  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 502.0k Views 73 Watching
  • R robosensor
    Does anyone know how to allow multiple TCP connections forwarded to one MYS tty port? This socat command blocks second TCP connection until first one disconnected.
    I just want to connect MYSController using TCP without disconnecting my custom MQTT<=>serial controller script. I'm using RPi with USB-serial gateway.
    P.S. @tekka is there any chances that MQTT access will be implemented in MYSController?
    @techRH said:
    $ sudo socat tcp-l:5003,reuseaddr,fork file:/dev/mySensorsCOM,nonblock,waitlock=/var/run/mySensorsCOM.lock
    P
    P
    pdey
    @robosensor I wrote a bridge to use on the Linino side of the Arduino Yun for this:
    https://github.com/peterdey/Yun-Linino-NewBridge
    But there's no reason you couldn't use this on an rPi - you'll probably just need to turn the baud rate down to 115200.
    • jmkhaelJ jmkhael
      @tekka great work! thank you for sharing this.
      Your controller and great contribution had me quickly started with mysensors. I am interested in a way to do OTA updates using MYSController via api or a script call or even rewriting the logic in an outside code. I'll try to explain the need based on my setup below.
      Given that I am using jeedom right now as a controller, but sadly it doesn't seem to support yet OTA updates. I'd like to be able to reuse or even contribute to this feature and I'd appreciate pointers to start doing that.
      My setup has it that jeedom runs off a raspi and has a mysensors serial gateway attached. (1 to 2 Watts draw for this setup). MYSController can work as an ethernet relay gateway, but if I understand correctly I have to run it on windows (more moving parts), or a much hungrier box than my raspi.
      Is there a way I can make that work somehow? I am ready and appreciate any type of suggestions with the current setup I have or an evolution which goes into that direction.
      tekkaT
      tekkaT
      tekka
      @jmkhael You can use "GW mode" (=proxy mode) in the tab bar
      • techRHT
        techRHT
        techRH
        I thought the socat command is to slow in switching so i have created a python script which will readout the mysensors serial GW and sends the data to a virtual serial port to connect to openhab and a TCP socket for the MySensors controller.
        https://github.com/Rutger798/serial_to_serial_and_tcp/blob/master/serial_to_serial_and_tcp.py
        • dopeeyeD
          dopeeyeD
          dopeeye
          How do i use MYSController with a Raspberry Pi ?
          I have a RPi2 with a NRF24 radio as a gateway and want to troubleshoot some communication issues i have been having. I usually log into the RPi2 via ssh to make adjustments.
          Can I just download the files and rund the .exe via command-line?
          • AndurilA
            AndurilA
            Anduril
            I think it's windows software only. If you want to use it this way you should make you gateway device accessible via ethernet, maybe socat or nodered is an option for you.
            dopeeyeD 1 Reply Last reply
            • AndurilA Anduril
              dopeeyeD
              dopeeyeD
              dopeeye
              ok thanks for clarifying.
              gonna give the node-red a try
              • P pdey
                @Mark-Swift : If you're happy to modify the MySensors library in an unsupported way, I've added a logMessage function to transmit text/debug messages from remote nodes:
                https://github.com/peterdey/MySensors-Arduino/commit/f5f339b71620ec3cd896304a2ca6aba40ad40218
                Found it useful, particularly in conjunction with MYSController OTA firmware updates.
                jumpingJ
                jumpingJ
                jumping
                is it possible to use with mysensor 2.0 API ?
                Raspberrry PI3 - Domoticz
                ESP8266 GW - MySensors 2.1.1
                • interxisI
                  interxisI
                  interxis
                  Very cool. It also works on Ubuntu with Wine.
                  You have to create a COM port like this:
                  ln -s /dev/ttyUSB0 ~/.wine/dosdevices/com1
                  • karlheinz2000K
                    karlheinz2000K
                    karlheinz2000
                    How do I get MYSController to save info about each node?
                    I always have to set "battery-powered" after each upload and it does not save sketch name etc.
                    • meanmrgreenM
                      meanmrgreenM
                      meanmrgreen
                      Ok this might be a realy stupid question but im what you call a "nuub" ;)
                      If i want to monitor my current setup (serial gateway on a pi3) on windows/mint. Do i build another gateway and plug it in the pc?
                      Sorry if i missed the instructions on this
                      tekkaT 1 Reply Last reply
                      • meanmrgreenM meanmrgreen
                        tekkaT
                        tekkaT
                        tekka
                        @meanmrgreen no, you can only have one GW in your setup. You could connect your GW to the PC, configure it for serial input, enable GW mode and have your rpi controller pointing at it (IP).
                        meanmrgreenM 1 Reply Last reply
                        • tekkaT tekka
                          meanmrgreenM
                          meanmrgreenM
                          meanmrgreen
                          @tekka
                          How about I'f i replace my serial with a Ethernet gw?
                          Do not want my pc running all the time. Just to debug
                            Samuel235
                            Hi @tekka - I'm currently running OpenHAB connected to mysensors by a GatewayW5100MQTTClient gateway and at the moment I have to manual upgrades to the nodes by disconnecting them and plugging them into the PC and recompiling all the software for each node. Would there be any way around this setup? I would like to keep OpenHAB as my controller and I really like the MQTT Client software too. Its simple and it just works for me. However, i would be open to change from MQTT if needed.
                            What is your recommendation of implementing MYScontroller to use for OTA firmware updates only?
                            MySensors 2.1.1
                            • AndurilA
                              AndurilA
                              Anduril
                              @tekka how do I initiate a reboot of a node from gateway side? I don't know how, but it's needed for updating OTA. Thanks in advance.
                              techRHT 1 Reply Last reply
                              • AndurilA Anduril
                                techRHT
                                techRHT
                                techRH
                                @Anduril said in Windows GUI/Controller for MySensors:
                                Right click on the node and than "reboot"
                                AndurilA 1 Reply Last reply
                                • techRHT techRH
                                  AndurilA
                                  AndurilA
                                  Anduril
                                  @techRH that doesn't work for the new bootloader/MySensors 2.x
                                  • AndurilA Anduril
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Anduril it does work, unless your node is sleeping and not able to process incoming messages
                                    • AndurilA
                                      AndurilA
                                      Anduril
                                      @tekka ok and whats the way to deal with sleeping nodes? Do I have to add a wait(xx) to receive reboot commands?
                                      • AndurilA Anduril
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Anduril The solution is to use smart sleep. If you are on MySensors 2.1.x, use:
                                        sleep(xyz_MS, true);
                                        This will issue a heartbeat message followed by a short wait() interval to process incoming messages, and finally send the node to sleep. The heartbeat message triggers the release of pending messages (i.e. reboot request) in MYSController (node has to be defined as battery-powered / sleeping node).
                                        In the upcoming MySensors 2.2.0 release we will introduce a dedicated sleep intention message.
                                        • AndurilA
                                          AndurilA
                                          Anduril
                                          @tekka thanks for your hint. Is smartsleep supported if the controller (pimatic) does not? So do I get problems when using withoug MYSController for debug?
                                          And another thing is that this node tries to save power and only sends updates if values have changed. So using smartsleep and sending a messag every sleep cycle would be against that. Can I simply put a wait(50) after the first message sending is triggered? What would be the necessary time to do wait(x)?
