  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.2k Views 73 Watching
  • AndurilA
    AndurilA
    Anduril
    wrote on last edited by Anduril
    #414
    @Harrdy I made the experience that a socat tcp tunnel is not stable all the time. I was trying to establish a connection between my ESP8266 gateway and a serial port (to be used with pimatic), but that tended to disconnect after few hours/days. This was also reported by other users in the pimatic forum. But maybe this is only a problem in relation with a ESP gateway.
    I would just recommend to check your connection regularly.
    If it is also unstable for you, I am testing node-red for that purpose at the moment and it looks promising. I will report when testing is finished.
    • techRHT
      techRHT
      techRH
      Maybe this helps any one else:
      I run openHAB on a RPI3 and i have made a Mysensors serial GW on a arduino nano.
      I want to use openHAB for the interface and MySController for the managment. So i need to forward my serial communication to a TCP socket.
      ser2net is a nice tool works fast but it block the Serial connection for openHAB.
      socat works better for me by executing the following command:
      $ sudo socat tcp-l:5003,reuseaddr,fork file:/dev/mySensorsCOM,nonblock,waitlock=/var/run/mySensorsCOM.lock
      next step will be to put it in a script and sends the process to the background and restarts it if there went something go's wrong.
      R 1 Reply Last reply
      • AndurilA
        AndurilA
        Anduril
        @Harrdy there is a ethernet branch of the mysensors plugin for pimatic now under development. You can have a look at the mysensors thread in the pimatic forum to find the instructions.
        • techRHT techRH
          R
          R
          robosensor
          Does anyone know how to allow multiple TCP connections forwarded to one MYS tty port? This socat command blocks second TCP connection until first one disconnected.
          I just want to connect MYSController using TCP without disconnecting my custom MQTT<=>serial controller script. I'm using RPi with USB-serial gateway.
          P.S. @tekka is there any chances that MQTT access will be implemented in MYSController?
          P 1 Reply Last reply
          • tekkaT tekka
            Hi all,
            I've been working on this project since some time, basically it's a GUI for controlling/updating/debugging a network of MySensors nodes. OTA functionality is supported via MYSBootloader - read posts for further instructions/troubleshooting or PM.
            link updated: MYSController Version 1.0.0.3316 released
            New features:
            • support OTA FW update Sensebender board
            • metric/imperial system I_CONFIG
            • save nodes
            Update via update button in MYSController or download here.
            jmkhaelJ
            jmkhaelJ
            jmkhael
            @tekka great work! thank you for sharing this.
            Your controller and great contribution had me quickly started with mysensors. I am interested in a way to do OTA updates using MYSController via api or a script call or even rewriting the logic in an outside code. I'll try to explain the need based on my setup below.
            Given that I am using jeedom right now as a controller, but sadly it doesn't seem to support yet OTA updates. I'd like to be able to reuse or even contribute to this feature and I'd appreciate pointers to start doing that.
            My setup has it that jeedom runs off a raspi and has a mysensors serial gateway attached. (1 to 2 Watts draw for this setup). MYSController can work as an ethernet relay gateway, but if I understand correctly I have to run it on windows (more moving parts), or a much hungrier box than my raspi.
            Is there a way I can make that work somehow? I am ready and appreciate any type of suggestions with the current setup I have or an evolution which goes into that direction.
            tekkaT 1 Reply Last reply
            • AndurilA
              AndurilA
              Anduril
              @robosensor you could try nodered. It can connect multiple inputs (mqtt, tcp,...) and merge it to a single serial output and vice versa. You might have to add some logic, but that shouldn't be a problem.
              • R robosensor
                P
                P
                pdey
                @robosensor I wrote a bridge to use on the Linino side of the Arduino Yun for this:
                https://github.com/peterdey/Yun-Linino-NewBridge
                But there's no reason you couldn't use this on an rPi - you'll probably just need to turn the baud rate down to 115200.
