  2. Bug Reports
  3. I_DEBUG variable is sent via "set" command, instead of "internal" command
6 Posts 2 Posters 2.7k Views 2 Watching
  • G Offline
    G Offline
    gogopotato
    In the latest version, I noticed that when a node is sending out a I_DEBUG type payload, it's being sent out as set (1) command instead of internal (3) command. The type value is correctly set to "28" in both cases.
    Example:
    // Debug msg container declaration
    MyMessage msgE1(255, I_DEBUG);
    // Send Debug payload
    send(msgE1.set("BME280 INIT SUCCESS"));
    Expected message sent to gateway:
    mygateway1-out/11/255/3/0/28 BME280 INIT SUCCESS
    Actual message sent to gateway:
    mygateway1-out/11/255/1/0/28 BME280 INIT SUCCESS
    • G gogopotato
      Example:
      @gogopotato it looks like the message is sent with the type V_VAR5. I am not sure how to send internal messages manually, but the constructor used in your code expects a V_ type, not an I_ type.
      • mfalkviddM Offline
        Looking at https://github.com/mysensors/MySensors/blob/4380d6618fe818aaf0edc6373bdff400338257a8/MyConfig.h#L38 it seems like there are no "free-form" debug messages.
        G 1 Reply Last reply
          G Offline
          G Offline
          gogopotato
          @mfalkvidd Makes sense. Is there another "free-form" message type I can use instead?
          • G gogopotato
            @gogopotato V_TEXT should work. https://www.mysensors.org/download/serial_api_20#set,-req
              G Offline
              G Offline
              gogopotato
              @mfalkvidd Great. Thanks for the help!
