBGW with usb, D4 goes ON. After pressing reset, D4 goes OFF and never goes on (I must unplug/plu usb power). Do you have the same with your board ? Perhaps a problem with bootloader ?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    #154
                                    @Fabien
                                    D4 is the yellow LED, and the only place it is used is in the onboard selftest routine.
                                    In my setup, D5 turns on when plugging in the device. If I hit reset one time, it momentarily switches off D5, and then back on. if I hit reset twice, it stays off (bootloader is activated)
                                    The above is done on my RFM69 debug gateway, so the sketch is for RFM69, but otherwise a standard SensebenderGatewaySerial sketch
                                    Have you checked dmesg, when plugging in, and when hitting the reset button?
                                    Have you tried with another USB cable? Have you tried with another computer?
                                    • F
                                      F
                                      Fabien
                                      I try with 2 different USB cable and 2 computer (1 laptop and 1 desktop). Same problem. With a charger too. And sorry for the mistake, it's D5 (orange)
                                      On log
                                      [ 4788.031324] usb 1-8: USB disconnect, device number 6
                                      • F
                                        F
                                        Fabien
                                        Thank you @scalz !
                                        You must have a very well calibrated printer to print it correctly. First try fails (oozing due to overtemp)
                                        Other side tomorrow !
                                        • D Disca
                                          MLs
                                          @Disca
                                          Where did you find the drivers for sensebender GW for Windows 7?
                                          //Mattias
                                          tbowmoT 1 Reply Last reply
