  3. Using debounce twice in the same sketch
10 Posts 3 Posters 2.7k Views 3 Watching
  • breimannB Offline
    breimannB Offline
    breimann
    Hi there, i'm struggling to combine a couple sketches and it seems the only issue now is using debouncer.
    The binaryswitchsensor sketch uses Debouncer, but my relay actuator with buttons sketch does as well.
    These are the errors i get compiling:
    ChookHouseAutomationV21.ino:89:26: error: conflicting declaration 'Bounce debouncer [7]'
    ChookHouseAutomationV21.ino:71:8: error: 'debouncer' has a previous declaration as 'Bounce debouncer'
    ChookHouseAutomationV21.ino: In function 'void setup()':
    ChookHouseAutomationV21.ino:151:14: error: no match for 'operator[]' (operand types are 'Bounce' and 'int')
    ChookHouseAutomationV21.ino:152:14: error: no match for 'operator[]' (operand types are 'Bounce' and 'int')
    ChookHouseAutomationV21.ino:153:14: error: no match for 'operator[]' (operand types are 'Bounce' and 'int')
    ChookHouseAutomationV21.ino: In function 'void loop()':
    ChookHouseAutomationV21.ino:219:18: error: no match for 'operator[]' (operand types are 'Bounce' and 'byte {aka unsigned char}')
    ChookHouseAutomationV21.ino:221:28: error: no match for 'operator[]' (operand types are 'Bounce' and 'byte {aka unsigned char}')
    Error compiling.
    Can anyone help please?? This is for my chook house automation system.
    blaceyB 1 Reply Last reply
    • breimannB breimann
      Error compiling.
      blaceyB Offline
      blaceyB Offline
      blacey
      @breimann It is usually helpful if you post the entire sketch within code blocks. You can create a code block by entering ``` before and after the code.
      breimannB 1 Reply Last reply
      • pansenP Offline
        pansenP Offline
        pansen
        said in Using debounce twice in the same sketch:
        Agree with @blacey, however, the problem is that one portion of the code uses
        Whereas the other uses
        Bounce debouncer
        It might be enough to remove this declaration and replace
        debouncer
        with
        debouncer[0]
        in the code using the non-array debouncer class. I do not know your hardware setup, so the index (the zero) might be different.
        Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
        • blaceyB blacey
          breimannB Offline
          breimannB Offline
          breimann
          Thankyou @blacey I can try and thanks for telling me how to post code properly!
          • pansenP pansen
            Bounce debouncer
            debouncer
            with
            debouncer[0]
            breimannB Offline
            breimannB Offline
            breimann
            @pansen, Thankyou for your suggestion. I just don't understand the bounce/debounce function properly.
            I'll try posting my whole code.
            Thankyou to both of you for taking the time to help.
              breimannB Offline
              breimannB Offline
              breimann
              @breimann Here is my code. It's not pretty.
              //#define MY_RS485
              #define DHT_DATA_PIN 14
              #define SENSOR_TEMP_OFFSET 0
              static const uint64_t UPDATE_INTERVAL = 60000;
              #define CHILD_ID_HUM 10
              #define CHILD_ID_TEMP 11
              #define CHILD_ID_DOOR 12
              #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
              #define RELAY_OFF 1
              #define DOOR_SENSOR 41                  // pin for door reed switch
              Bounce debouncer = Bounce();
              int oldValue=-1;
              #define noRelays 7                     //2-4
              const int relayPin[] = {42, 43, 44, 50, 51, 52, 53};       //  switch around pins to your desire
              const int buttonPin[] = {2, 3, 4, 5, 6, 7, 8};   //  switch around pins to your desire
              class Relay             // relay class, store all relevant data (equivalent to struct)
                public:
                  int buttonPin;                   // physical pin number of button
                  int relayPin;             // physical pin number of relay
                  boolean relayState;               // relay status (also stored in EEPROM)
              Relay Relays[noRelays];
              Bounce debouncer[noRelays];
              MyMessage msg[noRelays];
              float lastTemp;
              float lastHum;
              uint8_t nNoUpdatesTemp;
              uint8_t nNoUpdatesHum;
              bool metric = true;
              MyMessage msgDoor(CHILD_ID_DOOR, V_TRIPPED);
              DHT dht;
                sendSketchInfo("The Chook Hotel", "2.0");
                present(CHILD_ID_HUM, S_HUM);
                present(CHILD_ID_DOOR, S_DOOR);
                wait(100);
                for (int i = 0; i < noRelays; i++)
                  present(i, S_LIGHT);                               // present sensor to gateway
                wait(100);
                wait(100);
                for (int i = 0; i < noRelays; i++) {
                  Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                  msg[i].type = V_LIGHT;
                  wait(100);
                  Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                  digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                  send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                  wait(50);
                  debouncer[i].interval(30);
                  wait(50);
                // Setup the button
                pinMode(DOOR_SENSOR,INPUT);
                // Activate internal pull-up
                digitalWrite(DOOR_SENSOR,HIGH);
                debouncer.attach(DOOR_SENSOR);
                debouncer.interval(5);
                dht.readSensor(true);
                if (isnan(temperature)) {
                  lastTemp = temperature;
                  if (!metric) {
                  // Reset no updates counter
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                  Serial.print("T: ");
                  nNoUpdatesTemp++;
                if (isnan(humidity)) {
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                  Serial.print("H: ");
                  Serial.println(humidity);
                  nNoUpdatesHum++;
                for (byte i = 0; i < noRelays; i++) {
                  if (debouncer[i].update()) {
                    if ( value == LOW) {
                      // save sensor state in EEPROM (location == sensor number)
                      saveState( i, Relays[i].relayState );
              debouncer.update();
                // Get the update value
                int value = debouncer.read();
                if (value != oldValue) {
                   // Send in the new value
                   send(msgDoor.set(value==HIGH ? 1 : 0));
                   oldValue = value;
                //wait(20);
                  if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                    digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                    saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                wait(20);
              • pansenP Offline
                pansenP Offline
                pansen
                No worries. Can you upload a schematic? Like, what is connected where?
                As a start:
                Change 1
                to
                Bounce debouncer_door_sensor = Bounce();
                Change 2
                to
                 debouncer_door_sensor.attach(DOOR_SENSOR);
                 debouncer_door_sensor.interval(5);
                Change 3
                debouncer.update();
                to
                debouncer_door_sensor.update();
                 int value = debouncer_door_sensor.read();
                Good luck
                breimannB 3 Replies Last reply
                • pansenP pansen
                  As a start:
                  Change 1
                  to
                  Change 2
                  to
                  Change 3
                  debouncer.update();
                  to
                  Good luck
                  breimannB Offline
                  breimannB Offline
                  breimann
                  @pansen Thankyou!!! I made those 3 changes and tried compiling and it compiled all good. Now i just need to try uploading but that's a bit complex as my Mega is in the chookhouse! I'll try it tomorrow and let you know.
                  • pansenP pansen
                    As a start:
                    Change 1
                    to
                    Change 2
                    to
                    Change 3
                    debouncer.update();
                    to
                    Good luck
                    breimannB Offline
                    breimannB Offline
                    breimann
                    @pansen Sorry i haven't gotten to uploading it. Too much else on. Will let you know when i do.
                    • pansenP pansen
                      As a start:
                      Change 1
                      to
                      Change 2
                      to
                      Change 3
                      debouncer.update();
                      to
                      Good luck
                      breimannB Offline
                      breimannB Offline
                      breimann
                      @pansen I uploaded it last week, and it all works great!!! Thankyou Heaps!!
                      11.8k
                      113.2k
