  3. IncomingMessage function not firing
3 Posts 2 Posters 1.2k Views 2 Watching
  • J
    J
    jwoods
    I have a Serial Gateway running on a Nano v3 that's using the default MySensors Serial Gateway code along with the 2.1 mySensors library. I’m trying to track/monitor incoming messages from my nodes. The only code that has been added to the serial gateway sketch is
    Serial.println("Inside Incoming Message");
    But, I’m not seeing my “Inside Incoming Message" message in the serial monitor when my nodes communicate with the gateway.
    The sketch compiles and uploads to the gateway without error messages
    Is there something I need to include in my sketch or config files to make the incomingMessage function work?
      What happens if you use
      receive(const MyMessage &message)
      instead?
      • J
        J
        jwoods
        Placing the receive function in my Gateway sketch worked. Thanks. For some reason I thought that function would only work for sensor nodes to watch for messages sent from the Gateway.
