  3. IncomingMessage function not firing
3 Posts 2 Posters 1.2k Views 2 Watching
  • J Offline
    J Offline
    jwoods
    I have a Serial Gateway running on a Nano v3 that's using the default MySensors Serial Gateway code along with the 2.1 mySensors library. I’m trying to track/monitor incoming messages from my nodes. The only code that has been added to the serial gateway sketch is
    void incomingMessage(const MyMessage &message)
    Serial.println("Inside Incoming Message");
    But, I’m not seeing my “Inside Incoming Message" message in the serial monitor when my nodes communicate with the gateway.
    The sketch compiles and uploads to the gateway without error messages
    Is there something I need to include in my sketch or config files to make the incomingMessage function work?
    • hekH Offline
      hekH Offline
      What happens if you use
      receive(const MyMessage &message)
      instead?
      • J Offline
        J Offline
        jwoods
        Placing the receive function in my Gateway sketch worked. Thanks. For some reason I thought that function would only work for sensor nodes to watch for messages sent from the Gateway.