                • jmkhaelJ jmkhael
                  tekkaT
                  tekkaT
                  tekka
                  @jmkhael You can use "GW mode" (=proxy mode) in the tab bar
                  • techRHT
                    techRHT
                    techRH
                    I thought the socat command is to slow in switching so i have created a python script which will readout the mysensors serial GW and sends the data to a virtual serial port to connect to openhab and a TCP socket for the MySensors controller.
                    https://github.com/Rutger798/serial_to_serial_and_tcp/blob/master/serial_to_serial_and_tcp.py
                    • dopeeyeD
                      dopeeyeD
                      dopeeye
                      How do i use MYSController with a Raspberry Pi ?
                      I have a RPi2 with a NRF24 radio as a gateway and want to troubleshoot some communication issues i have been having. I usually log into the RPi2 via ssh to make adjustments.
                      Can I just download the files and rund the .exe via command-line?
                      • AndurilA
                        AndurilA
                        Anduril
                        I think it's windows software only. If you want to use it this way you should make you gateway device accessible via ethernet, maybe socat or nodered is an option for you.
                        dopeeyeD 1 Reply Last reply
                        • AndurilA Anduril
                          dopeeyeD
                          dopeeyeD
                          dopeeye
                          ok thanks for clarifying.
                          gonna give the node-red a try
                          • P pdey
                            @Mark-Swift : If you're happy to modify the MySensors library in an unsupported way, I've added a logMessage function to transmit text/debug messages from remote nodes:
                            https://github.com/peterdey/MySensors-Arduino/commit/f5f339b71620ec3cd896304a2ca6aba40ad40218
                            Found it useful, particularly in conjunction with MYSController OTA firmware updates.
                            jumpingJ
                            jumpingJ
                            jumping
                            is it possible to use with mysensor 2.0 API ?
                            Raspberrry PI3 - Domoticz
                            ESP8266 GW - MySensors 2.1.1
                            • interxisI
                              interxisI
                              interxis
                              Very cool. It also works on Ubuntu with Wine.
                              You have to create a COM port like this:
                              ln -s /dev/ttyUSB0 ~/.wine/dosdevices/com1
                              • karlheinz2000K
                                karlheinz2000K
                                karlheinz2000
                                How do I get MYSController to save info about each node?
                                I always have to set "battery-powered" after each upload and it does not save sketch name etc.
                                • meanmrgreenM
                                  meanmrgreenM
                                  meanmrgreen
                                  Ok this might be a realy stupid question but im what you call a "nuub" ;)
                                  If i want to monitor my current setup (serial gateway on a pi3) on windows/mint. Do i build another gateway and plug it in the pc?
                                  Sorry if i missed the instructions on this
                                  • meanmrgreenM meanmrgreen
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @meanmrgreen no, you can only have one GW in your setup. You could connect your GW to the PC, configure it for serial input, enable GW mode and have your rpi controller pointing at it (IP).
                                    meanmrgreenM 1 Reply Last reply
                                    • tekkaT tekka
                                      meanmrgreenM
                                      meanmrgreenM
                                      meanmrgreen
                                      @tekka
                                      How about I'f i replace my serial with a Ethernet gw?
                                      Do not want my pc running all the time. Just to debug
                                        Samuel235
                                        Hi @tekka - I'm currently running OpenHAB connected to mysensors by a GatewayW5100MQTTClient gateway and at the moment I have to manual upgrades to the nodes by disconnecting them and plugging them into the PC and recompiling all the software for each node. Would there be any way around this setup? I would like to keep OpenHAB as my controller and I really like the MQTT Client software too. Its simple and it just works for me. However, i would be open to change from MQTT if needed.
                                        What is your recommendation of implementing MYScontroller to use for OTA firmware updates only?
                                        MySensors 2.1.1
                                        • AndurilA
                                          AndurilA
                                          Anduril
                                          @tekka how do I initiate a reboot of a node from gateway side? I don't know how, but it's needed for updating OTA. Thanks in advance.
                                          techRHT 1 Reply Last reply
