  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • T TimO
    Hi @FusedHe3 !
    My first thought was: that's easy, lets add this! But after a second thought ...
    I see one problem with S_SCENE_CONTROLLER: how do I map this in OpenHAB?
    In MySensors there is V_SCENE_ON and V_SCENE_OFF. The message contains the corresponding scene number.
    In OpenHAB I've: Number, Switch, Selection ...
    0_1484735515591_upload-dac7eae9-cec0-4cbd-95ec-a0428268441c
    In OpenHAB I may choose between Scene A, Scene B and so on, but I can't select between ON and OFF. Is Scene A switched off, when I select Scene B?
    I'm using scenes with a switch in OpenHAB. Something like "Christmas decoration ON". In OpenHAB I'm using a group for that gChristmasDecoration or a rule: switch light on, shutter to 33%, ..
    My approach in implementing a (hardware) scene controller would be a mapping of those switches. So I would define a switch / child for every button (scene) on the controller.
    I'm open for ideas on how to map V_SCENE_CONTROLLER in OpenHAB, so if you or someone else have and idea, shout it out. :D
    FusedHe3F
    FusedHe3F
    FusedHe3
    @TimO Thanks for the quick reply!
    I do think the ON/OFF switch for every scene would be the most logical solution. In that way it's fully compatibel with the MySensors Scene Controller and you can have multiple scenes active at the same time.
    • AndrewZA
      AndrewZA
      AndrewZ
      Just updated my OH2 installation from snapshot to RC/beta and immediately got an error with the binding:
      [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.NumberFormatException: For input string: "Gateway startup complete.") on reading from connection, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
      But then the usual:
      [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
      [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
      What could be a problem? Do I need to perform some cleanup on my system? What exactly needs to be deleted?
      • T TimO
        Hey @Nicklas-Starkel !
        I hope it will work out for you! :-)
        It is not yet part of OH2 and downloadable within OH2 because my pull request is still open. A OH2 developer needs to look at it. :-)
        K
        K
        krejcarek
        I ran into trouble today by apt-get updating Openhab.
        I am over redefining the Distro for Snapshot... I have 2.0.0-SNAPSHOT, Build #743 up and running.
        my bundle list looks following:
        204 | Active | 80 | 3.12.0.OH | nrjavaserial
        205 | Installed | 80 | 2.0.0.201611221149 | MySensors Binding
        Still getting these errors:
        "03:17:10.911 [ERROR] [org.openhab.binding.mysensors ] - FrameworkEvent ERROR - org.openhab.binding.mysensors
        org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [205]
        Unresolved requirement: Require-Bundle: org.openhab.io.transport.serial"
        Any idea for next step?
        • K krejcarek
          TimO
          @krejcarek please upgrade the binding to the most recent version. :-)
          AndrewZA K 2 Replies Last reply
          • T TimO
            AndrewZA
            AndrewZA
            AndrewZ
            @TimO what about my error? I'm on the latest version already.
            • AndrewZA AndrewZ
              TimO
              @AndrewZ Sorry! Is it working despite the error? I need to test with RC1 myself. The error looks like it could be ignored. From time to time messages get corrupted, due to connection issues and the parser stumbles about that. But it should continue to work just fine. I suppose this is the case here, but I'll check!
              AndrewZA 1 Reply Last reply
              • T TimO
                AndrewZA
                AndrewZA
                AndrewZ
                @TimO yes, it is working, but please check this one and 2nd (Network Sanity Checker thread disabled). Thank you!
                • jogantJ
                  jogantJ
                  jogant
                  I had the same error messages on first boot of OH. After finishing upgrade procedure and restarting OH once again error message is gone. New version of the binding is working well. No hickups at the moment.
                  • ben999B
                    ben999B
                    ben999
                    wrote on last edited by ben999
                    #366
                    Hi Guys
                    I am currently playing with a fairly fresh install of openhab2 (last weekend)
                    I have played with the auto-discovery function in PaperUI
                    Wow that's amazing :)
                    But i am having trouble when it comes to sitemap file : sitemap function is not included within PaperUI (as far as i know) and i need this file to configure properly my iOS app
                    So i have to go back to the old fashionned way and edit thing, item and map files with a text editor (which is fine)
                    Two questions from here:
                    • please prove me wrong in the way that i can discover things and configure items within paperUI and still create a valid sitemap file usable by my iOS devices
                    • if above not possible, is there a way to "flush" openhab things and items database as i am getting warnings about things that don't exist anymore (things previously discovered by paperUI but deleted since)
                      Thanks a lot for reading
                    • H
                      H
                      hillmanr
                      I must be missing something. I have the same error as well. Is there a link to the latest binding. The one on the instructions page is dated 20161122 and a second one refereed to in this topic above dated 20161222. Which binding should I be using
                      • T TimO
                        K
                        K
                        krejcarek
                        @TimO, Thanks for the quick response. Probably was some stupid mistake with copying.jar file. Got mine now on 2.0.0.201701181308, and works like charm.
