  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 665.1k Views 99 Watching
  • T TimO
    @krejcarek please upgrade the binding to the most recent version. :-)
    K
    K
    krejcarek
    @TimO, Thanks for the quick response. Probably was some stupid mistake with copying.jar file. Got mine now on 2.0.0.201701181308, and works like charm.
    Hoping to have mysensors soon as official binding to avoid the need of workarounds and thus prone to mistakes.
    • H hillmanr
      I must be missing something. I have the same error as well. Is there a link to the latest binding. The one on the instructions page is dated 20161122 and a second one refereed to in this topic above dated 20161222. Which binding should I be using
      TimO
      @hillmanr please try this link: Download
      • ben999B ben999
        Hi Guys
        I am currently playing with a fairly fresh install of openhab2 (last weekend)
        I have played with the auto-discovery function in PaperUI
        Wow that's amazing :)
        But i am having trouble when it comes to sitemap file : sitemap function is not included within PaperUI (as far as i know) and i need this file to configure properly my iOS app
        So i have to go back to the old fashionned way and edit thing, item and map files with a text editor (which is fine)
        Two questions from here:
        • please prove me wrong in the way that i can discover things and configure items within paperUI and still create a valid sitemap file usable by my iOS devices
        • if above not possible, is there a way to "flush" openhab things and items database as i am getting warnings about things that don't exist anymore (things previously discovered by paperUI but deleted since)
          Thanks a lot for reading
        TimO
        @ben999
        1. It is possible to discover things with PaperUI and afterwards insert them in an item and sitemap file. Just use the channel that was given due to recovery. This way you don't need the things file.
        2. You may delete the hole database or edit it with a text editor as it is a jsondb file. I'm on my phone, so I can't give you the correct location right now.
        Did you try habmin? I've seen some amazing screenshots but haven't tried it myself.
        ben999B 1 Reply Last reply
        • H
          H
          hillmanr
          Got the 2.0.0.201701181308 binding, works, thanks. Amazing effort on the binding, great job.
          • T TimO
            @ben999
            ben999B
            ben999B
            ben999
            wrote on last edited by ben999
            #372
            @TimO
            Thanks a lot Tim
            Found a few interresting files in /usr/share/openhab2/userdata/jsondb (one containing history of discovery)
            Got rid of them all then rebooted but no change: my log is still polluted with that kind of entries:
            05:33:19.658 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '3' for item 'salonBatt01' to handler for channel 'mysensors:temperature:gateway:Temperature_1_0:battery', because no thing with the UID 'mysensors:temperature:gateway:Temperature_1_0' could be found.
            05:33:19.660 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '3' for item 'salonBatt01' to handler for channel 'mysensors:humidity:gateway:salonBatt01:battery', because no thing with the UID 'mysensors:humidity:gateway:salonBatt01' could be found.
            There also was a backup directory in there... deleted but no change
            Another location?
            EDIT : files in that directory are back after a reboot :D (meaning that the files themselves are back, and the one containing discovery data still contains it !!!)
            Thanks a lot for your help buddies
            • F
              F
              Fabien
              This binding works fine with 2.1.1 sensors actually Temp/Hum, Ph/ORP, RollerShutters. thanks for your work on this binding @TimO !
              Is this binding work with firmware update : http://docs.openhab.org/administration/runtime.html ?
              • F Fabien
                TimO
                @Fabien Thank you for your feedback!
                And: I've waited for that question according firmware updates to come up. :-D
                I've looked into it and I'm very interested but till now there is only the implementation in the library, I've not seen an implementation in a binding. I'll continue to look at it, but with low priority. :-)
                Current priority list is:
                1. Include binding in OH2 repository.
                2. Test and include the big refactoring from @andreacioni .
                3. Add MQTT gateway (proof of concept working, full integration after refactoring).
                4. Add little feature requests, add sensors ...
                • F
                  F
                  Fritzin
                  This is so great. I am fairly new to openhab 2. I have it up and running on a RP3. No issues during the install. I was able to get Habmin and paperhab up and running. I installed a few add-ons that were part of the img on openhab.com. However, i cant figure out how to add mysensors.org add-on. I am using OSX and I can't figure out where to place the file in openhab2 on the raspberry pi. Please help!!!!
                  • T
                    TimO
                    The jar needs to be placed here:
                    /usr/share/openhab2/addons/
                    You'll find further instructions here:
                    https://github.com/tobof/openhab2-addons/wiki/Installation
                    • A
                      azuntik
                      I was able to successfully install the binding, but when I added a temperature sensor as a test, it keeps failing. This is the error message I'm getting:
                      17:01:28.130 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'mysensors:temperature:4c0b17b9': java.lang.NullPointerException
                      java.util.concurrent.ExecutionException: java.lang.NullPointerException
                              at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_121]
                              at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_121]
                              at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:188)[98:org.eclipse.smarthome.core:0.9.0.b4]
                              at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:81)[98:org.eclipse.smarthome.core:0.9.0.b4]
                              at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:65)[98:org.eclipse.smarthome.core:0.9.0.b4]
                              at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:710)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
                              at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_121]
                              at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
                              at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_121]
                              at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_121]
                              at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
                              at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
                              at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
                      Caused by: java.lang.NullPointerException
                              at org.openhab.binding.mysensors.internal.handler.MySensorsThingHandler.getBridgeHandler(MySensorsThingHandler.java:268)[193:org.openhab.binding.mysensors:2.0.0.201701181308]
                              at org.openhab.binding.mysensors.internal.handler.MySensorsThingHandler.initialize(MySensorsThingHandler.java:77)[193:org.openhab.binding.mysensors:2.0.0.201701181308]
                              at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:713)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
                              at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
                              at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:179)[98:org.eclipse.smarthome.core:0.9.0.b4]
                              ... 3 more
                      Any thoughts?
                      • A azuntik
                                ... 3 more
                        Any thoughts?
                        TimO
                        @azuntik Did you configure the temperature thing in the things and items file? Please post the contents of these files. Please add the debug log from the time before and after the exception occurs. Which version (snapshot, stable) of OH2 are you running?
                        A 1 Reply Last reply
                        • T TimO
                          azuntik
                          wrote on last edited by azuntik
                          #379
                          @TimO I'll be honest with you: I'm not sure I configured everything properly. I don't have things or items files, because I set things up through the PaperUI. Do I need to set everything up through config files?
                          I've attached the complete log file. I'm running stable.
                          Thanks for your help!
                          Edit: Nevermind. I don't have permission to upload a file. So, here's a pastebin: http://pastebin.com/jLeTXbvX (the timestamps are wrong, you can ignore the date).
                          Edit2: One thing that I was having trouble with was determining the Node and Child IDs. I finally settled on what I think they are (105 and 255, respectively), but I may be wrong. Any advice with regard to figuring that out would also be greatly appreciated!
                          • A azuntik
                            marceltrapmanM
                            marceltrapmanM
                            marceltrapman
                            @azuntik You should know what you are creating ;)
                            In PaperUI you first create a thing for the gateway (I assume that worked for you).
                            Next OpenHAB should find all attached things for you, no need to create them manually. Just confirm what OpenHAB found.
                            Based on available properties you create an Item.
                            Fulltime Servoy Developer
                              azuntik
                              #381
                              @marceltrapman Frankenstein's Monster? :D
                              So, the UI is not detecting anything, although testing mysgw shows it receiving data. Is this a misconfiguration on my part?
                              Edit: Nevermind. I think what you said just sank in. Thanks for your help!
                              • N
                                N
                                nikos1671
                                Hi TimO
                                Can you please add support for gas meter S_GAS like the water meter.
                                Nikos
                                S 1 Reply Last reply
                                • D
                                  David Link
                                  Hello all! I believe I have done my due diligence in solving my own problem, but I am stuck. Can anyone point me in the right direction?
                                  I am trying to get started with an Ethernet Gateway. The gateway is displayed on the PaperUI, but in the log, it continues to try and connect to the ip bridge (Sending to MySensors: 0;0;3;0;2;)
                                  I am on:
                                  openhab 2.1.0-snapshot build #791
                                  MySensors Binding: 2.0.0.201701181308
                                  Gateway is using library 2.1.1
                                  I have tried:
                                  Clearing the EEPROM on the gateway thinking some garbage got stuck there.
                                  Set up and successfully used an MQTT gateway, thinking bad hardware?
                                  Restarted the binding, openhab, kitchen sink countless times.
                                  Updating everything to the latest build I could find
                                  Manually creating things
                                  The only thing that seems odd to me is the gateway repeats over and over what appears to be initialization data (displays ip address, 0;255;3;0;9;MC0;BGN;STP.....). However, it does receive data from a temperature node I built.
                                  I appreciate any pointers that can be provided, including "have you read this page?", though I think my Google search is permanently stuck on "mysensors openhab" at this point.
                                  Dave
                                  T A 2 Replies Last reply
                                  • N nikos1671
                                    Hi TimO
                                    Nikos
                                    stoffej
                                    @nikos1671
                                    Where do I found the Mysensors Binding 2.0.0.201701181308 jar file for download?
                                    Or is it mandatory to compile it from source?
                                    Thanks Kristoffer
                                    • D David Link
                                      I am on:
                                      I have tried:
                                      Dave
                                      TimO
                                      @David-Link Are you sure the gateway isn't in a boot loop?
                                      D 1 Reply Last reply
                                      • S stoffej
                                        @nikos1671
                                        Thanks Kristoffer
                                        TimO
                                        @stoffej HERE
                                        • T TimO
                                          David Link
                                          @TimO That's exactly what is going on. Thank you for the tip, I was pulling my hair out. Now on to solving that problem! Thanks again.