                        Hoping to have mysensors soon as official binding to avoid the need of workarounds and thus prone to mistakes.
                        • H hillmanr
                          TimO
                          @hillmanr please try this link: Download
                          • ben999B ben999
                            Hi Guys
                            TimO
                            @ben999
                            1. It is possible to discover things with PaperUI and afterwards insert them in an item and sitemap file. Just use the channel that was given due to recovery. This way you don't need the things file.
                            2. You may delete the hole database or edit it with a text editor as it is a jsondb file. I'm on my phone, so I can't give you the correct location right now.
                            Did you try habmin? I've seen some amazing screenshots but haven't tried it myself.
                            ben999B 1 Reply Last reply
                            • H
                              H
                              hillmanr
                              Got the 2.0.0.201701181308 binding, works, thanks. Amazing effort on the binding, great job.
                              • T TimO
                                @ben999
                                ben999B
                                ben999B
                                ben999
                                #372
                                @TimO
                                Thanks a lot Tim
                                Found a few interresting files in /usr/share/openhab2/userdata/jsondb (one containing history of discovery)
                                Got rid of them all then rebooted but no change: my log is still polluted with that kind of entries:
                                05:33:19.658 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '3' for item 'salonBatt01' to handler for channel 'mysensors:temperature:gateway:Temperature_1_0:battery', because no thing with the UID 'mysensors:temperature:gateway:Temperature_1_0' could be found.
                                05:33:19.660 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '3' for item 'salonBatt01' to handler for channel 'mysensors:humidity:gateway:salonBatt01:battery', because no thing with the UID 'mysensors:humidity:gateway:salonBatt01' could be found.
                                There also was a backup directory in there... deleted but no change
                                Another location?
                                EDIT : files in that directory are back after a reboot :D (meaning that the files themselves are back, and the one containing discovery data still contains it !!!)
                                Thanks a lot for your help buddies
                                • F
                                  F
                                  Fabien
                                  This binding works fine with 2.1.1 sensors actually Temp/Hum, Ph/ORP, RollerShutters. thanks for your work on this binding @TimO !
                                  Is this binding work with firmware update : http://docs.openhab.org/administration/runtime.html ?
                                  • F Fabien
                                    TimO
                                    @Fabien Thank you for your feedback!
                                    And: I've waited for that question according firmware updates to come up. :-D
                                    I've looked into it and I'm very interested but till now there is only the implementation in the library, I've not seen an implementation in a binding. I'll continue to look at it, but with low priority. :-)
                                    Current priority list is:
                                    1. Include binding in OH2 repository.
                                    2. Test and include the big refactoring from @andreacioni .
                                    3. Add MQTT gateway (proof of concept working, full integration after refactoring).
                                    4. Add little feature requests, add sensors ...
                                    • F
                                      F
                                      Fritzin
                                      This is so great. I am fairly new to openhab 2. I have it up and running on a RP3. No issues during the install. I was able to get Habmin and paperhab up and running. I installed a few add-ons that were part of the img on openhab.com. However, i cant figure out how to add mysensors.org add-on. I am using OSX and I can't figure out where to place the file in openhab2 on the raspberry pi. Please help!!!!
                                      • T
                                        TimO
                                        The jar needs to be placed here:
                                        /usr/share/openhab2/addons/
                                        You'll find further instructions here:
                                        https://github.com/tobof/openhab2-addons/wiki/Installation
                                        • A
                                          azuntik
                                          I was able to successfully install the binding, but when I added a temperature sensor as a test, it keeps failing. This is the error message I'm getting:
                                          17:01:28.130 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'mysensors:temperature:4c0b17b9': java.lang.NullPointerException
                                          java.util.concurrent.ExecutionException: java.lang.NullPointerException
                                                  at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_121]
                                                  at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_121]
                                                  at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:188)[98:org.eclipse.smarthome.core:0.9.0.b4]
                                                  at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:81)[98:org.eclipse.smarthome.core:0.9.0.b4]
                                                  at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:65)[98:org.eclipse.smarthome.core:0.9.0.b4]
                                                  at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:710)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
                                                  at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_121]
                                                  at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
                                                  at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_121]
                                                  at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_121]
                                                  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
                                                  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
                                                  at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
                                          Caused by: java.lang.NullPointerException
                                                  at org.openhab.binding.mysensors.internal.handler.MySensorsThingHandler.getBridgeHandler(MySensorsThingHandler.java:268)[193:org.openhab.binding.mysensors:2.0.0.201701181308]
                                                  at org.openhab.binding.mysensors.internal.handler.MySensorsThingHandler.initialize(MySensorsThingHandler.java:77)[193:org.openhab.binding.mysensors:2.0.0.201701181308]
                                                  at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:713)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
                                                  at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
                                                  at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:179)[98:org.eclipse.smarthome.core:0.9.0.b4]
                                                  ... 3 more
                                          Any thoughts?
